Hi everybody. I'm having a connection error and don't know how to fix it. can anyone help me to fix
Discussion in 'OpenBuilds Bug Report' started by Thien Duc, Oct 17, 2021.
  1. Thien Duc
    Thien Duc New
    What exactly are you trying to do?
    The device descriptor in the Ports menu tells you a lot too. Get a Genuine Arduino, or a BlackBox (see https://docs.openbuilds.com/blackbox)
    Possibly your chinese "arduino" doesn't have the right bootloader or is just junk. Money saved = time spent.
  4. Thien Duc
    Thien Duc New
    i tried to connect openbuild with makerbase dlc controller but failed "FLASH FAILED!"
    You weren't trying to connect (button on main toolbar) according to your Screenshot. You were trying to Reflash firmware (from Wizards and Tools)
  6. Thien Duc
    Thien Duc New
    [QUOTE = "Peter Van Der Walt, post: 119690, member: 69967"] Bạn đã không cố gắng kết nối (nút trên thanh công cụ chính) theo Ảnh chụp màn hình của bạn. Bạn đang cố sao lưu chương trình cơ sở (từ Wizards và Tools) [/ QUOTE]
    openbuild still errorr
    Then your controller is either fried, or doesn't run Grbl 1.1
  8. Thien Duc
    Thien Duc New
    i'am understand. Thanks for your support. I hope to learn from you in the future. I'm from Vietnam
  9. David the swarfer
    according to the github for makerbase it should support GRBL, but the message you got indicates it does not have a bootloader (this helps things like OBControl and Arduino install firmware through the USB port).
    if it is this board
    MKS Gen V2.0 DLC GRBL Controller - Makerbase
    then it looks like it has an ISP port so you can program it using an ISP programmer like this one
    2.38US $ 11% OFF|10 Pin to 6 Pin Adapter Board USBASP USBISP AVR Programmer USB ATMEGA8 ATMEGA128 ATtiny/CAN/PWM 10Pin Wire Module with Cable|avr programmer|set 6usb board - AliExpress
    You can choose to install the bootloader (from Arduino IDE) and then OBControl can load GRBL for you (without the USBASP board, just USB), or you could load one of the GRBL .hex files directly.
    I would load the bootloader, it makes later updates much easier.
