I Could use some suggestions for my project design. (Answered)
Discussion in 'Other Builds' started by Sniffles, Jul 19, 2019.
  1. Sniffles
    Sniffles New
    Hello. I have a frame of sorts that lets me move a camera horizontally and vertically.
    What I really need is an elegant way to move the vertical assembly up and down and lock it into any position quickly and easily without resorting to a motorized solution.
    I thought about drilling hole into a 1x2 and putting a bolt through the holes to lock the assembly in place but that isn't very convenient and it doesn't allow me to lock the assembly at any height.
    I thought about installing eye bolts and using say paracord to manually pull the assembly up and down and just hold it in place but that would be a pain and I really need to lock the assembly without it moving at all.
    I also thought about setting up a spring loaded bolt so I could squeeze two boards together to move the assembly up and down and release the boards to lock it into place in the nearest hole but then I can't lock it any where I want and I don't think that would work very well.
    If anyone has a suggestion about how I accomplish this using my current design I would really appreciate your feedback.
    The assembly will weigh about 5 pounds total with the equipment on it.
    Here's a link to a demo of what i'm working with:
    Here's a link to my Sketchup 2018 .skp file.
    2 Axis.skp
    Counterweight it so it naturally wants to stay put wherever you let go and then just use a simple spring loaded friction brake against the vertical rails to hold it in place.
    Sniffles likes this.
  3. Sniffles
    Sniffles New
    Thank you that is a genius idea. I like the idea of counter weighting it. I forgot I actually thought about some kind of friction brake but when I tried to look into how I could make one I didn't really find anything simple but reading your suggestion I think I have a few new ideas for that which would work. Thank you. :)
