Goliath - CNC + 3D printer Hybrid
Discussion in 'Other Builds' started by Joe Young, Nov 26, 2018.
  1. Joe Young
    Joe Young New
    Joe Young published a new build:
    Nickfaibs likes this.
  2. Bigidiot419
    Sorry not seeing what board you've gone to. I downloaded the zip but didn't see a doc or text file listing the electronics. I'd love to try the same but driving the extruder heat etc not available on my current OpenBuild Mill board
  3. Bigidiot419
    rad 3d printed motor got any posts of that running?
  4. Joe Young
    Joe Young New
    I’m using a custom assembly with a arduino mega for the brains, and leadshine drivers ( 3axis and single axis for the extruder). There’s also 3 SSR 30A relays for controlling the bed, and heater cartridge, and power. Everything is broken out on the back of Goliath, and tied to the extrusion.
    I’m running an upgrade right now, that should be done in a couple weeks. I’m replacing all of the plates with thickercarriages
    Hey Bigidiot419..Yea i've got some, but this was just a prototype.
    I'm working on a scratch build for a robotics actuator project that uses a hypo cycloidal reduction, and an axial pancake brushless PCB motor. I've been working on the controller side of it recently now that ive finished the reduction design. I just did a PCBA run for a custom BLDC driver w/ torque, position, and velocity control as well. So far its rated at 20 N.m., and coming in @ 450grams. BOM cost is sub $300. If anyone's interested, ill post a build on it.
  5. Joe Young
    Joe Young New
    Here's the updated cad assembly, and some renders. I'm in the process of upgrading the x axis and carriages.
  6. Chranis
    Chranis New
    Have you tried any aluminum/metal milling, or have you only stuck to wood/other soft materials? Is it stiff enough for metal milling?
  7. Brendan Puel
    Yeah, I'm really curious about what material you are milling.
  8. Brendan Puel
    Also, did you change the pack and go file type? I have solidworks 2016 and it says future version
