Errors in initial run - Z problems
Discussion in 'Control Software' started by Eric Arnold, Jul 10, 2019.
  1. Eric Arnold
    Hi All,
    We've finished our Workbee 1010, have set the Grbl settings, and calibrated XYZ in the OpenBuilds CONTROL v1.0.179. Our practice cut is failing due to problems with our Z. We're using the defualt Grbl settings for the Workbee 1010 but have limit switches that work...thankfully.
    Couple of questions...
    • In the control software, under the button gotozero, why does it say "(Retract Z to Work Coord Z5)"?
    • Why, when clicking the 'Run Job' button, does Z go up so drastically?
    We've generated g-code from Fusion 360. We've tried both the Autodesk and Strooom's grbl post processor and are not have any luck with either.
    I am new to g-code and would really appreciate some help resolving this issue. Thanks so much!!
    Aussie58 likes this.
  2. sharmstr
    "In the control software, under the button gotozero, why does it say "(Retract Z to Work Coord Z5)"?"
    Its a safe way to do it. You dont want your bit dragging across your stock (or your wasteboard depending on where you set Z0) so it moves up 5mm above 0, then moves to X0Y0, then moves down to Z0.
    "Why, when clicking the 'Run Job' button, does Z go up so drastically?" See above. But in Fusion it move 10mm below your Machine Z0. In other words, the highest your spindle can go, -10mm.
  3. Eric Arnold
    Thanks for replying so quickly Shawn,
    The info you provided makes sense. However, the behavior from our machine is different--on run, Z goes straight up until it trips the limit switch. From your experience, do you know what would be causing this? Is it hardware or software?
    Thanks again
  4. sharmstr
    Is it the first move it makes? If so, did you home your machine first? The machine is only going to know where Machine 0 is if you home it first.
    If its not the first move it makes and you've homed your machine... Do you have enough room to account for your retract and clearance settings in Fusion? To explain this. Lets say the top of your stock is 5mm away from the bottom of your cutter when your Z is as high as it will go without triggering the limit switch. If your clearance + your retract height is greater than 5mm, then it will trigger your limit switch.
    Maybe you can tell me which line it errors out on.
  5. Eric Arnold
    Thanks...we're away from our CNC for awhile but will try some things and then re-post later this afternoon.
  6. Eric Arnold
    Yes, oddly, Z going up until the limit switch was triggered was indeed the first move it made. Taking everything into account (inches vs. mm, clearance height, retract height, model top height, etc.), I'm not sure why Z was going up that much.
    On a separate note--we just for the first time opened and used the OpenBuilds CAM Gcode Creator online software, opened the default HelloWorld example, transferred the gcode to the OpenBuilds Control software, and ran it fine on our machine. So, according to this file, everything worked as expected.
    We must leave for today, but will resume troubleshooting tomorrow. Our goal is to use Fusion 360 as our CAD and CAM software, if possible.
    Thanks again,
    Eric
  7. sharmstr
    The only reason I can see for that then is that you didnt have your machine homed. The first move is G53 Z-10 which as I explained earlier is 10 mm below your where your limit switch triggers.
  8. Eric Arnold
    I'm inserting my gcode below for your review. I'm not seeing G53. The Z problem still persists with this file (and other files generated from Fusion 360). The machine was homed and the work areas were set prior. This file is basically a mounting board for a miter saw that will be attached to a metal stand. Thanks again for your review.
    Code:
    (NewMiterBenchTop)
    (NewMiterBenchTop)
    (T2  D=0.25 CR=0 - ZMIN=-0.7125 - flat end mill)
    G90 G94
    G17
    G20
    G28 G91 Z0
    G90
    (2D Pocket2 - the grooves)
    M9
    T2 M6
    S15000 M3
    G54
    G0 X14.413 Y27.8726
    Z0.45
    Z0.2
    G1 Z0.125 F39.37
    X14.4173 Y27.8682 Z0.1086 F12
    G3 X14.429 Y27.8581 Z0.1002 I0.083 J0.085
    G1 X14.431 Y27.8566 Z0.1
    G3 X14.5694 Y28.0496 Z0.087 I0.0692 J0.0965
    X14.431 Y27.8566 Z0.0739 I-0.0692 J-0.0965
    X14.5694 Y28.0496 Z0.0609 I0.0692 J0.0965
    X14.431 Y27.8566 Z0.0479 I-0.0692 J-0.0965
    X14.5694 Y28.0496 Z0.0349 I0.0692 J0.0965
    X14.431 Y27.8566 Z0.0218 I-0.0692 J-0.0965
    X14.5694 Y28.0496 Z0.0088 I0.0692 J0.0965
    X14.431 Y27.8566 Z-0.0042 I-0.0692 J-0.0965
    X14.5694 Y28.0496 Z-0.0172 I0.0692 J0.0965
    X14.431 Y27.8566 Z-0.0303 I-0.0692 J-0.0965
    X14.619 Y27.9531 Z-0.0394 I0.0692 J0.0965
    G1 Y28.4031 F39.37
    G3 X14.6062 Y28.4159 I-0.0128
    G1 X3.3938
    G3 X3.381 Y28.4031 J-0.0128
    G1 Y27.5032
    G3 X3.3938 Y27.4904 I0.0128
    G1 X14.6062
    G3 X14.619 Y27.5032 J0.0128
    G1 Y27.9531
    G3 X14.34 Y28.2202 I-0.2673
    G2 X13.9539 Y28.2118 I-0.3861 J8.8741
    G1 X3.5978
    G3 X3.5851 Y28.199 J-0.0128
    G1 Y27.7072
    G3 X3.5978 Y27.6944 I0.0128
    G1 X14.4021
    G3 X14.4149 Y27.7072 J0.0128
    G1 Y28.199
    G3 X14.4021 Y28.2118 I-0.0128
    G1 X13.9539
    G3 X13.9377 Y28.2058 Z-0.032 J-0.025
    G1 X13.9351 Y28.2032 Z-0.0232
    X13.9329 Y28.2003 Z-0.0144
    G0 Z0.2
    X13.2986 Y27.9059
    G1 Z0.0787 F39.37
    Z-0.0194
    X13.2989 Y27.9058 Z-0.0228
    X13.2997 Y27.9055 Z-0.0262
    X13.3011 Y27.9051 Z-0.0294
    X13.303 Y27.9045 Z-0.0322
    X13.3054 Y27.9037 Z-0.0347
    X13.3081 Y27.9028 Z-0.0367
    X13.3111 Y27.9018 Z-0.0382
    X13.3143 Y27.9008 Z-0.0391
    X13.3176 Y27.8997 Z-0.0394
    X13.3214 Y27.8988
    X13.3253 Y27.8985
    X14.1981
    G3 X14.2109 Y27.9113 J0.0128
    G1 Y27.995
    G3 X14.1981 Y28.0078 I-0.0128
    G1 X13.3153
    X13.3114
    G18 G3 X13.2864 Z-0.0144 K0.025
    G0 Z0.2
    X13.1467 Y28.0004
    G1 Z0.0787 F39.37
    Z-0.0194
    X13.1464 Z-0.0228
    X13.1456 Y28.0007 Z-0.0262
    X13.1442 Y28.0012 Z-0.0294
    X13.1423 Y28.0018 Z-0.0322
    X13.1399 Y28.0026 Z-0.0347
    X13.1372 Y28.0034 Z-0.0367
    X13.1342 Y28.0044 Z-0.0382
    X13.131 Y28.0055 Z-0.0391
    X13.1277 Y28.0065 Z-0.0394
    X13.1239 Y28.0074
    X13.12 Y28.0078
    X11.8153
    X11.8114
    G3 X11.7864 Z-0.0144 K0.025
    G0 Z0.2
    X11.7986 Y27.9059
    G1 Z0.0787 F39.37
    Z-0.0194
    X11.7989 Y27.9058 Z-0.0228
    X11.7997 Y27.9055 Z-0.0262
    X11.8011 Y27.9051 Z-0.0294
    X11.803 Y27.9045 Z-0.0322
    X11.8054 Y27.9037 Z-0.0347
    X11.8081 Y27.9028 Z-0.0367
    X11.8111 Y27.9018 Z-0.0382
    X11.8143 Y27.9008 Z-0.0391
    X11.8176 Y27.8997 Z-0.0394
    X11.8214 Y27.8988
    X11.8253 Y27.8985
    X13.1144
    X13.1164
    G2 X13.1414 Z-0.0144 K0.025
    G0 Z0.2
    X11.6467 Y28.0004
    G1 Z0.0787 F39.37
    Z-0.0194
    X11.6464 Z-0.0228
    X11.6456 Y28.0007 Z-0.0262
    X11.6442 Y28.0012 Z-0.0294
    X11.6423 Y28.0018 Z-0.0322
    X11.6399 Y28.0026 Z-0.0347
    X11.6372 Y28.0034 Z-0.0367
    X11.6342 Y28.0044 Z-0.0382
    X11.631 Y28.0055 Z-0.0391
    X11.6277 Y28.0065 Z-0.0394
    X11.6239 Y28.0074
    X11.62 Y28.0078
    X6.3778
    X6.3739
    G3 X6.3489 Z-0.0144 K0.025
    G0 Z0.2
    X6.3611 Y27.9059
    G1 Z0.0787 F39.37
    Z-0.0194
    X6.3614 Y27.9058 Z-0.0228
    X6.3622 Y27.9055 Z-0.0262
    X6.3636 Y27.9051 Z-0.0294
    X6.3655 Y27.9045 Z-0.0322
    X6.3679 Y27.9037 Z-0.0347
    X6.3706 Y27.9028 Z-0.0367
    X6.3736 Y27.9018 Z-0.0382
    X6.3768 Y27.9008 Z-0.0391
    X6.3801 Y27.8997 Z-0.0394
    X6.3839 Y27.8988
    X6.3878 Y27.8985
    X11.6144
    X11.6164
    G2 X11.6414 Z-0.0144 K0.025
    G0 Z0.2
    X6.2092 Y28.0004
    G1 Z0.0787 F39.37
    Z-0.0194
    X6.2089 Z-0.0228
    X6.2081 Y28.0007 Z-0.0262
    X6.2067 Y28.0012 Z-0.0294
    X6.2048 Y28.0018 Z-0.0322
    X6.2024 Y28.0026 Z-0.0347
    X6.1997 Y28.0034 Z-0.0367
    X6.1967 Y28.0044 Z-0.0382
    X6.1935 Y28.0055 Z-0.0391
    X6.1902 Y28.0065 Z-0.0394
    X6.1864 Y28.0074
    X6.1825 Y28.0078
    X4.8778
    X4.8739
    G3 X4.8489 Z-0.0144 K0.025
    G0 Z0.2
    X4.8611 Y27.9059
    G1 Z0.0787 F39.37
    Z-0.0194
    X4.8614 Y27.9058 Z-0.0228
    X4.8622 Y27.9055 Z-0.0262
    X4.8636 Y27.9051 Z-0.0294
    X4.8655 Y27.9045 Z-0.0322
    X4.8679 Y27.9037 Z-0.0347
    X4.8706 Y27.9028 Z-0.0367
    X4.8736 Y27.9018 Z-0.0382
    X4.8768 Y27.9008 Z-0.0391
    X4.8801 Y27.8997 Z-0.0394
    X4.8839 Y27.8988
    X4.8878 Y27.8985
    X6.1769
    X6.1779
    G2 X6.2029 Z-0.0144 K0.025
    G0 Z0.2
    X4.7092 Y28.0004
    G1 Z0.0787 F39.37
    Z-0.0194
    X4.7089 Z-0.0228
    X4.7081 Y28.0007 Z-0.0262
    X4.7067 Y28.0012 Z-0.0294
    X4.7048 Y28.0018 Z-0.0322
    X4.7024 Y28.0026 Z-0.0347
    X4.6997 Y28.0034 Z-0.0367
    X4.6967 Y28.0044 Z-0.0382
    X4.6935 Y28.0055 Z-0.0391
    X4.6902 Y28.0065 Z-0.0394
    X4.6864 Y28.0074
    X4.6825 Y28.0078
    X3.8019
    G17 G3 X3.7891 Y27.995 J-0.0128
    G1 Y27.9113
    G3 X3.8019 Y27.8985 I0.0128
    G1 X4.6769
    X4.6779
    G18 G2 X4.7029 Z-0.0144 K0.025
    G0 Z0.2
    X14.413 Y27.8726
    G1 Z0.0856 F39.37
    X14.4173 Y27.8682 Z0.0692 F12
    G17 G3 X14.429 Y27.8581 Z0.0609 I0.083 J0.085
    G1 X14.431 Y27.8566 Z0.0606
    G3 X14.5694 Y28.0496 Z0.0476 I0.0692 J0.0965
    X14.431 Y27.8566 Z0.0346 I-0.0692 J-0.0965
    X14.5694 Y28.0496 Z0.0215 I0.0692 J0.0965
    X14.431 Y27.8566 Z0.0085 I-0.0692 J-0.0965
    X14.5694 Y28.0496 Z-0.0045 I0.0692 J0.0965
    X14.431 Y27.8566 Z-0.0175 I-0.0692 J-0.0965
    X14.5694 Y28.0496 Z-0.0306 I0.0692 J0.0965
    X14.431 Y27.8566 Z-0.0436 I-0.0692 J-0.0965
    X14.5694 Y28.0496 Z-0.0566 I0.0692 J0.0965
    X14.431 Y27.8566 Z-0.0696 I-0.0692 J-0.0965
    X14.619 Y27.9531 Z-0.0787 I0.0692 J0.0965
    G1 Y28.4031 F39.37
    G1 X3.3938
    G1 Y27.5032
    G1 X14.6062
    G1 Y27.9531
    G1 X3.5978
    G1 Y27.7072
    G1 X14.4021
    G1 Y28.199
    G1 X13.9539
    G3 X13.9377 Y28.2058 Z-0.0714 J-0.025
    G1 X13.9351 Y28.2032 Z-0.0626
    X13.9329 Y28.2003 Z-0.0537
    G0 Z0.2
    X13.2986 Y27.9059
    G1 Z0.0394 F39.37
    Z-0.0587
    X13.2989 Y27.9058 Z-0.0622
    X13.2997 Y27.9055 Z-0.0656
    X13.3011 Y27.9051 Z-0.0687
    X13.303 Y27.9045 Z-0.0716
    X13.3054 Y27.9037 Z-0.0741
    X13.3081 Y27.9028 Z-0.0761
    X13.3111 Y27.9018 Z-0.0775
    X13.3143 Y27.9008 Z-0.0784
    X13.3176 Y27.8997 Z-0.0787
    X13.3214 Y27.8988
    X13.3253 Y27.8985
    X14.1981
    G1 Y27.995
    G1 X13.3153
    X13.3114
    G18 G3 X13.2864 Z-0.0537 K0.025
    G0 Z0.2
    X13.1467 Y28.0004
    G1 Z0.0394 F39.37
    Z-0.0587
    X13.1464 Z-0.0622
    X13.1456 Y28.0007 Z-0.0656
    X13.1442 Y28.0012 Z-0.0687
    X13.1423 Y28.0018 Z-0.0716
    X13.1399 Y28.0026 Z-0.0741
    X13.1372 Y28.0034 Z-0.0761
    X13.1342 Y28.0044 Z-0.0775
    X13.131 Y28.0055 Z-0.0784
    X13.1277 Y28.0065 Z-0.0787
    X13.1239 Y28.0074
    X13.12 Y28.0078
    X11.8153
    X11.8114
    G3 X11.7864 Z-0.0537 K0.025
    G0 Z0.2
    X11.7986 Y27.9059
    G1 Z0.0394 F39.37
    Z-0.0587
    X11.7989 Y27.9058 Z-0.0622
    X11.7997 Y27.9055 Z-0.0656
    X11.8011 Y27.9051 Z-0.0687
    X11.803 Y27.9045 Z-0.0716
    X11.8054 Y27.9037 Z-0.0741
    X11.8081 Y27.9028 Z-0.0761
    X11.8111 Y27.9018 Z-0.0775
    X11.8143 Y27.9008 Z-0.0784
    X11.8176 Y27.8997 Z-0.0787
    X11.8214 Y27.8988
    X11.8253 Y27.8985
    X13.1144
    X13.1164
    G2 X13.1414 Z-0.0537 K0.025
    G0 Z0.2
    X11.6467 Y28.0004
    G1 Z0.0394 F39.37
    Z-0.0587
    X11.6464 Z-0.0622
    X11.6456 Y28.0007 Z-0.0656
    X11.6442 Y28.0012 Z-0.0687
    X11.6423 Y28.0018 Z-0.0716
    X11.6399 Y28.0026 Z-0.0741
    X11.6372 Y28.0034 Z-0.0761
    X11.6342 Y28.0044 Z-0.0775
    X11.631 Y28.0055 Z-0.0784
    X11.6277 Y28.0065 Z-0.0787
    X11.6239 Y28.0074
    X11.62 Y28.0078
    X6.3778
    X6.3739
    G3 X6.3489 Z-0.0537 K0.025
    G0 Z0.2
    X6.3611 Y27.9059
    G1 Z0.0394 F39.37
    Z-0.0587
    X6.3614 Y27.9058 Z-0.0622
    X6.3622 Y27.9055 Z-0.0656
    X6.3636 Y27.9051 Z-0.0687
    X6.3655 Y27.9045 Z-0.0716
    X6.3679 Y27.9037 Z-0.0741
    X6.3706 Y27.9028 Z-0.0761
    X6.3736 Y27.9018 Z-0.0775
    X6.3768 Y27.9008 Z-0.0784
    X6.3801 Y27.8997 Z-0.0787
    X6.3839 Y27.8988
    X6.3878 Y27.8985
    X11.6144
    X11.6164
    G2 X11.6414 Z-0.0537 K0.025
    G0 Z0.2
    X6.2092 Y28.0004
    G1 Z0.0394 F39.37
    Z-0.0587
    X6.2089 Z-0.0622
    X6.2081 Y28.0007 Z-0.0656
    X6.2067 Y28.0012 Z-0.0687
    X6.2048 Y28.0018 Z-0.0716
    X6.2024 Y28.0026 Z-0.0741
    X6.1997 Y28.0034 Z-0.0761
    X6.1967 Y28.0044 Z-0.0775
    X6.1935 Y28.0055 Z-0.0784
    X6.1902 Y28.0065 Z-0.0787
    X6.1864 Y28.0074
    X6.1825 Y28.0078
    X4.8778
    X4.8739
    G3 X4.8489 Z-0.0537 K0.025
    G0 Z0.2
    X4.8611 Y27.9059
    G1 Z0.0394 F39.37
    Z-0.0587
    X4.8614 Y27.9058 Z-0.0622
    X4.8622 Y27.9055 Z-0.0656
    X4.8636 Y27.9051 Z-0.0687
    X4.8655 Y27.9045 Z-0.0716
    X4.8679 Y27.9037 Z-0.0741
    X4.8706 Y27.9028 Z-0.0761
    X4.8736 Y27.9018 Z-0.0775
    X4.8768 Y27.9008 Z-0.0784
    X4.8801 Y27.8997 Z-0.0787
    X4.8839 Y27.8988
    X4.8878 Y27.8985
    X6.1769
    X6.1779
    G2 X6.2029 Z-0.0537 K0.025
    G0 Z0.2
    X4.7092 Y28.0004
    G1 Z0.0394 F39.37
    Z-0.0587
    X4.7089 Z-0.0622
    X4.7081 Y28.0007 Z-0.0656
    X4.7067 Y28.0012 Z-0.0687
    X4.7048 Y28.0018 Z-0.0716
    X4.7024 Y28.0026 Z-0.0741
    X4.6997 Y28.0034 Z-0.0761
    X4.6967 Y28.0044 Z-0.0775
    X4.6935 Y28.0055 Z-0.0784
    X4.6902 Y28.0065 Z-0.0787
    X4.6864 Y28.0074
    X4.6825 Y28.0078
    X3.8019
    G1 Y27.9113
    G1 X4.6769
    X4.6779
    G18 G2 X4.7029 Z-0.0537 K0.025
    G0 Z0.2
    X14.413 Y27.8726
    G1 Z0.0462 F39.37
    X14.4173 Y27.8682 Z0.0298 F12
    G17 G3 X14.429 Y27.8581 Z0.0215 I0.083 J0.085
    G1 X14.431 Y27.8566 Z0.0213
    G3 X14.5694 Y28.0496 Z0.0082 I0.0692 J0.0965
    X14.431 Y27.8566 Z-0.0048 I-0.0692 J-0.0965
    X14.5694 Y28.0496 Z-0.0178 I0.0692 J0.0965
    X14.431 Y27.8566 Z-0.0309 I-0.0692 J-0.0965
    X14.5694 Y28.0496 Z-0.0439 I0.0692 J0.0965
    X14.431 Y27.8566 Z-0.0569 I-0.0692 J-0.0965
    X14.5694 Y28.0496 Z-0.0699 I0.0692 J0.0965
    X14.431 Y27.8566 Z-0.083 I-0.0692 J-0.0965
    X14.5694 Y28.0496 Z-0.096 I0.0692 J0.0965
    X14.431 Y27.8566 Z-0.109 I-0.0692 J-0.0965
    X14.619 Y27.9531 Z-0.1181 I0.0692 J0.0965
    G1 Y28.4031 F39.37
    G1 X3.3938
    G1 Y27.5032
    G1 X14.6062
    G1 Y27.9531
    G1 X3.5978
    G1 Y27.7072
    G1 X14.4021
    G1 Y28.199
    G1 X13.9539
    G3 X13.9377 Y28.2058 Z-0.1108 J-0.025
    G1 X13.9351 Y28.2032 Z-0.1019
    X13.9329 Y28.2003 Z-0.0931
    G0 Z0.2
    X13.2986 Y27.9059
    G1 Z0 F39.37
    Z-0.0981
    X13.2989 Y27.9058 Z-0.1016
    X13.2997 Y27.9055 Z-0.105
    X13.3011 Y27.9051 Z-0.1081
    X13.303 Y27.9045 Z-0.111
    X13.3054 Y27.9037 Z-0.1134
    X13.3081 Y27.9028 Z-0.1154
    X13.3111 Y27.9018 Z-0.1169
    X13.3143 Y27.9008 Z-0.1178
    X13.3176 Y27.8997 Z-0.1181
    X13.3214 Y27.8988
    X13.3253 Y27.8985
    X14.1981
    G1 Y27.995
    G1 X13.3153
    X13.3114
    G18 G3 X13.2864 Z-0.0931 K0.025
    G0 Z0.2
    X13.1467 Y28.0004
    G1 Z0 F39.37
    Z-0.0981
    X13.1464 Z-0.1016
    X13.1456 Y28.0007 Z-0.105
    X13.1442 Y28.0012 Z-0.1081
    X13.1423 Y28.0018 Z-0.111
    X13.1399 Y28.0026 Z-0.1134
    X13.1372 Y28.0034 Z-0.1154
    X13.1342 Y28.0044 Z-0.1169
    X13.131 Y28.0055 Z-0.1178
    X13.1277 Y28.0065 Z-0.1181
