GRBL arc pauses.
Discussion in 'CNC Mills/Routers' started by Danni, Mar 19, 2021.
  1. Danni
    Danni New
    Hi.
    I have a problem with arcs. I have searched after solutions but can't find a similar problem. It looks like it pauses short between each command in a arc. If it just moves diagonally all is normal.
    look at the video of the stepper drivers. The drives getting disabled and enabled many times. If i keep the drives enabled with $1 it still pauses movement.
    i tried to change:
    $0 step pulse
    $1 step idle delay
    $10 status report
    $11 junction deviation
    $12 arc tolerance
    Nothing helps. Can someone see anything that could be the problem??
    My setup:
    Arduino mega with ramps 1.4
    Grbl mega 5x build on Grbl v1.1f
    DQ542MA stepper drivers
    Stepper motors 57BYGH115-003B 3A setup in 1/8 step. Have tried 1/2 and 1/4 step
    36V 350W power supply.
    G-code generated in GrblGru:
    Code:
    ( Job: Rectangle 160.00 x 100.00  -> Cut 1 mm mit 3 Tabs )
    ( TransformationTyp = NONE )
    ( Clearance Plane = 5 )
    ( Sum of depth = 1.1 )
    ( Depth per path = 1.1 )
    ( Diving Ramp = 1 )
    ( Tab Ramp = 1 )
    ( Splitting size = 2 )
    ( Cut Feedrate = 1000 )
    ( Rapid Feedrate = 2000 )
    ( Plunge Feedrate = 500 )
    ( Type of Tool = SPINDLE )
    ( Tool = endmill 3.175mm )
    ( Tool diameter = 3.175 )
    G1 G90 F100
    ( Path 0 )
    ( Current depth = -1.100 )
    ( MoveToStartpoint2 )
    F2000 G90 z5.000
    F2000 x10.000 y-1.588 z5.000
    F2000 x10.000 y-1.588 z0.000
    ( Loop )
    G90 F500
    F1000
    x11.100 y-1.588 z-1.100
    x75.413 y-1.588 z-1.100
    x75.913 y-1.588 z-0.600
    x84.088 y-1.588 z-0.600
    F500
    x84.588 y-1.588 z-1.100
    F1000
    x150.000 y-1.588 z-1.100
    x150.009 y-1.587 z-1.100
    x150.183 y-1.586 z-1.100
    x150.220 y-1.586 z-1.100
    x150.394 y-1.581 z-1.100
    x150.411 y-1.580 z-1.100
    x150.586 y-1.573 z-1.100
    x150.623 y-1.571 z-1.100
    x150.797 y-1.560 z-1.100
    x150.824 y-1.558 z-1.100
    x150.998 y-1.544 z-1.100
    x151.016 y-1.543 z-1.100
    x151.190 y-1.527 z-1.100
    x151.227 y-1.523 z-1.100
    x151.400 y-1.503 z-1.100
    x151.427 y-1.500 z-1.100
    x151.600 y-1.477 z-1.100
    x151.627 y-1.473 z-1.100
    x151.800 y-1.447 z-1.100
    x151.819 y-1.444 z-1.100
    x151.991 y-1.416 z-1.100
    x152.026 y-1.410 z-1.100
    x152.198 y-1.378 z-1.100
    x152.226 y-1.372 z-1.100
    x152.397 y-1.337 z-1.100
    x152.425 y-1.331 z-1.100
    x152.595 y-1.293 z-1.100
    x152.621 y-1.287 z-1.100
    x152.791 y-1.246 z-1.100
    x152.810 y-1.241 z-1.100
    x152.979 y-1.198 z-1.100
    x153.016 y-1.189 z-1.100
    x153.184 y-1.142 z-1.100
    x153.203 y-1.136 z-1.100
    x153.370 y-1.087 z-1.100
    x153.403 y-1.077 z-1.100
    x153.570 y-1.024 z-1.100
    x153.592 y-1.017 z-1.100
    x153.790 y-0.951 z-1.100
    x153.955 y-0.892 z-1.100
