Grbl error
Discussion in 'General Talk' started by Rajiv Divakaran, Jan 4, 2023.
  1. Rajiv Divakaran
    HI,
    Am facing frequent hard limit error while running my workbee cnc. screen shot enclosed. Help me out
    If its a false trigger (axis really didn't hit a switch) its likely EMI: docs:blackbox:faq-emi [OpenBuilds Documentation]
  3. Rajiv Divakaran
    its happening only recently, been using the machine flawlessly since a year now.
    Do you have a Blackbox? Or 3rd party machine/controller?
  5. Rajiv Divakaran
    its blackbox
    1) Check all wiring making sure there aren't any accidental shorts / chaffed through wiring / etc
    2) Climate changing (India is moving toward winter - colder weather increases likelyhood of static)
    3) Damaged switches - switches itself can become faulty over time (hard hits, etc causing damage)
  7. Rajiv Divakaran
    Ok Peter, i will have a thorough check on all cables and switches. Yes its cold weather over here, as you said may be the likely cause. or may be i will better change all the proximity limit switches to its mechanical counterpart. Thanks a lot Peter. Also a small doubt, measurement from the drawing from inkscape file is showing 1 to 2mm difference when imported to openbuild cam. The inkscape dpi i checked is set to 96. Is there any solution to it?
    EMI is typically induced in cabling, so not particularly more robust to switch to Inductives (still same length of cable). If you have our Xtension Limits their onboard filtering are superior to most cheap inductives already.
    See the EMI FAQ again and make sure to space Limits wiring clear of other noisy cables
    Provide test cases / sample for us to check on. We try to guess the DPI from the version OpenBuilds-CAM/svgparser.js at master · OpenBuilds/OpenBuilds-CAM
  9. Rajiv Divakaran
    can i order from India these switches?
    i have enclosed a sample drawing prepared in inkscape
    Yes, openbuidspartstore.com ships internationally
    Code:
    File: drawing (1).svg was created in inkscape version 1.1.  Setting import resolution to 90dpi
    Make sure you are exporting at 90DPI, which should be the default for 1.1
    Code:
    1.1.1 (3bf5ae0d25, 2021-09-20)
    Its also a very old version of Inkscape - consider getting up to date Download Inkscape 1.2.2 | Inkscape instead
  11. Rajiv Divakaran
    Thanks a lot Peter. Will go with latest version and shall update on this isssue.
  12. Rajiv Divakaran
    HI Peter, what would be the import resolution dpi you have updated for the version 1.2.2
  13. Peter Van Der Walt
  14. Rajiv Divakaran
    yes got it dpi96, but still the issue remains. But i found another solution to this and would like to share too, reduce the obect stroke style width to 0.001 then the imported svg image to ob cam shows exact measurements as in the original inkscape file. Thank you.