    X13.1239 Y28.0074
    X13.12 Y28.0078
    X11.8153
    X11.8114
    G3 X11.7864 Z-0.0931 K0.025
    G0 Z0.2
    X11.7986 Y27.9059
    G1 Z0 F39.37
    Z-0.0981
    X11.7989 Y27.9058 Z-0.1016
    X11.7997 Y27.9055 Z-0.105
    X11.8011 Y27.9051 Z-0.1081
    X11.803 Y27.9045 Z-0.111
    X11.8054 Y27.9037 Z-0.1134
    X11.8081 Y27.9028 Z-0.1154
    X11.8111 Y27.9018 Z-0.1169
    X11.8143 Y27.9008 Z-0.1178
    X11.8176 Y27.8997 Z-0.1181
    X11.8214 Y27.8988
    X11.8253 Y27.8985
    X13.1144
    X13.1164
    G2 X13.1414 Z-0.0931 K0.025
    G0 Z0.2
    X11.6467 Y28.0004
    G1 Z0 F39.37
    Z-0.0981
    X11.6464 Z-0.1016
    X11.6456 Y28.0007 Z-0.105
    X11.6442 Y28.0012 Z-0.1081
    X11.6423 Y28.0018 Z-0.111
    X11.6399 Y28.0026 Z-0.1134
    X11.6372 Y28.0034 Z-0.1154
    X11.6342 Y28.0044 Z-0.1169
    X11.631 Y28.0055 Z-0.1178
    X11.6277 Y28.0065 Z-0.1181
    X11.6239 Y28.0074
    X11.62 Y28.0078
    X6.3778
    X6.3739
    G3 X6.3489 Z-0.0931 K0.025
    G0 Z0.2
    X6.3611 Y27.9059
    G1 Z0 F39.37
    Z-0.0981
    X6.3614 Y27.9058 Z-0.1016
    X6.3622 Y27.9055 Z-0.105
    X6.3636 Y27.9051 Z-0.1081
    X6.3655 Y27.9045 Z-0.111
    X6.3679 Y27.9037 Z-0.1134
    X6.3706 Y27.9028 Z-0.1154
    X6.3736 Y27.9018 Z-0.1169
    X6.3768 Y27.9008 Z-0.1178
    X6.3801 Y27.8997 Z-0.1181
    X6.3839 Y27.8988
    X6.3878 Y27.8985
    X11.6144
    X11.6164
    G2 X11.6414 Z-0.0931 K0.025
    G0 Z0.2
    X6.2092 Y28.0004
    G1 Z0 F39.37
    Z-0.0981
    X6.2089 Z-0.1016
    X6.2081 Y28.0007 Z-0.105
    X6.2067 Y28.0012 Z-0.1081
    X6.2048 Y28.0018 Z-0.111
    X6.2024 Y28.0026 Z-0.1134
    X6.1997 Y28.0034 Z-0.1154
    X6.1967 Y28.0044 Z-0.1169
    X6.1935 Y28.0055 Z-0.1178
    X6.1902 Y28.0065 Z-0.1181
    X6.1864 Y28.0074
    X6.1825 Y28.0078
    X4.8778
    X4.8739
    G3 X4.8489 Z-0.0931 K0.025
    G0 Z0.2
    X4.8611 Y27.9059
    G1 Z0 F39.37
    Z-0.0981
    X4.8614 Y27.9058 Z-0.1016
    X4.8622 Y27.9055 Z-0.105
    X4.8636 Y27.9051 Z-0.1081
    X4.8655 Y27.9045 Z-0.111
    X4.8679 Y27.9037 Z-0.1134
    X4.8706 Y27.9028 Z-0.1154
    X4.8736 Y27.9018 Z-0.1169
    X4.8768 Y27.9008 Z-0.1178
    X4.8801 Y27.8997 Z-0.1181
    X4.8839 Y27.8988
    X4.8878 Y27.8985
    X6.1769
    X6.1779
    G2 X6.2029 Z-0.0931 K0.025
    G0 Z0.2
    X4.7092 Y28.0004
    G1 Z0 F39.37
    Z-0.0981
    X4.7089 Z-0.1016
    X4.7081 Y28.0007 Z-0.105
    X4.7067 Y28.0012 Z-0.1081
    X4.7048 Y28.0018 Z-0.111
    X4.7024 Y28.0026 Z-0.1134
    X4.6997 Y28.0034 Z-0.1154
    X4.6967 Y28.0044 Z-0.1169
    X4.6935 Y28.0055 Z-0.1178
    X4.6902 Y28.0065 Z-0.1181
    X4.6864 Y28.0074
    X4.6825 Y28.0078
    X3.8019
    G1 Y27.9113
    G1 X4.6769
    X4.6779
    G18 G2 X4.7029 Z-0.0931 K0.025
    G0 Z0.2
    X14.4403 Y27.8506
    G1 Z0.0069 F39.37
    X14.4465 Y27.8472 Z-0.0105 F12
    G17 G3 X14.4623 Y27.8406 Z-0.0181 I0.0537 J0.1059
    X14.5382 Y28.0657 Z-0.0311 I0.038 J0.1125
    X14.4623 Y27.8406 Z-0.0442 I-0.038 J-0.1125
    X14.5382 Y28.0657 Z-0.0572 I0.038 J0.1125
    X14.4623 Y27.8406 Z-0.0702 I-0.038 J-0.1125
    X14.5382 Y28.0657 Z-0.0832 I0.038 J0.1125
    X14.4623 Y27.8406 Z-0.0963 I-0.038 J-0.1125
    X14.5382 Y28.0657 Z-0.1093 I0.038 J0.1125
    X14.4623 Y27.8406 Z-0.1223 I-0.038 J-0.1125
    X14.5382 Y28.0657 Z-0.1354 I0.038 J0.1125
    X14.4623 Y27.8406 Z-0.1484 I-0.038 J-0.1125
    X14.619 Y27.9531 Z-0.1563 I0.038 J0.1125
    G1 Y28.4031 F39.37
    G1 X3.3938
    G1 Y27.5032
    G1 X14.6062
    G1 Y27.9531
    G1 X3.5978
    G1 Y27.7072
    G1 X14.4021
    G1 Y28.199
    G1 X13.9539
    G3 X13.9377 Y28.2058 Z-0.1489 J-0.025
    G1 X13.9351 Y28.2032 Z-0.1401
    X13.9329 Y28.2003 Z-0.1313
    G0 Z0.2
    X13.2986 Y27.9059
    G1 Z-0.0394 F39.37
    Z-0.1363
    X13.2989 Y27.9058 Z-0.1397
    X13.2997 Y27.9055 Z-0.1431
    X13.3011 Y27.9051 Z-0.1462
    X13.303 Y27.9045 Z-0.1491
    X13.3054 Y27.9037 Z-0.1516
    X13.3081 Y27.9028 Z-0.1536
    X13.3111 Y27.9018 Z-0.155
    X13.3143 Y27.9008 Z-0.1559
    X13.3176 Y27.8997 Z-0.1563
    X13.3214 Y27.8988
    X13.3253 Y27.8985
    X14.1981
    G1 Y27.995
    G1 X13.3153
    X13.3114
    G18 G3 X13.2864 Z-0.1313 K0.025
    G0 Z0.2
    X13.1467 Y28.0004
    G1 Z-0.0394 F39.37
    Z-0.1363
    X13.1464 Z-0.1397
    X13.1456 Y28.0007 Z-0.1431
    X13.1442 Y28.0012 Z-0.1463
    X13.1423 Y28.0018 Z-0.1491
    X13.1399 Y28.0026 Z-0.1516
    X13.1372 Y28.0034 Z-0.1536
    X13.1342 Y28.0044 Z-0.155
    X13.131 Y28.0055 Z-0.1559
    X13.1277 Y28.0065 Z-0.1563
    X13.1239 Y28.0074
    X13.12 Y28.0078
    X11.8153
    X11.8114
    G3 X11.7864 Z-0.1313 K0.025
    G0 Z0.2
    X11.7986 Y27.9059
    G1 Z-0.0394 F39.37
    Z-0.1363
    X11.7989 Y27.9058 Z-0.1397
    X11.7997 Y27.9055 Z-0.1431
    X11.8011 Y27.9051 Z-0.1462
    X11.803 Y27.9045 Z-0.1491
    X11.8054 Y27.9037 Z-0.1516
    X11.8081 Y27.9028 Z-0.1536
    X11.8111 Y27.9018 Z-0.155
    X11.8143 Y27.9008 Z-0.1559
    X11.8176 Y27.8997 Z-0.1563
    X11.8214 Y27.8988
    X11.8253 Y27.8985
    X13.1144
    X13.1164
    G2 X13.1414 Z-0.1313 K0.025
    G0 Z0.2
    X11.6467 Y28.0004
    G1 Z-0.0394 F39.37
    Z-0.1363
    X11.6464 Z-0.1397
    X11.6456 Y28.0007 Z-0.1431
    X11.6442 Y28.0012 Z-0.1463
    X11.6423 Y28.0018 Z-0.1491
    X11.6399 Y28.0026 Z-0.1516
    X11.6372 Y28.0034 Z-0.1536
    X11.6342 Y28.0044 Z-0.155
    X11.631 Y28.0055 Z-0.1559
    X11.6277 Y28.0065 Z-0.1563
    X11.6239 Y28.0074
    X11.62 Y28.0078
    X6.3778
    X6.3739
    G3 X6.3489 Z-0.1313 K0.025
    G0 Z0.2
    X6.3611 Y27.9059
    G1 Z-0.0394 F39.37
    Z-0.1363
    X6.3614 Y27.9058 Z-0.1397
    X6.3622 Y27.9055 Z-0.1431
    X6.3636 Y27.9051 Z-0.1463
    X6.3655 Y27.9045 Z-0.1491
    X6.3679 Y27.9037 Z-0.1516
    X6.3706 Y27.9028 Z-0.1536
    X6.3736 Y27.9018 Z-0.155
    X6.3768 Y27.9008 Z-0.1559
    X6.3801 Y27.8997 Z-0.1563
    X6.3839 Y27.8988
    X6.3878 Y27.8985
    X11.6144
    X11.6164
    G2 X11.6414 Z-0.1313 K0.025
    G0 Z0.2
    X6.2092 Y28.0004
    G1 Z-0.0394 F39.37
    Z-0.1363
    X6.2089 Z-0.1397
    X6.2081 Y28.0007 Z-0.1431
    X6.2067 Y28.0012 Z-0.1463
    X6.2048 Y28.0018 Z-0.1491
    X6.2024 Y28.0026 Z-0.1516
    X6.1997 Y28.0034 Z-0.1536
    X6.1967 Y28.0044 Z-0.155
    X6.1935 Y28.0055 Z-0.1559
    X6.1902 Y28.0065 Z-0.1563
    X6.1864 Y28.0074
    X6.1825 Y28.0078
    X4.8778
    X4.8739
    G3 X4.8489 Z-0.1313 K0.025
    G0 Z0.2
    X4.8611 Y27.9059
    G1 Z-0.0394 F39.37
    Z-0.1363
    X4.8614 Y27.9058 Z-0.1397
    X4.8622 Y27.9055 Z-0.1431
    X4.8636 Y27.9051 Z-0.1463
    X4.8655 Y27.9045 Z-0.1491
    X4.8679 Y27.9037 Z-0.1516
    X4.8706 Y27.9028 Z-0.1536
    X4.8736 Y27.9018 Z-0.155
    X4.8768 Y27.9008 Z-0.1559
    X4.8801 Y27.8997 Z-0.1563
    X4.8839 Y27.8988
    X4.8878 Y27.8985
    X6.1769
    X6.1779
    G2 X6.2029 Z-0.1313 K0.025
    G0 Z0.2
    X4.7092 Y28.0004
    G1 Z-0.0394 F39.37
    Z-0.1363
    X4.7089 Z-0.1397
    X4.7081 Y28.0007 Z-0.1431
    X4.7067 Y28.0012 Z-0.1463
    X4.7048 Y28.0018 Z-0.1491
    X4.7024 Y28.0026 Z-0.1516
    X4.6997 Y28.0034 Z-0.1536
    X4.6967 Y28.0044 Z-0.155
    X4.6935 Y28.0055 Z-0.1559
    X4.6902 Y28.0065 Z-0.1563
    X4.6864 Y28.0074
    X4.6825 Y28.0078
    X3.8019
    G1 Y27.9113
    G1 X4.6769
    X4.6779
    G18 G2 X4.7029 Z-0.1313 K0.025
    G0 Z0.45
    X4.7045 Y4.6015
    Z0.2
    G1 Z0.0787 F39.37
    Z-0.0144
    G3 X4.6795 Z-0.0394 I-0.025
    G1 X4.6747
    G17 G3 X4.3217 Y4.4371 J-0.4609
    X4.4862 Y4.0841 I0.1644 J-0.1381
    G1 X14.6062
    G3 X14.619 Y4.0969 J0.0128
    G1 Y4.9968
    G3 X14.6062 Y5.0096 I-0.0128
    G1 X3.3938
    G3 X3.381 Y4.9968 J-0.0128
    G1 Y4.0969
    G3 X3.3938 Y4.0841 I0.0128
    G1 X4.4862
    G3 X4.6392 Y4.1862 J0.1658
    G2 X4.7923 Y4.2882 I0.153 J-0.0638
    G1 X14.4021
    G3 X14.4149 Y4.301 J0.0128
    G1 Y4.7928
    G3 X14.4021 Y4.8056 I-0.0128
    G1 X3.5978
    G3 X3.5851 Y4.7928 J-0.0128
    G1 Y4.301
    G3 X3.5978 Y4.2882 I0.0128
    G1 X4.7923
    G3 X4.817 Y4.3093 J0.025
    G1 X4.8356 Y4.4269
    X4.8362 Y4.4308 Z-0.0391
    X4.8368 Y4.4346 Z-0.0381
    X4.8374 Y4.4382 Z-0.0366
    X4.8379 Y4.4415 Z-0.0346
    X4.8384 Y4.4444 Z-0.032
    X4.8388 Y4.4469 Z-0.0291
    X4.8391 Y4.4489 Z-0.0257
    X4.8393 Y4.4504 Z-0.0221
    X4.8395 Y4.4513 Z-0.0183
    Y4.4516 Z-0.0144
    G0 Z0.2
    X4.8533 Y4.4996
    G1 Z0.0787 F39.37
    Z-0.0194
    X4.8536 Y4.4995 Z-0.0228
    X4.8544 Y4.4993 Z-0.0262
    X4.8558 Y4.4988 Z-0.0294
    X4.8577 Y4.4982 Z-0.0322
    X4.8601 Y4.4974 Z-0.0347
    X4.8628 Y4.4966 Z-0.0367
    X4.8658 Y4.4956 Z-0.0382
    X4.869 Y4.4945 Z-0.0391
    X4.8723 Y4.4935 Z-0.0394
    X4.8761 Y4.4925
    X4.88 Y4.4922
    X6.1847
    X6.1886
    G18 G2 X6.2136 Z-0.0144 K0.025
    G0 Z0.2
    X6.2014 Y4.5941
    G1 Z0.0787 F39.37
    Z-0.0194
    X6.2011 Y4.5942 Z-0.0228
    X6.2003 Y4.5945 Z-0.0262
    X6.1989 Y4.5949 Z-0.0294
    X6.197 Y4.5955 Z-0.0322
    X6.1946 Y4.5963 Z-0.0347
    X6.1919 Y4.5972 Z-0.0367
    X6.1889 Y4.5982 Z-0.0382
    X6.1857 Y4.5992 Z-0.0391
    X6.1824 Y4.6003 Z-0.0394
    X6.1786 Y4.6012
    X6.1747 Y4.6015
    X4.8856
    X4.8836
    G3 X4.8586 Z-0.0144 K0.025
    G0 Z0.2
    X4.7014 Y4.5941
    G1 Z0.0787 F39.37
    Z-0.0194
    X4.7011 Y4.5942 Z-0.0228
    X4.7003 Y4.5945 Z-0.0262
    X4.6989 Y4.5949 Z-0.0294
    X4.697 Y4.5955 Z-0.0322
    X4.6946 Y4.5963 Z-0.0347
    X4.6919 Y4.5972 Z-0.0367
    X4.6889 Y4.5982 Z-0.0382
    X4.6857 Y4.5992 Z-0.0391
    X4.6824 Y4.6003 Z-0.0394
    X4.6786 Y4.6012
    X4.6747 Y4.6015
    X3.8019
    G17 G3 X3.7891 Y4.5887 J-0.0128
    G1 Y4.505
    G3 X3.8019 Y4.4922 I0.0128
    G1 X4.6847
    X4.6886
    G18 G2 X4.7136 Z-0.0144 K0.025
    G0 Z0.2
    X6.3533 Y4.4996
    G1 Z0.0787 F39.37
    Z-0.0194
    X6.3536 Y4.4995 Z-0.0228
    X6.3544 Y4.4993 Z-0.0262
    X6.3558 Y4.4988 Z-0.0294
    X6.3577 Y4.4982 Z-0.0322
    X6.3601 Y4.4974 Z-0.0347
    X6.3628 Y4.4966 Z-0.0367
    X6.3658 Y4.4956 Z-0.0382
    X6.369 Y4.4945 Z-0.0391
    X6.3723 Y4.4935 Z-0.0394
    X6.3761 Y4.4925
    X6.38 Y4.4922
    X11.6222
    X11.6261
    G2 X11.6511 Z-0.0144 K0.025
    G0 Z0.2
    X11.6389 Y4.5941
    G1 Z0.0787 F39.37
    Z-0.0194
    X11.6386 Y4.5942 Z-0.0228
    X11.6378 Y4.5945 Z-0.0262
    X11.6364 Y4.5949 Z-0.0294
    X11.6345 Y4.5955 Z-0.0322
    X11.6321 Y4.5963 Z-0.0347
    X11.6294 Y4.5972 Z-0.0367
    X11.6264 Y4.5982 Z-0.0382
    X11.6232 Y4.5992 Z-0.0391
    X11.6199 Y4.6003 Z-0.0394
    X11.6161 Y4.6012
    X11.6122 Y4.6015
    X6.3856
    X6.3836
    G3 X6.3586 Z-0.0144 K0.025
    G0 Z0.2
    X11.7908 Y4.4996
    G1 Z0.0787 F39.37
    Z-0.0194
    X11.7911 Y4.4995 Z-0.0228
    X11.7919 Y4.4993 Z-0.0262
    X11.7933 Y4.4988 Z-0.0294
    X11.7952 Y4.4982 Z-0.0322
    X11.7976 Y4.4974 Z-0.0347
    X11.8003 Y4.4966 Z-0.0367
    X11.8033 Y4.4956 Z-0.0382
    X11.8065 Y4.4945 Z-0.0391
    X11.8098 Y4.4935 Z-0.0394
    X11.8136 Y4.4925
    X11.8175 Y4.4922
    X13.1222
    X13.1261
    G2 X13.1511 Z-0.0144 K0.025
    G0 Z0.2
    X13.1389 Y4.5941
    G1 Z0.0787 F39.37
    Z-0.0194
    X13.1386 Y4.5942 Z-0.0228
    X13.1378 Y4.5945 Z-0.0262
    X13.1364 Y4.5949 Z-0.0294
    X13.1345 Y4.5955 Z-0.0322
    X13.1321 Y4.5963 Z-0.0347
    X13.1294 Y4.5972 Z-0.0367
    X13.1264 Y4.5982 Z-0.0382
    X13.1232 Y4.5992 Z-0.0391
    X13.1199 Y4.6003 Z-0.0394
    X13.1161 Y4.6012
    X13.1122 Y4.6015
    X11.8231
    X11.8221
    G3 X11.7971 Z-0.0144 K0.025
    G0 Z0.2
    X13.2908 Y4.4996
    G1 Z0.0787 F39.37
    Z-0.0194
    X13.2911 Y4.4995 Z-0.0228
    X13.2919 Y4.4993 Z-0.0262
    X13.2933 Y4.4988 Z-0.0294
    X13.2952 Y4.4982 Z-0.0322
    X13.2976 Y4.4974 Z-0.0347
    X13.3003 Y4.4966 Z-0.0367
    X13.3033 Y4.4956 Z-0.0382
    X13.3065 Y4.4945 Z-0.0391
    X13.3098 Y4.4935 Z-0.0394
    X13.3136 Y4.4925
    X13.3175 Y4.4922
    X14.1981
    G17 G3 X14.2109 Y4.505 J0.0128
    G1 Y4.5887
    G3 X14.1981 Y4.6015 I-0.0128
    G1 X13.3231
    X13.3221
    G18 G3 X13.2971 Z-0.0144 K0.025
    G0 Z0.2
    X4.7045
    G1 Z0.0394 F39.37
    Z-0.0537
    G3 X4.6795 Z-0.0787 I-0.025
    G1 X4.6747
    G1 X14.6062
    G1 Y4.9968
    G1 X3.3938
    G1 Y4.0969
    G1 X4.4862
    G1 X14.4021
    G1 Y4.7928
    G1 X3.5978
    G1 Y4.301
    G1 X4.7923
    G1 X4.8356 Y4.4269
    X4.8362 Y4.4308 Z-0.0784
    X4.8368 Y4.4346 Z-0.0775
    X4.8374 Y4.4382 Z-0.076
    X4.8379 Y4.4415 Z-0.074
    X4.8384 Y4.4444 Z-0.0714
    X4.8388 Y4.4469 Z-0.0684
    X4.8391 Y4.4489 Z-0.0651
    X4.8393 Y4.4504 Z-0.0615
    X4.8395 Y4.4513 Z-0.0577
    Y4.4516 Z-0.0537
    G0 Z0.2
    X4.8533 Y4.4996
    G1 Z0.0394 F39.37
    Z-0.0587
    X4.8536 Y4.4995 Z-0.0622
    X4.8544 Y4.4993 Z-0.0656
    X4.8558 Y4.4988 Z-0.0687
    X4.8577 Y4.4982 Z-0.0716
    X4.8601 Y4.4974 Z-0.0741
    X4.8628 Y4.4966 Z-0.0761
    X4.8658 Y4.4956 Z-0.0775
    X4.869 Y4.4945 Z-0.0784
    X4.8723 Y4.4935 Z-0.0787
    X4.8761 Y4.4925
    X4.88 Y4.4922
    X6.1847
    X6.1886
    G18 G2 X6.2136 Z-0.0537 K0.025
    G0 Z0.2
    X6.2014 Y4.5941
    G1 Z0.0394 F39.37
    Z-0.0587
    X6.2011 Y4.5942 Z-0.0622
    X6.2003 Y4.5945 Z-0.0656
    X6.1989 Y4.5949 Z-0.0687
    X6.197 Y4.5955 Z-0.0716
    X6.1946 Y4.5963 Z-0.0741
    X6.1919 Y4.5972 Z-0.0761
    X6.1889 Y4.5982 Z-0.0775
    X6.1857 Y4.5992 Z-0.0784
    X6.1824 Y4.6003 Z-0.0787
    X6.1786 Y4.6012
    X6.1747 Y4.6015
    X4.8856
    X4.8836
    G3 X4.8586 Z-0.0537 K0.025
    G0 Z0.2
    X4.7014 Y4.5941
    G1 Z0.0394 F39.37
    Z-0.0587
    X4.7011 Y4.5942 Z-0.0622
    X4.7003 Y4.5945 Z-0.0656
    X4.6989 Y4.5949 Z-0.0687
    X4.697 Y4.5955 Z-0.0716
    X4.6946 Y4.5963 Z-0.0741
    X4.6919 Y4.5972 Z-0.0761
    X4.6889 Y4.5982 Z-0.0775
    X4.6857 Y4.5992 Z-0.0784
    X4.6824 Y4.6003 Z-0.0787
    X4.6786 Y4.6012
    X4.6747 Y4.6015
    X3.8019
    G1 Y4.505
    G1 X4.6847
    X4.6886
    G18 G2 X4.7136 Z-0.0537 K0.025
    G0 Z0.2
    X6.3533 Y4.4996
    G1 Z0.0394 F39.37
    Z-0.0587
    X6.3536 Y4.4995 Z-0.0622
    X6.3544 Y4.4993 Z-0.0656
    X6.3558 Y4.4988 Z-0.0687
    X6.3577 Y4.4982 Z-0.0716
    X6.3601 Y4.4974 Z-0.0741
    X6.3628 Y4.4966 Z-0.0761
    X6.3658 Y4.4956 Z-0.0775
    X6.369 Y4.4945 Z-0.0784
    X6.3723 Y4.4935 Z-0.0787
    X6.3761 Y4.4925
    X6.38 Y4.4922
    X11.6222
    X11.6261
    G2 X11.6511 Z-0.0537 K0.025
    G0 Z0.2
    X11.6389 Y4.5941
    G1 Z0.0394 F39.37
    Z-0.0587
    X11.6386 Y4.5942 Z-0.0622
    X11.6378 Y4.5945 Z-0.0656
    X11.6364 Y4.5949 Z-0.0687
    X11.6345 Y4.5955 Z-0.0716
    X11.6321 Y4.5963 Z-0.0741
    X11.6294 Y4.5972 Z-0.0761
    X11.6264 Y4.5982 Z-0.0775
    X11.6232 Y4.5992 Z-0.0784
    X11.6199 Y4.6003 Z-0.0787
    X11.6161 Y4.6012
    X11.6122 Y4.6015
    X6.3856
    X6.3836
    G3 X6.3586 Z-0.0537 K0.025
    G0 Z0.2
    X11.7908 Y4.4996
    G1 Z0.0394 F39.37
    Z-0.0587
    X11.7911 Y4.4995 Z-0.0622
    X11.7919 Y4.4993 Z-0.0656
    X11.7933 Y4.4988 Z-0.0687
    X11.7952 Y4.4982 Z-0.0716
    X11.7976 Y4.4974 Z-0.0741
    X11.8003 Y4.4966 Z-0.0761
    X11.8033 Y4.4956 Z-0.0775
    X11.8065 Y4.4945 Z-0.0784
    X11.8098 Y4.4935 Z-0.0787
    X11.8136 Y4.4925
    X11.8175 Y4.4922
    X13.1222
    X13.1261
    G2 X13.1511 Z-0.0537 K0.025
    G0 Z0.2
    X13.1389 Y4.5941
    G1 Z0.0394 F39.37
    Z-0.0587
    X13.1386 Y4.5942 Z-0.0622
    X13.1378 Y4.5945 Z-0.0656
    X13.1364 Y4.5949 Z-0.0687
    X13.1345 Y4.5955 Z-0.0716
    X13.1321 Y4.5963 Z-0.0741
    X13.1294 Y4.5972 Z-0.0761
    X13.1264 Y4.5982 Z-0.0775
    X13.1232 Y4.5992 Z-0.0784
    X13.1199 Y4.6003 Z-0.0787
