Help with a couple calibration questions?
Discussion in 'CNC Mills/Routers' started by iH8vols, Oct 23, 2017.
  1. iH8vols
    iH8vols New
    My Ox CNC is getting closer (i think). I calibrated the x,y and z axis this weekend. I feel like the movement is pretty spot on. However, I did a test circle with a sharpie and my circle didn't quite close. Below is a link to a pic I took. I'm only worried about the part where the drawing started and ended. I haven't leveled my spoiler board yet. Circle with Pen:IMG_3112.JPG
    Also, I used a 3/4 diameter double flute to drill some holes in my MDF to use for holding work in place. As it was drilling the holes, I noticed the z axis would tilt very slightly as it began moving down into the wood. When the z axis finished and began raising, it would clear out the hole. Therefore when I put the dowel in, there's a small bit of separation in the front as you can see in this pic: IMG_3113.JPG
    It repeated this on every hole. Is this considered Backlash? Is there anything I can do to correct this? There's no wiggle on the z axis, so I don't think anything is loose.
    I use Universal G Code Sender. I don't believe there is a backlash adjustment available within it that I'm aware of.
    Below are my current GRBL settings. I would really appreciate any help or suggestions. Thanks!!
    GRBL Setting:
    $0=10 (step pulse, usec)
    $1=255 (step idle delay, msec)
    $2=0 (step port invert mask:00000000)
    $3=2 (dir port invert mask:00000010)
    $4=1 (step enable invert, bool)
    $5=0 (limit pins invert, bool)
    $6=0 (probe pin invert, bool)
    $10=3 (status report mask:00000011)
    $11=0.020 (junction deviation, mm)
    $12=0.002 (arc tolerance, mm)
    $13=0 (report inches, bool)
    $20=0 (soft limits, bool)
    $21=0 (hard limits, bool)
    $22=1 (homing cycle, bool)
    $23=0 (homing dir invert mask:00000000)
    $24=500.000 (homing feed, mm/min)
    $25=3000.000 (homing seek, mm/min)
    $26=244 (homing debounce, msec)
    $27=5.000 (homing pull-off, mm)
    $100=27.000 (x, step/mm)
    $101=26.634 (y, step/mm)
    $102=202.000 (z, step/mm)
    $110=4000.000 (x max rate, mm/min)
    $111=3000.000 (y max rate, mm/min)
    $112=1000.000 (z max rate, mm/min)
    $120=2000.000 (x accel, mm/sec^2)
    $121=2000.000 (y accel, mm/sec^2)
    $122=1000.000 (z accel, mm/sec^2)
    $130=1190.000 (x max travel, mm)
    $131=569.220 (y max travel, mm)
    $132=1000.000 (z max travel, mm)
  2. JustinTime
    JustinTime Veteran
    It could be backlash but to tell for sure we need to see the complete circle. Level your bed and reprint it.
