Fusion 360 purge unnecessary objects?
Discussion in 'CAD' started by jeffmorris, Nov 6, 2023.
  1. jeffmorris
    jeffmorris Journeyman
    AutoCAD has "Purge" command that lets you purge unnecessary objects from drawings. Does Fusion 360 have similar command?
  2. Misterg
    Misterg Veteran
    I don't believe so.
    Since F360 is parametric, I don't think that the need arises as everything is associated with an object of some sort.