    x153.976 y-0.884 z-1.100
    x154.139 y-0.823 z-1.100
    x154.163 y-0.814 z-1.100
    x154.326 y-0.750 z-1.100
    x154.348 y-0.741 z-1.100
    x154.509 y-0.675 z-1.100
    x154.543 y-0.660 z-1.100
    x154.703 y-0.590 z-1.100
    x154.722 y-0.582 z-1.100
    x154.881 y-0.510 z-1.100
    x154.918 y-0.493 z-1.100
    x155.075 y-0.417 z-1.100
    x155.086 y-0.412 z-1.100
    x155.242 y-0.335 z-1.100
    x155.274 y-0.318 z-1.100
    x155.429 y-0.237 z-1.100
    x155.447 y-0.227 z-1.100
    x155.601 y-0.144 z-1.100
    x155.630 y-0.129 z-1.100
    x155.782 y-0.043 z-1.100
    x155.810 y-0.026 z-1.100
    x155.960 y0.063 z-1.100
    x155.977 y0.073 z-1.100
    x156.126 y0.164 z-1.100
    x156.154 y0.182 z-1.100
    x156.301 y0.276 z-1.100
    x156.322 y0.289 z-1.100
    x156.467 y0.385 z-1.100
    x156.490 y0.401 z-1.100
    x156.634 y0.500 z-1.100
    x156.655 y0.514 z-1.100
    x156.797 y0.615 z-1.100
    x156.819 y0.631 z-1.100
    x156.960 y0.735 z-1.100
    x156.985 y0.754 z-1.100
    x157.123 y0.860 z-1.100
    x157.144 y0.877 z-1.100
    x157.281 y0.986 z-1.100
    x157.306 y1.005 z-1.100
    x157.440 y1.116 z-1.100
    x157.455 y1.129 z-1.100
    x157.588 y1.242 z-1.100
    x157.612 y1.263 z-1.100
    x157.743 y1.379 z-1.100
    x157.767 y1.401 z-1.100
    x157.895 y1.519 z-1.100
    x157.909 y1.532 z-1.100
    x158.036 y1.652 z-1.100
    x158.055 y1.670 z-1.100
    x158.180 y1.792 z-1.100
    x158.207 y1.819 z-1.100
    x158.329 y1.944 z-1.100
    x158.347 y1.963 z-1.100
    x158.467 y2.090 z-1.100
    x158.480 y2.104 z-1.100
    x158.598 y2.232 z-1.100
    x158.620 y2.256 z-1.100
    x158.736 y2.387 z-1.100
    x158.757 y2.411 z-1.100
    x158.870 y2.544 z-1.100
    x158.883 y2.559 z-1.100
    x158.994 y2.693 z-1.100
    x159.013 y2.718 z-1.100
    x159.122 y2.855 z-1.100
    x159.139 y2.876 z-1.100
    x159.245 y3.014 z-1.100
    x159.264 y3.039 z-1.100
    x159.368 y3.180 z-1.100
    x159.384 y3.202 z-1.100
    x159.485 y3.344 z-1.100
    x159.499 y3.365 z-1.100
    x159.598 y3.509 z-1.100
    x159.614 y3.532 z-1.100
    x159.710 y3.677 z-1.100
    x159.723 y3.698 z-1.100
    x159.817 y3.845 z-1.100
    x159.835 y3.873 z-1.100
    x159.926 y4.022 z-1.100
    x159.939 y4.043 z-1.100
    x160.028 y4.194 z-1.100
    x160.039 y4.214 z-1.100
    x160.125 y4.365 z-1.100
    x160.143 y4.398 z-1.100
    x160.226 y4.552 z-1.100
    x160.236 y4.570 z-1.100
    x160.317 y4.725 z-1.100
    x160.334 y4.757 z-1.100
    x160.411 y4.913 z-1.100
    x160.416 y4.924 z-1.100
    x160.492 y5.081 z-1.100
    x160.509 y5.118 z-1.100
    x160.581 y5.277 z-1.100
    x160.589 y5.296 z-1.100
    x160.659 y5.456 z-1.100
    x160.674 y5.490 z-1.100
    x160.740 y5.651 z-1.100
    x160.749 y5.673 z-1.100
    x160.813 y5.836 z-1.100
    x160.822 y5.860 z-1.100
    x160.883 y6.023 z-1.100
    x160.891 y6.044 z-1.100
    x160.950 y6.209 z-1.100
    x161.016 y6.407 z-1.100