    X13.1161 Y4.6012
    X13.1122 Y4.6015
    X11.8231
    X11.8221
    G3 X11.7971 Z-0.0537 K0.025
    G0 Z0.2
    X13.2908 Y4.4996
    G1 Z0.0394 F39.37
    Z-0.0587
    X13.2911 Y4.4995 Z-0.0622
    X13.2919 Y4.4993 Z-0.0656
    X13.2933 Y4.4988 Z-0.0687
    X13.2952 Y4.4982 Z-0.0716
    X13.2976 Y4.4974 Z-0.0741
    X13.3003 Y4.4966 Z-0.0761
    X13.3033 Y4.4956 Z-0.0775
    X13.3065 Y4.4945 Z-0.0784
    X13.3098 Y4.4935 Z-0.0787
    X13.3136 Y4.4925
    X13.3175 Y4.4922
    X14.1981
    G1 Y4.5887
    G1 X13.3231
    X13.3221
    G18 G3 X13.2971 Z-0.0537 K0.025
    G0 Z0.2
    X4.7045
    G1 Z0 F39.37
    Z-0.0931
    G3 X4.6795 Z-0.1181 I-0.025
    G1 X4.6747
    G1 X14.6062
    G1 Y4.9968
    G1 X3.3938
    G1 Y4.0969
    G1 X4.4862
    G1 X14.4021
    G1 Y4.7928
    G1 X3.5978
    G1 Y4.301
    G1 X4.7923
    G1 X4.8356 Y4.4269
    X4.8362 Y4.4308 Z-0.1178
    X4.8368 Y4.4346 Z-0.1169
    X4.8374 Y4.4382 Z-0.1154
    X4.8379 Y4.4415 Z-0.1133
    X4.8384 Y4.4444 Z-0.1108
    X4.8388 Y4.4469 Z-0.1078
    X4.8391 Y4.4489 Z-0.1045
    X4.8393 Y4.4504 Z-0.1008
    X4.8395 Y4.4513 Z-0.097
    Y4.4516 Z-0.0931
    G0 Z0.2
    X4.8533 Y4.4996
    G1 Z0 F39.37
    Z-0.0981
    X4.8536 Y4.4995 Z-0.1016
    X4.8544 Y4.4993 Z-0.105
    X4.8558 Y4.4988 Z-0.1081
    X4.8577 Y4.4982 Z-0.111
    X4.8601 Y4.4974 Z-0.1134
    X4.8628 Y4.4966 Z-0.1154
    X4.8658 Y4.4956 Z-0.1169
    X4.869 Y4.4945 Z-0.1178
    X4.8723 Y4.4935 Z-0.1181
    X4.8761 Y4.4925
    X4.88 Y4.4922
    X6.1847
    X6.1886
    G18 G2 X6.2136 Z-0.0931 K0.025
    G0 Z0.2
    X6.2014 Y4.5941
    G1 Z0 F39.37
    Z-0.0981
    X6.2011 Y4.5942 Z-0.1016
    X6.2003 Y4.5945 Z-0.105
    X6.1989 Y4.5949 Z-0.1081
    X6.197 Y4.5955 Z-0.111
    X6.1946 Y4.5963 Z-0.1134
    X6.1919 Y4.5972 Z-0.1154
    X6.1889 Y4.5982 Z-0.1169
    X6.1857 Y4.5992 Z-0.1178
    X6.1824 Y4.6003 Z-0.1181
    X6.1786 Y4.6012
    X6.1747 Y4.6015
    X4.8856
    X4.8836
    G3 X4.8586 Z-0.0931 K0.025
    G0 Z0.2
    X4.7014 Y4.5941
    G1 Z0 F39.37
    Z-0.0981
    X4.7011 Y4.5942 Z-0.1016
    X4.7003 Y4.5945 Z-0.105
    X4.6989 Y4.5949 Z-0.1081
    X4.697 Y4.5955 Z-0.111
    X4.6946 Y4.5963 Z-0.1134
    X4.6919 Y4.5972 Z-0.1154
    X4.6889 Y4.5982 Z-0.1169
    X4.6857 Y4.5992 Z-0.1178
    X4.6824 Y4.6003 Z-0.1181
    X4.6786 Y4.6012
    X4.6747 Y4.6015
    X3.8019
    G1 Y4.505
    G1 X4.6847
    X4.6886
    G18 G2 X4.7136 Z-0.0931 K0.025
    G0 Z0.2
    X6.3533 Y4.4996
    G1 Z0 F39.37
    Z-0.0981
    X6.3536 Y4.4995 Z-0.1016
    X6.3544 Y4.4993 Z-0.105
    X6.3558 Y4.4988 Z-0.1081
    X6.3577 Y4.4982 Z-0.111
    X6.3601 Y4.4974 Z-0.1134
    X6.3628 Y4.4966 Z-0.1154
    X6.3658 Y4.4956 Z-0.1169
    X6.369 Y4.4945 Z-0.1178
    X6.3723 Y4.4935 Z-0.1181
    X6.3761 Y4.4925
    X6.38 Y4.4922
    X11.6222
    X11.6261
    G2 X11.6511 Z-0.0931 K0.025
    G0 Z0.2
    X11.6389 Y4.5941
    G1 Z0 F39.37
    Z-0.0981
    X11.6386 Y4.5942 Z-0.1016
    X11.6378 Y4.5945 Z-0.105
    X11.6364 Y4.5949 Z-0.1081
    X11.6345 Y4.5955 Z-0.111
    X11.6321 Y4.5963 Z-0.1134
    X11.6294 Y4.5972 Z-0.1154
    X11.6264 Y4.5982 Z-0.1169
    X11.6232 Y4.5992 Z-0.1178
    X11.6199 Y4.6003 Z-0.1181
    X11.6161 Y4.6012
    X11.6122 Y4.6015
    X6.3856
    X6.3836
    G3 X6.3586 Z-0.0931 K0.025
    G0 Z0.2
    X11.7908 Y4.4996
    G1 Z0 F39.37
    Z-0.0981
    X11.7911 Y4.4995 Z-0.1016
    X11.7919 Y4.4993 Z-0.105
    X11.7933 Y4.4988 Z-0.1081
    X11.7952 Y4.4982 Z-0.111
    X11.7976 Y4.4974 Z-0.1134
    X11.8003 Y4.4966 Z-0.1154
    X11.8033 Y4.4956 Z-0.1169
    X11.8065 Y4.4945 Z-0.1178
    X11.8098 Y4.4935 Z-0.1181
    X11.8136 Y4.4925
    X11.8175 Y4.4922
    X13.1222
    X13.1261
    G2 X13.1511 Z-0.0931 K0.025
    G0 Z0.2
    X13.1389 Y4.5941
    G1 Z0 F39.37
    Z-0.0981
    X13.1386 Y4.5942 Z-0.1016
    X13.1378 Y4.5945 Z-0.105
    X13.1364 Y4.5949 Z-0.1081
    X13.1345 Y4.5955 Z-0.111
    X13.1321 Y4.5963 Z-0.1134
    X13.1294 Y4.5972 Z-0.1154
    X13.1264 Y4.5982 Z-0.1169
    X13.1232 Y4.5992 Z-0.1178
    X13.1199 Y4.6003 Z-0.1181
    X13.1161 Y4.6012
    X13.1122 Y4.6015
    X11.8231
    X11.8221
    G3 X11.7971 Z-0.0931 K0.025
    G0 Z0.2
    X13.2908 Y4.4996
    G1 Z0 F39.37
    Z-0.0981
    X13.2911 Y4.4995 Z-0.1016
    X13.2919 Y4.4993 Z-0.105
    X13.2933 Y4.4988 Z-0.1081
    X13.2952 Y4.4982 Z-0.111
    X13.2976 Y4.4974 Z-0.1134
    X13.3003 Y4.4966 Z-0.1154
    X13.3033 Y4.4956 Z-0.1169
    X13.3065 Y4.4945 Z-0.1178
    X13.3098 Y4.4935 Z-0.1181
    X13.3136 Y4.4925
    X13.3175 Y4.4922
    X14.1981
    G1 Y4.5887
    G1 X13.3231
    X13.3221
    G18 G3 X13.2971 Z-0.0931 K0.025
    G0 Z0.2
    X4.7045
    G1 Z-0.0394 F39.37
    Z-0.1313
    G3 X4.6795 Z-0.1563 I-0.025
    G1 X4.6747
    G1 X14.6062
    G1 Y4.9968
    G1 X3.3938
    G1 Y4.0969
    G1 X4.4862
    G1 X14.4021
    G1 Y4.7928
    G1 X3.5978
    G1 Y4.301
    G1 X4.7923
    G1 X4.8356 Y4.4269
    X4.8362 Y4.4308 Z-0.1559
    X4.8368 Y4.4346 Z-0.155
    X4.8374 Y4.4382 Z-0.1535
    X4.8379 Y4.4415 Z-0.1515
    X4.8384 Y4.4444 Z-0.1489
    X4.8388 Y4.4469 Z-0.1459
    X4.8391 Y4.4489 Z-0.1426
    X4.8393 Y4.4504 Z-0.139
    X4.8395 Y4.4513 Z-0.1352
    Y4.4516 Z-0.1313
    G0 Z0.2
    X4.8533 Y4.4996
    G1 Z-0.0394 F39.37
    Z-0.1363
    X4.8536 Y4.4995 Z-0.1397
    X4.8544 Y4.4993 Z-0.1431
    X4.8558 Y4.4988 Z-0.1463
    X4.8577 Y4.4982 Z-0.1491
    X4.8601 Y4.4974 Z-0.1516
    X4.8628 Y4.4966 Z-0.1536
    X4.8658 Y4.4956 Z-0.155
    X4.869 Y4.4945 Z-0.1559
    X4.8723 Y4.4935 Z-0.1563
    X4.8761 Y4.4925
    X4.88 Y4.4922
    X6.1847
    X6.1886
    G18 G2 X6.2136 Z-0.1313 K0.025
    G0 Z0.2
    X6.2014 Y4.5941
    G1 Z-0.0394 F39.37
    Z-0.1363
    X6.2011 Y4.5942 Z-0.1397
    X6.2003 Y4.5945 Z-0.1431
    X6.1989 Y4.5949 Z-0.1463
    X6.197 Y4.5955 Z-0.1491
    X6.1946 Y4.5963 Z-0.1516
    X6.1919 Y4.5972 Z-0.1536
    X6.1889 Y4.5982 Z-0.155
    X6.1857 Y4.5992 Z-0.1559
    X6.1824 Y4.6003 Z-0.1563
    X6.1786 Y4.6012
    X6.1747 Y4.6015
    X4.8856
    X4.8836
    G3 X4.8586 Z-0.1313 K0.025
    G0 Z0.2
    X4.7014 Y4.5941
    G1 Z-0.0394 F39.37
    Z-0.1363
    X4.7011 Y4.5942 Z-0.1397
    X4.7003 Y4.5945 Z-0.1431
    X4.6989 Y4.5949 Z-0.1462
    X4.697 Y4.5955 Z-0.1491
    X4.6946 Y4.5963 Z-0.1516
    X4.6919 Y4.5972 Z-0.1536
    X4.6889 Y4.5982 Z-0.155
    X4.6857 Y4.5992 Z-0.1559
    X4.6824 Y4.6003 Z-0.1563
    X4.6786 Y4.6012
    X4.6747 Y4.6015
    X3.8019
    G1 Y4.505
    G1 X4.6847
    X4.6886
    G18 G2 X4.7136 Z-0.1313 K0.025
    G0 Z0.2
    X6.3533 Y4.4996
    G1 Z-0.0394 F39.37
    Z-0.1363
    X6.3536 Y4.4995 Z-0.1397
    X6.3544 Y4.4993 Z-0.1431
    X6.3558 Y4.4988 Z-0.1463
    X6.3577 Y4.4982 Z-0.1491
    X6.3601 Y4.4974 Z-0.1516
    X6.3628 Y4.4966 Z-0.1536
    X6.3658 Y4.4956 Z-0.155
    X6.369 Y4.4945 Z-0.1559
    X6.3723 Y4.4935 Z-0.1563
    X6.3761 Y4.4925
    X6.38 Y4.4922
    X11.6222
    X11.6261
    G2 X11.6511 Z-0.1313 K0.025
    G0 Z0.2
    X11.6389 Y4.5941
    G1 Z-0.0394 F39.37
    Z-0.1363
    X11.6386 Y4.5942 Z-0.1397
    X11.6378 Y4.5945 Z-0.1431
    X11.6364 Y4.5949 Z-0.1463
    X11.6345 Y4.5955 Z-0.1491
    X11.6321 Y4.5963 Z-0.1516
    X11.6294 Y4.5972 Z-0.1536
    X11.6264 Y4.5982 Z-0.155
    X11.6232 Y4.5992 Z-0.1559
    X11.6199 Y4.6003 Z-0.1563
    X11.6161 Y4.6012
    X11.6122 Y4.6015
    X6.3856
    X6.3836
    G3 X6.3586 Z-0.1313 K0.025
    G0 Z0.2
    X11.7908 Y4.4996
    G1 Z-0.0394 F39.37
    Z-0.1363
    X11.7911 Y4.4995 Z-0.1397
    X11.7919 Y4.4993 Z-0.1431
    X11.7933 Y4.4988 Z-0.1462
    X11.7952 Y4.4982 Z-0.1491
    X11.7976 Y4.4974 Z-0.1516
    X11.8003 Y4.4966 Z-0.1536
    X11.8033 Y4.4956 Z-0.155
    X11.8065 Y4.4945 Z-0.1559
    X11.8098 Y4.4935 Z-0.1563
    X11.8136 Y4.4925
    X11.8175 Y4.4922
    X13.1222
    X13.1261
    G2 X13.1511 Z-0.1313 K0.025
    G0 Z0.2
    X13.1389 Y4.5941
    G1 Z-0.0394 F39.37
    Z-0.1363
    X13.1386 Y4.5942 Z-0.1397
    X13.1378 Y4.5945 Z-0.1431
    X13.1364 Y4.5949 Z-0.1463
    X13.1345 Y4.5955 Z-0.1491
    X13.1321 Y4.5963 Z-0.1516
    X13.1294 Y4.5972 Z-0.1536
    X13.1264 Y4.5982 Z-0.155
    X13.1232 Y4.5992 Z-0.1559
    X13.1199 Y4.6003 Z-0.1563
    X13.1161 Y4.6012
    X13.1122 Y4.6015
    X11.8231
    X11.8221
    G3 X11.7971 Z-0.1313 K0.025
    G0 Z0.2
    X13.2908 Y4.4996
    G1 Z-0.0394 F39.37
    Z-0.1363
    X13.2911 Y4.4995 Z-0.1397
    X13.2919 Y4.4993 Z-0.1431
    X13.2933 Y4.4988 Z-0.1462
    X13.2952 Y4.4982 Z-0.1491
    X13.2976 Y4.4974 Z-0.1516
    X13.3003 Y4.4966 Z-0.1536
    X13.3033 Y4.4956 Z-0.155
    X13.3065 Y4.4945 Z-0.1559
    X13.3098 Y4.4935 Z-0.1563
    X13.3136 Y4.4925
    X13.3175 Y4.4922
    X14.1981
    G1 Y4.5887
    G1 X13.3231
    X13.3221
    G18 G3 X13.2971 Z-0.1313 K0.025
    G0 Z0.45
    G17
    (Pocket1)
    G0 X3.8037 Y11.6985
    Z0.45
    Z0.0787
    G1 Z-0.0144 F12
    X3.8067 Y11.6964 Z-0.0232
    X3.8099 Y11.6947 Z-0.032
    G3 X3.8272 Y11.694 Z-0.0394 I0.0096 J0.0231
    G1 X3.8644 Y11.7061 F39.37
    X3.8769 Y11.7233
    X3.877 Y11.7443
    X3.8624 Y11.7633
    X3.8211 Y11.7767
    X3.737 Y11.7754
    X3.7 Y11.7633
    X3.6894 Y11.7506
    X3.6863 Y11.7463
    X3.686 Y11.7231
    X3.6988 Y11.7058
    X3.7401 Y11.6924
    X3.8208 Y11.6919
    X3.8272 Y11.694
    G3 X3.8462 Y11.7478 I-0.0111 J0.0341
    G1 X3.8347 Y11.7654
    Z-0.0537 F12
    X3.8325 Y11.7683 Z-0.0626
    X3.8299 Y11.7708 Z-0.0714
    G3 X3.8135 Y11.7766 Z-0.0787 I-0.0159 J-0.0193
    G1 X3.737 Y11.7754 F39.37
    X3.7 Y11.7633
    X3.6894 Y11.7506
    X3.6863 Y11.7463
    X3.686 Y11.7231
    X3.6988 Y11.7058
    X3.7401 Y11.6924
    X3.8208 Y11.6919
    X3.8644 Y11.7061
    X3.8769 Y11.7233
    X3.877 Y11.7443
    X3.8624 Y11.7633
    X3.8211 Y11.7767
    X3.8135 Y11.7766
    G3 X3.7946 Y11.7031 I0.0006 J-0.0393
    G1 X3.8037 Y11.6985
    Z-0.0931 F12
    X3.8067 Y11.6964 Z-0.1019
    X3.8099 Y11.6947 Z-0.1108
    G3 X3.8272 Y11.694 Z-0.1181 I0.0096 J0.0231
    X3.8769 Y11.7233
    X3.877 Y11.7443
    X3.8624 Y11.7633
    X3.8211 Y11.7767
    X3.737 Y11.7754
    X3.7 Y11.7633
    X3.6894 Y11.7506
    X3.6863 Y11.7463
    X3.686 Y11.7231
    X3.6988 Y11.7058
    X3.7401 Y11.6924
    X3.8208 Y11.6919
    X3.8272 Y11.694
    G3 X3.8265 Y11.7056 I-0.0018 J0.0057
    G1 X3.8086 Y11.709
    G3 X3.8037 Y11.6985 I-0.0011 J-0.0059
    G1 Z-0.1325 F12
    X3.8067 Y11.6964 Z-0.1413
    X3.8099 Y11.6947 Z-0.1502
    G3 X3.8272 Y11.694 Z-0.1575 I0.0096 J0.0231
    X3.8769 Y11.7233
    X3.877 Y11.7443
    X3.8624 Y11.7633
    X3.8211 Y11.7767
    X3.737 Y11.7754
    X3.7 Y11.7633
    X3.6894 Y11.7506
    X3.6863 Y11.7463
    X3.686 Y11.7231
    X3.6988 Y11.7058
    X3.7401 Y11.6924
    X3.8208 Y11.6919
    X3.8272 Y11.694
    G1 X3.8086 Y11.709
    G1 Z-0.1719 F12
    X3.8067 Y11.6964 Z-0.1807
    X3.8099 Y11.6947 Z-0.1895
    G3 X3.8272 Y11.694 Z-0.1969 I0.0096 J0.0231
    X3.8769 Y11.7233
    X3.877 Y11.7443
    X3.8624 Y11.7633
    X3.8211 Y11.7767
    X3.737 Y11.7754
    X3.7 Y11.7633
    X3.6894 Y11.7506
    X3.6863 Y11.7463
    X3.686 Y11.7231
    X3.6988 Y11.7058
    X3.7401 Y11.6924
    X3.8208 Y11.6919
    X3.8272 Y11.694
    G1 X3.8086 Y11.709
    G1 Z-0.2112 F12
    X3.8067 Y11.6964 Z-0.2201
    X3.8099 Y11.6947 Z-0.2289
    G3 X3.8272 Y11.694 Z-0.2362 I0.0096 J0.0231
    X3.8769 Y11.7233
    X3.877 Y11.7443
    X3.8624 Y11.7633
    X3.8211 Y11.7767
    X3.737 Y11.7754
    X3.7 Y11.7633
    X3.6894 Y11.7506
    X3.6863 Y11.7463
    X3.686 Y11.7231
    X3.6988 Y11.7058
    X3.7401 Y11.6924
    X3.8208 Y11.6919
    X3.8272 Y11.694
    G1 X3.8086 Y11.709
    G1 Z-0.2506 F12
    X3.8067 Y11.6964 Z-0.2594
    X3.8099 Y11.6947 Z-0.2683
    G3 X3.8272 Y11.694 Z-0.2756 I0.0096 J0.0231
    X3.8769 Y11.7233
    X3.877 Y11.7443
    X3.8624 Y11.7633
    X3.8211 Y11.7767
    X3.737 Y11.7754
    X3.7 Y11.7633
    X3.6894 Y11.7506
    X3.6863 Y11.7463
    X3.686 Y11.7231
    X3.6988 Y11.7058
    X3.7401 Y11.6924
    X3.8208 Y11.6919
    X3.8272 Y11.694
    G1 X3.8086 Y11.709
    G1 Z-0.29 F12
    X3.8067 Y11.6964 Z-0.2988
    X3.8099 Y11.6947 Z-0.3076
    G3 X3.8272 Y11.694 Z-0.315 I0.0096 J0.0231
    X3.8769 Y11.7233
    X3.877 Y11.7443
    X3.8624 Y11.7633
    X3.8211 Y11.7767
    X3.737 Y11.7754
    X3.7 Y11.7633
    X3.6894 Y11.7506
    X3.6863 Y11.7463
    X3.686 Y11.7231
    X3.6988 Y11.7058
    X3.7401 Y11.6924
    X3.8208 Y11.6919
    X3.8272 Y11.694
    G1 X3.8086 Y11.709
    G1 Z-0.3293 F12
    X3.8067 Y11.6964 Z-0.3382
    X3.8099 Y11.6947 Z-0.347
    G3 X3.8272 Y11.694 Z-0.3543 I0.0096 J0.0231
    X3.8769 Y11.7233
    X3.877 Y11.7443
    X3.8624 Y11.7633
    X3.8211 Y11.7767
    X3.737 Y11.7754
    X3.7 Y11.7633
    X3.6894 Y11.7506
    X3.6863 Y11.7463
    X3.686 Y11.7231
    X3.6988 Y11.7058
    X3.7401 Y11.6924
    X3.8208 Y11.6919
    X3.8272 Y11.694
    G1 X3.8086 Y11.709
    G1 Z-0.3687 F12
    X3.8067 Y11.6964 Z-0.3775
    X3.8099 Y11.6947 Z-0.3864
    G3 X3.8272 Y11.694 Z-0.3937 I0.0096 J0.0231
    X3.8769 Y11.7233
    X3.877 Y11.7443
    X3.8624 Y11.7633
    X3.8211 Y11.7767
    X3.737 Y11.7754
    X3.7 Y11.7633
    X3.6894 Y11.7506
    X3.6863 Y11.7463
    X3.686 Y11.7231
    X3.6988 Y11.7058
    X3.7401 Y11.6924
    X3.8208 Y11.6919
    X3.8272 Y11.694
    G1 X3.8086 Y11.709
    G1 Z-0.4081 F12
    X3.8067 Y11.6964 Z-0.4169
    X3.8099 Y11.6947 Z-0.4257
    G3 X3.8272 Y11.694 Z-0.4331 I0.0096 J0.0231
    X3.8769 Y11.7233
    X3.877 Y11.7443
    X3.8624 Y11.7633
    X3.8211 Y11.7767
    X3.737 Y11.7754
    X3.7 Y11.7633
    X3.6894 Y11.7506
    X3.6863 Y11.7463
    X3.686 Y11.7231
    X3.6988 Y11.7058
    X3.7401 Y11.6924
    X3.8208 Y11.6919
    X3.8272 Y11.694
    G1 X3.8086 Y11.709
    G1 Z-0.4474 F12
    X3.8067 Y11.6964 Z-0.4563
    X3.8099 Y11.6947 Z-0.4651
    G3 X3.8272 Y11.694 Z-0.4724 I0.0096 J0.0231
    X3.8769 Y11.7233
    X3.877 Y11.7443
    X3.8624 Y11.7633
    X3.8211 Y11.7767
    X3.737 Y11.7754
    X3.7 Y11.7633
    X3.6894 Y11.7506
    X3.6863 Y11.7463
    X3.686 Y11.7231
    X3.6988 Y11.7058
    X3.7401 Y11.6924
    X3.8208 Y11.6919
    X3.8272 Y11.694
    G1 X3.8086 Y11.709
    G1 Z-0.4868 F12
    X3.8067 Y11.6964 Z-0.4956
    X3.8099 Y11.6947 Z-0.5045
    G3 X3.8272 Y11.694 Z-0.5118 I0.0096 J0.0231
    X3.8769 Y11.7233
    X3.877 Y11.7443
    X3.8624 Y11.7633
    X3.8211 Y11.7767
    X3.737 Y11.7754
    X3.7 Y11.7633
    X3.6894 Y11.7506
    X3.6863 Y11.7463
    X3.686 Y11.7231
    X3.6988 Y11.7058
    X3.7401 Y11.6924
    X3.8208 Y11.6919
    X3.8272 Y11.694
    G1 X3.8086 Y11.709
    G1 Z-0.5262 F12
    X3.8067 Y11.6964 Z-0.535
    X3.8099 Y11.6947 Z-0.5439
    G3 X3.8272 Y11.694 Z-0.5512 I0.0096 J0.0231
    X3.8769 Y11.7233
    X3.877 Y11.7443
    X3.8624 Y11.7633
    X3.8211 Y11.7767
    X3.737 Y11.7754
    X3.7 Y11.7633
    X3.6894 Y11.7506
    X3.6863 Y11.7463
    X3.686 Y11.7231
    X3.6988 Y11.7058
    X3.7401 Y11.6924
    X3.8208 Y11.6919
    X3.8272 Y11.694
    X3.8203 Y11.6951
    X3.793 Y11.7036
    Z-0.5656 F12
    X3.7952 Y11.7007 Z-0.5744
    X3.7978 Y11.6981 Z-0.5832
    G3 X3.814 Y11.692 Z-0.5906 I0.0163 J0.0189
    G1 X3.8208 Y11.6919 F39.37
    X3.8644 Y11.7061
    X3.8769 Y11.7233
    X3.877 Y11.7443
    X3.8624 Y11.7633
    X3.8211 Y11.7767
    X3.737 Y11.7754
    X3.7 Y11.7633
    X3.6894 Y11.7506
    X3.6863 Y11.7463
    X3.686 Y11.7231
    X3.6988 Y11.7058
    X3.7401 Y11.6924
    X3.814 Y11.692
    G3 X3.8149 Y11.717 I0.0001 J0.0125
    G1 X3.8102 Y11.7173
    G3 X3.8056 Y11.6929 I-0.0008 J-0.0125
