eTrueUp Glide
Discussion in '3D printers' started by Elmo Clarity, Apr 14, 2017.
  1. Reanimator2k
    If publishing all of them is take too much of your time, than only a 20x40 Z mount for wheels, and 20x40 z mount for nylon inserts. I want to try to speed-up this build to 150-180mm/s, but on 100 it's already vibrating a lot. I have two spare 20x40 pieces for Z axis, want to try them because if i use 20x20 they play a lot when bed is moving.
  2. Elmo Clarity
    Elmo Clarity Journeyman
    I don't have a drawing for nylon inserts. I am using lead screws.
    I am making some design changes that you might be interested in for getting the speed up. I am using a Nimble extruder, Piezo Probe, and Berd-Air for part cooling. I have reduced the weight of the carriage from 420g to 180g. That should allow for some faster printing.
    Here is a picture of the two carriages. The old one on the left used a Titan extruder.
    Keith Davis likes this.
  3. Keith Davis
    Keith Davis Veteran
    +Elmo do you have an STL for your Aero Titan extruder mount? I have a customer who wants to convert to that extruder.
  4. Elmo Clarity
    I should have. Just have to find it.
  5. Keith Davis
    Keith Davis Veteran
    LOL!! I know how that works :(
  6. Elmo Clarity
    I posted a note to you on your profile concerning the files.
  7. Alessandro Parisi
    Hello Keith,
    talking about the plate size and thickness versus weight (320x220mm plate, 6062 alluminium, specific wieght 2,7g/cm3):
    320x220x3mm = 570gr.
    320x220x5mm = 950gr.
    is it quite a thickness of 3mm or better 5mm, considering the traction force that is created between the two plates given by the adjusting springs? If 3mm, can the support plate bend ?
    I'm going to buy one from my hardware shop here in Italy...
  8. Elmo Clarity
    If I had of had access to a 5mm plate, I would have used it. The weight on the Y axis is not as critical as the X in this design. If you use a 6mm tool plate for the bed, that is where most of the weight will be.
  9. Alessandro Parisi
    Why the Y weight is not critical as the X axis? In my design I planned all the same movements and speed for X and Y axis..
    Anyway I planned to lighten it (the 5mm model) doing some holes, when the mount on the rails will be completed
  10. Elmo Clarity
    Probably worded that poorly. Weight is critical, but the extra weight between the 3mm and 5mm plate is very small compared to the weight of the tool plate.
    Alessandro Parisi likes this.
  11. Ariel Yahni
    Ariel Yahni OpenBuilds Team
    Staff Member Moderator Project Maker Builder Resident Builder
    I like this build and have plenty of parts available to make it. Are you sharing the files?
  12. Elmo Clarity
    I am planning on it. I'll be starting a new build with the files. I have just recently completed the new build, but because it is not using the glide system, I didn't want to confuse things by using that name. Right now I have some family issues I need to take care of and hopefully I will get the files posted here by the end of the month.
    Ariel Yahni likes this.
  13. Keith Davis
    Keith Davis Veteran
    I had a custromer ask me to redesign his TrueUp Glide for 20x40 Z upright using v-wheels. Here's what we came up with. The SKP is the entire thing assembled.
    ASSEMBLED SKP ZIP
  14. Aravoth
    Aravoth New
    Keith or Elmo, do either of you sell just the printed parts? I'm interested in purchasing them.