    x161.023 y6.429 z-1.100
    x161.076 y6.596 z-1.100
    x161.086 y6.629 z-1.100
    x161.135 y6.796 z-1.100
    x161.141 y6.815 z-1.100
    x161.188 y6.983 z-1.100
    x161.197 y7.020 z-1.100
    x161.240 y7.189 z-1.100
    x161.245 y7.208 z-1.100
    x161.286 y7.378 z-1.100
    x161.292 y7.404 z-1.100
    x161.330 y7.574 z-1.100
    x161.336 y7.602 z-1.100
    x161.371 y7.773 z-1.100
    x161.377 y7.801 z-1.100
    x161.409 y7.973 z-1.100
    x161.415 y8.008 z-1.100
    x161.443 y8.180 z-1.100
    x161.446 y8.199 z-1.100
    x161.472 y8.372 z-1.100
    x161.476 y8.399 z-1.100
    x161.499 y8.572 z-1.100
    x161.502 y8.599 z-1.100
    x161.522 y8.772 z-1.100
    x161.526 y8.809 z-1.100
    x161.542 y8.983 z-1.100
    x161.543 y9.001 z-1.100
    x161.557 y9.175 z-1.100
    x161.559 y9.202 z-1.100
    x161.570 y9.376 z-1.100
    x161.572 y9.413 z-1.100
    x161.579 y9.588 z-1.100
    x161.580 y9.605 z-1.100
    x161.585 y9.779 z-1.100
    x161.585 y9.807 z-1.100
    x161.587 y9.982 z-1.100
    x161.588 y10.000 z-1.100
    x161.588 y90.000 z-1.100
    x161.587 y90.018 z-1.100
    x161.585 y90.192 z-1.100
    x161.585 y90.220 z-1.100
    x161.580 y90.394 z-1.100
    x161.579 y90.411 z-1.100
    x161.572 y90.586 z-1.100
    x161.570 y90.623 z-1.100
    x161.559 y90.797 z-1.100
    x161.557 y90.824 z-1.100
    x161.543 y90.998 z-1.100
    x161.542 y91.016 z-1.100
    x161.526 y91.190 z-1.100
    x161.522 y91.227 z-1.100
    x161.502 y91.400 z-1.100
    x161.499 y91.427 z-1.100
    x161.476 y91.600 z-1.100
    x161.472 y91.627 z-1.100
    x161.446 y91.800 z-1.100
    x161.443 y91.819 z-1.100
    x161.415 y91.991 z-1.100
    x161.409 y92.026 z-1.100
    x161.377 y92.198 z-1.100
    x161.371 y92.226 z-1.100
    x161.336 y92.397 z-1.100
    x161.330 y92.425 z-1.100
    x161.292 y92.595 z-1.100
    x161.286 y92.621 z-1.100
    x161.245 y92.791 z-1.100
    x161.240 y92.810 z-1.100
    x161.197 y92.979 z-1.100
    x161.188 y93.016 z-1.100
    x161.141 y93.184 z-1.100
    x161.135 y93.203 z-1.100
    x161.086 y93.370 z-1.100
    x161.076 y93.403 z-1.100
    x161.023 y93.570 z-1.100
    x161.016 y93.592 z-1.100
    x160.950 y93.790 z-1.100
    x160.891 y93.955 z-1.100
    x160.883 y93.976 z-1.100
    x160.822 y94.139 z-1.100
    x160.813 y94.163 z-1.100
    x160.749 y94.326 z-1.100
    x160.740 y94.348 z-1.100
    x160.674 y94.509 z-1.100
    x160.659 y94.543 z-1.100
    x160.589 y94.703 z-1.100
    x160.581 y94.722 z-1.100
    x160.509 y94.881 z-1.100
    x160.492 y94.918 z-1.100
    x160.416 y95.075 z-1.100
    x160.411 y95.086 z-1.100
    x160.334 y95.242 z-1.100
    x160.317 y95.274 z-1.100
    x160.236 y95.429 z-1.100
    x160.226 y95.447 z-1.100
    x160.143 y95.601 z-1.100
    x160.128 y95.630 z-1.100
    x160.042 y95.782 z-1.100
    x160.025 y95.810 z-1.100
    x159.936 y95.960 z-1.100
    x159.926 y95.977 z-1.100
    x159.835 y96.126 z-1.100