    X3.8147 Y11.7087 I0.0028 J0.0089
    G1 X3.8072 Y11.7155
    G3 X3.793 Y11.7036 I-0.0063 J-0.0069
    G1 Z-0.6049 F12
    X3.7952 Y11.7007 Z-0.6138
    X3.7978 Y11.6981 Z-0.6226
    G3 X3.814 Y11.692 Z-0.6299 I0.0163 J0.0189
    X3.8644 Y11.7061
    X3.8769 Y11.7233
    X3.877 Y11.7443
    X3.8624 Y11.7633
    X3.8211 Y11.7767
    X3.737 Y11.7754
    X3.7 Y11.7633
    X3.6894 Y11.7506
    X3.6863 Y11.7463
    X3.686 Y11.7231
    X3.6988 Y11.7058
    X3.7401 Y11.6924
    X3.814 Y11.692
    G1 X3.8102 Y11.7173
    G1 X3.8072 Y11.7155
    G1 Z-0.6443 F12
    X3.7952 Y11.7007 Z-0.6531
    X3.7978 Y11.6981 Z-0.662
    G3 X3.814 Y11.692 Z-0.6693 I0.0163 J0.0189
    X3.8644 Y11.7061
    X3.8769 Y11.7233
    X3.877 Y11.7443
    X3.8624 Y11.7633
    X3.8211 Y11.7767
    X3.737 Y11.7754
    X3.7 Y11.7633
    X3.6894 Y11.7506
    X3.6863 Y11.7463
    X3.686 Y11.7231
    X3.6988 Y11.7058
    X3.7401 Y11.6924
    X3.814 Y11.692
    G3 X3.8148 Y11.717 I0.0001 J0.0125
    G1 X3.8104 Y11.7172
    G3 X3.8061 Y11.6928 I-0.0008 J-0.0125
    X3.8147 Y11.709 I0.0027 J0.009
    G1 X3.8075 Y11.7149
    G3 X3.794 Y11.7021 I-0.006 J-0.0072
    G1 X3.7962 Y11.6995 Z-0.6775 F12
    X3.7987 Y11.6973 Z-0.6857
    G3 X3.814 Y11.692 Z-0.6925 I0.0154 J0.0197
    X3.8644 Y11.7061
    X3.8769 Y11.7233
    X3.877 Y11.7443
    X3.8624 Y11.7633
    X3.8211 Y11.7767
    X3.737 Y11.7754
    X3.7 Y11.7633
    X3.6894 Y11.7506
    X3.6863 Y11.7463
    X3.686 Y11.7231
    X3.6988 Y11.7058
    X3.7401 Y11.6924
    X3.814 Y11.692
    G3 X3.8302 Y11.6979 Z-0.6852 I0.0001 J0.025
    G1 X3.8329 Y11.7004 Z-0.6763
    X3.8351 Y11.7034 Z-0.6675
    G0 Z0.2
    Y7.0154
    Z0.0787
    G1 Z-0.0144 F12
    X3.8328 Y7.0183 Z-0.0232
    X3.8302 Y7.0209 Z-0.032
    G3 X3.814 Y7.0268 Z-0.0394 I-0.0161 J-0.0191
    G1 X3.741 Y7.0264 F39.37
    X3.6969 Y7.011
    X3.6854 Y6.9952
    Y6.9747
    X3.6978 Y6.9571
    X3.7407 Y6.9424
    X3.8208 Y6.9419
    X3.864 Y6.9559
    X3.8771 Y6.9747
    Y6.9952
    X3.8644 Y7.0127
    X3.8208 Y7.0268
    X3.814
    X3.8211 Y7.0148
    X3.8351 Y7.0154
    Z-0.0537 F12
    X3.8328 Y7.0183 Z-0.0626
    X3.8302 Y7.0209 Z-0.0714
    G3 X3.814 Y7.0268 Z-0.0787 I-0.0161 J-0.0191
    X3.6969 Y7.011
    X3.6854 Y6.9952
    Y6.9747
    X3.6978 Y6.9571
    X3.7407 Y6.9424
    X3.8208 Y6.9419
    X3.864 Y6.9559
    X3.8771 Y6.9747
    Y6.9952
    X3.8644 Y7.0127
    X3.8208 Y7.0268
    X3.814
    X3.8211 Y7.0148
    X3.8351 Y7.0154
    Z-0.0931 F12
    X3.8328 Y7.0183 Z-0.1019
    X3.8302 Y7.0209 Z-0.1108
    G3 X3.814 Y7.0268 Z-0.1181 I-0.0161 J-0.0191
    X3.6969 Y7.011
    X3.6854 Y6.9952
    Y6.9747
    X3.6978 Y6.9571
    X3.7407 Y6.9424
    X3.8208 Y6.9419
    X3.864 Y6.9559
    X3.8771 Y6.9747
    Y6.9952
    X3.8644 Y7.0127
    X3.8208 Y7.0268
    X3.814
    X3.8211 Y7.0148
    X3.8351 Y7.0154
    Z-0.1325 F12
    X3.8328 Y7.0183 Z-0.1413
    X3.8302 Y7.0209 Z-0.1502
    G3 X3.814 Y7.0268 Z-0.1575 I-0.0161 J-0.0191
    X3.6969 Y7.011
    X3.6854 Y6.9952
    Y6.9747
    X3.6978 Y6.9571
    X3.7407 Y6.9424
    X3.8208 Y6.9419
    X3.864 Y6.9559
    X3.8771 Y6.9747
    Y6.9952
    X3.8644 Y7.0127
    X3.8208 Y7.0268
    X3.814
    X3.8211 Y7.0148
    X3.8351 Y7.0154
    Z-0.1719 F12
    X3.8328 Y7.0183 Z-0.1807
    X3.8302 Y7.0209 Z-0.1895
    G3 X3.814 Y7.0268 Z-0.1969 I-0.0161 J-0.0191
    X3.6969 Y7.011
    X3.6854 Y6.9952
    Y6.9747
    X3.6978 Y6.9571
    X3.7407 Y6.9424
    X3.8208 Y6.9419
    X3.864 Y6.9559
    X3.8771 Y6.9747
    Y6.9952
    X3.8644 Y7.0127
    X3.8208 Y7.0268
    X3.814
    X3.8211 Y7.0148
    X3.8351 Y7.0154
    Z-0.2112 F12
    X3.8328 Y7.0183 Z-0.2201
    X3.8302 Y7.0209 Z-0.2289
    G3 X3.814 Y7.0268 Z-0.2362 I-0.0161 J-0.0191
    X3.6969 Y7.011
    X3.6854 Y6.9952
    Y6.9747
    X3.6978 Y6.9571
    X3.7407 Y6.9424
    X3.8208 Y6.9419
    X3.864 Y6.9559
    X3.8771 Y6.9747
    Y6.9952
    X3.8644 Y7.0127
    X3.8208 Y7.0268
    X3.814
    X3.8211 Y7.0148
    X3.8351 Y7.0154
    Z-0.2506 F12
    X3.8328 Y7.0183 Z-0.2594
    X3.8302 Y7.0209 Z-0.2683
    G3 X3.814 Y7.0268 Z-0.2756 I-0.0161 J-0.0191
    X3.6969 Y7.011
    X3.6854 Y6.9952
    Y6.9747
    X3.6978 Y6.9571
    X3.7407 Y6.9424
    X3.8208 Y6.9419
    X3.864 Y6.9559
    X3.8771 Y6.9747
    Y6.9952
    X3.8644 Y7.0127
    X3.8208 Y7.0268
    X3.814
    X3.8211 Y7.0148
    X3.8351 Y7.0154
    Z-0.29 F12
    X3.8328 Y7.0183 Z-0.2988
    X3.8302 Y7.0209 Z-0.3076
    G3 X3.814 Y7.0268 Z-0.315 I-0.0161 J-0.0191
    X3.6969 Y7.011
    X3.6854 Y6.9952
    Y6.9747
    X3.6978 Y6.9571
    X3.7407 Y6.9424
    X3.8208 Y6.9419
    X3.864 Y6.9559
    X3.8771 Y6.9747
    Y6.9952
    X3.8644 Y7.0127
    X3.8208 Y7.0268
    X3.814
    X3.8211 Y7.0148
    X3.8351 Y7.0154
    Z-0.3293 F12
    X3.8328 Y7.0183 Z-0.3382
    X3.8302 Y7.0209 Z-0.347
    G3 X3.814 Y7.0268 Z-0.3543 I-0.0161 J-0.0191
    X3.6969 Y7.011
    X3.6854 Y6.9952
    Y6.9747
    X3.6978 Y6.9571
    X3.7407 Y6.9424
    X3.8208 Y6.9419
    X3.864 Y6.9559
    X3.8771 Y6.9747
    Y6.9952
    X3.8644 Y7.0127
    X3.8208 Y7.0268
    X3.814
    X3.8211 Y7.0148
    X3.8351 Y7.0154
    Z-0.3687 F12
    X3.8328 Y7.0183 Z-0.3775
    X3.8302 Y7.0209 Z-0.3864
    G3 X3.814 Y7.0268 Z-0.3937 I-0.0161 J-0.0191
    X3.6969 Y7.011
    X3.6854 Y6.9952
    Y6.9747
    X3.6978 Y6.9571
    X3.7407 Y6.9424
    X3.8208 Y6.9419
    X3.864 Y6.9559
    X3.8771 Y6.9747
    Y6.9952
    X3.8644 Y7.0127
    X3.8208 Y7.0268
    X3.814
    X3.8211 Y7.0148
    X3.8351 Y7.0154
    Z-0.4081 F12
    X3.8328 Y7.0183 Z-0.4169
    X3.8302 Y7.0209 Z-0.4257
    G3 X3.814 Y7.0268 Z-0.4331 I-0.0161 J-0.0191
    X3.6969 Y7.011
    X3.6854 Y6.9952
    Y6.9747
    X3.6978 Y6.9571
    X3.7407 Y6.9424
    X3.8208 Y6.9419
    X3.864 Y6.9559
    X3.8771 Y6.9747
    Y6.9952
    X3.8644 Y7.0127
    X3.8208 Y7.0268
    X3.814
    X3.8211 Y7.0148
    X3.8351 Y7.0154
    Z-0.4474 F12
    X3.8328 Y7.0183 Z-0.4563
    X3.8302 Y7.0209 Z-0.4651
    G3 X3.814 Y7.0268 Z-0.4724 I-0.0161 J-0.0191
    X3.6969 Y7.011
    X3.6854 Y6.9952
    Y6.9747
    X3.6978 Y6.9571
    X3.7407 Y6.9424
    X3.8208 Y6.9419
    X3.864 Y6.9559
    X3.8771 Y6.9747
    Y6.9952
    X3.8644 Y7.0127
    X3.8208 Y7.0268
    X3.814
    X3.8211 Y7.0148
    X3.8351 Y7.0154
    Z-0.4868 F12
    X3.8328 Y7.0183 Z-0.4956
    X3.8302 Y7.0209 Z-0.5045
    G3 X3.814 Y7.0268 Z-0.5118 I-0.0161 J-0.0191
    X3.6969 Y7.011
    X3.6854 Y6.9952
    Y6.9747
    X3.6978 Y6.9571
    X3.7407 Y6.9424
    X3.8208 Y6.9419
    X3.864 Y6.9559
    X3.8771 Y6.9747
    Y6.9952
    X3.8644 Y7.0127
    X3.8208 Y7.0268
    X3.814
    X3.8211 Y7.0148
    X3.8351 Y7.0154
    Z-0.5262 F12
    X3.8328 Y7.0183 Z-0.535
    X3.8302 Y7.0209 Z-0.5439
    G3 X3.814 Y7.0268 Z-0.5512 I-0.0161 J-0.0191
    X3.6969 Y7.011
    X3.6854 Y6.9952
    Y6.9747
    X3.6978 Y6.9571
    X3.7407 Y6.9424
    X3.8208 Y6.9419
    X3.864 Y6.9559
    X3.8771 Y6.9747
    Y6.9952
    X3.8644 Y7.0127
    X3.8208 Y7.0268
    X3.814
    X3.8211 Y7.0148
    X3.8351 Y7.0154
    Z-0.5656 F12
    X3.8328 Y7.0183 Z-0.5744
    X3.8302 Y7.0209 Z-0.5832
    G3 X3.814 Y7.0268 Z-0.5906 I-0.0161 J-0.0191
    X3.6969 Y7.011
    X3.6854 Y6.9952
    Y6.9747
    X3.6978 Y6.9571
    X3.7407 Y6.9424
    X3.8208 Y6.9419
    X3.864 Y6.9559
    X3.8771 Y6.9747
    Y6.9952
    X3.8644 Y7.0127
    X3.8208 Y7.0268
    X3.814
    X3.8211 Y7.0148
    X3.8351 Y7.0154
    Z-0.6049 F12
    X3.8328 Y7.0183 Z-0.6138
    X3.8302 Y7.0209 Z-0.6226
    G3 X3.814 Y7.0268 Z-0.6299 I-0.0161 J-0.0191
    X3.6969 Y7.011
    X3.6854 Y6.9952
    Y6.9747
    X3.6978 Y6.9571
    X3.7407 Y6.9424
    X3.8208 Y6.9419
    X3.864 Y6.9559
    X3.8771 Y6.9747
    Y6.9952
    X3.8644 Y7.0127
    X3.8208 Y7.0268
    X3.814
    X3.8211 Y7.0148
    X3.8351 Y7.0154
    Z-0.6443 F12
    X3.8328 Y7.0183 Z-0.6531
    X3.8302 Y7.0209 Z-0.662
    G3 X3.814 Y7.0268 Z-0.6693 I-0.0161 J-0.0191
    X3.6969 Y7.011
    X3.6854 Y6.9952
    Y6.9747
    X3.6978 Y6.9571
    X3.7407 Y6.9424
    X3.8208 Y6.9419
    X3.864 Y6.9559
    X3.8771 Y6.9747
    Y6.9952
    X3.8644 Y7.0127
    X3.8208 Y7.0268
    X3.814
    X3.8209 Y7.0156
    X3.834 Y7.0169
    X3.8318 Y7.0194 Z-0.6775 F12
    X3.8292 Y7.0217 Z-0.6857
    G3 X3.814 Y7.0268 Z-0.6925 I-0.0151 J-0.0199
    X3.6969 Y7.011
    X3.6854 Y6.9952
    Y6.9747
    X3.6978 Y6.9571
    X3.7407 Y6.9424
    X3.8208 Y6.9419
    X3.864 Y6.9559
    X3.8771 Y6.9747
    Y6.9952
    X3.8644 Y7.0127
    X3.8208 Y7.0268
    X3.814
    G3 X3.7977 Y7.0207 Z-0.6852 I0.0001 J-0.025
    G1 X3.7952 Y7.0181 Z-0.6763
    X3.793 Y7.0152 Z-0.6675
    G0 Z0.2
    X3.8437 Y5.5073
    Z0.0787
    G1 Z-0.0144 F12
    X3.8425 Y5.5108 Z-0.0232
    X3.8409 Y5.514 Z-0.032
    G3 X3.8272 Y5.5247 Z-0.0394 I-0.0213 J-0.0131
    G1 X3.8208 Y5.5268 F39.37
    X3.7406 Y5.5264
    X3.6976 Y5.5117
    X3.6854 Y5.4948
    Y5.4735
    X3.6967 Y5.458
    X3.7411 Y5.4424
    X3.8208 Y5.4419
    X3.8644 Y5.4561
    X3.8771 Y5.4735
    Y5.4948
    X3.8642 Y5.5127
    X3.8272 Y5.5247
    G3 X3.8188 Y5.5012 I-0.0039 J-0.0119
    G1 X3.8232 Y5.4995
    G3 X3.835 Y5.5213 I0.0046 J0.0116
    X3.8215 Y5.509 I-0.0054 J-0.0076
    G1 X3.8266 Y5.5002
    G3 X3.8437 Y5.5073 I0.0081 J0.0047
    G1 Z-0.0537 F12
    X3.8425 Y5.5108 Z-0.0626
    X3.8409 Y5.514 Z-0.0714
    G3 X3.8272 Y5.5247 Z-0.0787 I-0.0213 J-0.0131
    X3.7406 Y5.5264
    X3.6976 Y5.5117
    X3.6854 Y5.4948
    Y5.4735
    X3.6967 Y5.458
    X3.7411 Y5.4424
    X3.8208 Y5.4419
    X3.8644 Y5.4561
    X3.8771 Y5.4735
    Y5.4948
    X3.8642 Y5.5127
    X3.8272 Y5.5247
    G1 X3.8232 Y5.4995
    G1 X3.8266 Y5.5002
    G1 Z-0.0931 F12
    X3.8425 Y5.5108 Z-0.1019
    X3.8409 Y5.514 Z-0.1108
    G3 X3.8272 Y5.5247 Z-0.1181 I-0.0213 J-0.0131
    X3.7406 Y5.5264
    X3.6976 Y5.5117
    X3.6854 Y5.4948
    Y5.4735
    X3.6967 Y5.458
    X3.7411 Y5.4424
    X3.8208 Y5.4419
    X3.8644 Y5.4561
    X3.8771 Y5.4735
    Y5.4948
    X3.8642 Y5.5127
    X3.8272 Y5.5247
    G1 X3.8232 Y5.4995
    G1 X3.8266 Y5.5002
    G1 Z-0.1325 F12
    X3.8425 Y5.5108 Z-0.1413
    X3.8409 Y5.514 Z-0.1502
    G3 X3.8272 Y5.5247 Z-0.1575 I-0.0213 J-0.0131
    X3.7406 Y5.5264
    X3.6976 Y5.5117
    X3.6854 Y5.4948
    Y5.4735
    X3.6967 Y5.458
    X3.7411 Y5.4424
    X3.8208 Y5.4419
    X3.8644 Y5.4561
    X3.8771 Y5.4735
    Y5.4948
    X3.8642 Y5.5127
    X3.8272 Y5.5247
    G1 X3.8232 Y5.4995
    G1 X3.8266 Y5.5002
    G1 Z-0.1719 F12
    X3.8425 Y5.5108 Z-0.1807
    X3.8409 Y5.514 Z-0.1895
    G3 X3.8272 Y5.5247 Z-0.1969 I-0.0213 J-0.0131
    X3.7406 Y5.5264
    X3.6976 Y5.5117
    X3.6854 Y5.4948
    Y5.4735
    X3.6967 Y5.458
    X3.7411 Y5.4424
    X3.8208 Y5.4419
    X3.8644 Y5.4561
    X3.8771 Y5.4735
    Y5.4948
    X3.8642 Y5.5127
    X3.8272 Y5.5247
    G1 X3.8232 Y5.4995
    G1 X3.8266 Y5.5002
    G1 Z-0.2112 F12
    X3.8425 Y5.5108 Z-0.2201
    X3.8409 Y5.514 Z-0.2289
    G3 X3.8272 Y5.5247 Z-0.2362 I-0.0213 J-0.0131
    X3.7406 Y5.5264
    X3.6976 Y5.5117
    X3.6854 Y5.4948
    Y5.4735
    X3.6967 Y5.458
    X3.7411 Y5.4424
    X3.8208 Y5.4419
    X3.8644 Y5.4561
    X3.8771 Y5.4735
    Y5.4948
    X3.8642 Y5.5127
    X3.8272 Y5.5247
    G1 X3.8232 Y5.4995
    G1 X3.8266 Y5.5002
    G1 Z-0.2506 F12
    X3.8425 Y5.5108 Z-0.2594
    X3.8409 Y5.514 Z-0.2683
    G3 X3.8272 Y5.5247 Z-0.2756 I-0.0213 J-0.0131
    X3.7406 Y5.5264
    X3.6976 Y5.5117
    X3.6854 Y5.4948
    Y5.4735
    X3.6967 Y5.458
    X3.7411 Y5.4424
    X3.8208 Y5.4419
    X3.8644 Y5.4561
    X3.8771 Y5.4735
    Y5.4948
    X3.8642 Y5.5127
    X3.8272 Y5.5247
    G1 X3.8232 Y5.4995
    G1 X3.8266 Y5.5002
    G1 Z-0.29 F12
    X3.8425 Y5.5108 Z-0.2988
    X3.8409 Y5.514 Z-0.3076
    G3 X3.8272 Y5.5247 Z-0.315 I-0.0213 J-0.0131
    X3.7406 Y5.5264
    X3.6976 Y5.5117
    X3.6854 Y5.4948
    Y5.4735
    X3.6967 Y5.458
    X3.7411 Y5.4424
    X3.8208 Y5.4419
    X3.8644 Y5.4561
    X3.8771 Y5.4735
    Y5.4948
    X3.8642 Y5.5127
    X3.8272 Y5.5247
    G1 X3.8232 Y5.4995
    G1 X3.8266 Y5.5002
    G1 Z-0.3293 F12
    X3.8425 Y5.5108 Z-0.3382
    X3.8409 Y5.514 Z-0.347
    G3 X3.8272 Y5.5247 Z-0.3543 I-0.0213 J-0.0131
    X3.7406 Y5.5264
    X3.6976 Y5.5117
    X3.6854 Y5.4948
    Y5.4735
    X3.6967 Y5.458
    X3.7411 Y5.4424
    X3.8208 Y5.4419
    X3.8644 Y5.4561
    X3.8771 Y5.4735
    Y5.4948
    X3.8642 Y5.5127
    X3.8272 Y5.5247
    G1 X3.8232 Y5.4995
    G1 X3.8266 Y5.5002
    G1 Z-0.3687 F12
    X3.8425 Y5.5108 Z-0.3775
    X3.8409 Y5.514 Z-0.3864
    G3 X3.8272 Y5.5247 Z-0.3937 I-0.0213 J-0.0131
    X3.7406 Y5.5264
    X3.6976 Y5.5117
    X3.6854 Y5.4948
    Y5.4735
    X3.6967 Y5.458
    X3.7411 Y5.4424
    X3.8208 Y5.4419
    X3.8644 Y5.4561
    X3.8771 Y5.4735
    Y5.4948
    X3.8642 Y5.5127
    X3.8272 Y5.5247
    G1 X3.8232 Y5.4995
    G1 X3.8266 Y5.5002
    G1 Z-0.4081 F12
    X3.8425 Y5.5108 Z-0.4169
    X3.8409 Y5.514 Z-0.4257
    G3 X3.8272 Y5.5247 Z-0.4331 I-0.0213 J-0.0131
    X3.7406 Y5.5264
    X3.6976 Y5.5117
    X3.6854 Y5.4948
    Y5.4735
    X3.6967 Y5.458
    X3.7411 Y5.4424
    X3.8208 Y5.4419
    X3.8644 Y5.4561
    X3.8771 Y5.4735
    Y5.4948
    X3.8642 Y5.5127
    X3.8272 Y5.5247
    G1 X3.8232 Y5.4995
    G1 X3.8266 Y5.5002
    G1 Z-0.4474 F12
    X3.8425 Y5.5108 Z-0.4563
    X3.8409 Y5.514 Z-0.4651
    G3 X3.8272 Y5.5247 Z-0.4724 I-0.0213 J-0.0131
    X3.7406 Y5.5264
    X3.6976 Y5.5117
    X3.6854 Y5.4948
    Y5.4735
    X3.6967 Y5.458
    X3.7411 Y5.4424
    X3.8208 Y5.4419
    X3.8644 Y5.4561
    X3.8771 Y5.4735
    Y5.4948
    X3.8642 Y5.5127
    X3.8272 Y5.5247
    G1 X3.8232 Y5.4995
    G1 X3.8266 Y5.5002
    G1 Z-0.4868 F12
    X3.8425 Y5.5108 Z-0.4956
    X3.8409 Y5.514 Z-0.5045
    G3 X3.8272 Y5.5247 Z-0.5118 I-0.0213 J-0.0131
    X3.7406 Y5.5264
    X3.6976 Y5.5117
    X3.6854 Y5.4948
    Y5.4735
    X3.6967 Y5.458
    X3.7411 Y5.4424
    X3.8208 Y5.4419
    X3.8644 Y5.4561
    X3.8771 Y5.4735
    Y5.4948
    X3.8642 Y5.5127
    X3.8272 Y5.5247
    G1 X3.8232 Y5.4995
    G1 X3.8266 Y5.5002
    G1 Z-0.5262 F12
    X3.8425 Y5.5108 Z-0.535
    X3.8409 Y5.514 Z-0.5439
    G3 X3.8272 Y5.5247 Z-0.5512 I-0.0213 J-0.0131
    X3.7406 Y5.5264
    X3.6976 Y5.5117
    X3.6854 Y5.4948
    Y5.4735
    X3.6967 Y5.458
    X3.7411 Y5.4424
    X3.8208 Y5.4419
    X3.8644 Y5.4561
    X3.8771 Y5.4735
    Y5.4948
    X3.8642 Y5.5127
    X3.8272 Y5.5247
    G1 X3.8232 Y5.4995
    G1 X3.8266 Y5.5002
    G1 Z-0.5656 F12
    X3.8425 Y5.5108 Z-0.5744
    X3.8409 Y5.514 Z-0.5832
    G3 X3.8272 Y5.5247 Z-0.5906 I-0.0213 J-0.0131
    X3.7406 Y5.5264
    X3.6976 Y5.5117
    X3.6854 Y5.4948
    Y5.4735
    X3.6967 Y5.458
    X3.7411 Y5.4424
    X3.8208 Y5.4419
    X3.8644 Y5.4561
    X3.8771 Y5.4735
    Y5.4948
    X3.8642 Y5.5127
    X3.8272 Y5.5247
    G1 X3.8232 Y5.4995
    G1 X3.8266 Y5.5002
    G1 Z-0.6049 F12
    X3.8425 Y5.5108 Z-0.6138
    X3.8409 Y5.514 Z-0.6226
    G3 X3.8272 Y5.5247 Z-0.6299 I-0.0213 J-0.0131
    X3.7406 Y5.5264
    X3.6976 Y5.5117
    X3.6854 Y5.4948
    Y5.4735
    X3.6967 Y5.458
    X3.7411 Y5.4424
    X3.8208 Y5.4419
    X3.8644 Y5.4561
    X3.8771 Y5.4735
    Y5.4948
    X3.8642 Y5.5127
    X3.8272 Y5.5247
    G1 X3.8232 Y5.4995
    G1 X3.8266 Y5.5002
    G1 Z-0.6443 F12
    X3.8425 Y5.5108 Z-0.6531
    X3.8409 Y5.514 Z-0.662
    G3 X3.8272 Y5.5247 Z-0.6693 I-0.0213 J-0.0131
    X3.7406 Y5.5264
    X3.6976 Y5.5117
    X3.6854 Y5.4948
    Y5.4735
    X3.6967 Y5.458
    X3.7411 Y5.4424
    X3.8208 Y5.4419
