GRBL Settings
Discussion in 'General Talk' started by GARY GEORGE, Feb 28, 2022.
  1. GARY GEORGE
    Any suggestions where I can download the Grbl settings for a Workbee 1510. My laptop got stolen, hence starting from scratch again. Yes I know should have backed up somewhere else etc.
    OpenBuildsCONTROL > Connect > Go to Grbl Settings tab > select from profiles (nearest similar machine) > scroll down and fix any values that need changing > save
  3. GARY GEORGE
    Thanks Peter much appreciated. Im a green horn in terms of this stuff, hence will the default settings suffice, or can you recommend any changes I need to do?
    Defaults are good for a test
