GRBL 1.1 x axis calibration
Discussion in 'OpenBuilds Forum Help' started by GraemeGoode, Mar 4, 2021.
  1. GraemeGoode
    Hi All
    I recently reflashed my uno board with 1.1.... after calibrating Z and Y axis i went onto X - it only moves 14mm even after putting in the adjusted measurement in Openbuilds calibration wizard... all other axis work perfectly. X axis jogs fine as well...
    Thanks!
    Soft limits turned on, and forgot to Home so soft limits knows where it can go?
  3. GraemeGoode
    soft limits aren't turned on - the other axis calibrate perfectly without this happening. Thanks!
    Initial steps per mm value at least in the ballpark? If its very far, its hard to use as a starting point. Use the calculators in CONTROL > Grbl Settings next to the $100-102 fields
  5. GraemeGoode
    So the strange thing is it was working before I did a recalibration of all the axis. I'm beginning to think this uno may have an issue
  6. sharmstr
    Maybe typo when entering moved value in wizard?
  7. GraemeGoode
    It crossed my mind but I've done it too many times now and made sure it was correct. So strange.
    Paste your Grbl settings please. Grbl Settings > Backup Settings button on top toolbar.
  9. GraemeGoode
    Will do - I'm not in front of the pc anymore - will do so when I'm back in the morning. Thanks Peter appreciate it.
  10. GraemeGoode
    Hi - here are the grbl settings
    $0 = 10 (Step pulse time, microseconds)
    $1 = 25 (Step idle delay, milliseconds)
    $2 = 0 (Step pulse invert, mask)
    $3 = 5 (Step direction invert, mask)
    $4 = 0 (Invert step enable pin, boolean)
    $5 = 0 (Invert limit pins, boolean)
    $6 = 0 (Invert probe pin, boolean)
    $10 = 1 (Status report options, mask)
    $11 = 0.010 (Junction deviation, millimeters)
    $12 = 0.002 (Arc tolerance, millimeters)
    $13 = 0 (Report in inches, boolean)
    $20 = 0 (Soft limits enable, boolean)
    $21 = 0 (Hard limits enable, boolean)
    $22 = 0 (Homing cycle enable, boolean)
    $23 = 0 (Homing direction invert, mask)
    $24 = 25.000 (Homing locate feed rate, mm/min)
    $25 = 500.000 (Homing search seek rate, mm/min)
    $26 = 250 (Homing switch debounce delay, milliseconds)
    $27 = 1.000 (Homing switch pull-off distance, millimeters)
    $30 = 1000 (Maximum spindle speed, RPM)
    $31 = 0 (Minimum spindle speed, RPM)
    $32 = 1 (Laser-mode enable, boolean)
    $100 = 250.000 (X-axis travel resolution, step/mm)
    $101 = 250.000 (Y-axis travel resolution, step/mm)
    $102 = 250.000 (Z-axis travel resolution, step/mm)
    $110 = 3000.000 (X-axis maximum rate, mm/min)
    $111 = 2500.000 (Y-axis maximum rate, mm/min)
    $112 = 2500.000 (Z-axis maximum rate, mm/min)
    $120 = 320.000 (X-axis acceleration, mm/sec^2)
    $121 = 320.000 (Y-axis acceleration, mm/sec^2)
    $122 = 320.000 (Z-axis acceleration, mm/sec^2)
    $130 = 1200.000 (X-axis maximum travel, millimeters)
    $131 = 1200.000 (Y-axis maximum travel, millimeters)
    $132 = 100.000 (Z-axis maximum travel, millimeters)
    ok
  11. Peter Van Der Walt
    And what kind of machine is it again?
  12. GraemeGoode
    It's a 1500x1500 workbee with 2.2kw water cooled spindle. I calibrated it using 10mm travel and got it spot on... It won't do the 100mm travel option.
  13. Peter Van Der Walt
    Standard steps per mm for TR8*2 screw, 1.8deg motors and 1/8th microstepping is +-200
  14. GraemeGoode
    Correct - I recalibrated using the 10mm travel and seems to have sorted it for now. Thanks for your assistance!
  15. David the swarfer
    Code:
    X is trying to go faster, maybe it is stalling?
  16. JustinTime
    JustinTime Veteran
    In your OP you said you are using the "Openbuilds calibration wizard". That wizard will do any distance that you want. You just have to entre the distance. The number you see when you open the wizard is just a suggestion and not cast in stone. You can overwrite it.
  17. GraemeGoode
    Hi David I did slow it down and it did the same. Thanks!
  18. GraemeGoode
    Hi - just an update - i downloaded and installed the latest version of the openbuilds control software - sorted the issue out. thanks to all that responded.
