G Code error 11- help
Discussion in 'CAM' started by CaptainSawdust, May 19, 2019.
  1. CaptainSawdust
    Hi there,
    Trying to cut my first piece ever using a CNC but had the attached error.
    error: 11 - Max Characters per line exceeded (then a line of G Code)
    Attached is a screenshot.
    Can anyone explain to me what's happened and how to solve it?
    Thank you so much in advance to anyone who can help.
    James
  2. sharmstr
    The issue is all the digits after the decimals in your coordinates. I dont know any machine on earth that can cut to that type of precision. How is your gcode being generated?
  3. David the swarfer
    agree, you only need 4 or 5 digits after the decimal point
  4. CaptainSawdust
    Thank you both so much for your replies.
    I'm using MakerCam as suggested by Jay Bates. Can you recommend a better G Code generator? Would the Open Cam software create the correct standard of code? I've opened the G Code that MakerCam generated and every coordinate seems to be to 12 decimal places!
    James
    Of course, OpenBuilds CAM was designed exactly to handle our ecosystem
  6. David the swarfer
    A long time ago this was supposed to have been fixed in MakerCam
    Rounding Float Values · Issue #4 · shapeoko/makercam
    with a pull request (PR6) but I don't see where that pull was ever merged. OR you have a very old version installed.
    Maybe you should open an issue with MakerCam and have this fixed properly at source?
