GRANITE 1.0
Discussion in 'CNC Mills/Routers' started by Michael.M, Sep 29, 2018.
  1. Michael.M
    Michael.M Veteran
    Nope. It's almost the same. The gantry does lean back a little bit more so the orientation of the work area has shifted towards the back of the machine.
  2. NeeqOne
    NeeqOne Well-Known
    thanks, for the info.
  3. HuguesP
    HuguesP Well-Known
    Nice machine Michael
    Michael.M likes this.
  4. Michael.M
    Michael.M Veteran
    Thanks buddy!
  5. Michael.M
    Michael.M Veteran
    Worked on the drag chains this weekend. The enclosure is probably next on the list. I'm just waiting on one more material. I say "probably" because it seems like I'll set plans to work on something specific but can easily get side tracked for hours.
  6. Michael.M
    Michael.M Veteran
    I still need to settle on some sort of protection for the linear rails & carriages. I'm also waiting for the g1/4" bsp tap to mill a 2 position manifold for the dual coolant nozzles.
  7. GrayUK
    The Linear Rail thing. The only thing that comes to mind immediately, is some sort of plastic expandible piping with a slot cut in the bottom of it. I'm trying to think where I've seen piping that you can pull longer and squash shorter. :rolleyes: It makes a distinctive cracking noise as you do so. Ah yes. :D They make 2" flexible pipe for joining waste shower pipes etc. If you had a piece either side of your carriages, so one would expand and one would collapse as the carriages move up and down. You may need to have small extensions each end to park it so to speak. :thumbsup:
  8. HuguesP
    HuguesP Well-Known
    From what i see, a long bent shape screwed in the y axis extrusion with just a kink to let pass the carrier, would prevent the chips to load below the carrier, 99.9% of the chips would be block, anothwr option is the angle screwed on the gantry this time , would be the lenght of the gantry plates, some small dust on the rail have not been an issue for me to date. the carriers are pretry much well sealed on the rails.
  9. Michael.M
    Michael.M Veteran
    Really want to go the DIY route. I'm trying to think of a way to seal pieces of rubber together. I know you can cut and fold some materials to make bellows but I think that requires a stiffer material than rubber.
  10. HPB
    HPB Well-Known
    This is really a solid build! Kudos on an exceptional job. I was hearing some folks tell me that aluminium extrusions (Openbuilds or otherwise) do not make rigid machines and this definitely proves them wrong by a mile. Are those THK rails?
  11. Michael.M
    Michael.M Veteran
    Hey thank you! Yeah they are THK 20mm & 15mm rails. My first machine was an Open Builds Sphinx. That machine introduced me to the world of CNC routers and really got the ball rolling for this machine.
    HPB likes this.
  12. HPB
    HPB Well-Known
    It looks really nice. I'm in the process of building a fixed gantry router using linear rails and ball screws. I've never worked with them before so it will be an experience of its own. The idea is to increase rigidity (and hopefully keep costs down) to mill materials such as stainless steel etc.
  13. Michael.M
    Michael.M Veteran
    Thanks! It sounds like you're working on an awesome build. You should definitely start a build log. I considered a fixed gantry machine for the same reason (rigidity) but moving gantry style machines are just so cool. I'm excited to see what this Granite machine is capable of.
    HPB likes this.
  14. Michael.M
    Michael.M Veteran
    Working on a more compact, dual nozzle solution. Each nozzle will have it's own flow valve and only one will have coolant for now.
    These Misumi extrusions are way thicker than I thought. Very heavy duty. Almost 1/4" thick! Awesome. Thanks to CNCMD for putting me on to these.
    #74 Michael.M, Nov 10, 2018
    CNCMD likes this.
  15. Michael.M
    Michael.M Veteran
    DSCN2376.JPG DSCN2367.JPG I added o-ring grooves to make sure nothing leaks.
  16. joe williams
    joe williams Well-Known
    Looking good!
  17. Michael.M
    Michael.M Veteran
    Those pneumatic fittings will be replaced with 90 degree fittings and a hose will coonect each noozle to the valves behind the Z axis.
  18. HuguesP
    HuguesP Well-Known
    This is becoming one of a kind Super Epic build! Keep up!
  19. Michael.M
    Michael.M Veteran
    Haha thanks buddy!
  20. Giarc
    I am curious how you are blowing air? Are you using a standard air compressor, or some other kind of pump? I have been using my air compressor, but it is sooooo noisy so I am looking at other options.
  21. Michael.M
    Michael.M Veteran
    I am using a small oiless air compressor from California Air tools. It's not crazy powerfull but it is quiet.
    Giarc likes this.
  22. HPB
    HPB Well-Known
    I use a 35W aquarium pump on my setup and that does the job well. It’s not crazy air flow but it gets it done.
  23. Giarc
    Thank you.
  24. GrayUK
    Never thought to use something as small as a Pond Air Pump, but I see it is quite common on YouTube.
    They are certainly designed to run for long periods as well. I've seen a couple I like the look of. :thumbsup:
  25. Giarc
    The price is right too. I have always manually turned the air on with the compressor and not for all materials. The pump looks convenient and quiet enough that I may actually get around to automating it. I just bought some relays.
  26. Michael.M
    Michael.M Veteran
    I've seen them used also. I like that they are designed with long duty cycles in mind. My small compressor is quiet but it is constantly running due to it's size.
  27. Michael.M
    Michael.M Veteran
    20181124_174611.jpg Something fishy is going on. I removed the bottom frame and sub plate to attach the tslot table and things aren't going back together as expected. On a plus side, removing the base is a cake walk as it's the same as the Sphinx (thank's kyo)
  28. GrayUK
    How so? What's happening? Is the framework settling so to speak?
  29. Michael.M
    Michael.M Veteran
    So I assembled the machine in two halves (like the Sphinx) and before I installed the two 4040 X axis cbeams, I tried to make sure the Y axis gantry plates were in the exact same spot. I measured everything as best I can and actually it all seems to check out but that's where I am having issues. The bottom frame of the machine is not sliding back in correctly. Before all of of this, I was thinking I need to go back through the machine and square everything up before I run it for the first time. I really just tried to assembled it and didn't focus too much on making sure everything was square.
  30. Michael.M
    Michael.M Veteran
    I also assembled the machine with the gantry plates in the middle of the machine (as you see in the pic) but this makes it difficult to reference their position in relation to anything else. Each side has to be in the exact location. Assembling the machine with the gantry plates all the forward or back against the end plates would have allowed for accurate reference with a micrometer. As it is now, I have to use a tape measure to postion them because I dont have a mic that big.
