Homing Cycle not working
Discussion in 'General Talk' started by Stacey Miller, Sep 3, 2020.
  1. Stacey Miller
    I am new member ( a couple weeks) and just wanted to say Thank you all.
    Have a quick question My Workbee is from SPAM 3d but I went with the Openbuilds controller. Can I use the 1510 profile and just change everything to lead screws? I have been having some difficulty getting the homing cycle to work. It tells me I have ran out of the parameters for the size of the machine, it will not travel far enough to reach the limit switch unless I park the gantry pretty close to the limit switch....... Again Thank You!
    Due to Max travel setting, or incorrect steps-per-mm yes
    Basically yes, (as the wizard shows in the the text notes) step 1 is to load a profile, step 2 is to customize the profile as per your individual needs:
