GRBL 1.1 Alarm 8 while homing machine
Discussion in 'Controller Boards' started by jeffmorris, Jan 2, 2019.
  1. jeffmorris
    jeffmorris Journeyman
    My CNC router has CNC XPro V3 board, three limit switches, and GRBL Panel. I had to replace the limit switches because one of them was not working. Now, when I home the machine, I get Alarm 8. This didn't happen before changing limit switches. I have limit switches at the home position and not at other ends of axis's. Should $20 and $21 be set at 0? If I test the limit switches, the checkmarks stay on instead of going off. I test X-axis limit switch and the checkmark stay on. If I test Y-axis limit switch, the checkmark for X-Axis goes off and checkmark for Y-Axis goes on. If I test Z-axis limit switch, the checkmark for Y-Axis goes off and checkmark for Z-Axis goes on. How can I fix the problem?
