How to connect 3.5W Fabool Laser to BlackBox
Discussion in 'CNC Mills/Routers' started by gusgus, Mar 2, 2020.
Tags:
  1. gusgus
    gusgus New
    Hi, I just built the Lead1010 machine, and it's fantastic. Love it, so solid.
    Now that I have this beauty, I also want to add my older Fabool / SmartDIY's 3.5W laser mini (FABOOL Laser Mini - Desktop laser cutter) to run from the BlackBox. Has anyone done this setup before?
  3. gusgus
    gusgus New
    If you get stuck, always welcome to check back in
    Include pictures of any connectors / labels if you get stuck
  5. Bober
    Bober New
    hello, how to connect this laser to the 12v blackbox?
    GND and PWM are known but where is 12v
  6. Giarc
    You need a 12v power supply and it needs to share a common ground with the Blackbox like the Blackbox documents show.
    docs:blackbox-4x:connect-3-wire-laser [OpenBuilds Documentation]
    Unless of course there is some other board associated with the laser you are not showing us. The laser vendor should also provide information .
