Homing goes the wrong way
Discussion in 'Laser Cutters' started by The-Dozer, Jul 21, 2020.
  1. The-Dozer
    The-Dozer New
    Hi all,
    When I jog the acro 510 with blackbox controller and OpenBuilds control software it seams tat the moment is correct according to setup video from OpenBuilds.
    But when I start the homing setup it goes the wrong way...
    I can invert arises and then the homing is ok but jog mood is reversed?
    Is this ok or what im I doing wrong.
    1) Set it up so it jogs correctly first (Machine has to follow cartesian standards first)
    2) Change Homing Dir Invert to make it do what you need: gnea/grbl
    3) Also have a read through gnea/grbl
    David the swarfer and The-Dozer like this.
  3. The-Dozer
    The-Dozer New
    Thank you!
    Missed that setting...
    Soled so much... :)
