Grbl Flashing problem
Discussion in 'Controller Boards' started by Denisteen, Apr 6, 2020.
  1. Denisteen
    Denisteen New
    Having same thing have flashed on 2 computers many times same thing flash failed.
    Try just connecting first - reflash is not a normally required action: Explain why you wanted to reflash, so we can assist further?
    What controller do you have? (assuming BlackBox for now, but please do include details)
    1) Disconnect everything except USB if you are getting any errors that it couldn't find firmware: more likely a wiring short preventing board from running (usually incorrectly wired limit switches, compare against docs.openbuilds.com if this is the case)
    2) Are you sure you followed steps 4.1 and 4.2 from docs.openbuilds.com
    3) Sure you are selecting the correct port?
    4) Include Serial Log copy-pastes to help diagnose issues
    #2 Peter Van Der Walt, Apr 6, 2020
  3. Denisteen
    Denisteen New
    Yes I have black box was trying to flash the door control so I could put in an e stop.
    Needed to flash normally closed an when I did flash failed then usb would not connect. Finally after several tries it worked.
    Glad you are sorted
    Note we advise strongly against using the DOOR function as an emergency stop:
    An emergency can be
    - the power strip caught on fire from overloading
    - router caught fire
    - psu caught fire
    - runaway machine
    - broken endmill making router vibrate like crazy
    - dust particles caugh fire inside the dust collector from static charges
    In only on of those cases the Door sensor would've helped.
    For proper emegency switch functionality, wire it so it cuts power coming to the desk where the machine is, before the power strip. So one hit of the Emergency stop, can cut off ANY connected peripheral
  5. Denisteen
    Denisteen New
    I will do that put a switch in to kill every thing. I have another question when I first got the BB every worked fine witch was 11-2019 when the control software upgraded the check size does not work nore does the 3D function does not show the job on screen.
    Check the serial log just after starting for clues (before connecting)
    It'll tell you whether your PC doesnt meet the neccesary specs for WebGL,
    or check whether 3D viewer system has been disabled from Troubleshooting>Application Diagnostics
    Screenshot of an example where 3Dview can run:
    CheckSize needs the 3D view to calculate the extent of the job
  7. Denisteen
    Denisteen New
    It says no WebGL support on this computer 3D disable .
    Any way to fix this.
    Did you check the second part:
    If its not that, then the PC really doesn't properly support WebGL
    - Upgrade drivers (chipset and GPU)
    - Upgrade GPU
    - Replace PC
  9. Denisteen
    Denisteen New
    Yes 3D viewer is not disabled.I am running windows 7.
    Windows 7 is end of life as of Jan 2020: Windows 7 End of Life: everything you need to know about the death of Windows 7 | TechRadar (just a sidenote, wouldn't be the cause of your issues but still, better to keep up than catch up)
    That said, refer above, update drivers, etc maybe theres some outdated drivers where you can still update a bit. WebGL issues has more todo with GPU capabilities, whether actual hardware capabilities or driver versions
    Denisteen likes this.
  11. Denisteen
    Denisteen New
    Will have to upgrade to windows 10 I suppose . Trying to update but does't look good.
    Thanks for the help.
