Fusion 360 with openbuilds
Discussion in 'CNC Mills/Routers' started by bo Toepfer, Aug 9, 2020.
  1. bo Toepfer
    I need to know what makes the two products work best together?. Today I designed my first 2d part. I worked to get the cam side of 360 complete. But when i went to look up how to make the two "talk" i got one air cut then in the actual cut it was stopped with error codes? I am frustrated. If there is s preferred way kindly provide me a link!
  2. Giarc
  4. bo Toepfer
    Peter, Let me say I should have watched closer as what was happening was the way I had my router mounted and my End mill adjusted in the collet it was causing the limit switch to be activated, After a few adjustments I solved the issue
    Ahh ok, so not a false trigger, but actually really was hitting the switch. Gotcha
