Fusion 360 engrave function
Discussion in 'Other Software' started by bo Toepfer, Oct 5, 2020.
  1. bo Toepfer
    Hi folks I have used this combination successfully a few times, Today was my first attempt to use a 60degree Chamfer mill for an engraving function, I simulated it and post processed it as I have . When I opened the G code and went to run it the router would not move? I then tested a few other files I have cut before and it worked,, I am stumped any help?
  2. sharmstr
    Fusion is now adding a comment to the code if you dont have the paid version. Fix here: Life After Fusion 360
    update your post to the newest (docs.openbuilds.com > fusion page under software)
    autodesks licencing changes are breaking things by adding long comments etc. new post works around that
