GRBL/Candle S3 Jerky
Discussion in 'Control Software' started by GregiBoy, Sep 20, 2020.
  1. GregiBoy
    GregiBoy New
    Hi All.
    Newbie here but I have had some experience with CNC.
    I am having a problem with the S3 command on my cheap chinese 3018 machine that I have just built.
    It is running on a chinese Arduino Geekcreit® ATmega328P Nano V3 and I have updated GRBL to V1.1h.
    The problem is the following:-
    When I start the spindle with M3 S1000 in the G Code, movement is jerky in all axes.
    When I start the spindle with M3 S1000 outside the G Code, movement is smooth in all axes.
    I have (I think) throughly gone through the GRBL machine settings and have attached the file that I use to write them. I have also attached a small GRBL example where the problem rears its ugly head.
    Hope someone has some ideas as I am just about at wits end.
    GregiBoy
  2. GregiBoy
    GregiBoy New
    Sorry... CAndle Version 1.1.7
  3. David the swarfer
    what drivers?
    wiring all correctly star grounded?
    home switch signal wires far way from motor power and spindle power wires?
    any chance of a video showing what you call smooth and what you call jerky? preferably exactly the same code of course.
  4. GregiBoy
    GregiBoy New
    Thanks David.
    The USB port is the usual cheap Chinese Serial-CH340 running at 115200 Baud.
    All communications appear fine through both Candle Version 1.1.7 (Various versions also tested fine) and Universal G-Code Sender Version 1.0.9
    All wiring appears ok and is installed as per manufacturers instruction and all setting that I know about have been tested and the GRBL settings written. (All settings are in the file attached above)
    There are NO home or limit switches/wiring installed.
    I have tested another spindle and another control board and the same problem occurs.
    I will make/edit/post the comparative videos later today. (I am in Australia so there may be some time difference, currently 8:30am)
    Regards GregiBoy
  5. GregiBoy
    GregiBoy New
    I don't know whether to believe this or not!!!
    I have been checking everything methodically and after working it through and reading my notes, I hadn't eliminated on possibility, the smart powerboard that everything is plugged into.
    I eliminated this by plugging the machine directly into the power socket.
    NO more problems!!!
    Obviously the SMART??? powerboard is not up to the amperage required.
    I still csnnot understand why it works fine wehn the M3 S1000 comand is issued outside of program control though??
    Still cannot believe it.
  6. David the swarfer
    probably the lack of a time delay between powering the spindle (motors take a lot more power to start than to run) and the beginning of stepper motion when the program starts the spindle
  7. GregiBoy
    GregiBoy New
    I had tried G04 P2.5 after the spindle start but before any movement.
