Fusion 360 questions
Discussion in 'CAD' started by jeffmorris, Oct 19, 2021.
  1. jeffmorris
    jeffmorris Journeyman
    I have been using Fusion 360 for 2D drawing and 3D modeling. If I select sketch objects and use copy/move, I can't snap sketch objects to other sketch objects like I can in AutoCAD (trial version). Any suggestions? I don't have money for AutoCAD.
  2. sharmstr
    Try changing the move type. I often use point to point.
  3. rscamp
    rscamp Well-Known
    I’m not sure what you are trying to do but perhaps the function you are looking for is Coincident. This can be used to join line endpoints for example.
  4. David the swarfer
