Headless Raspberry Pi Control server
Discussion in 'Control Software' started by gthiesfeld, Dec 29, 2020.
  1. gthiesfeld
    I'm kicking this idea around because my USB cable isn't long enough to reach from the Black Box controller to my laptop, and I have a spare Pi.
    I've read through the forums and the Github wiki page, and understand raspberry pi isn't officially supported. I see people are using it, but I think my setup may be a little different. I want to run the node.js backend server portion of Control on a Raspberry pi, and the chromium app portion on my windows laptop. I installed openbuilds-control on the pi using the included script and wiki instructions. I then configured node.js as a daemon. I installed chromium on my windows laptop, and configured a shortcut pointing to chrome.exe --app="http://[raspbery_pi_ip]:3000/". That all seems to work fine.
    Next step is to plug the pi into the blackbox and connect, etc. My CNC machine is currently torn apart, so I can't do much more than that until I can get it up and running. I guess I'm posting this here to make sure I'm not missing anything obvious, or if this idea raises any red flags with the folks who understand the code better.
  3. gthiesfeld
    I guess that part was a bit of overkill, but I like that it still looks like the normal Control app, vs another browser tab. :)
  4. JustinTime
    JustinTime Veteran
    Peter, for some reasons the link doesn't work for me. Is it the correct spelling?
    http://ip-of-device-running-control:3000/ ? - read that again (; in the context above (keeping in mind the forum turns text like that into a link. don't click it, read it)
  6. gthiesfeld
    That's not a real link, the forum automatically converts it to one. The middle part needs to be replaced with the IP address of the machine running Control. The raspberry pi in my case.
