Help needed with step size XPRO4
Discussion in 'Controller Boards' started by CaptainSawdust, May 17, 2019.
  1. CaptainSawdust
    CaptainSawdust Well-Known
    Hi there,
    Absolute newbie with zero experience and hoping someone can help me.
    I have built an OX machine and paired it with the XPro4 controller.
    When I try and jog the machine by 1mm the axis moves by around 6mm.
    I get the impression that I need to change the $$ settings and that this is probably a really simple issue but I have no idea what to do.
    Can anyone help?
    James
  2. sharmstr
    sharmstr Master
    You need to adjust your motors steps/mm. Its referred to as steps calibration. If you're using OpenBuilds Control, there are wizards for this in the Wizards& Tools menu. If not, then look for something in the software you are using or do it this way: HOWTO Calibrate your CNC Machine for MACH3 or GRBL
  3. CaptainSawdust
    Thank you so much for your help Shawn. Sorted the issue.
    My machine works!!!!
  4. sharmstr
    sharmstr Master
    Excellent! Have fun.
