Hard Limits not working
Discussion in 'OpenBuilds Forum Help' started by yojavirodriguez, Nov 23, 2023.
  1. yojavirodriguez
    Hello,
    I am sending GRBL commands to an ACRO 55 machine from an external software (MATLAB). Everything is working OK (including Homing) but not hard limits. Yes, they are enabled ($21=1).
    The weird thing is the hard limits work (homing too) when I work directly with OpenBuildsCONTROL but if I disconnect Serial Port from OpenBuildsCONTROL and connect it from MATLAB, hard limits do not work anymore (homing yes). I checked grbl configuration in both cases (connected to OpenBuildsCONTROL and MATLAB) and parameters $21 are identical.
    Any idea what is happening?
    Regards,
    Odd indeed as Limits are handled by Firmware not the host application.
    Double check it still works under CONTROL?
    Confirm X and Y isn't swopped in Troubleshooting tab?
    As its an Acro, no Z axis: make sure you flashed the 2axes firmware?
  3. yojavirodriguez
    I forgot to say I am usign a BlackBox X32.
    Yes...It is really weird.
    By typing (copy/paste) the same command (in CONROL and MATLAB), in CONTROL works everything OK but not in MATLAB
    I flashed the default "2/3 axes CNC/Laser: Dual-Y" included in OpenbuildsCONTROL (Wizards&Tools->Firmware Flashing Tool)
    In troubleshooting tab nothing happen by activating the Endlimits, whichever the axis...
    Make sure you have $10=511
