I have built a modified version of the OPENBUILDS 1010 WORKBEE screw driven machine using the Black Box controller and software. I believe everything is identical to the 1010, except I built it to a 750mm (x axis) x 1000mm (y axis) format. I have downloaded the software and am formatting the grbl settings. My question is if I select the 1010 Workbee machine from the listed machines and alter only the grbl settings for the x (550mm) and y(780mm) work area and save the other pre-set parameters will it work for my 750 x 1000 machine?
