Help with post process on fusion 360
Discussion in 'Other Builds' started by Eric Nunez, Aug 3, 2024.
  1. Eric Nunez
    Like the title says. I am new to fusion 360. I recently finished my jds plasma cutter build a year ago. Everything was working great. I stop messing with my machine for a few months. And now when i try to run a new build in fusion 360 i can not get it to post progress. I keep getting the failed message. Can anyone give me some insight of what i am doing wrong? Thank you in advance
  2. Alex Chambers
    Can't read that - please use a screenshot or the windows snipping tool.
    From what I can see you have not selected a wcs in Fusion cam setup.
    What controller do you have and which post processor are you using?
  3. David the swarfer
    you must upgrade your postprocessor to match the new version of Fusion
    docs:software:fusion360 [OpenBuilds Documentation]
  4. Eric Nunez
    david i just did the upgrade and still no luck here is a screen shot alex
  5. Eric Nunez
    also i am running open builds processor and a adrino
  6. David the swarfer
    you are trying to use the X32 multiaxis post which is milling only, says so right in that message.
    Use the file OpenbuildsFusion360PostGrbl.cps which will do milling,plasma and laser on all Blackbox controllers (but no multiaxis)