    x159.817 y96.154 z-1.100
    x159.723 y96.301 z-1.100
    x159.710 y96.322 z-1.100
    x159.614 y96.467 z-1.100
    x159.598 y96.490 z-1.100
    x159.499 y96.634 z-1.100
    x159.485 y96.655 z-1.100
    x159.384 y96.797 z-1.100
    x159.368 y96.819 z-1.100
    x159.264 y96.960 z-1.100
    x159.245 y96.985 z-1.100
    x159.139 y97.123 z-1.100
    x159.122 y97.144 z-1.100
    x159.013 y97.281 z-1.100
    x158.994 y97.306 z-1.100
    x158.883 y97.440 z-1.100
    x158.870 y97.455 z-1.100
    x158.757 y97.588 z-1.100
    x158.736 y97.612 z-1.100
    x158.620 y97.743 z-1.100
    x158.598 y97.767 z-1.100
    x158.480 y97.895 z-1.100
    x158.467 y97.909 z-1.100
    x158.347 y98.036 z-1.100
    x158.329 y98.055 z-1.100
    x158.207 y98.180 z-1.100
    x158.180 y98.207 z-1.100
    x158.055 y98.329 z-1.100
    x158.036 y98.347 z-1.100
    x157.909 y98.467 z-1.100
    x157.895 y98.480 z-1.100
    x157.767 y98.598 z-1.100
    x157.743 y98.620 z-1.100
    x157.612 y98.736 z-1.100
    x157.588 y98.757 z-1.100
    x157.455 y98.870 z-1.100
    x157.440 y98.883 z-1.100
    x157.306 y98.994 z-1.100
    x157.281 y99.013 z-1.100
    x157.144 y99.122 z-1.100
    x157.123 y99.139 z-1.100
    x156.985 y99.245 z-1.100
    x156.960 y99.264 z-1.100
    x156.819 y99.368 z-1.100
    x156.797 y99.384 z-1.100
    x156.655 y99.485 z-1.100
    x156.634 y99.499 z-1.100
    x156.490 y99.598 z-1.100
    x156.467 y99.614 z-1.100
    x156.322 y99.710 z-1.100
    x156.301 y99.723 z-1.100
    x156.154 y99.817 z-1.100
    x156.126 y99.835 z-1.100
    x155.977 y99.926 z-1.100
    x155.960 y99.936 z-1.100
    x155.810 y100.025 z-1.100
    x155.782 y100.042 z-1.100
    x155.630 y100.128 z-1.100
    x155.601 y100.143 z-1.100
    x155.447 y100.226 z-1.100
    x155.429 y100.236 z-1.100
    x155.274 y100.317 z-1.100
    x155.242 y100.334 z-1.100
    x155.086 y100.411 z-1.100
    x155.075 y100.416 z-1.100
    x154.918 y100.492 z-1.100
    x154.881 y100.509 z-1.100
    x154.722 y100.581 z-1.100
    x154.703 y100.589 z-1.100
    x154.543 y100.659 z-1.100
    x154.509 y100.674 z-1.100
    x154.348 y100.740 z-1.100
    x154.326 y100.749 z-1.100
    x154.163 y100.813 z-1.100
    x154.139 y100.822 z-1.100
    x153.976 y100.883 z-1.100
    x153.955 y100.891 z-1.100
    x153.790 y100.950 z-1.100
    x153.592 y101.016 z-1.100
    x153.570 y101.023 z-1.100
    x153.403 y101.076 z-1.100
    x153.370 y101.086 z-1.100
    x153.203 y101.135 z-1.100
    x153.184 y101.141 z-1.100
    x153.016 y101.188 z-1.100
    x152.979 y101.197 z-1.100
    x152.810 y101.240 z-1.100
    x152.791 y101.245 z-1.100
    x152.621 y101.286 z-1.100
    x152.595 y101.292 z-1.100
    x152.425 y101.330 z-1.100
    x152.397 y101.336 z-1.100
    x152.226 y101.371 z-1.100
    x152.198 y101.377 z-1.100
    x152.026 y101.409 z-1.100
    x151.991 y101.415 z-1.100
    x151.819 y101.443 z-1.100
    x151.800 y101.446 z-1.100
    x151.627 y101.472 z-1.100