    X3.8644 Y5.4561
    X3.8771 Y5.4735
    Y5.4948
    X3.8642 Y5.5127
    X3.8272 Y5.5247
    X3.8284 Y5.5177
    X3.834 Y5.5169
    X3.8318 Y5.5194 Z-0.6775 F12
    X3.8292 Y5.5217 Z-0.6857
    G3 X3.814 Y5.5268 Z-0.6925 I-0.0151 J-0.0199
    G1 X3.7406 Y5.5264 F39.37
    X3.6976 Y5.5117
    X3.6854 Y5.4948
    Y5.4735
    X3.6967 Y5.458
    X3.7411 Y5.4424
    X3.8208 Y5.4419
    X3.8644 Y5.4561
    X3.8771 Y5.4735
    Y5.4948
    X3.8642 Y5.5127
    X3.8208 Y5.5268
    X3.814
    G3 X3.7977 Y5.5207 Z-0.6852 I0.0001 J-0.025
    G1 X3.7952 Y5.5181 Z-0.6763
    X3.793 Y5.5152 Z-0.6675
    G0 Z0.2
    X4.8206 Y4.4999
    Z0.0787
    G1 Z-0.0144 F12
    X4.8241 Y4.5008 Z-0.0232
    X4.8275 Y4.5022 Z-0.032
    G3 X4.8391 Y4.515 Z-0.0394 I-0.0115 J0.0222
    G1 X4.8437 Y4.5263 F39.37
    Y4.5999
    X4.8181 Y4.6619
    X4.7813 Y4.6772
    X4.7444 Y4.6619
    X4.7187 Y4.5999
    Y4.5249
    X4.7275 Y4.5037
    X4.7443 Y4.4631
    X4.7813 Y4.4478
    X4.818 Y4.463
    X4.8391 Y4.515
    G3 X4.816 Y4.5246 I-0.0116 J0.0047
    G1 X4.8139 Y4.5194
    G3 X4.8347 Y4.5063 I0.0115 J-0.0048
    X4.8228 Y4.5238 I-0.0082 J0.0072
    G1 X4.8148 Y4.5209
    G3 X4.8206 Y4.4999 I0.0037 J-0.0103
    G1 Z-0.0537 F12
    X4.8241 Y4.5008 Z-0.0626
    X4.8275 Y4.5022 Z-0.0714
    G3 X4.8391 Y4.515 Z-0.0787 I-0.0115 J0.0222
    Y4.5999
    X4.8181 Y4.6619
    X4.7813 Y4.6772
    X4.7444 Y4.6619
    X4.7187 Y4.5999
    Y4.5249
    X4.7275 Y4.5037
    X4.7443 Y4.4631
    X4.7813 Y4.4478
    X4.818 Y4.463
    X4.8391 Y4.515
    G1 X4.8139 Y4.5194
    G1 X4.8148 Y4.5209
    G1 Z-0.0931 F12
    X4.8241 Y4.5008 Z-0.1019
    X4.8275 Y4.5022 Z-0.1108
    G3 X4.8391 Y4.515 Z-0.1181 I-0.0115 J0.0222
    Y4.5999
    X4.8181 Y4.6619
    X4.7813 Y4.6772
    X4.7444 Y4.6619
    X4.7187 Y4.5999
    Y4.5249
    X4.7275 Y4.5037
    X4.7443 Y4.4631
    X4.7813 Y4.4478
    X4.818 Y4.463
    X4.8391 Y4.515
    G1 X4.8139 Y4.5194
    G1 X4.8148 Y4.5209
    G1 Z-0.1325 F12
    X4.8241 Y4.5008 Z-0.1413
    X4.8275 Y4.5022 Z-0.1502
    G3 X4.8391 Y4.515 Z-0.1575 I-0.0115 J0.0222
    Y4.5999
    X4.8181 Y4.6619
    X4.7813 Y4.6772
    X4.7444 Y4.6619
    X4.7187 Y4.5999
    Y4.5249
    X4.7275 Y4.5037
    X4.7443 Y4.4631
    X4.7813 Y4.4478
    X4.818 Y4.463
    X4.8391 Y4.515
    G1 X4.8139 Y4.5194
    G1 X4.8148 Y4.5209
    G1 Z-0.1719 F12
    X4.8241 Y4.5008 Z-0.1807
    X4.8275 Y4.5022 Z-0.1895
    G3 X4.8391 Y4.515 Z-0.1969 I-0.0115 J0.0222
    Y4.5999
    X4.8181 Y4.6619
    X4.7813 Y4.6772
    X4.7444 Y4.6619
    X4.7187 Y4.5999
    Y4.5249
    X4.7275 Y4.5037
    X4.7443 Y4.4631
    X4.7813 Y4.4478
    X4.818 Y4.463
    X4.8391 Y4.515
    G1 X4.8139 Y4.5194
    G1 X4.8148 Y4.5209
    G1 Z-0.2112 F12
    X4.8241 Y4.5008 Z-0.2201
    X4.8275 Y4.5022 Z-0.2289
    G3 X4.8391 Y4.515 Z-0.2362 I-0.0115 J0.0222
    Y4.5999
    X4.8181 Y4.6619
    X4.7813 Y4.6772
    X4.7444 Y4.6619
    X4.7187 Y4.5999
    Y4.5249
    X4.7275 Y4.5037
    X4.7443 Y4.4631
    X4.7813 Y4.4478
    X4.818 Y4.463
    X4.8391 Y4.515
    G1 X4.8139 Y4.5194
    G1 X4.8148 Y4.5209
    G1 Z-0.2506 F12
    X4.8241 Y4.5008 Z-0.2594
    X4.8275 Y4.5022 Z-0.2683
    G3 X4.8391 Y4.515 Z-0.2756 I-0.0115 J0.0222
    Y4.5999
    X4.8181 Y4.6619
    X4.7813 Y4.6772
    X4.7444 Y4.6619
    X4.7187 Y4.5999
    Y4.5249
    X4.7275 Y4.5037
    X4.7443 Y4.4631
    X4.7813 Y4.4478
    X4.818 Y4.463
    X4.8391 Y4.515
    G1 X4.8139 Y4.5194
    G1 X4.8148 Y4.5209
    G1 Z-0.29 F12
    X4.8241 Y4.5008 Z-0.2988
    X4.8275 Y4.5022 Z-0.3076
    G3 X4.8391 Y4.515 Z-0.315 I-0.0115 J0.0222
    Y4.5999
    X4.8181 Y4.6619
    X4.7813 Y4.6772
    X4.7444 Y4.6619
    X4.7187 Y4.5999
    Y4.5249
    X4.7275 Y4.5037
    X4.7443 Y4.4631
    X4.7813 Y4.4478
    X4.818 Y4.463
    X4.8391 Y4.515
    G1 X4.8139 Y4.5194
    G1 X4.8148 Y4.5209
    G1 Z-0.3293 F12
    X4.8241 Y4.5008 Z-0.3382
    X4.8275 Y4.5022 Z-0.347
    G3 X4.8391 Y4.515 Z-0.3543 I-0.0115 J0.0222
    Y4.5999
    X4.8181 Y4.6619
    X4.7813 Y4.6772
    X4.7444 Y4.6619
    X4.7187 Y4.5999
    Y4.5249
    X4.7275 Y4.5037
    X4.7443 Y4.4631
    X4.7813 Y4.4478
    X4.818 Y4.463
    X4.8391 Y4.515
    G1 X4.8139 Y4.5194
    G1 X4.8148 Y4.5209
    G1 Z-0.3687 F12
    X4.8241 Y4.5008 Z-0.3775
    X4.8275 Y4.5022 Z-0.3864
    G3 X4.8391 Y4.515 Z-0.3937 I-0.0115 J0.0222
    Y4.5999
    X4.8181 Y4.6619
    X4.7813 Y4.6772
    X4.7444 Y4.6619
    X4.7187 Y4.5999
    Y4.5249
    X4.7275 Y4.5037
    X4.7443 Y4.4631
    X4.7813 Y4.4478
    X4.818 Y4.463
    X4.8391 Y4.515
    G1 X4.8139 Y4.5194
    G1 X4.8148 Y4.5209
    G1 Z-0.4081 F12
    X4.8241 Y4.5008 Z-0.4169
    X4.8275 Y4.5022 Z-0.4257
    G3 X4.8391 Y4.515 Z-0.4331 I-0.0115 J0.0222
    Y4.5999
    X4.8181 Y4.6619
    X4.7813 Y4.6772
    X4.7444 Y4.6619
    X4.7187 Y4.5999
    Y4.5249
    X4.7275 Y4.5037
    X4.7443 Y4.4631
    X4.7813 Y4.4478
    X4.818 Y4.463
    X4.8391 Y4.515
    G1 X4.8139 Y4.5194
    G1 X4.8148 Y4.5209
    G1 Z-0.4474 F12
    X4.8241 Y4.5008 Z-0.4563
    X4.8275 Y4.5022 Z-0.4651
    G3 X4.8391 Y4.515 Z-0.4724 I-0.0115 J0.0222
    Y4.5999
    X4.8181 Y4.6619
    X4.7813 Y4.6772
    X4.7444 Y4.6619
    X4.7187 Y4.5999
    Y4.5249
    X4.7275 Y4.5037
    X4.7443 Y4.4631
    X4.7813 Y4.4478
    X4.818 Y4.463
    X4.8391 Y4.515
    G1 X4.8139 Y4.5194
    G1 X4.8148 Y4.5209
    G1 Z-0.4868 F12
    X4.8241 Y4.5008 Z-0.4956
    X4.8275 Y4.5022 Z-0.5045
    G3 X4.8391 Y4.515 Z-0.5118 I-0.0115 J0.0222
    Y4.5999
    X4.8181 Y4.6619
    X4.7813 Y4.6772
    X4.7444 Y4.6619
    X4.7187 Y4.5999
    Y4.5249
    X4.7275 Y4.5037
    X4.7443 Y4.4631
    X4.7813 Y4.4478
    X4.818 Y4.463
    X4.8391 Y4.515
    G1 X4.8139 Y4.5194
    G1 X4.8148 Y4.5209
    G1 Z-0.5262 F12
    X4.8241 Y4.5008 Z-0.535
    X4.8275 Y4.5022 Z-0.5439
    G3 X4.8391 Y4.515 Z-0.5512 I-0.0115 J0.0222
    Y4.5999
    X4.8181 Y4.6619
    X4.7813 Y4.6772
    X4.7444 Y4.6619
    X4.7187 Y4.5999
    Y4.5249
    X4.7275 Y4.5037
    X4.7443 Y4.4631
    X4.7813 Y4.4478
    X4.818 Y4.463
    X4.8391 Y4.515
    G1 X4.8139 Y4.5194
    G1 X4.8148 Y4.5209
    G1 Z-0.5656 F12
    X4.8241 Y4.5008 Z-0.5744
    X4.8275 Y4.5022 Z-0.5832
    G3 X4.8391 Y4.515 Z-0.5906 I-0.0115 J0.0222
    Y4.5999
    X4.8181 Y4.6619
    X4.7813 Y4.6772
    X4.7444 Y4.6619
    X4.7187 Y4.5999
    Y4.5249
    X4.7275 Y4.5037
    X4.7443 Y4.4631
    X4.7813 Y4.4478
    X4.818 Y4.463
    X4.8391 Y4.515
    G1 X4.8139 Y4.5194
    G1 X4.8148 Y4.5209
    G1 Z-0.6049 F12
    X4.8241 Y4.5008 Z-0.6138
    X4.8275 Y4.5022 Z-0.6226
    G3 X4.8391 Y4.515 Z-0.6299 I-0.0115 J0.0222
    Y4.5999
    X4.8181 Y4.6619
    X4.7813 Y4.6772
    X4.7444 Y4.6619
    X4.7187 Y4.5999
    Y4.5249
    X4.7275 Y4.5037
    X4.7443 Y4.4631
    X4.7813 Y4.4478
    X4.818 Y4.463
    X4.8391 Y4.515
    G1 X4.8139 Y4.5194
    G1 X4.8148 Y4.5209
    G1 Z-0.6443 F12
    X4.8241 Y4.5008 Z-0.6531
    X4.8275 Y4.5022 Z-0.662
    G3 X4.8391 Y4.515 Z-0.6693 I-0.0115 J0.0222
    Y4.5999
    X4.8181 Y4.6619
    X4.7813 Y4.6772
    X4.7444 Y4.6619
    X4.7187 Y4.5999
    Y4.5249
    X4.7275 Y4.5037
    X4.7443 Y4.4631
    X4.7813 Y4.4478
    X4.818 Y4.463
    X4.8391 Y4.515
    G3 X4.816 Y4.5245 I-0.0116 J0.0047
    G1 X4.814 Y4.5197
    G3 X4.8351 Y4.5068 I0.0115 J-0.0048
    X4.8224 Y4.5241 I-0.0084 J0.0071
    G1 X4.8152 Y4.521
    G3 X4.8223 Y4.5003 I0.0043 J-0.0101
    G1 X4.8255 Y4.5013 Z-0.6775 F12
    X4.8286 Y4.5028 Z-0.6857
    G3 X4.8391 Y4.515 Z-0.6925 I-0.0126 J0.0216
    Y4.5999
    X4.8181 Y4.6619
    X4.7813 Y4.6772
    X4.7444 Y4.6619
    X4.7187 Y4.5999
    Y4.5249
    X4.7275 Y4.5037
    X4.7443 Y4.4631
    X4.7813 Y4.4478
    X4.818 Y4.463
    X4.8391 Y4.515
    G3 X4.8397 Y4.5323 Z-0.6852 I-0.0232 J0.0094
    G1 X4.8383 Y4.5357 Z-0.6763
    X4.8364 Y4.5388 Z-0.6675
    G0 Z0.2
    X6.3363 Y4.5878
    Z0.0787
    G1 Z-0.0144 F12
    X6.3382 Y4.591 Z-0.0232
    X6.3395 Y4.5944 Z-0.032
    G3 X6.3389 Y4.6117 Z-0.0394 I-0.0238 J0.0078
    G1 X6.3181 Y4.6619 F39.37
    X6.2813 Y4.6772
    X6.2444 Y4.6619
    X6.219 Y4.6006
    X6.2205 Y4.5206
    X6.2443 Y4.4631
    X6.2813 Y4.4478
    X6.3181 Y4.4631
    X6.3432 Y4.5237
    X6.3437 Y4.6001
    X6.3389 Y4.6117
    X6.3305 Y4.6005
    X6.3363 Y4.5878
    Z-0.0537 F12
    X6.3382 Y4.591 Z-0.0626
    X6.3395 Y4.5944 Z-0.0714
    G3 X6.3389 Y4.6117 Z-0.0787 I-0.0238 J0.0078
    X6.2813 Y4.6772
    X6.2444 Y4.6619
    X6.219 Y4.6006
    X6.2205 Y4.5206
    X6.2443 Y4.4631
    X6.2813 Y4.4478
    X6.3181 Y4.4631
    X6.3432 Y4.5237
    X6.3437 Y4.6001
    X6.3389 Y4.6117
    X6.3305 Y4.6005
    X6.3363 Y4.5878
    Z-0.0931 F12
    X6.3382 Y4.591 Z-0.1019
    X6.3395 Y4.5944 Z-0.1108
    G3 X6.3389 Y4.6117 Z-0.1181 I-0.0238 J0.0078
    X6.2813 Y4.6772
    X6.2444 Y4.6619
    X6.219 Y4.6006
    X6.2205 Y4.5206
    X6.2443 Y4.4631
    X6.2813 Y4.4478
    X6.3181 Y4.4631
    X6.3432 Y4.5237
    X6.3437 Y4.6001
    X6.3389 Y4.6117
    X6.3305 Y4.6005
    X6.3363 Y4.5878
    Z-0.1325 F12
    X6.3382 Y4.591 Z-0.1413
    X6.3395 Y4.5944 Z-0.1502
    G3 X6.3389 Y4.6117 Z-0.1575 I-0.0238 J0.0078
    X6.2813 Y4.6772
    X6.2444 Y4.6619
    X6.219 Y4.6006
    X6.2205 Y4.5206
    X6.2443 Y4.4631
    X6.2813 Y4.4478
    X6.3181 Y4.4631
    X6.3432 Y4.5237
    X6.3437 Y4.6001
    X6.3389 Y4.6117
    X6.3305 Y4.6005
    X6.3363 Y4.5878
    Z-0.1719 F12
    X6.3382 Y4.591 Z-0.1807
    X6.3395 Y4.5944 Z-0.1895
    G3 X6.3389 Y4.6117 Z-0.1969 I-0.0238 J0.0078
    X6.2813 Y4.6772
    X6.2444 Y4.6619
    X6.219 Y4.6006
    X6.2205 Y4.5206
    X6.2443 Y4.4631
    X6.2813 Y4.4478
    X6.3181 Y4.4631
    X6.3432 Y4.5237
    X6.3437 Y4.6001
    X6.3389 Y4.6117
    X6.3305 Y4.6005
    X6.3363 Y4.5878
    Z-0.2112 F12
    X6.3382 Y4.591 Z-0.2201
    X6.3395 Y4.5944 Z-0.2289
    G3 X6.3389 Y4.6117 Z-0.2362 I-0.0238 J0.0078
    X6.2813 Y4.6772
    X6.2444 Y4.6619
    X6.219 Y4.6006
    X6.2205 Y4.5206
    X6.2443 Y4.4631
    X6.2813 Y4.4478
    X6.3181 Y4.4631
    X6.3432 Y4.5237
    X6.3437 Y4.6001
    X6.3389 Y4.6117
    X6.3305 Y4.6005
    X6.3363 Y4.5878
    Z-0.2506 F12
    X6.3382 Y4.591 Z-0.2594
    X6.3395 Y4.5944 Z-0.2683
    G3 X6.3389 Y4.6117 Z-0.2756 I-0.0238 J0.0078
    X6.2813 Y4.6772
    X6.2444 Y4.6619
    X6.219 Y4.6006
    X6.2205 Y4.5206
    X6.2443 Y4.4631
    X6.2813 Y4.4478
    X6.3181 Y4.4631
    X6.3432 Y4.5237
    X6.3437 Y4.6001
    X6.3389 Y4.6117
    X6.3305 Y4.6005
    X6.3363 Y4.5878
    Z-0.29 F12
    X6.3382 Y4.591 Z-0.2988
    X6.3395 Y4.5944 Z-0.3076
    G3 X6.3389 Y4.6117 Z-0.315 I-0.0238 J0.0078
    X6.2813 Y4.6772
    X6.2444 Y4.6619
    X6.219 Y4.6006
    X6.2205 Y4.5206
    X6.2443 Y4.4631
    X6.2813 Y4.4478
    X6.3181 Y4.4631
    X6.3432 Y4.5237
    X6.3437 Y4.6001
    X6.3389 Y4.6117
    X6.3305 Y4.6005
    X6.3363 Y4.5878
    Z-0.3293 F12
    X6.3382 Y4.591 Z-0.3382
    X6.3395 Y4.5944 Z-0.347
    G3 X6.3389 Y4.6117 Z-0.3543 I-0.0238 J0.0078
    X6.2813 Y4.6772
    X6.2444 Y4.6619
    X6.219 Y4.6006
    X6.2205 Y4.5206
    X6.2443 Y4.4631
    X6.2813 Y4.4478
    X6.3181 Y4.4631
    X6.3432 Y4.5237
    X6.3437 Y4.6001
    X6.3389 Y4.6117
    X6.3305 Y4.6005
    X6.3363 Y4.5878
    Z-0.3687 F12
    X6.3382 Y4.591 Z-0.3775
    X6.3395 Y4.5944 Z-0.3864
    G3 X6.3389 Y4.6117 Z-0.3937 I-0.0238 J0.0078
    X6.2813 Y4.6772
    X6.2444 Y4.6619
    X6.219 Y4.6006
    X6.2205 Y4.5206
    X6.2443 Y4.4631
    X6.2813 Y4.4478
    X6.3181 Y4.4631
    X6.3432 Y4.5237
    X6.3437 Y4.6001
    X6.3389 Y4.6117
    X6.3305 Y4.6005
    X6.3363 Y4.5878
    Z-0.4081 F12
    X6.3382 Y4.591 Z-0.4169
    X6.3395 Y4.5944 Z-0.4257
    G3 X6.3389 Y4.6117 Z-0.4331 I-0.0238 J0.0078
    X6.2813 Y4.6772
    X6.2444 Y4.6619
    X6.219 Y4.6006
    X6.2205 Y4.5206
    X6.2443 Y4.4631
    X6.2813 Y4.4478
    X6.3181 Y4.4631
    X6.3432 Y4.5237
    X6.3437 Y4.6001
    X6.3389 Y4.6117
    X6.3305 Y4.6005
    X6.3363 Y4.5878
    Z-0.4474 F12
    X6.3382 Y4.591 Z-0.4563
    X6.3395 Y4.5944 Z-0.4651
    G3 X6.3389 Y4.6117 Z-0.4724 I-0.0238 J0.0078
    X6.2813 Y4.6772
    X6.2444 Y4.6619
    X6.219 Y4.6006
    X6.2205 Y4.5206
    X6.2443 Y4.4631
    X6.2813 Y4.4478
    X6.3181 Y4.4631
    X6.3432 Y4.5237
    X6.3437 Y4.6001
    X6.3389 Y4.6117
    X6.3305 Y4.6005
    X6.3363 Y4.5878
    Z-0.4868 F12
    X6.3382 Y4.591 Z-0.4956
    X6.3395 Y4.5944 Z-0.5045
    G3 X6.3389 Y4.6117 Z-0.5118 I-0.0238 J0.0078
    X6.2813 Y4.6772
    X6.2444 Y4.6619
    X6.219 Y4.6006
    X6.2205 Y4.5206
    X6.2443 Y4.4631
    X6.2813 Y4.4478
    X6.3181 Y4.4631
    X6.3432 Y4.5237
    X6.3437 Y4.6001
    X6.3389 Y4.6117
    X6.3305 Y4.6005
    X6.3363 Y4.5878
    Z-0.5262 F12
    X6.3382 Y4.591 Z-0.535
    X6.3395 Y4.5944 Z-0.5439
    G3 X6.3389 Y4.6117 Z-0.5512 I-0.0238 J0.0078
    X6.2813 Y4.6772
    X6.2444 Y4.6619
    X6.219 Y4.6006
    X6.2205 Y4.5206
    X6.2443 Y4.4631
    X6.2813 Y4.4478
    X6.3181 Y4.4631
    X6.3432 Y4.5237
    X6.3437 Y4.6001
    X6.3389 Y4.6117
    X6.3305 Y4.6005
    X6.3363 Y4.5878
    Z-0.5656 F12
    X6.3382 Y4.591 Z-0.5744
    X6.3395 Y4.5944 Z-0.5832
    G3 X6.3389 Y4.6117 Z-0.5906 I-0.0238 J0.0078
    X6.2813 Y4.6772
    X6.2444 Y4.6619
    X6.219 Y4.6006
    X6.2205 Y4.5206
    X6.2443 Y4.4631
    X6.2813 Y4.4478
    X6.3181 Y4.4631
    X6.3432 Y4.5237
    X6.3437 Y4.6001
    X6.3389 Y4.6117
    X6.3305 Y4.6005
    X6.3363 Y4.5878
    Z-0.6049 F12
    X6.3382 Y4.591 Z-0.6138
    X6.3395 Y4.5944 Z-0.6226
    G3 X6.3389 Y4.6117 Z-0.6299 I-0.0238 J0.0078
    X6.2813 Y4.6772
    X6.2444 Y4.6619
    X6.219 Y4.6006
    X6.2205 Y4.5206
    X6.2443 Y4.4631
    X6.2813 Y4.4478
    X6.3181 Y4.4631
    X6.3432 Y4.5237
    X6.3437 Y4.6001
    X6.3389 Y4.6117
    X6.3305 Y4.6005
    X6.3363 Y4.5878
    Z-0.6443 F12
    X6.3382 Y4.591 Z-0.6531
    X6.3395 Y4.5944 Z-0.662
    G3 X6.3389 Y4.6117 Z-0.6693 I-0.0238 J0.0078
    X6.2813 Y4.6772
    X6.2444 Y4.6619
    X6.219 Y4.6006
    X6.2205 Y4.5206
    X6.2443 Y4.4631
    X6.2813 Y4.4478
    X6.3181 Y4.4631
    X6.3432 Y4.5237
    X6.3437 Y4.6001
    X6.3389 Y4.6117
    X6.3312 Y4.601
    X6.3373 Y4.5893
    X6.3388 Y4.5924 Z-0.6775 F12
    X6.3399 Y4.5956 Z-0.6857
    G3 X6.3389 Y4.6117 Z-0.6925 I-0.0241 J0.0065
    X6.2813 Y4.6772
    X6.2444 Y4.6619
    X6.219 Y4.6006
    X6.2205 Y4.5206
    X6.2443 Y4.4631
    X6.2813 Y4.4478
    X6.3181 Y4.4631
    X6.3432 Y4.5237
    X6.3437 Y4.6001
    X6.3389 Y4.6117
    G3 X6.3271 Y4.6244 Z-0.6852 I-0.0231 J-0.0095
    G1 X6.3238 Y4.6258 Z-0.6763
    X6.3202 Y4.6267 Z-0.6675
    G0 Z0.2
    X11.6678 Y4.6073
    Z0.0787
    G1 Z-0.0144 F12
    X11.6648 Y4.6051 Z-0.0232
    X11.6623 Y4.6025 Z-0.032
    G3 X11.6563 Y4.5863 Z-0.0394 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X11.6819 Y4.4631
    X11.7187 Y4.4478
    X11.7557 Y4.4631
    X11.7812 Y4.5248
    X11.7813 Y4.5993
    X11.7537 Y4.6627
    X11.7187 Y4.6772
    X11.6819 Y4.6619
    X11.6563 Y4.5999
    Y4.5863
    X11.6682 Y4.5934
    X11.6678 Y4.6073
    Z-0.0537 F12
    X11.6648 Y4.6051 Z-0.0626
    X11.6623 Y4.6025 Z-0.0714
    G3 X11.6563 Y4.5863 Z-0.0787 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X11.6819 Y4.4631
    X11.7187 Y4.4478
    X11.7557 Y4.4631
    X11.7812 Y4.5248
    X11.7813 Y4.5993
    X11.7537 Y4.6627
    X11.7187 Y4.6772
    X11.6819 Y4.6619
    X11.6563 Y4.5999
    Y4.5863
    X11.6682 Y4.5934
    X11.6678 Y4.6073
    Z-0.0931 F12
    X11.6648 Y4.6051 Z-0.1019
    X11.6623 Y4.6025 Z-0.1108
