Grbl error
Discussion in 'OpenBuilds Bug Report' started by laurent deschaumes, Sep 28, 2020.
  1. laurent deschaumes
    Hi all,
    this is my first post :) So many thanks in advance for any answer
    I've got an issue with the Gcode generated by SprutCam.
    When i try to run it with Openbuilds (V 1.0.250) i have this error message
    Enclosed the code (al1)
    The target is just below :
    • al1.TAP
      File size:
      154.5 KB
    You need a Grbl compatible Post Processor for SprutCAM
    See gnea/grbl (about halfway down) for the list of gcodes Grbl supports
    G64 from your gcode is not supported (see the list)
  3. laurent deschaumes
    Thanks Peter !
    I solved this issue with Fusion 360
  4. David the swarfer