    x151.600 y101.476 z-1.100
    x151.427 y101.499 z-1.100
    x151.400 y101.502 z-1.100
    x151.227 y101.522 z-1.100
    x151.190 y101.526 z-1.100
    x151.016 y101.542 z-1.100
    x150.998 y101.543 z-1.100
    x150.824 y101.557 z-1.100
    x150.797 y101.559 z-1.100
    x150.623 y101.570 z-1.100
    x150.586 y101.572 z-1.100
    x150.411 y101.579 z-1.100
    x150.394 y101.580 z-1.100
    x150.220 y101.585 z-1.100
    x150.192 y101.585 z-1.100
    x150.018 y101.587 z-1.100
    x150.000 y101.588 z-1.100
    x84.588 y101.588 z-1.100
    x84.088 y101.588 z-0.600
    x75.913 y101.588 z-0.600
    F500
    x75.413 y101.588 z-1.100
    F1000
    x10.000 y101.588 z-1.100
    x9.982 y101.587 z-1.100
    x9.807 y101.585 z-1.100
    x9.779 y101.585 z-1.100
    x9.605 y101.580 z-1.100
    x9.588 y101.579 z-1.100
    x9.413 y101.572 z-1.100
    x9.376 y101.570 z-1.100
    x9.202 y101.559 z-1.100
    x9.175 y101.557 z-1.100
    x9.001 y101.543 z-1.100
    x8.983 y101.542 z-1.100
    x8.809 y101.526 z-1.100
    x8.772 y101.522 z-1.100
    x8.599 y101.502 z-1.100
    x8.572 y101.499 z-1.100
    x8.399 y101.476 z-1.100
    x8.372 y101.472 z-1.100
    x8.199 y101.446 z-1.100
    x8.180 y101.443 z-1.100
    x8.008 y101.415 z-1.100
    x7.973 y101.409 z-1.100
    x7.801 y101.377 z-1.100
    x7.773 y101.371 z-1.100
    x7.602 y101.336 z-1.100
    x7.574 y101.330 z-1.100
    x7.404 y101.292 z-1.100
    x7.378 y101.286 z-1.100
    x7.208 y101.245 z-1.100
    x7.189 y101.240 z-1.100
    x7.020 y101.197 z-1.100
    x6.983 y101.188 z-1.100
    x6.815 y101.141 z-1.100
    x6.796 y101.135 z-1.100
    x6.629 y101.086 z-1.100
    x6.596 y101.076 z-1.100
    x6.429 y101.023 z-1.100
    x6.407 y101.016 z-1.100
    x6.209 y100.950 z-1.100
    x6.044 y100.891 z-1.100
    x6.023 y100.883 z-1.100
    x5.860 y100.822 z-1.100
    x5.836 y100.813 z-1.100
    x5.673 y100.749 z-1.100
    x5.651 y100.740 z-1.100
    x5.490 y100.674 z-1.100
    x5.456 y100.659 z-1.100
    x5.296 y100.589 z-1.100
    x5.277 y100.581 z-1.100
    x5.118 y100.509 z-1.100
    x5.081 y100.492 z-1.100
    x4.924 y100.416 z-1.100
    x4.913 y100.411 z-1.100
    x4.757 y100.334 z-1.100
    x4.725 y100.317 z-1.100
    x4.570 y100.236 z-1.100
    x4.552 y100.226 z-1.100
    x4.398 y100.143 z-1.100
    x4.369 y100.128 z-1.100
    x4.217 y100.042 z-1.100
    x4.189 y100.025 z-1.100
    x4.039 y99.936 z-1.100
    x4.022 y99.926 z-1.100
    x3.873 y99.835 z-1.100
    x3.845 y99.817 z-1.100
    x3.698 y99.723 z-1.100
    x3.677 y99.710 z-1.100
    x3.532 y99.614 z-1.100
    x3.509 y99.598 z-1.100
    x3.365 y99.499 z-1.100
    x3.344 y99.485 z-1.100
    x3.202 y99.384 z-1.100
    x3.180 y99.368 z-1.100
    x3.039 y99.264 z-1.100
    x3.014 y99.245 z-1.100
    x2.876 y99.139 z-1.100
    x2.855 y99.122 z-1.100
    x2.718 y99.013 z-1.100
    x2.693 y98.994 z-1.100
    x2.559 y98.883 z-1.100
    x2.544 y98.870 z-1.100
    x2.411 y98.757 z-1.100