    G3 X11.6563 Y4.5863 Z-0.1181 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X11.6819 Y4.4631
    X11.7187 Y4.4478
    X11.7557 Y4.4631
    X11.7812 Y4.5248
    X11.7813 Y4.5993
    X11.7537 Y4.6627
    X11.7187 Y4.6772
    X11.6819 Y4.6619
    X11.6563 Y4.5999
    Y4.5863
    X11.6682 Y4.5934
    X11.6678 Y4.6073
    Z-0.1325 F12
    X11.6648 Y4.6051 Z-0.1413
    X11.6623 Y4.6025 Z-0.1502
    G3 X11.6563 Y4.5863 Z-0.1575 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X11.6819 Y4.4631
    X11.7187 Y4.4478
    X11.7557 Y4.4631
    X11.7812 Y4.5248
    X11.7813 Y4.5993
    X11.7537 Y4.6627
    X11.7187 Y4.6772
    X11.6819 Y4.6619
    X11.6563 Y4.5999
    Y4.5863
    X11.6682 Y4.5934
    X11.6678 Y4.6073
    Z-0.1719 F12
    X11.6648 Y4.6051 Z-0.1807
    X11.6623 Y4.6025 Z-0.1895
    G3 X11.6563 Y4.5863 Z-0.1969 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X11.6819 Y4.4631
    X11.7187 Y4.4478
    X11.7557 Y4.4631
    X11.7812 Y4.5248
    X11.7813 Y4.5993
    X11.7537 Y4.6627
    X11.7187 Y4.6772
    X11.6819 Y4.6619
    X11.6563 Y4.5999
    Y4.5863
    X11.6682 Y4.5934
    X11.6678 Y4.6073
    Z-0.2112 F12
    X11.6648 Y4.6051 Z-0.2201
    X11.6623 Y4.6025 Z-0.2289
    G3 X11.6563 Y4.5863 Z-0.2362 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X11.6819 Y4.4631
    X11.7187 Y4.4478
    X11.7557 Y4.4631
    X11.7812 Y4.5248
    X11.7813 Y4.5993
    X11.7537 Y4.6627
    X11.7187 Y4.6772
    X11.6819 Y4.6619
    X11.6563 Y4.5999
    Y4.5863
    X11.6682 Y4.5934
    X11.6678 Y4.6073
    Z-0.2506 F12
    X11.6648 Y4.6051 Z-0.2594
    X11.6623 Y4.6025 Z-0.2683
    G3 X11.6563 Y4.5863 Z-0.2756 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X11.6819 Y4.4631
    X11.7187 Y4.4478
    X11.7557 Y4.4631
    X11.7812 Y4.5248
    X11.7813 Y4.5993
    X11.7537 Y4.6627
    X11.7187 Y4.6772
    X11.6819 Y4.6619
    X11.6563 Y4.5999
    Y4.5863
    X11.6682 Y4.5934
    X11.6678 Y4.6073
    Z-0.29 F12
    X11.6648 Y4.6051 Z-0.2988
    X11.6623 Y4.6025 Z-0.3076
    G3 X11.6563 Y4.5863 Z-0.315 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X11.6819 Y4.4631
    X11.7187 Y4.4478
    X11.7557 Y4.4631
    X11.7812 Y4.5248
    X11.7813 Y4.5993
    X11.7537 Y4.6627
    X11.7187 Y4.6772
    X11.6819 Y4.6619
    X11.6563 Y4.5999
    Y4.5863
    X11.6682 Y4.5934
    X11.6678 Y4.6073
    Z-0.3293 F12
    X11.6648 Y4.6051 Z-0.3382
    X11.6623 Y4.6025 Z-0.347
    G3 X11.6563 Y4.5863 Z-0.3543 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X11.6819 Y4.4631
    X11.7187 Y4.4478
    X11.7557 Y4.4631
    X11.7812 Y4.5248
    X11.7813 Y4.5993
    X11.7537 Y4.6627
    X11.7187 Y4.6772
    X11.6819 Y4.6619
    X11.6563 Y4.5999
    Y4.5863
    X11.6682 Y4.5934
    X11.6678 Y4.6073
    Z-0.3687 F12
    X11.6648 Y4.6051 Z-0.3775
    X11.6623 Y4.6025 Z-0.3864
    G3 X11.6563 Y4.5863 Z-0.3937 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X11.6819 Y4.4631
    X11.7187 Y4.4478
    X11.7557 Y4.4631
    X11.7812 Y4.5248
    X11.7813 Y4.5993
    X11.7537 Y4.6627
    X11.7187 Y4.6772
    X11.6819 Y4.6619
    X11.6563 Y4.5999
    Y4.5863
    X11.6682 Y4.5934
    X11.6678 Y4.6073
    Z-0.4081 F12
    X11.6648 Y4.6051 Z-0.4169
    X11.6623 Y4.6025 Z-0.4257
    G3 X11.6563 Y4.5863 Z-0.4331 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X11.6819 Y4.4631
    X11.7187 Y4.4478
    X11.7557 Y4.4631
    X11.7812 Y4.5248
    X11.7813 Y4.5993
    X11.7537 Y4.6627
    X11.7187 Y4.6772
    X11.6819 Y4.6619
    X11.6563 Y4.5999
    Y4.5863
    X11.6682 Y4.5934
    X11.6678 Y4.6073
    Z-0.4474 F12
    X11.6648 Y4.6051 Z-0.4563
    X11.6623 Y4.6025 Z-0.4651
    G3 X11.6563 Y4.5863 Z-0.4724 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X11.6819 Y4.4631
    X11.7187 Y4.4478
    X11.7557 Y4.4631
    X11.7812 Y4.5248
    X11.7813 Y4.5993
    X11.7537 Y4.6627
    X11.7187 Y4.6772
    X11.6819 Y4.6619
    X11.6563 Y4.5999
    Y4.5863
    X11.6682 Y4.5934
    X11.6678 Y4.6073
    Z-0.4868 F12
    X11.6648 Y4.6051 Z-0.4956
    X11.6623 Y4.6025 Z-0.5045
    G3 X11.6563 Y4.5863 Z-0.5118 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X11.6819 Y4.4631
    X11.7187 Y4.4478
    X11.7557 Y4.4631
    X11.7812 Y4.5248
    X11.7813 Y4.5993
    X11.7537 Y4.6627
    X11.7187 Y4.6772
    X11.6819 Y4.6619
    X11.6563 Y4.5999
    Y4.5863
    X11.6682 Y4.5934
    X11.6678 Y4.6073
    Z-0.5262 F12
    X11.6648 Y4.6051 Z-0.535
    X11.6623 Y4.6025 Z-0.5439
    G3 X11.6563 Y4.5863 Z-0.5512 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X11.6819 Y4.4631
    X11.7187 Y4.4478
    X11.7557 Y4.4631
    X11.7812 Y4.5248
    X11.7813 Y4.5993
    X11.7537 Y4.6627
    X11.7187 Y4.6772
    X11.6819 Y4.6619
    X11.6563 Y4.5999
    Y4.5863
    X11.6682 Y4.5934
    X11.6678 Y4.6073
    Z-0.5656 F12
    X11.6648 Y4.6051 Z-0.5744
    X11.6623 Y4.6025 Z-0.5832
    G3 X11.6563 Y4.5863 Z-0.5906 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X11.6819 Y4.4631
    X11.7187 Y4.4478
    X11.7557 Y4.4631
    X11.7812 Y4.5248
    X11.7813 Y4.5993
    X11.7537 Y4.6627
    X11.7187 Y4.6772
    X11.6819 Y4.6619
    X11.6563 Y4.5999
    Y4.5863
    X11.6682 Y4.5934
    X11.6678 Y4.6073
    Z-0.6049 F12
    X11.6648 Y4.6051 Z-0.6138
    X11.6623 Y4.6025 Z-0.6226
    G3 X11.6563 Y4.5863 Z-0.6299 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X11.6819 Y4.4631
    X11.7187 Y4.4478
    X11.7557 Y4.4631
    X11.7812 Y4.5248
    X11.7813 Y4.5993
    X11.7537 Y4.6627
    X11.7187 Y4.6772
    X11.6819 Y4.6619
    X11.6563 Y4.5999
    Y4.5863
    X11.6682 Y4.5934
    X11.6678 Y4.6073
    Z-0.6443 F12
    X11.6648 Y4.6051 Z-0.6531
    X11.6623 Y4.6025 Z-0.662
    G3 X11.6563 Y4.5863 Z-0.6693 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X11.6819 Y4.4631
    X11.7187 Y4.4478
    X11.7557 Y4.4631
    X11.7812 Y4.5248
    X11.7813 Y4.5993
    X11.7537 Y4.6627
    X11.7187 Y4.6772
    X11.6819 Y4.6619
    X11.6563 Y4.5999
    Y4.5863
    X11.6675 Y4.5932
    X11.6663 Y4.6063
    X11.6637 Y4.6041 Z-0.6775 F12
    X11.6615 Y4.6015 Z-0.6857
    G3 X11.6563 Y4.5863 Z-0.6925 I0.0198 J-0.0153
    G1 Y4.5248 F39.37
    X11.6819 Y4.4631
    X11.7187 Y4.4478
    X11.7557 Y4.4631
    X11.7812 Y4.5248
    X11.7813 Y4.5993
    X11.7537 Y4.6627
    X11.7187 Y4.6772
    X11.6819 Y4.6619
    X11.6563 Y4.5999
    Y4.5863
    G3 X11.6623 Y4.57 Z-0.6852 I0.025
    G1 X11.6648 Y4.5674 Z-0.6763
    X11.6678 Y4.5652 Z-0.6675
    G0 Z0.2
    X13.1678 Y4.6085
    Z0.0787
    G1 Z-0.0144 F12
    X13.1648 Y4.6064 Z-0.0232
    X13.1623 Y4.6038 Z-0.032
    G3 X13.1563 Y4.5875 Z-0.0394 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X13.1783 Y4.4717
    X13.1819 Y4.4631
    X13.2187 Y4.4478
    X13.2557 Y4.4631
    X13.2812 Y4.5248
    X13.2813 Y4.5999
    X13.2556 Y4.6619
    X13.2187 Y4.6772
    X13.1819 Y4.6619
    X13.1563 Y4.5999
    Y4.5875
    X13.1682 Y4.5946
    X13.1678 Y4.6085
    Z-0.0537 F12
    X13.1648 Y4.6064 Z-0.0626
    X13.1623 Y4.6038 Z-0.0714
    G3 X13.1563 Y4.5875 Z-0.0787 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X13.1783 Y4.4717
    X13.1819 Y4.4631
    X13.2187 Y4.4478
    X13.2557 Y4.4631
    X13.2812 Y4.5248
    X13.2813 Y4.5999
    X13.2556 Y4.6619
    X13.2187 Y4.6772
    X13.1819 Y4.6619
    X13.1563 Y4.5999
    Y4.5875
    X13.1682 Y4.5946
    X13.1678 Y4.6085
    Z-0.0931 F12
    X13.1648 Y4.6064 Z-0.1019
    X13.1623 Y4.6038 Z-0.1108
    G3 X13.1563 Y4.5875 Z-0.1181 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X13.1783 Y4.4717
    X13.1819 Y4.4631
    X13.2187 Y4.4478
    X13.2557 Y4.4631
    X13.2812 Y4.5248
    X13.2813 Y4.5999
    X13.2556 Y4.6619
    X13.2187 Y4.6772
    X13.1819 Y4.6619
    X13.1563 Y4.5999
    Y4.5875
    X13.1682 Y4.5946
    X13.1678 Y4.6085
    Z-0.1325 F12
    X13.1648 Y4.6064 Z-0.1413
    X13.1623 Y4.6038 Z-0.1502
    G3 X13.1563 Y4.5875 Z-0.1575 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X13.1783 Y4.4717
    X13.1819 Y4.4631
    X13.2187 Y4.4478
    X13.2557 Y4.4631
    X13.2812 Y4.5248
    X13.2813 Y4.5999
    X13.2556 Y4.6619
    X13.2187 Y4.6772
    X13.1819 Y4.6619
    X13.1563 Y4.5999
    Y4.5875
    X13.1682 Y4.5946
    X13.1678 Y4.6085
    Z-0.1719 F12
    X13.1648 Y4.6064 Z-0.1807
    X13.1623 Y4.6038 Z-0.1895
    G3 X13.1563 Y4.5875 Z-0.1969 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X13.1783 Y4.4717
    X13.1819 Y4.4631
    X13.2187 Y4.4478
    X13.2557 Y4.4631
    X13.2812 Y4.5248
    X13.2813 Y4.5999
    X13.2556 Y4.6619
    X13.2187 Y4.6772
    X13.1819 Y4.6619
    X13.1563 Y4.5999
    Y4.5875
    X13.1682 Y4.5946
    X13.1678 Y4.6085
    Z-0.2112 F12
    X13.1648 Y4.6064 Z-0.2201
    X13.1623 Y4.6038 Z-0.2289
    G3 X13.1563 Y4.5875 Z-0.2362 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X13.1783 Y4.4717
    X13.1819 Y4.4631
    X13.2187 Y4.4478
    X13.2557 Y4.4631
    X13.2812 Y4.5248
    X13.2813 Y4.5999
    X13.2556 Y4.6619
    X13.2187 Y4.6772
    X13.1819 Y4.6619
    X13.1563 Y4.5999
    Y4.5875
    X13.1682 Y4.5946
    X13.1678 Y4.6085
    Z-0.2506 F12
    X13.1648 Y4.6064 Z-0.2594
    X13.1623 Y4.6038 Z-0.2683
    G3 X13.1563 Y4.5875 Z-0.2756 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X13.1783 Y4.4717
    X13.1819 Y4.4631
    X13.2187 Y4.4478
    X13.2557 Y4.4631
    X13.2812 Y4.5248
    X13.2813 Y4.5999
    X13.2556 Y4.6619
    X13.2187 Y4.6772
    X13.1819 Y4.6619
    X13.1563 Y4.5999
    Y4.5875
    X13.1682 Y4.5946
    X13.1678 Y4.6085
    Z-0.29 F12
    X13.1648 Y4.6064 Z-0.2988
    X13.1623 Y4.6038 Z-0.3076
    G3 X13.1563 Y4.5875 Z-0.315 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X13.1783 Y4.4717
    X13.1819 Y4.4631
    X13.2187 Y4.4478
    X13.2557 Y4.4631
    X13.2812 Y4.5248
    X13.2813 Y4.5999
    X13.2556 Y4.6619
    X13.2187 Y4.6772
    X13.1819 Y4.6619
    X13.1563 Y4.5999
    Y4.5875
    X13.1682 Y4.5946
    X13.1678 Y4.6085
    Z-0.3293 F12
    X13.1648 Y4.6064 Z-0.3382
    X13.1623 Y4.6038 Z-0.347
    G3 X13.1563 Y4.5875 Z-0.3543 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X13.1783 Y4.4717
    X13.1819 Y4.4631
    X13.2187 Y4.4478
    X13.2557 Y4.4631
    X13.2812 Y4.5248
    X13.2813 Y4.5999
    X13.2556 Y4.6619
    X13.2187 Y4.6772
    X13.1819 Y4.6619
    X13.1563 Y4.5999
    Y4.5875
    X13.1682 Y4.5946
    X13.1678 Y4.6085
    Z-0.3687 F12
    X13.1648 Y4.6064 Z-0.3775
    X13.1623 Y4.6038 Z-0.3864
    G3 X13.1563 Y4.5875 Z-0.3937 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X13.1783 Y4.4717
    X13.1819 Y4.4631
    X13.2187 Y4.4478
    X13.2557 Y4.4631
    X13.2812 Y4.5248
    X13.2813 Y4.5999
    X13.2556 Y4.6619
    X13.2187 Y4.6772
    X13.1819 Y4.6619
    X13.1563 Y4.5999
    Y4.5875
    X13.1682 Y4.5946
    X13.1678 Y4.6085
    Z-0.4081 F12
    X13.1648 Y4.6064 Z-0.4169
    X13.1623 Y4.6038 Z-0.4257
    G3 X13.1563 Y4.5875 Z-0.4331 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X13.1783 Y4.4717
    X13.1819 Y4.4631
    X13.2187 Y4.4478
    X13.2557 Y4.4631
    X13.2812 Y4.5248
    X13.2813 Y4.5999
    X13.2556 Y4.6619
    X13.2187 Y4.6772
    X13.1819 Y4.6619
    X13.1563 Y4.5999
    Y4.5875
    X13.1682 Y4.5946
    X13.1678 Y4.6085
    Z-0.4474 F12
    X13.1648 Y4.6064 Z-0.4563
    X13.1623 Y4.6038 Z-0.4651
    G3 X13.1563 Y4.5875 Z-0.4724 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X13.1783 Y4.4717
    X13.1819 Y4.4631
    X13.2187 Y4.4478
    X13.2557 Y4.4631
    X13.2812 Y4.5248
    X13.2813 Y4.5999
    X13.2556 Y4.6619
    X13.2187 Y4.6772
    X13.1819 Y4.6619
    X13.1563 Y4.5999
    Y4.5875
    X13.1682 Y4.5946
    X13.1678 Y4.6085
    Z-0.4868 F12
    X13.1648 Y4.6064 Z-0.4956
    X13.1623 Y4.6038 Z-0.5045
    G3 X13.1563 Y4.5875 Z-0.5118 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X13.1783 Y4.4717
    X13.1819 Y4.4631
    X13.2187 Y4.4478
    X13.2557 Y4.4631
    X13.2812 Y4.5248
    X13.2813 Y4.5999
    X13.2556 Y4.6619
    X13.2187 Y4.6772
    X13.1819 Y4.6619
    X13.1563 Y4.5999
    Y4.5875
    X13.1682 Y4.5946
    X13.1678 Y4.6085
    Z-0.5262 F12
    X13.1648 Y4.6064 Z-0.535
    X13.1623 Y4.6038 Z-0.5439
    G3 X13.1563 Y4.5875 Z-0.5512 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X13.1783 Y4.4717
    X13.1819 Y4.4631
    X13.2187 Y4.4478
    X13.2557 Y4.4631
    X13.2812 Y4.5248
    X13.2813 Y4.5999
    X13.2556 Y4.6619
    X13.2187 Y4.6772
    X13.1819 Y4.6619
    X13.1563 Y4.5999
    Y4.5875
    X13.1682 Y4.5946
    X13.1678 Y4.6085
    Z-0.5656 F12
    X13.1648 Y4.6064 Z-0.5744
    X13.1623 Y4.6038 Z-0.5832
    G3 X13.1563 Y4.5875 Z-0.5906 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X13.1783 Y4.4717
    X13.1819 Y4.4631
    X13.2187 Y4.4478
    X13.2557 Y4.4631
    X13.2812 Y4.5248
    X13.2813 Y4.5999
    X13.2556 Y4.6619
    X13.2187 Y4.6772
    X13.1819 Y4.6619
    X13.1563 Y4.5999
    Y4.5875
    X13.1682 Y4.5946
    X13.1678 Y4.6085
    Z-0.6049 F12
    X13.1648 Y4.6064 Z-0.6138
    X13.1623 Y4.6038 Z-0.6226
    G3 X13.1563 Y4.5875 Z-0.6299 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X13.1783 Y4.4717
    X13.1819 Y4.4631
    X13.2187 Y4.4478
    X13.2557 Y4.4631
    X13.2812 Y4.5248
    X13.2813 Y4.5999
    X13.2556 Y4.6619
    X13.2187 Y4.6772
    X13.1819 Y4.6619
    X13.1563 Y4.5999
    Y4.5875
    X13.1682 Y4.5946
    X13.1678 Y4.6085
    Z-0.6443 F12
    X13.1648 Y4.6064 Z-0.6531
    X13.1623 Y4.6038 Z-0.662
    G3 X13.1563 Y4.5875 Z-0.6693 I0.019 J-0.0162
    G1 Y4.5248 F39.37
    X13.1783 Y4.4717
    X13.1819 Y4.4631
    X13.2187 Y4.4478
    X13.2557 Y4.4631
    X13.2812 Y4.5248
    X13.2813 Y4.5999
    X13.2556 Y4.6619
    X13.2187 Y4.6772
    X13.1819 Y4.6619
    X13.1563 Y4.5999
    Y4.5875
    X13.1675 Y4.5944
    X13.1663 Y4.6075
    X13.1637 Y4.6053 Z-0.6775 F12
    X13.1615 Y4.6028 Z-0.6857
    G3 X13.1563 Y4.5875 Z-0.6925 I0.0198 J-0.0153
    G1 Y4.5248 F39.37
    X13.1783 Y4.4717
    X13.1819 Y4.4631
    X13.2187 Y4.4478
    X13.2557 Y4.4631
    X13.2812 Y4.5248
    X13.2813 Y4.5999
    X13.2556 Y4.6619
    X13.2187 Y4.6772
    X13.1819 Y4.6619
    X13.1563 Y4.5999
    Y4.5875
    G3 X13.1623 Y4.5713 Z-0.6852 I0.025
    G1 X13.1648 Y4.5687 Z-0.6763
    X13.1678 Y4.5665 Z-0.6675
    G0 Z0.2
    X14.1338 Y5.5203
    Z0.0787
    G1 Z-0.0144 F12
    X14.1308 Y5.5224 Z-0.0232
    X14.1276 Y5.524 Z-0.032
    G3 X14.1103 Y5.5247 Z-0.0394 I-0.0096 J-0.0231
    G1 X14.0733 Y5.5127 F39.37
    X14.0604 Y5.4948
    Y5.4735
    X14.0731 Y5.4561
    X14.1167 Y5.4419
    X14.1965 Y5.4424
    X14.2408 Y5.458
    X14.2521 Y5.4735
    Y5.4948
    X14.2399 Y5.5117
    X14.1969 Y5.5264
    X14.1167 Y5.5268
    X14.1103 Y5.5247
    G3 X14.111 Y5.5131 I0.0018 J-0.0057
    G1 X14.1289 Y5.5097
    G3 X14.1338 Y5.5203 I0.0011 J0.0059
    G1 Z-0.0537 F12
    X14.1308 Y5.5224 Z-0.0626
    X14.1276 Y5.524 Z-0.0714
    G3 X14.1103 Y5.5247 Z-0.0787 I-0.0096 J-0.0231
    X14.0604 Y5.4948
    Y5.4735
    X14.0731 Y5.4561
    X14.1167 Y5.4419
    X14.1965 Y5.4424
    X14.2408 Y5.458
    X14.2521 Y5.4735
    Y5.4948
    X14.2399 Y5.5117
    X14.1969 Y5.5264
    X14.1167 Y5.5268
    X14.1103 Y5.5247
    X14.1207 Y5.5155
    X14.1338 Y5.5203
    Z-0.0931 F12
    X14.1308 Y5.5224 Z-0.1019
    X14.1276 Y5.524 Z-0.1108
    G3 X14.1103 Y5.5247 Z-0.1181 I-0.0096 J-0.0231
    X14.0604 Y5.4948
    Y5.4735
    X14.0731 Y5.4561
    X14.1167 Y5.4419
    X14.1965 Y5.4424
    X14.2408 Y5.458
    X14.2521 Y5.4735
    Y5.4948
    X14.2399 Y5.5117
    X14.1969 Y5.5264
    X14.1167 Y5.5268
    X14.1103 Y5.5247
