Fusion 360 Lead In
Discussion in 'CNC Mills/Routers' started by Cornerspace, Jul 26, 2021.
  1. Cornerspace
    For want of a better description, how do I tweak the settings for the motion of the tool head from origin to cutting point? I have managed to identify and define the point where the tool is at origin, what I haven't figured out is the height of the movement. A illustration of what is happening is the the tool is zero at origin. However, it translated to the cutting point at a height of 10mm (Eg) and moves up to the rest height at 25mm before beginning the cut at 20mm (Stock height). I want to have the tool move from origin to z 25 before translating to cut point at height z 25 before begining its toolpath cut. Is this a Fusion issue? If so, where is the part where I can define that. Thanks. :)
    The settings are on the heights tab, and also relates to the Setup origin
  3. Cornerspace
    Thanks, went through the video. Sadly it doesn't really address my issue. Can you have a look at the attached video and comment on the cause and hopefully the solution? I am trying to pinpoint the movement from origin to retraction. :)
  4. Alex Chambers
    Share your Fusion file and one of us can have a look to see if we can spot the issue.
  5. David the swarfer
    fusion file AND Gcode file please
    Alex Chambers likes this.
