Fusion 360 Question
Discussion in 'General Talk' started by Michael Cramer, Dec 25, 2020.
  1. Michael Cramer
    Hello all. Merry Christmas! i know this isn't exact a machine question but i could really use someones assistance with Fusion360. i have attached two screenshots. When i am in the design phase, everything is good. i am able to select inside the letters and its all good. But when i move to the MFG stage to create tool paths, it wont let me select the areas i want for machining, but just the entire component itself. I cannot for the life of me figure out why this is happening and its never happened on anything else I've done. I did insert the letters from an SVG file but followed the proper steps for inserting it. Can anyone give me a hand here?
  2. sharmstr
    You can't select it in the mfg space unless you are assigning a tool path to it.
  3. Michael Cramer
    so how do I assign a tool path? Because I can’t select the letter in the mdf space at all.
  4. Michael Cramer
    Sorry guys I’m dumb. I figured it out.
  5. sharmstr
    For future members with the same issue...
    You need to pick a toolpath first, then click on the text.
  6. Rob Taylor
    Any sketch does this, I've found so far, not just text. You can click on geometry all you like to measure distances, etc. But as soon as the cursor goes near a sketch line, it'll blue out the whole thing.
  7. David the swarfer
    I highly recommend watching all of the 'Fusion Friday' series of video on the NYCCNC channel on Youtube.