    G1 X14.1289 Y5.5097
    G1 Z-0.1325 F12
    X14.1308 Y5.5224 Z-0.1413
    X14.1276 Y5.524 Z-0.1502
    G3 X14.1103 Y5.5247 Z-0.1575 I-0.0096 J-0.0231
    X14.0604 Y5.4948
    Y5.4735
    X14.0731 Y5.4561
    X14.1167 Y5.4419
    X14.1965 Y5.4424
    X14.2408 Y5.458
    X14.2521 Y5.4735
    Y5.4948
    X14.2399 Y5.5117
    X14.1969 Y5.5264
    X14.1167 Y5.5268
    X14.1103 Y5.5247
    X14.1207 Y5.5155
    X14.1338 Y5.5203
    Z-0.1719 F12
    X14.1308 Y5.5224 Z-0.1807
    X14.1276 Y5.524 Z-0.1895
    G3 X14.1103 Y5.5247 Z-0.1969 I-0.0096 J-0.0231
    X14.0604 Y5.4948
    Y5.4735
    X14.0731 Y5.4561
    X14.1167 Y5.4419
    X14.1965 Y5.4424
    X14.2408 Y5.458
    X14.2521 Y5.4735
    Y5.4948
    X14.2399 Y5.5117
    X14.1969 Y5.5264
    X14.1167 Y5.5268
    X14.1103 Y5.5247
    G1 X14.1289 Y5.5097
    G1 Z-0.2112 F12
    X14.1308 Y5.5224 Z-0.2201
    X14.1276 Y5.524 Z-0.2289
    G3 X14.1103 Y5.5247 Z-0.2362 I-0.0096 J-0.0231
    X14.0604 Y5.4948
    Y5.4735
    X14.0731 Y5.4561
    X14.1167 Y5.4419
    X14.1965 Y5.4424
    X14.2408 Y5.458
    X14.2521 Y5.4735
    Y5.4948
    X14.2399 Y5.5117
    X14.1969 Y5.5264
    X14.1167 Y5.5268
    X14.1103 Y5.5247
    X14.1207 Y5.5155
    X14.1338 Y5.5203
    Z-0.2506 F12
    X14.1308 Y5.5224 Z-0.2594
    X14.1276 Y5.524 Z-0.2683
    G3 X14.1103 Y5.5247 Z-0.2756 I-0.0096 J-0.0231
    X14.0604 Y5.4948
    Y5.4735
    X14.0731 Y5.4561
    X14.1167 Y5.4419
    X14.1965 Y5.4424
    X14.2408 Y5.458
    X14.2521 Y5.4735
    Y5.4948
    X14.2399 Y5.5117
    X14.1969 Y5.5264
    X14.1167 Y5.5268
    X14.1103 Y5.5247
    G1 X14.1289 Y5.5097
    G1 Z-0.29 F12
    X14.1308 Y5.5224 Z-0.2988
    X14.1276 Y5.524 Z-0.3076
    G3 X14.1103 Y5.5247 Z-0.315 I-0.0096 J-0.0231
    X14.0604 Y5.4948
    Y5.4735
    X14.0731 Y5.4561
    X14.1167 Y5.4419
    X14.1965 Y5.4424
    X14.2408 Y5.458
    X14.2521 Y5.4735
    Y5.4948
    X14.2399 Y5.5117
    X14.1969 Y5.5264
    X14.1167 Y5.5268
    X14.1103 Y5.5247
    X14.1207 Y5.5155
    X14.1338 Y5.5203
    Z-0.3293 F12
    X14.1308 Y5.5224 Z-0.3382
    X14.1276 Y5.524 Z-0.347
    G3 X14.1103 Y5.5247 Z-0.3543 I-0.0096 J-0.0231
    X14.0604 Y5.4948
    Y5.4735
    X14.0731 Y5.4561
    X14.1167 Y5.4419
    X14.1965 Y5.4424
    X14.2408 Y5.458
    X14.2521 Y5.4735
    Y5.4948
    X14.2399 Y5.5117
    X14.1969 Y5.5264
    X14.1167 Y5.5268
    X14.1103 Y5.5247
    G1 X14.1289 Y5.5097
    G1 Z-0.3687 F12
    X14.1308 Y5.5224 Z-0.3775
    X14.1276 Y5.524 Z-0.3864
    G3 X14.1103 Y5.5247 Z-0.3937 I-0.0096 J-0.0231
    X14.0604 Y5.4948
    Y5.4735
    X14.0731 Y5.4561
    X14.1167 Y5.4419
    X14.1965 Y5.4424
    X14.2408 Y5.458
    X14.2521 Y5.4735
    Y5.4948
    X14.2399 Y5.5117
    X14.1969 Y5.5264
    X14.1167 Y5.5268
    X14.1103 Y5.5247
    X14.1207 Y5.5155
    X14.1338 Y5.5203
    Z-0.4081 F12
    X14.1308 Y5.5224 Z-0.4169
    X14.1276 Y5.524 Z-0.4257
    G3 X14.1103 Y5.5247 Z-0.4331 I-0.0096 J-0.0231
    X14.0604 Y5.4948
    Y5.4735
    X14.0731 Y5.4561
    X14.1167 Y5.4419
    X14.1965 Y5.4424
    X14.2408 Y5.458
    X14.2521 Y5.4735
    Y5.4948
    X14.2399 Y5.5117
    X14.1969 Y5.5264
    X14.1167 Y5.5268
    X14.1103 Y5.5247
    G1 X14.1289 Y5.5097
    G1 Z-0.4474 F12
    X14.1308 Y5.5224 Z-0.4563
    X14.1276 Y5.524 Z-0.4651
    G3 X14.1103 Y5.5247 Z-0.4724 I-0.0096 J-0.0231
    X14.0604 Y5.4948
    Y5.4735
    X14.0731 Y5.4561
    X14.1167 Y5.4419
    X14.1965 Y5.4424
    X14.2408 Y5.458
    X14.2521 Y5.4735
    Y5.4948
    X14.2399 Y5.5117
    X14.1969 Y5.5264
    X14.1167 Y5.5268
    X14.1103 Y5.5247
    X14.1207 Y5.5155
    X14.1338 Y5.5203
    Z-0.4868 F12
    X14.1308 Y5.5224 Z-0.4956
    X14.1276 Y5.524 Z-0.5045
    G3 X14.1103 Y5.5247 Z-0.5118 I-0.0096 J-0.0231
    X14.0604 Y5.4948
    Y5.4735
    X14.0731 Y5.4561
    X14.1167 Y5.4419
    X14.1965 Y5.4424
    X14.2408 Y5.458
    X14.2521 Y5.4735
    Y5.4948
    X14.2399 Y5.5117
    X14.1969 Y5.5264
    X14.1167 Y5.5268
    X14.1103 Y5.5247
    G1 X14.1289 Y5.5097
    G1 Z-0.5262 F12
    X14.1308 Y5.5224 Z-0.535
    X14.1276 Y5.524 Z-0.5439
    G3 X14.1103 Y5.5247 Z-0.5512 I-0.0096 J-0.0231
    X14.0604 Y5.4948
    Y5.4735
    X14.0731 Y5.4561
    X14.1167 Y5.4419
    X14.1965 Y5.4424
    X14.2408 Y5.458
    X14.2521 Y5.4735
    Y5.4948
    X14.2399 Y5.5117
    X14.1969 Y5.5264
    X14.1167 Y5.5268
    X14.1103 Y5.5247
    X14.1207 Y5.5155
    X14.1338 Y5.5203
    Z-0.5656 F12
    X14.1308 Y5.5224 Z-0.5744
    X14.1276 Y5.524 Z-0.5832
    G3 X14.1103 Y5.5247 Z-0.5906 I-0.0096 J-0.0231
    X14.0604 Y5.4948
    Y5.4735
    X14.0731 Y5.4561
    X14.1167 Y5.4419
    X14.1965 Y5.4424
    X14.2408 Y5.458
    X14.2521 Y5.4735
    Y5.4948
    X14.2399 Y5.5117
    X14.1969 Y5.5264
    X14.1167 Y5.5268
    X14.1103 Y5.5247
    G1 X14.1289 Y5.5097
    G1 Z-0.6049 F12
    X14.1308 Y5.5224 Z-0.6138
    X14.1276 Y5.524 Z-0.6226
    G3 X14.1103 Y5.5247 Z-0.6299 I-0.0096 J-0.0231
    X14.0604 Y5.4948
    Y5.4735
    X14.0731 Y5.4561
    X14.1167 Y5.4419
    X14.1965 Y5.4424
    X14.2408 Y5.458
    X14.2521 Y5.4735
    Y5.4948
    X14.2399 Y5.5117
    X14.1969 Y5.5264
    X14.1167 Y5.5268
    X14.1103 Y5.5247
    X14.1207 Y5.5155
    X14.1338 Y5.5203
    Z-0.6443 F12
    X14.1308 Y5.5224 Z-0.6531
    X14.1276 Y5.524 Z-0.662
    G3 X14.1103 Y5.5247 Z-0.6693 I-0.0096 J-0.0231
    X14.0604 Y5.4948
    Y5.4735
    X14.0731 Y5.4561
    X14.1167 Y5.4419
    X14.1965 Y5.4424
    X14.2408 Y5.458
    X14.2521 Y5.4735
    Y5.4948
    X14.2399 Y5.5117
    X14.1969 Y5.5264
    X14.1167 Y5.5268
    X14.1103 Y5.5247
    X14.1203 Y5.5162
    X14.1324 Y5.5213
    X14.1295 Y5.5231 Z-0.6775 F12
    X14.1264 Y5.5245 Z-0.6857
    G3 X14.1103 Y5.5247 Z-0.6925 I-0.0084 J-0.0235
    X14.0604 Y5.4948
    Y5.4735
    X14.0731 Y5.4561
    X14.1167 Y5.4419
    X14.1965 Y5.4424
    X14.2408 Y5.458
    X14.2521 Y5.4735
    Y5.4948
    X14.2399 Y5.5117
    X14.1969 Y5.5264
    X14.1167 Y5.5268
    X14.1103 Y5.5247
    G3 X14.0967 Y5.514 Z-0.6852 I0.0077 J-0.0238
    G1 X14.095 Y5.5108 Z-0.6763
    X14.0938 Y5.5073 Z-0.6675
    G0 Z0.2
    X14.1338 Y7.0203
    Z0.0787
    G1 Z-0.0144 F12
    X14.1308 Y7.0224 Z-0.0232
    X14.1276 Y7.024 Z-0.032
    G3 X14.1103 Y7.0247 Z-0.0394 I-0.0096 J-0.0231
    G1 X14.0731 Y7.0127 F39.37
    X14.0604 Y6.9952
    Y6.9747
    X14.0735 Y6.9559
    X14.1167 Y6.9419
    X14.1968 Y6.9424
    X14.2397 Y6.9571
    X14.2521 Y6.9747
    Y6.9952
    X14.2406 Y7.0109
    X14.1966 Y7.0264
    X14.1167 Y7.0268
    X14.1103 Y7.0247
    X14.1207 Y7.0155
    X14.1338 Y7.0203
    Z-0.0537 F12
    X14.1308 Y7.0224 Z-0.0626
    X14.1276 Y7.024 Z-0.0714
    G3 X14.1103 Y7.0247 Z-0.0787 I-0.0096 J-0.0231
    X14.0604 Y6.9952
    Y6.9747
    X14.0735 Y6.9559
    X14.1167 Y6.9419
    X14.1968 Y6.9424
    X14.2397 Y6.9571
    X14.2521 Y6.9747
    Y6.9952
    X14.2406 Y7.0109
    X14.1966 Y7.0264
    X14.1167 Y7.0268
    X14.1103 Y7.0247
    X14.1207 Y7.0155
    X14.1338 Y7.0203
    Z-0.0931 F12
    X14.1308 Y7.0224 Z-0.1019
    X14.1276 Y7.024 Z-0.1108
    G3 X14.1103 Y7.0247 Z-0.1181 I-0.0096 J-0.0231
    X14.0604 Y6.9952
    Y6.9747
    X14.0735 Y6.9559
    X14.1167 Y6.9419
    X14.1968 Y6.9424
    X14.2397 Y6.9571
    X14.2521 Y6.9747
    Y6.9952
    X14.2406 Y7.0109
    X14.1966 Y7.0264
    X14.1167 Y7.0268
    X14.1103 Y7.0247
    X14.1207 Y7.0155
    X14.1338 Y7.0203
    Z-0.1325 F12
    X14.1308 Y7.0224 Z-0.1413
    X14.1276 Y7.024 Z-0.1502
    G3 X14.1103 Y7.0247 Z-0.1575 I-0.0096 J-0.0231
    X14.0604 Y6.9952
    Y6.9747
    X14.0735 Y6.9559
    X14.1167 Y6.9419
    X14.1968 Y6.9424
    X14.2397 Y6.9571
    X14.2521 Y6.9747
    Y6.9952
    X14.2406 Y7.0109
    X14.1966 Y7.0264
    X14.1167 Y7.0268
    X14.1103 Y7.0247
    X14.1207 Y7.0155
    X14.1338 Y7.0203
    Z-0.1719 F12
    X14.1308 Y7.0224 Z-0.1807
    X14.1276 Y7.024 Z-0.1895
    G3 X14.1103 Y7.0247 Z-0.1969 I-0.0096 J-0.0231
    X14.0604 Y6.9952
    Y6.9747
    X14.0735 Y6.9559
    X14.1167 Y6.9419
    X14.1968 Y6.9424
    X14.2397 Y6.9571
    X14.2521 Y6.9747
    Y6.9952
    X14.2406 Y7.0109
    X14.1966 Y7.0264
    X14.1167 Y7.0268
    X14.1103 Y7.0247
    X14.1207 Y7.0155
    X14.1338 Y7.0203
    Z-0.2112 F12
    X14.1308 Y7.0224 Z-0.2201
    X14.1276 Y7.024 Z-0.2289
    G3 X14.1103 Y7.0247 Z-0.2362 I-0.0096 J-0.0231
    X14.0604 Y6.9952
    Y6.9747
    X14.0735 Y6.9559
    X14.1167 Y6.9419
    X14.1968 Y6.9424
    X14.2397 Y6.9571
    X14.2521 Y6.9747
    Y6.9952
    X14.2406 Y7.0109
    X14.1966 Y7.0264
    X14.1167 Y7.0268
    X14.1103 Y7.0247
    X14.1207 Y7.0155
    X14.1338 Y7.0203
    Z-0.2506 F12
    X14.1308 Y7.0224 Z-0.2594
    X14.1276 Y7.024 Z-0.2683
    G3 X14.1103 Y7.0247 Z-0.2756 I-0.0096 J-0.0231
    X14.0604 Y6.9952
    Y6.9747
    X14.0735 Y6.9559
    X14.1167 Y6.9419
    X14.1968 Y6.9424
    X14.2397 Y6.9571
    X14.2521 Y6.9747
    Y6.9952
    X14.2406 Y7.0109
    X14.1966 Y7.0264
    X14.1167 Y7.0268
    X14.1103 Y7.0247
    X14.1207 Y7.0155
    X14.1338 Y7.0203
    Z-0.29 F12
    X14.1308 Y7.0224 Z-0.2988
    X14.1276 Y7.024 Z-0.3076
    G3 X14.1103 Y7.0247 Z-0.315 I-0.0096 J-0.0231
    X14.0604 Y6.9952
    Y6.9747
    X14.0735 Y6.9559
    X14.1167 Y6.9419
    X14.1968 Y6.9424
    X14.2397 Y6.9571
    X14.2521 Y6.9747
    Y6.9952
    X14.2406 Y7.0109
    X14.1966 Y7.0264
    X14.1167 Y7.0268
    X14.1103 Y7.0247
    X14.1207 Y7.0155
    X14.1338 Y7.0203
    Z-0.3293 F12
    X14.1308 Y7.0224 Z-0.3382
    X14.1276 Y7.024 Z-0.347
    G3 X14.1103 Y7.0247 Z-0.3543 I-0.0096 J-0.0231
    X14.0604 Y6.9952
    Y6.9747
    X14.0735 Y6.9559
    X14.1167 Y6.9419
    X14.1968 Y6.9424
    X14.2397 Y6.9571
    X14.2521 Y6.9747
    Y6.9952
    X14.2406 Y7.0109
    X14.1966 Y7.0264
    X14.1167 Y7.0268
    X14.1103 Y7.0247
    X14.1207 Y7.0155
    X14.1338 Y7.0203
    Z-0.3687 F12
    X14.1308 Y7.0224 Z-0.3775
    X14.1276 Y7.024 Z-0.3864
    G3 X14.1103 Y7.0247 Z-0.3937 I-0.0096 J-0.0231
    X14.0604 Y6.9952
    Y6.9747
    X14.0735 Y6.9559
    X14.1167 Y6.9419
    X14.1968 Y6.9424
    X14.2397 Y6.9571
    X14.2521 Y6.9747
    Y6.9952
    X14.2406 Y7.0109
    X14.1966 Y7.0264
    X14.1167 Y7.0268
    X14.1103 Y7.0247
    X14.1172 Y7.0236
    X14.1445 Y7.0152
    Z-0.4081 F12
    X14.1423 Y7.0181 Z-0.4169
    X14.1398 Y7.0207 Z-0.4257
    G3 X14.1236 Y7.0268 Z-0.4331 I-0.0163 J-0.0189
    G1 X14.1167 F39.37
    X14.0731 Y7.0127
    X14.0604 Y6.9952
    Y6.9747
    X14.0735 Y6.9559
    X14.1167 Y6.9419
    X14.1968 Y6.9424
    X14.2397 Y6.9571
    X14.2521 Y6.9747
    Y6.9952
    X14.2406 Y7.0109
    X14.1966 Y7.0264
    X14.1236 Y7.0268
    X14.1272 Y7.0194
    X14.1338 Y7.0203
    Z-0.4474 F12
    X14.1308 Y7.0224 Z-0.4563
    X14.1276 Y7.024 Z-0.4651
    G3 X14.1103 Y7.0247 Z-0.4724 I-0.0096 J-0.0231
    X14.0604 Y6.9952
    Y6.9747
    X14.0735 Y6.9559
    X14.1167 Y6.9419
    X14.1968 Y6.9424
    X14.2397 Y6.9571
    X14.2521 Y6.9747
    Y6.9952
    X14.2406 Y7.0109
    X14.1966 Y7.0264
    X14.1167 Y7.0268
    X14.1103 Y7.0247
    X14.1207 Y7.0155
    X14.1338 Y7.0203
    Z-0.4868 F12
    X14.1308 Y7.0224 Z-0.4956
    X14.1276 Y7.024 Z-0.5045
    G3 X14.1103 Y7.0247 Z-0.5118 I-0.0096 J-0.0231
    X14.0604 Y6.9952
    Y6.9747
    X14.0735 Y6.9559
    X14.1167 Y6.9419
    X14.1968 Y6.9424
    X14.2397 Y6.9571
    X14.2521 Y6.9747
    Y6.9952
    X14.2406 Y7.0109
    X14.1966 Y7.0264
    X14.1167 Y7.0268
    X14.1103 Y7.0247
    X14.1207 Y7.0155
    X14.1338 Y7.0203
    Z-0.5262 F12
    X14.1308 Y7.0224 Z-0.535
    X14.1276 Y7.024 Z-0.5439
    G3 X14.1103 Y7.0247 Z-0.5512 I-0.0096 J-0.0231
    X14.0604 Y6.9952
    Y6.9747
    X14.0735 Y6.9559
    X14.1167 Y6.9419
    X14.1968 Y6.9424
    X14.2397 Y6.9571
    X14.2521 Y6.9747
    Y6.9952
    X14.2406 Y7.0109
    X14.1966 Y7.0264
    X14.1167 Y7.0268
    X14.1103 Y7.0247
    X14.1207 Y7.0155
    X14.1338 Y7.0203
    Z-0.5656 F12
    X14.1308 Y7.0224 Z-0.5744
    X14.1276 Y7.024 Z-0.5832
    G3 X14.1103 Y7.0247 Z-0.5906 I-0.0096 J-0.0231
    X14.0604 Y6.9952
    Y6.9747
    X14.0735 Y6.9559
    X14.1167 Y6.9419
    X14.1968 Y6.9424
    X14.2397 Y6.9571
    X14.2521 Y6.9747
    Y6.9952
    X14.2406 Y7.0109
    X14.1966 Y7.0264
    X14.1167 Y7.0268
    X14.1103 Y7.0247
    X14.1172 Y7.0236
    X14.1445 Y7.0152
    Z-0.6049 F12
    X14.1423 Y7.0181 Z-0.6138
    X14.1398 Y7.0207 Z-0.6226
    G3 X14.1236 Y7.0268 Z-0.6299 I-0.0163 J-0.0189
    G1 X14.1167 F39.37
    X14.0731 Y7.0127
    X14.0604 Y6.9952
    Y6.9747
    X14.0735 Y6.9559
    X14.1167 Y6.9419
    X14.1968 Y6.9424
    X14.2397 Y6.9571
    X14.2521 Y6.9747
    Y6.9952
    X14.2406 Y7.0109
    X14.1966 Y7.0264
    X14.1236 Y7.0268
    G3 X14.1227 Y7.0018 I-0.0001 J-0.0125
    G1 X14.1274 Y7.0015
    G3 X14.132 Y7.0259 I0.0008 J0.0125
    X14.1229 Y7.0101 I-0.0028 J-0.0089
    G1 X14.1304 Y7.0033
    G3 X14.1445 Y7.0152 I0.0063 J0.0069
    G1 Z-0.6443 F12
    X14.1423 Y7.0181 Z-0.6531
    X14.1398 Y7.0207 Z-0.662
    G3 X14.1236 Y7.0268 Z-0.6693 I-0.0163 J-0.0189
    G1 X14.1167 F39.37
    X14.0731 Y7.0127
    X14.0604 Y6.9952
    Y6.9747
    X14.0735 Y6.9559
    X14.1167 Y6.9419
    X14.1968 Y6.9424
    X14.2397 Y6.9571
    X14.2521 Y6.9747
    Y6.9952
    X14.2406 Y7.0109
    X14.1966 Y7.0264
    X14.1236 Y7.0268
    X14.1268 Y7.0204
    X14.1324 Y7.0213
    X14.1295 Y7.0231 Z-0.6775 F12
    X14.1264 Y7.0245 Z-0.6857
    G3 X14.1103 Y7.0247 Z-0.6925 I-0.0084 J-0.0235
    X14.0604 Y6.9952
    Y6.9747
    X14.0735 Y6.9559
    X14.1167 Y6.9419
    X14.1968 Y6.9424
    X14.2397 Y6.9571
    X14.2521 Y6.9747
    Y6.9952
    X14.2406 Y7.0109
    X14.1966 Y7.0264
    X14.1167 Y7.0268
    X14.1103 Y7.0247
    G3 X14.0967 Y7.014 Z-0.6852 I0.0077 J-0.0238
    G1 X14.095 Y7.0108 Z-0.6763
    X14.0938 Y7.0073 Z-0.6675
    G0 Z0.2
    X14.2086 Y11.7654
    Z0.0787
    G1 Z-0.0144 F12
    X14.2063 Y11.7683 Z-0.0232
    X14.2037 Y11.7709 Z-0.032
    G3 X14.1873 Y11.7765 Z-0.0394 I-0.0159 J-0.0193
    G1 X14.1109 Y11.775 F39.37
    X14.0751 Y11.7634
    X14.0605 Y11.7443
    X14.0606 Y11.7233
    X14.0731 Y11.7061
    X14.1167 Y11.6919
    X14.1974 Y11.6924
    X14.2387 Y11.7058
    X14.2515 Y11.7231
    X14.2512 Y11.7463
    X14.2395 Y11.7625
    X14.1941 Y11.7767
    X14.1873 Y11.7765
    X14.1947 Y11.7647
    X14.2086 Y11.7654
    Z-0.0537 F12
    X14.2063 Y11.7683 Z-0.0626
    X14.2037 Y11.7709 Z-0.0714
    G3 X14.1873 Y11.7765 Z-0.0787 I-0.0159 J-0.0193
    X14.0751 Y11.7634
    X14.0605 Y11.7443
    X14.0606 Y11.7233
    X14.0731 Y11.7061
    X14.1167 Y11.6919
    X14.1974 Y11.6924
    X14.2387 Y11.7058
    X14.2515 Y11.7231
    X14.2512 Y11.7463
    X14.2395 Y11.7625
    X14.1941 Y11.7767
    X14.1873 Y11.7765
    X14.1947 Y11.7647
    X14.2086 Y11.7654
    Z-0.0931 F12
    X14.2063 Y11.7683 Z-0.1019
    X14.2037 Y11.7709 Z-0.1108
    G3 X14.1873 Y11.7765 Z-0.1181 I-0.0159 J-0.0193
    X14.0751 Y11.7634
    X14.0605 Y11.7443
    X14.0606 Y11.7233
    X14.0731 Y11.7061
    X14.1167 Y11.6919
    X14.1974 Y11.6924
    X14.2387 Y11.7058
    X14.2515 Y11.7231
    X14.2512 Y11.7463
    X14.2395 Y11.7625
    X14.1941 Y11.7767
    X14.1873 Y11.7765
    X14.1947 Y11.7647
    X14.2086 Y11.7654
    Z-0.1325 F12
    X14.2063 Y11.7683 Z-0.1413
    X14.2037 Y11.7709 Z-0.1502
    G3 X14.1873 Y11.7765 Z-0.1575 I-0.0159 J-0.0193
    X14.0751 Y11.7634
    X14.0605 Y11.7443
    X14.0606 Y11.7233
    X14.0731 Y11.7061
    X14.1167 Y11.6919
    X14.1974 Y11.6924
    X14.2387 Y11.7058
    X14.2515 Y11.7231
