i cannot get my axis move right in mach3
Discussion in 'CAM' started by Ali Khaled Ahmed, Nov 5, 2014.
  1. Ali Khaled Ahmed
    thanks :) it works :)
  2. Ali Khaled Ahmed
    when i run my spindle while am ref home the axis the axis stop moving and when i did go to the diagnostics tap i see that there is M1Home and sometimes M2Home getting connected (the box getting yellow) which mean the home switches some how when i run the spindle it get connected ? so how can i fix it ?why it happens only when the spindle ruining
  3. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Hi Ali,
    This is a common problem and generally relates to electrical noise and poorly shielded / grounded wiring for the limit switch inputs.
    Rather than repeat things please check out Electronics 101
    http://openbuilds.com/threads/electronics-101.693/ which gives some pointers as to how inputs wiring should be connected etc.
    Tweakie.
  4. Ali Khaled Ahmed
    thanks tweaki :) you always there :) thanks a lot your info. really helps dum like me :)
