Guitar Bridge - modificaiton
Discussion in 'CNC Mills/Routers' started by JIMM E PANIK, Jul 29, 2020.
  1. JIMM E PANIK
    Below is a photo of a typical Telecaster guitar bridge.
    I can provide specific dimensions for my project.
    Basically, I am making a 5 string guitar and would need this plate fabricated with mount holes for 5 saddles instead of 6. Also, the pickup slot will be 0.300" shorter than the original. The three screw holes for mounting the pickup would remain in the stock location. I want this made from 0.080" Brass and it must have the 90 bend on the end where the saddles mount at the rear
    I need the mounting plate only. The saddles will be used from an existing bridge.
  2. JustinTime
    JustinTime Veteran
    Jimm, is there a question somewhere?
  3. Christian James
    Christian James Journeyman
    There's a suggestion of one but it needs clarity!
