fusion post question
Discussion in 'CAM' started by baum, Aug 12, 2020.
  1. baum
    baum New
    fusion with the latest open builds post from @David the swarfer Is there a settings that could change the accuracy of the cuts? I was using an older post of his from about january and the cuts were accurate. I had to uninstall and reinstall fusion and i used the new version and my cuts dont seem to be as accurate. like i cut a 21" circle previously and it would measure 21" I do it now and in the x travel its a little undersized.
    any ideas?
  2. JustinTime
    JustinTime Veteran
    Is it possible that you didn't set up the bit diameter correctly?
  3. baum
    baum New
    My machine is using 1605 ball screws so in theory as long as my gbrl settings are the same the travel should be the same. If i measure in the y direction its right on, in the x its off by about 1/64 or so.
    to the eye this project is ok but to my engineering side of me i want it to be on.
    tool dia is all good
  4. JustinTime
    JustinTime Veteran
    That sounds to me like your x axis is not calibrated properly. It's off by a frog's hair. Recalibrate the x axis and it should be OK then.
  5. David the swarfer
    nothing has changed in the post that will change accuracy
  6. David the swarfer
    this is backlash in X. check all wheels.
