Getting gcode errors openbuild control
Discussion in 'CAM' started by William Harper, Sep 5, 2019.
  1. William Harper
    I'm using Dmap2gcode to generate 3d gcode from a grayscale emiage. when I start the project in openbuild control I get a error code 20. What do I need to get it running? I have attached the file.
  2. sharmstr
    sharmstr Master
    G64 isnt supported. Change your first line from
    Code:
    G17 G90 G64 P0.001 M3 S3000
    To
    Code:
    G17 G90 M3 S3000
    I'm not familar with Dmap2gcode so there might be other issues I dont see. Basically you need a post processor that supports grbl: gnea/grbl
  3. sharmstr
    sharmstr Master
    I just installed it. If you go into settings, you can change the header so it doesnt output the G54 P0.001 codes.
  4. William Harper
    thanks shaker I will give it a shot.
  5. William Harper
    shaker your right all it took was to change the header. Working great now. Two thumbs up for you.
  6. sharmstr
    sharmstr Master
  7. phil from seattle
    phil from seattle Well-Known
    I bet those drinks are well mixed!
    On the original point, some controllers throw an error and allow you to press go to continue - Grbl Panel, for example.
    Also, DMap2gcode has common code with F-Engrave which has the same issue.
  8. sharmstr
    sharmstr Master
    I think some allow you to even ignore them.