    x2.387 y98.736 z-1.100
    x2.256 y98.620 z-1.100
    x2.232 y98.598 z-1.100
    x2.104 y98.480 z-1.100
    x2.090 y98.467 z-1.100
    x1.963 y98.347 z-1.100
    x1.944 y98.329 z-1.100
    x1.819 y98.207 z-1.100
    x1.792 y98.180 z-1.100
    x1.670 y98.055 z-1.100
    x1.652 y98.036 z-1.100
    x1.532 y97.909 z-1.100
    x1.519 y97.895 z-1.100
    x1.401 y97.767 z-1.100
    x1.379 y97.743 z-1.100
    x1.263 y97.612 z-1.100
    x1.242 y97.588 z-1.100
    x1.129 y97.455 z-1.100
    x1.116 y97.440 z-1.100
    x1.005 y97.306 z-1.100
    x0.986 y97.281 z-1.100
    x0.877 y97.144 z-1.100
    x0.860 y97.123 z-1.100
    x0.754 y96.985 z-1.100
    x0.735 y96.960 z-1.100
    x0.631 y96.819 z-1.100
    x0.615 y96.797 z-1.100
    x0.514 y96.655 z-1.100
    x0.500 y96.634 z-1.100
    x0.401 y96.490 z-1.100
    x0.385 y96.467 z-1.100
    x0.289 y96.322 z-1.100
    x0.276 y96.301 z-1.100
    x0.182 y96.154 z-1.100
    x0.164 y96.126 z-1.100
    x0.073 y95.977 z-1.100
    x0.060 y95.956 z-1.100
    x-0.029 y95.805 z-1.100
    x-0.040 y95.785 z-1.100
    x-0.126 y95.634 z-1.100
    x-0.144 y95.601 z-1.100
    x-0.227 y95.447 z-1.100
    x-0.237 y95.429 z-1.100
    x-0.318 y95.274 z-1.100
    x-0.335 y95.242 z-1.100
    x-0.412 y95.086 z-1.100
    x-0.417 y95.075 z-1.100
    x-0.493 y94.918 z-1.100
    x-0.510 y94.881 z-1.100
    x-0.582 y94.722 z-1.100
    x-0.590 y94.703 z-1.100
    x-0.660 y94.543 z-1.100
    x-0.675 y94.509 z-1.100
    x-0.741 y94.348 z-1.100
    x-0.750 y94.326 z-1.100
    x-0.814 y94.163 z-1.100
    x-0.823 y94.139 z-1.100
    x-0.884 y93.976 z-1.100
    x-0.892 y93.955 z-1.100
    x-0.951 y93.790 z-1.100
    x-1.017 y93.592 z-1.100
    x-1.024 y93.570 z-1.100
    x-1.077 y93.403 z-1.100
    x-1.087 y93.370 z-1.100
    x-1.136 y93.203 z-1.100
    x-1.142 y93.184 z-1.100
    x-1.189 y93.016 z-1.100
    x-1.198 y92.979 z-1.100
    x-1.241 y92.810 z-1.100
    x-1.246 y92.791 z-1.100
    x-1.287 y92.621 z-1.100
    x-1.293 y92.595 z-1.100
    x-1.331 y92.425 z-1.100
    x-1.337 y92.397 z-1.100
    x-1.372 y92.226 z-1.100
    x-1.378 y92.198 z-1.100
    x-1.410 y92.026 z-1.100
    x-1.416 y91.991 z-1.100
    x-1.444 y91.819 z-1.100
    x-1.447 y91.800 z-1.100
    x-1.473 y91.627 z-1.100
    x-1.477 y91.600 z-1.100
    x-1.500 y91.427 z-1.100
    x-1.503 y91.400 z-1.100
    x-1.523 y91.227 z-1.100
    x-1.527 y91.190 z-1.100
    x-1.543 y91.016 z-1.100
    x-1.544 y90.998 z-1.100
    x-1.558 y90.824 z-1.100
    x-1.560 y90.797 z-1.100
    x-1.571 y90.623 z-1.100
    x-1.573 y90.586 z-1.100
    x-1.580 y90.411 z-1.100
    x-1.581 y90.394 z-1.100
    x-1.586 y90.220 z-1.100
    x-1.586 y90.183 z-1.100
    x-1.587 y90.009 z-1.100
    x-1.588 y90.000 z-1.100
    x-1.588 y54.588 z-1.100
    x-1.588 y54.088 z-0.600
    x-1.588 y45.913 z-0.600
    F500
    x-1.588 y45.413 z-1.100
    F1000
    x-1.588 y10.000 z-1.100
    x-1.587 y9.991 z-1.100
