Hi, I want to build a cnc router of 3 meters by 2.5 meters and I would like to know
Discussion in 'CNC Mills/Routers' started by Beisser, Sep 27, 2019.
  1. Beisser
    Beisser New
    Hi, I want to build a cnc router of 3 meters by 2.5 meters and I would like to know:
    1. What would be the list of suggested elements (rails, motors, plates, belts, control card, router recommended for wood and non-structural aluminum, screws, bearings, screws, others) that would be necessary.
    2. I can use coreldraw directly for my designs.
    3. Could you give me the necessary advice.
    4. List price?
    thanks for the info
    These are hobby grade systems and they max out around 1m x 1.5m. Anything beyond that gets too flexible to make a decent cut. If you want to go bigger I suggest you check with Avid CNC | CNC Router Parts. Expect to spend at least $20,000 for anything usable.
  3. Beisser
    Beisser New
    Thank you very much for the help, I will review and tell you how I am doing. see you later.
