Grbl and firmware not connecting
Discussion in 'General Talk' started by eric weatherman, Jan 28, 2023.
  1. eric weatherman
    Saw the GRBL error on controller and then saw yellow wire is severed on controller in pic I attached. Is this the possible culprit? Also is there a way to reinstall the wire…it has plenty of room but I would have to remove the other wires
    That would be the reason yes.
    You can order replacement cables from the Openbuilds Partstore. Contact via support.openbuilds.com
  3. eric weatherman
    Thank you!
