exportar incompleto
Discussion in 'General Talk' started by Nodos Creativos LLC, Jul 19, 2024.
  1. Nodos Creativos LLC
    Cuando quiero exportar el archivo de illustrator a cam, vectorizado, lo exporta incompleto, aunque los vectores estén cerrados
    Checkout Section 15 of Terms of Service and Rules | OpenBuilds
    Nodos Creativos LLC likes this.
  3. David the swarfer
    used chatgpt to translate, you can too
    "When I want to export the file from Illustrator to CAM, vectorized, it exports incompletely, even though the vectors are closed."
    do you mean that the file does not export completely from Illustrator?
    do you mean the file does not import completely into OpenBuilds CAM?
    do you mean that after adding toolpaths in CAM. it does not export as Gcode completely?