    x-1.586 y9.816 z-1.100
    x-1.586 y9.779 z-1.100
    x-1.581 y9.605 z-1.100
    x-1.580 y9.588 z-1.100
    x-1.573 y9.413 z-1.100
    x-1.571 y9.376 z-1.100
    x-1.560 y9.202 z-1.100
    x-1.558 y9.175 z-1.100
    x-1.544 y9.001 z-1.100
    x-1.543 y8.983 z-1.100
    x-1.527 y8.809 z-1.100
    x-1.523 y8.772 z-1.100
    x-1.503 y8.599 z-1.100
    x-1.500 y8.572 z-1.100
    x-1.477 y8.399 z-1.100
    x-1.473 y8.372 z-1.100
    x-1.447 y8.199 z-1.100
    x-1.444 y8.180 z-1.100
    x-1.416 y8.008 z-1.100
    x-1.410 y7.973 z-1.100
    x-1.378 y7.801 z-1.100
    x-1.372 y7.773 z-1.100
    x-1.337 y7.602 z-1.100
    x-1.331 y7.574 z-1.100
    x-1.293 y7.404 z-1.100
    x-1.287 y7.378 z-1.100
    x-1.246 y7.208 z-1.100
    x-1.241 y7.189 z-1.100
    x-1.198 y7.020 z-1.100
    x-1.189 y6.983 z-1.100
    x-1.142 y6.815 z-1.100
    x-1.136 y6.796 z-1.100
    x-1.087 y6.629 z-1.100
    x-1.077 y6.596 z-1.100
    x-1.024 y6.429 z-1.100
    x-1.017 y6.407 z-1.100
    x-0.951 y6.209 z-1.100
    x-0.892 y6.044 z-1.100
    x-0.884 y6.023 z-1.100
    x-0.823 y5.860 z-1.100
    x-0.814 y5.836 z-1.100
    x-0.750 y5.673 z-1.100
    x-0.741 y5.651 z-1.100
    x-0.675 y5.490 z-1.100
    x-0.660 y5.456 z-1.100
    x-0.590 y5.296 z-1.100
    x-0.582 y5.277 z-1.100
    x-0.510 y5.118 z-1.100
    x-0.493 y5.081 z-1.100
    x-0.417 y4.924 z-1.100
    x-0.412 y4.913 z-1.100
    x-0.335 y4.757 z-1.100
    x-0.318 y4.725 z-1.100
    x-0.237 y4.570 z-1.100
    x-0.227 y4.552 z-1.100
    x-0.144 y4.398 z-1.100
    x-0.129 y4.369 z-1.100
    x-0.043 y4.217 z-1.100
    x-0.026 y4.189 z-1.100
    x0.063 y4.039 z-1.100
    x0.073 y4.022 z-1.100
    x0.164 y3.873 z-1.100
    x0.182 y3.845 z-1.100
    x0.276 y3.698 z-1.100
    x0.289 y3.677 z-1.100
    x0.385 y3.532 z-1.100
    x0.401 y3.509 z-1.100
    x0.500 y3.365 z-1.100
    x0.514 y3.344 z-1.100
    x0.615 y3.202 z-1.100
    x0.631 y3.180 z-1.100
    x0.735 y3.039 z-1.100
    x0.754 y3.014 z-1.100
    x0.860 y2.876 z-1.100
    x0.877 y2.855 z-1.100
    x0.986 y2.718 z-1.100
    x1.005 y2.693 z-1.100
    x1.116 y2.559 z-1.100
    x1.129 y2.544 z-1.100
    x1.242 y2.411 z-1.100
    x1.263 y2.387 z-1.100
    x1.379 y2.256 z-1.100
    x1.401 y2.232 z-1.100
    x1.519 y2.104 z-1.100
    x1.532 y2.090 z-1.100
    x1.652 y1.963 z-1.100
    x1.670 y1.944 z-1.100
    x1.792 y1.819 z-1.100
    x1.819 y1.792 z-1.100
    x1.944 y1.670 z-1.100
    x1.963 y1.652 z-1.100
    x2.090 y1.532 z-1.100
    x2.104 y1.519 z-1.100
    x2.232 y1.401 z-1.100
    x2.256 y1.379 z-1.100
    x2.387 y1.263 z-1.100
    x2.411 y1.242 z-1.100
    x2.544 y1.129 z-1.100
    x2.559 y1.116 z-1.100
    x2.693 y1.005 z-1.100
    x2.718 y0.986 z-1.100
    x2.855 y0.877 z-1.100
    x2.876 y0.860 z-1.100
    x3.014 y0.754 z-1.100
    x3.039 y0.735 z-1.100
    x3.180 y0.631 z-1.100
    x3.202 y0.615 z-1.100
    x3.344 y0.514 z-1.100
    x3.365 y0.500 z-1.100
    x3.509 y0.401 z-1.100
