Help!! windows 10 does not like blackbox? [Solved, wiring issue]
Discussion in 'OpenBuilds Forum Help' started by Fit-lab Pat, Sep 17, 2019.
  1. Fit-lab Pat
    my new HP probook on windows 10 usb port does not reconnize my blackbox!!
  2. sharmstr
    and do a test with everything except USB unplugged. Incorrectly wired things like limit switches for example, can prevent the board from running properly (if your limits are not wired as shown in docs.openbuilds.com they can short 5v to gnd for example - quick test, unplug all the connectors, just leave USB then you tests PC+BlackBox without external factors)
    MaryD likes this.
  4. Fit-lab Pat
    thanks that works! will verify wiring!!
