Hello, I have a problem with the openbuilds lead 1010 milling machine. When I mill and turn on the vacuum cleaner, the light stops or when I turn it on, it mills at you at some point. If I want a milling machine, I can't move because I have to disable and enable the openbuilds controls program again. Or if I load the program, I change another one, then I have to turn the program off and on again. If I want the whole cycle to be milled, I must turn off the limit switches. Or after finishing the milling, I can't turn on the limit switches because I have to turn the openbuilds control off again.
Vacuums create a lot of static electricity (particles rubbing against the hose, air moving against the hose etc) Run a length of bare copper wire down the hose end to end, earthing the side near the Vacuum cleaner to help dissipate EMI Also see How to ground vacuum hose?