    x3.532 y0.385 z-1.100
    x3.677 y0.289 z-1.100
    x3.698 y0.276 z-1.100
    x3.845 y0.182 z-1.100
    x3.873 y0.164 z-1.100
    x4.022 y0.073 z-1.100
    x4.043 y0.060 z-1.100
    x4.194 y-0.029 z-1.100
    x4.214 y-0.040 z-1.100
    x4.365 y-0.126 z-1.100
    x4.398 y-0.144 z-1.100
    x4.552 y-0.227 z-1.100
    x4.570 y-0.237 z-1.100
    x4.725 y-0.318 z-1.100
    x4.757 y-0.335 z-1.100
    x4.913 y-0.412 z-1.100
    x4.924 y-0.417 z-1.100
    x5.081 y-0.493 z-1.100
    x5.118 y-0.510 z-1.100
    x5.277 y-0.582 z-1.100
    x5.296 y-0.590 z-1.100
    x5.456 y-0.660 z-1.100
    x5.490 y-0.675 z-1.100
    x5.651 y-0.741 z-1.100
    x5.673 y-0.750 z-1.100
    x5.836 y-0.814 z-1.100
    x5.860 y-0.823 z-1.100
    x6.023 y-0.884 z-1.100
    x6.044 y-0.892 z-1.100
    x6.209 y-0.951 z-1.100
    x6.407 y-1.017 z-1.100
    x6.429 y-1.024 z-1.100
    x6.596 y-1.077 z-1.100
    x6.629 y-1.087 z-1.100
    x6.796 y-1.136 z-1.100
    x6.815 y-1.142 z-1.100
    x6.983 y-1.189 z-1.100
    x7.020 y-1.198 z-1.100
    x7.189 y-1.241 z-1.100
    x7.208 y-1.246 z-1.100
    x7.378 y-1.287 z-1.100
    x7.404 y-1.293 z-1.100
    x7.574 y-1.331 z-1.100
    x7.602 y-1.337 z-1.100
    x7.773 y-1.372 z-1.100
    x7.801 y-1.378 z-1.100
    x7.973 y-1.410 z-1.100
    x8.008 y-1.416 z-1.100
    x8.180 y-1.444 z-1.100
    x8.199 y-1.447 z-1.100
    x8.372 y-1.473 z-1.100
    x8.399 y-1.477 z-1.100
    x8.572 y-1.500 z-1.100
    x8.599 y-1.503 z-1.100
    x8.772 y-1.523 z-1.100
    x8.809 y-1.527 z-1.100
    x8.983 y-1.543 z-1.100
    x9.001 y-1.544 z-1.100
    x9.175 y-1.558 z-1.100
    x9.202 y-1.560 z-1.100
    x9.376 y-1.571 z-1.100
    x9.413 y-1.573 z-1.100
    x9.588 y-1.580 z-1.100
    x9.605 y-1.581 z-1.100
    x9.779 y-1.586 z-1.100
    x9.816 y-1.586 z-1.100
    x9.991 y-1.587 z-1.100
    x10.000 y-1.588 z-1.100
    ( Lift to 5.000 )
    F2000 z5.000
    ( Program end, back to origin )
    G90 F2000 z5.000
    ( Spindle off )
    M05
    F2000 x0.000 y0.000 z5.000
    Keep the advanced Grbl Settings at Default values - those advanced settings have been tweaked over years, the defaults works great.
    There is no Arcs in the gcode. Its a bunch of G1 straight sections. You will need a proper CAM that does generate G2/3 arcs if you want to use Arcs, Fusion360 for example
    Line segments can work, if it stutters on them, its the changed grbl settings rather, or a slow PC/Software that cannot stream fast enough, or uses a Ping Pong buffer instead of the more efficient Character Counting method of streaming to grbl
    #2 Peter Van Der Walt, Mar 20, 2021
  3. David the swarfer
    GRBL will stop when the angle between one line and the next is too great to negotiate at speed, there is no parameter that can prevent this.
    Here are the slopes of your line segments, you can see that there are some big slope changes which will definitely make GRBL stop to change direction
