How to draw spline with CAM software (no vector)
Discussion in 'CAM' started by Emmanuel GIOANNI, Jan 28, 2019.
  1. Emmanuel GIOANNI
    Hi.
    I'm new with CNC and I recently build a Sphinx 55 one. Now, I trying to draw some chart inside wood.
    This work well, but I've got some trouble with spline line. Each time I try to import a SVG with spline, the CAM software close the spline when i generate a toolpath.
    What i would like to do is tell to the software to only draw the line i provide (previously made by inkskape for example), not using a close vector, but just a line.
    Is it something special to set when I configure the Toolpaths, to just follow the spline, without try to close the shape ?
    Regards.
    #1 Emmanuel GIOANNI, Jan 28, 2019
    Sorry, closed vectors only supported at this time :)
    Do post the file i'll keep it around here for testing purposes when we work on open paths
  3. Emmanuel GIOANNI
    Thank you for the reply.
    Here my SVG file.
