I'm trying to get dual y axis working with a Protoneer Rpi CNC shield v2.60. No matter what I try I am unable to get the second y motor to move. The developer says this board uses the same pinout as the v3.51 board. I did notice that the dir and step pins are reversed in cpu_map.h but switching them made no difference. I traced the paths on the board and confirmed the A-axis is indeed on A3/A4. #define ENABLE_DUAL_AXIS #define DUAL_AXIS_SELECT Y_AXIS #define DUAL_AXIS_CONFIG_PROTONEER_V3_51 Any ideas? Thanks, Duane
I have this board and it works fine. Did you enable Y2 with the solder bridges? That’s all I had to do.
