Help
Discussion in 'General Talk' started by Mark Plesek, Jan 25, 2022.
  1. Mark Plesek
    When I go to test my 1515 it doesn’t move I went over the wiring everything is hooked up correctly. I went to the software and where he says that he’s going to change the direction to 10 mm I cannot get that to change anything mine are all stuck on 0.1 inches how do you change it.
    Using the mm/inch tab:
    Also,
    1) Make sure you are connected to your Controller first
    2) Once connected you can Jog, change move sizes, etc
    3) If that was not the issue, take a screenshot of the application and forward for us to check
