I have a custom build and I am using a 32x controller. When my x and y move they show 80 mm when in fact they have moved over 380 mm. here are my settings controller 4x machine acro 1010 x axis 700mm y axis 700 mm z axis 100 mm please give me some direction
Did you remember to select the Acro from the Grbl Settings tab in CONTROL > Select machine from the list > Save and Reset when Prompted? As its not quite a Acro we'll have to fix Z homing (Set $44=7, and $45=0) afterwards as well as Z-steps-per-mm (200 if its our leadscrew) After initial setup you should be closer, then fine tune using the Calibration wizard under Wizards and Tools
