help me to the promised land
Discussion in 'General Talk' started by ROY DAVIES, Nov 23, 2020.
  1. ROY DAVIES
    hi there ....please help me if you can..... i am a newbee to cnc and aquired a groovy cnc machine recently...and after trying for a while cant get the gcode into the machine because the app won connect via usb
    the cnc macine is powered up 24v and the controller has a number of red lights / fans are spinning....but wont bloody connect
    cheers makers
    Care so share more? What exactly is it, where's it from, brand name, what kind of controller, pictures of its controller, what software are you trying to use, and all other relevant details may help people help you
  3. ROY DAVIES
    cheers peter....its an openbuids machine with a 1000 x 1000 mm baseboard...a bosch router gkf 600...the controller has no name on it but has 2 small fans mounted on it.
    i have used vcarve desktop (free version) to chose thier free snowflakes design as a practice.....then saved the gcode as a file......I then downloaded the openbuilds control software....i opened up the snowflake file in command (could see the gcodes and image) but could not connect to the pc
    The power unit to cnc machine is (24.4v) and the usb makes the plink noise when plugged into pc BUT IT WONT CONNECT WHEN I PRESS CONNECT BUTTON
    any help will be appreciated by newbie roy in sheffield uk
  4. Alex Chambers
    See if you can get some pics of the control board - what's under the fans (if you can see that) might give a clue.
  6. ROY DAVIES
    Hi I bought it from a guy who has a camper van business and it was too small for his needs....I cannot find any details of what model it is other than what I’ve posted so far....here’s some photos of the controller and machine
    Nothing attached to your post. Use the Upload a File button :)
  8. ROY DAVIES
    Photos
    Alex Chambers likes this.
  9. ROY DAVIES
    Thanks alex
    Controller is an xPro V4: See Spark-Concepts/xPro-V4
    Post screenshot of the connection log, some of the xPro versions still had an old versions of Grbl (then you can just update) - but I think all the V4s were all Grbl 1.1, as were most of the later V3s) or it may be dead
    Or maybe you don't have the right drivers? Virtual COM Port Drivers
    Lets see the log and log will tell you what it is: You can find it in CONTROL on the Serial Terminal tab
    Sidenote, from the pictures it looks like a Workbee OpenBuilds Workbee 1010 (40" x 40") - but maybe not original, some of the parts looks self-made though I may be wrong
    #10 Peter Van Der Walt, Nov 23, 2020
    ROY DAVIES likes this.
  11. ROY DAVIES
    Thanks bud will do ....
