I have a CubePro 3D printer with firmware 2.02 and I need to reinstall firmware 2.0 Download the 2.0 but the printer will not let me install it, first it will verify the existence of new firmware and then throw "download failure". Has anyone done this operation before ?, knows what can be done ?. Finally, is there a way to reset the printer to its original state? or in short, something I'm doing wrong ... can you help me?
The discussion has come up on the print3dforum. I cannot swear to the exact process but it is in the light of the following: Have a valid 2.02 FW on the stick; Start a FW update; interrupt the update once started; have another stick with the 2.00 firmware but named as the 2.02 FW file name. Resume the FW update with the second stick. If this works, yea!.... if not, come on over to the forum and look around the Cube 3 sub-forum. The Cube Pro gets involved often.
