How to interface Proma SD to BlackBox Motion Control System
Discussion in 'General Talk' started by Bengt Carlsson, Sep 13, 2021.
Tags:
  1. Bengt Carlsson
    Hello
    I have managed to interface Proma SD for THC to BlackBox Motion Control System with successful results.
    If there is interest I can describe how to do it?
    Sincerely
    Bengt Carlsson
  2. Taylor Peper
    I am very interested.
    Did you run into issues with damaging onboard drivers?
    thanks in advance.
  3. Bengt Carlsson
    Hi
    I broke the signal (5 V dir and step) inside the Openbulds blackbox between the controller and the connection to the drive circuit for the Z-motor.
    I connected the signal from the controller to Proma SD and then I connected the signal back from Prom SD to the drive module in Blackbox.
    I have some pictures of what I have done and also a schedule that I can share if there is interest.
    With kind regards
    Bengt Carlsson
  4. Todd Meigs
    I'm interested in how you did this and pictures would be awesome!
  5. Bengt Carlsson
    Hello
    Attached is a small description of how I did.
    Bengt
    Tate, Dmaclean and Peter Van Der Walt like this.
  6. Sean Drummond
    Hi Bengt, great work! Very interested in this! Id like to try it myself. I have just got my openbuilds plasma up and running with a floating head design and am already noticing how important a THC controller is.
    All the best, Sean.
  7. Bengt Carlsson
    Hi Sean,
    Excited, me and my son Fredrik are starting to find the parameters to get good cuts with our plasma.
    Good luck
    With kind regards
    Bengt Carlsson
    Dmaclean likes this.
  8. Todd Meigs
    Thanks!!!
