Hubless Rotation Structure
Discussion in 'Other Builds' started by BillyBob, Apr 19, 2019.
  1. BillyBob
    BillyBob New
    I have a sheet of aluminum 10" x 48" that I rolled into a semicircle (180 deg). I need to be able to rotate this smoothly around its imaginary center point which is a radius of about 15" in a "hub-less" fashion. So I think I will need to build some kind of structure with a 30" diameter to use as a "track" for my sheet to use as a guide. Only about 1" on the outside edges of the rolled aluminum can be used for supports/guides and the remaining area must be left open. Hope that makes sense.
    So I have either side of the this piece's edges of 48" to add some kind of guide/track that will be used to move this piece around the center point and to keep it true in its angular motion. Hopefully the attached rendering may help illustrate what I am trying to do.
    Any suggestions on how I can mechanically arrange this?
    Thank you for your help.
    Bob
    Would pocketed V-wheels do the trick? Make the base ring with a 1" cross section and cut some vertical pockets spaced around the ring with the V-wheels set down in them. Maybe even add a recess down the middle of cross section so the bottom edge of the aluminum would sit down slightly inside and the wheels would be fully recessed so they're not visible...
    BillyBob likes this.
  3. BillyBob
    BillyBob New
    Hmmm, well that is the kind of thing I was looking into, and why I posted here... I am just trying to visualize exactly what you are suggesting. However, yes the v-wheel arrangement would provide for the kind of movement I am wanting.
  4. Rick 2.0
    This is basically what I was suggesting:
    Sketchup file attached
  5. BillyBob
    BillyBob New
    Ah, yes! Very interesting... Thank you. Let me contemplate how to go about the construction of such... This has got me excited, awesome!
  6. BillyBob
    BillyBob New
    Rick, this here, your suggestions/help is one of the several reasons why when I need to purchase items for my projects that the OpenBuilds Parts offer, I support them... Thank you very much for helping me through my mental block.
    Rick 2.0 likes this.