    X14.2512 Y11.7463
    X14.2395 Y11.7625
    X14.1941 Y11.7767
    X14.1873 Y11.7765
    X14.1947 Y11.7647
    X14.2086 Y11.7654
    Z-0.1719 F12
    X14.2063 Y11.7683 Z-0.1807
    X14.2037 Y11.7709 Z-0.1895
    G3 X14.1873 Y11.7765 Z-0.1969 I-0.0159 J-0.0193
    X14.0751 Y11.7634
    X14.0605 Y11.7443
    X14.0606 Y11.7233
    X14.0731 Y11.7061
    X14.1167 Y11.6919
    X14.1974 Y11.6924
    X14.2387 Y11.7058
    X14.2515 Y11.7231
    X14.2512 Y11.7463
    X14.2395 Y11.7625
    X14.1941 Y11.7767
    X14.1873 Y11.7765
    X14.1947 Y11.7647
    X14.2086 Y11.7654
    Z-0.2112 F12
    X14.2063 Y11.7683 Z-0.2201
    X14.2037 Y11.7709 Z-0.2289
    G3 X14.1873 Y11.7765 Z-0.2362 I-0.0159 J-0.0193
    X14.0751 Y11.7634
    X14.0605 Y11.7443
    X14.0606 Y11.7233
    X14.0731 Y11.7061
    X14.1167 Y11.6919
    X14.1974 Y11.6924
    X14.2387 Y11.7058
    X14.2515 Y11.7231
    X14.2512 Y11.7463
    X14.2395 Y11.7625
    X14.1941 Y11.7767
    X14.1873 Y11.7765
    X14.1947 Y11.7647
    X14.2086 Y11.7654
    Z-0.2506 F12
    X14.2063 Y11.7683 Z-0.2594
    X14.2037 Y11.7709 Z-0.2683
    G3 X14.1873 Y11.7765 Z-0.2756 I-0.0159 J-0.0193
    X14.0751 Y11.7634
    X14.0605 Y11.7443
    X14.0606 Y11.7233
    X14.0731 Y11.7061
    X14.1167 Y11.6919
    X14.1974 Y11.6924
    X14.2387 Y11.7058
    X14.2515 Y11.7231
    X14.2512 Y11.7463
    X14.2395 Y11.7625
    X14.1941 Y11.7767
    X14.1873 Y11.7765
    X14.1947 Y11.7647
    X14.2086 Y11.7654
    Z-0.29 F12
    X14.2063 Y11.7683 Z-0.2988
    X14.2037 Y11.7709 Z-0.3076
    G3 X14.1873 Y11.7765 Z-0.315 I-0.0159 J-0.0193
    X14.0751 Y11.7634
    X14.0605 Y11.7443
    X14.0606 Y11.7233
    X14.0731 Y11.7061
    X14.1167 Y11.6919
    X14.1974 Y11.6924
    X14.2387 Y11.7058
    X14.2515 Y11.7231
    X14.2512 Y11.7463
    X14.2395 Y11.7625
    X14.1941 Y11.7767
    X14.1873 Y11.7765
    X14.1947 Y11.7647
    X14.2086 Y11.7654
    Z-0.3293 F12
    X14.2063 Y11.7683 Z-0.3382
    X14.2037 Y11.7709 Z-0.347
    G3 X14.1873 Y11.7765 Z-0.3543 I-0.0159 J-0.0193
    X14.0751 Y11.7634
    X14.0605 Y11.7443
    X14.0606 Y11.7233
    X14.0731 Y11.7061
    X14.1167 Y11.6919
    X14.1974 Y11.6924
    X14.2387 Y11.7058
    X14.2515 Y11.7231
    X14.2512 Y11.7463
    X14.2395 Y11.7625
    X14.1941 Y11.7767
    X14.1873 Y11.7765
    X14.1947 Y11.7647
    X14.2086 Y11.7654
    Z-0.3687 F12
    X14.2063 Y11.7683 Z-0.3775
    X14.2037 Y11.7709 Z-0.3864
    G3 X14.1873 Y11.7765 Z-0.3937 I-0.0159 J-0.0193
    X14.0751 Y11.7634
    X14.0605 Y11.7443
    X14.0606 Y11.7233
    X14.0731 Y11.7061
    X14.1167 Y11.6919
    X14.1974 Y11.6924
    X14.2387 Y11.7058
    X14.2515 Y11.7231
    X14.2512 Y11.7463
    X14.2395 Y11.7625
    X14.1941 Y11.7767
    X14.1873 Y11.7765
    X14.1947 Y11.7647
    X14.2086 Y11.7654
    Z-0.4081 F12
    X14.2063 Y11.7683 Z-0.4169
    X14.2037 Y11.7709 Z-0.4257
    G3 X14.1873 Y11.7765 Z-0.4331 I-0.0159 J-0.0193
    X14.0751 Y11.7634
    X14.0605 Y11.7443
    X14.0606 Y11.7233
    X14.0731 Y11.7061
    X14.1167 Y11.6919
    X14.1974 Y11.6924
    X14.2387 Y11.7058
    X14.2515 Y11.7231
    X14.2512 Y11.7463
    X14.2395 Y11.7625
    X14.1941 Y11.7767
    X14.1873 Y11.7765
    X14.1947 Y11.7647
    X14.2086 Y11.7654
    Z-0.4474 F12
    X14.2063 Y11.7683 Z-0.4563
    X14.2037 Y11.7709 Z-0.4651
    G3 X14.1873 Y11.7765 Z-0.4724 I-0.0159 J-0.0193
    X14.0751 Y11.7634
    X14.0605 Y11.7443
    X14.0606 Y11.7233
    X14.0731 Y11.7061
    X14.1167 Y11.6919
    X14.1974 Y11.6924
    X14.2387 Y11.7058
    X14.2515 Y11.7231
    X14.2512 Y11.7463
    X14.2395 Y11.7625
    X14.1941 Y11.7767
    X14.1873 Y11.7765
    X14.1947 Y11.7647
    X14.2086 Y11.7654
    Z-0.4868 F12
    X14.2063 Y11.7683 Z-0.4956
    X14.2037 Y11.7709 Z-0.5045
    G3 X14.1873 Y11.7765 Z-0.5118 I-0.0159 J-0.0193
    X14.0751 Y11.7634
    X14.0605 Y11.7443
    X14.0606 Y11.7233
    X14.0731 Y11.7061
    X14.1167 Y11.6919
    X14.1974 Y11.6924
    X14.2387 Y11.7058
    X14.2515 Y11.7231
    X14.2512 Y11.7463
    X14.2395 Y11.7625
    X14.1941 Y11.7767
    X14.1873 Y11.7765
    X14.1947 Y11.7647
    X14.2086 Y11.7654
    Z-0.5262 F12
    X14.2063 Y11.7683 Z-0.535
    X14.2037 Y11.7709 Z-0.5439
    G3 X14.1873 Y11.7765 Z-0.5512 I-0.0159 J-0.0193
    X14.0751 Y11.7634
    X14.0605 Y11.7443
    X14.0606 Y11.7233
    X14.0731 Y11.7061
    X14.1167 Y11.6919
    X14.1974 Y11.6924
    X14.2387 Y11.7058
    X14.2515 Y11.7231
    X14.2512 Y11.7463
    X14.2395 Y11.7625
    X14.1941 Y11.7767
    X14.1873 Y11.7765
    X14.1947 Y11.7647
    X14.2086 Y11.7654
    Z-0.5656 F12
    X14.2063 Y11.7683 Z-0.5744
    X14.2037 Y11.7709 Z-0.5832
    G3 X14.1873 Y11.7765 Z-0.5906 I-0.0159 J-0.0193
    X14.0751 Y11.7634
    X14.0605 Y11.7443
    X14.0606 Y11.7233
    X14.0731 Y11.7061
    X14.1167 Y11.6919
    X14.1974 Y11.6924
    X14.2387 Y11.7058
    X14.2515 Y11.7231
    X14.2512 Y11.7463
    X14.2395 Y11.7625
    X14.1941 Y11.7767
    X14.1873 Y11.7765
    X14.1937 Y11.7734
    X14.2173 Y11.7574
    Z-0.6049 F12
    X14.2161 Y11.7608 Z-0.6138
    X14.2144 Y11.7641 Z-0.6226
    G3 X14.2007 Y11.7746 Z-0.6299 I-0.0212 J-0.0133
    G1 X14.1941 Y11.7767 F39.37
    X14.1109 Y11.775
    X14.0751 Y11.7634
    X14.0605 Y11.7443
    X14.0606 Y11.7233
    X14.0731 Y11.7061
    X14.1167 Y11.6919
    X14.1974 Y11.6924
    X14.2387 Y11.7058
    X14.2515 Y11.7231
    X14.2512 Y11.7463
    X14.2395 Y11.7625
    X14.2007 Y11.7746
    G3 X14.1925 Y11.751 I-0.0037 J-0.0119
    G1 X14.1969 Y11.7493
    G3 X14.2085 Y11.7713 I0.0044 J0.0117
    X14.1951 Y11.7589 I-0.0053 J-0.0077
    G1 X14.2003 Y11.7501
    G3 X14.2173 Y11.7574 I0.008 J0.0048
    G1 Z-0.6443 F12
    X14.2161 Y11.7608 Z-0.6531
    X14.2144 Y11.7641 Z-0.662
    G3 X14.2007 Y11.7746 Z-0.6693 I-0.0212 J-0.0133
    X14.1109 Y11.775
    X14.0751 Y11.7634
    X14.0605 Y11.7443
    X14.0606 Y11.7233
    X14.0731 Y11.7061
    X14.1167 Y11.6919
    X14.1974 Y11.6924
    X14.2387 Y11.7058
    X14.2515 Y11.7231
    X14.2512 Y11.7463
    X14.2395 Y11.7625
    X14.2007 Y11.7746
    G3 X14.1926 Y11.751 I-0.0037 J-0.0119
    G1 X14.1967 Y11.7494
    G3 X14.208 Y11.7716 I0.0044 J0.0117
    X14.195 Y11.7586 I-0.0052 J-0.0078
    G1 X14.2002 Y11.7508
    G3 X14.2168 Y11.7591 I0.0078 J0.0052
    G1 X14.2155 Y11.7622 Z-0.6775 F12
    X14.2137 Y11.7651 Z-0.6857
    G3 X14.2007 Y11.7746 Z-0.6925 I-0.0205 J-0.0144
    X14.1109 Y11.775
    X14.0751 Y11.7634
    X14.0605 Y11.7443
    X14.0606 Y11.7233
    X14.0731 Y11.7061
    X14.1167 Y11.6919
    X14.1974 Y11.6924
    X14.2387 Y11.7058
    X14.2515 Y11.7231
    X14.2512 Y11.7463
    X14.2395 Y11.7625
    X14.2007 Y11.7746
    G3 X14.1834 Y11.7737 Z-0.6852 I-0.0074 J-0.0239
    G1 X14.1801 Y11.772 Z-0.6763
    X14.1772 Y11.7699 Z-0.6675
    G0 Z0.2
    X14.1028 Y20.7346
    Z0.0787
    G1 Z-0.0144 F12
    X14.105 Y20.7317 Z-0.0232
    X14.1076 Y20.7292 Z-0.032
    G3 X14.124 Y20.7234 Z-0.0394 I0.0159 J0.0193
    G1 X14.2005 Y20.7246 F39.37
    X14.2375 Y20.7367
    X14.2481 Y20.7494
    X14.2512 Y20.7537
    X14.2515 Y20.7769
    X14.2387 Y20.7942
    X14.1974 Y20.8076
    X14.1167 Y20.8081
    X14.0731 Y20.7939
    X14.0606 Y20.7767
    X14.0605 Y20.7547
    X14.0731 Y20.7373
    X14.1164 Y20.7233
    X14.124 Y20.7234
    X14.1167 Y20.7353
    X14.1028 Y20.7346
    Z-0.0537 F12
    X14.105 Y20.7317 Z-0.0626
    X14.1076 Y20.7292 Z-0.0714
    G3 X14.124 Y20.7234 Z-0.0787 I0.0159 J0.0193
    X14.2375 Y20.7367
    X14.2481 Y20.7494
    X14.2512 Y20.7537
    X14.2515 Y20.7769
    X14.2387 Y20.7942
    X14.1974 Y20.8076
    X14.1167 Y20.8081
    X14.0731 Y20.7939
    X14.0606 Y20.7767
    X14.0605 Y20.7547
    X14.0731 Y20.7373
    X14.1164 Y20.7233
    X14.124 Y20.7234
    X14.1167 Y20.7353
    X14.1028 Y20.7346
    Z-0.0931 F12
    X14.105 Y20.7317 Z-0.1019
    X14.1076 Y20.7292 Z-0.1108
    G3 X14.124 Y20.7234 Z-0.1181 I0.0159 J0.0193
    X14.2375 Y20.7367
    X14.2481 Y20.7494
    X14.2512 Y20.7537
    X14.2515 Y20.7769
    X14.2387 Y20.7942
    X14.1974 Y20.8076
    X14.1167 Y20.8081
    X14.0731 Y20.7939
    X14.0606 Y20.7767
    X14.0605 Y20.7547
    X14.0731 Y20.7373
    X14.1164 Y20.7233
    X14.124 Y20.7234
    X14.1167 Y20.7353
    X14.1028 Y20.7346
    Z-0.1325 F12
    X14.105 Y20.7317 Z-0.1413
    X14.1076 Y20.7292 Z-0.1502
    G3 X14.124 Y20.7234 Z-0.1575 I0.0159 J0.0193
    X14.2375 Y20.7367
    X14.2481 Y20.7494
    X14.2512 Y20.7537
    X14.2515 Y20.7769
    X14.2387 Y20.7942
    X14.1974 Y20.8076
    X14.1167 Y20.8081
    X14.0731 Y20.7939
    X14.0606 Y20.7767
    X14.0605 Y20.7547
    X14.0731 Y20.7373
    X14.1164 Y20.7233
    X14.124 Y20.7234
    X14.1167 Y20.7353
    X14.1028 Y20.7346
    Z-0.1719 F12
    X14.105 Y20.7317 Z-0.1807
    X14.1076 Y20.7292 Z-0.1895
    G3 X14.124 Y20.7234 Z-0.1969 I0.0159 J0.0193
    X14.2375 Y20.7367
    X14.2481 Y20.7494
    X14.2512 Y20.7537
    X14.2515 Y20.7769
    X14.2387 Y20.7942
    X14.1974 Y20.8076
    X14.1167 Y20.8081
    X14.0731 Y20.7939
    X14.0606 Y20.7767
    X14.0605 Y20.7547
    X14.0731 Y20.7373
    X14.1164 Y20.7233
    X14.124 Y20.7234
    X14.1167 Y20.7353
    X14.1028 Y20.7346
    Z-0.2112 F12
    X14.105 Y20.7317 Z-0.2201
    X14.1076 Y20.7292 Z-0.2289
    G3 X14.124 Y20.7234 Z-0.2362 I0.0159 J0.0193
    X14.2375 Y20.7367
    X14.2481 Y20.7494
    X14.2512 Y20.7537
    X14.2515 Y20.7769
    X14.2387 Y20.7942
    X14.1974 Y20.8076
    X14.1167 Y20.8081
    X14.0731 Y20.7939
    X14.0606 Y20.7767
    X14.0605 Y20.7547
    X14.0731 Y20.7373
    X14.1164 Y20.7233
    X14.124 Y20.7234
    X14.1167 Y20.7353
    X14.1028 Y20.7346
    Z-0.2506 F12
    X14.105 Y20.7317 Z-0.2594
    X14.1076 Y20.7292 Z-0.2683
    G3 X14.124 Y20.7234 Z-0.2756 I0.0159 J0.0193
    X14.2375 Y20.7367
    X14.2481 Y20.7494
    X14.2512 Y20.7537
    X14.2515 Y20.7769
    X14.2387 Y20.7942
    X14.1974 Y20.8076
    X14.1167 Y20.8081
    X14.0731 Y20.7939
    X14.0606 Y20.7767
    X14.0605 Y20.7547
    X14.0731 Y20.7373
    X14.1164 Y20.7233
    X14.124 Y20.7234
    X14.1167 Y20.7353
    X14.1028 Y20.7346
    Z-0.29 F12
    X14.105 Y20.7317 Z-0.2988
    X14.1076 Y20.7292 Z-0.3076
    G3 X14.124 Y20.7234 Z-0.315 I0.0159 J0.0193
    X14.2375 Y20.7367
    X14.2481 Y20.7494
    X14.2512 Y20.7537
    X14.2515 Y20.7769
    X14.2387 Y20.7942
    X14.1974 Y20.8076
    X14.1167 Y20.8081
    X14.0731 Y20.7939
    X14.0606 Y20.7767
    X14.0605 Y20.7547
    X14.0731 Y20.7373
    X14.1164 Y20.7233
    X14.124 Y20.7234
    X14.1167 Y20.7353
    X14.1028 Y20.7346
    Z-0.3293 F12
    X14.105 Y20.7317 Z-0.3382
    X14.1076 Y20.7292 Z-0.347
    G3 X14.124 Y20.7234 Z-0.3543 I0.0159 J0.0193
    X14.2375 Y20.7367
    X14.2481 Y20.7494
    X14.2512 Y20.7537
    X14.2515 Y20.7769
    X14.2387 Y20.7942
    X14.1974 Y20.8076
    X14.1167 Y20.8081
    X14.0731 Y20.7939
    X14.0606 Y20.7767
    X14.0605 Y20.7547
    X14.0731 Y20.7373
    X14.1164 Y20.7233
    X14.124 Y20.7234
    X14.1167 Y20.7353
    X14.1028 Y20.7346
    Z-0.3687 F12
    X14.105 Y20.7317 Z-0.3775
    X14.1076 Y20.7292 Z-0.3864
    G3 X14.124 Y20.7234 Z-0.3937 I0.0159 J0.0193
    X14.2375 Y20.7367
    X14.2481 Y20.7494
    X14.2512 Y20.7537
    X14.2515 Y20.7769
    X14.2387 Y20.7942
    X14.1974 Y20.8076
    X14.1167 Y20.8081
    X14.0731 Y20.7939
    X14.0606 Y20.7767
    X14.0605 Y20.7547
    X14.0731 Y20.7373
    X14.1164 Y20.7233
    X14.124 Y20.7234
    X14.1167 Y20.7353
    X14.1028 Y20.7346
    Z-0.4081 F12
    X14.105 Y20.7317 Z-0.4169
    X14.1076 Y20.7292 Z-0.4257
    G3 X14.124 Y20.7234 Z-0.4331 I0.0159 J0.0193
    X14.2375 Y20.7367
    X14.2481 Y20.7494
    X14.2512 Y20.7537
    X14.2515 Y20.7769
    X14.2387 Y20.7942
    X14.1974 Y20.8076
    X14.1167 Y20.8081
    X14.0731 Y20.7939
    X14.0606 Y20.7767
    X14.0605 Y20.7547
    X14.0731 Y20.7373
    X14.1164 Y20.7233
    X14.124 Y20.7234
    X14.1167 Y20.7353
    X14.1028 Y20.7346
    Z-0.4474 F12
    X14.105 Y20.7317 Z-0.4563
    X14.1076 Y20.7292 Z-0.4651
    G3 X14.124 Y20.7234 Z-0.4724 I0.0159 J0.0193
    X14.2375 Y20.7367
    X14.2481 Y20.7494
    X14.2512 Y20.7537
    X14.2515 Y20.7769
    X14.2387 Y20.7942
    X14.1974 Y20.8076
    X14.1167 Y20.8081
    X14.0731 Y20.7939
    X14.0606 Y20.7767
    X14.0605 Y20.7547
    X14.0731 Y20.7373
    X14.1164 Y20.7233
    X14.124 Y20.7234
    X14.1167 Y20.7353
    X14.1028 Y20.7346
    Z-0.4868 F12
    X14.105 Y20.7317 Z-0.4956
    X14.1076 Y20.7292 Z-0.5045
    G3 X14.124 Y20.7234 Z-0.5118 I0.0159 J0.0193
    X14.2375 Y20.7367
    X14.2481 Y20.7494
    X14.2512 Y20.7537
    X14.2515 Y20.7769
    X14.2387 Y20.7942
    X14.1974 Y20.8076
    X14.1167 Y20.8081
    X14.0731 Y20.7939
    X14.0606 Y20.7767
    X14.0605 Y20.7547
    X14.0731 Y20.7373
    X14.1164 Y20.7233
    X14.124 Y20.7234
    X14.1167 Y20.7353
    X14.1028 Y20.7346
    Z-0.5262 F12
    X14.105 Y20.7317 Z-0.535
    X14.1076 Y20.7292 Z-0.5439
    G3 X14.124 Y20.7234 Z-0.5512 I0.0159 J0.0193
    X14.2375 Y20.7367
    X14.2481 Y20.7494
    X14.2512 Y20.7537
    X14.2515 Y20.7769
    X14.2387 Y20.7942
    X14.1974 Y20.8076
    X14.1167 Y20.8081
    X14.0731 Y20.7939
    X14.0606 Y20.7767
    X14.0605 Y20.7547
    X14.0731 Y20.7373
    X14.1164 Y20.7233
    X14.124 Y20.7234
    X14.1167 Y20.7353
    X14.1028 Y20.7346
    Z-0.5656 F12
    X14.105 Y20.7317 Z-0.5744
    X14.1076 Y20.7292 Z-0.5832
    G3 X14.124 Y20.7234 Z-0.5906 I0.0159 J0.0193
    X14.2375 Y20.7367
    X14.2481 Y20.7494
    X14.2512 Y20.7537
    X14.2515 Y20.7769
    X14.2387 Y20.7942
    X14.1974 Y20.8076
    X14.1167 Y20.8081
    X14.0731 Y20.7939
    X14.0606 Y20.7767
    X14.0605 Y20.7547
    X14.0731 Y20.7373
    X14.1164 Y20.7233
    X14.124 Y20.7234
    X14.1167 Y20.7353
    X14.1028 Y20.7346
    Z-0.6049 F12
    X14.105 Y20.7317 Z-0.6138
    X14.1076 Y20.7292 Z-0.6226
    G3 X14.124 Y20.7234 Z-0.6299 I0.0159 J0.0193
    X14.2375 Y20.7367
    X14.2481 Y20.7494
    X14.2512 Y20.7537
    X14.2515 Y20.7769
    X14.2387 Y20.7942
    X14.1974 Y20.8076
    X14.1167 Y20.8081
    X14.0731 Y20.7939
    X14.0606 Y20.7767
    X14.0605 Y20.7547
    X14.0731 Y20.7373
    X14.1164 Y20.7233
    X14.124 Y20.7234
    X14.1167 Y20.7353
    X14.1028 Y20.7346
    Z-0.6443 F12
    X14.105 Y20.7317 Z-0.6531
    X14.1076 Y20.7292 Z-0.662
    G3 X14.124 Y20.7234 Z-0.6693 I0.0159 J0.0193
    X14.2375 Y20.7367
    X14.2481 Y20.7494
    X14.2512 Y20.7537
    X14.2515 Y20.7769
    X14.2387 Y20.7942
    X14.1974 Y20.8076
    X14.1167 Y20.8081
    X14.0731 Y20.7939
    X14.0606 Y20.7767
    X14.0605 Y20.7547
    X14.0731 Y20.7373
    X14.1164 Y20.7233
    X14.124 Y20.7234
    X14.1169 Y20.7345
    X14.1038 Y20.7331
    X14.1061 Y20.7306 Z-0.6775 F12
    X14.1086 Y20.7284 Z-0.6857
    G3 X14.124 Y20.7234 Z-0.6925 I0.0149 J0.02
    X14.2375 Y20.7367
    X14.2481 Y20.7494
    X14.2512 Y20.7537
    X14.2515 Y20.7769
    X14.2387 Y20.7942
    X14.1974 Y20.8076
    X14.1167 Y20.8081
    X14.0731 Y20.7939
    X14.0606 Y20.7767
    X14.0605 Y20.7547
    X14.0731 Y20.7373
    X14.1164 Y20.7233
    X14.124 Y20.7234
    G3 X14.1401 Y20.7297 Z-0.6852 I-0.0004 J0.025
    G1 X14.1427 Y20.7323 Z-0.6763
    X14.1448 Y20.7353 Z-0.6675
    G0 Z0.2
    X14.1338 Y25.5515
    Z0.0787
    G1 Z-0.0144 F12
    X14.1308 Y25.5536 Z-0.0232
    X14.1276 Y25.5553 Z-0.032
    G3 X14.1103 Y25.556 Z-0.0394 I-0.0096 J-0.0231
    G1 X14.0735 Y25.5441 F39.37
    X14.0604 Y25.5253
    Y25.5048
    X14.0731 Y25.4873
    X14.1167 Y25.4732
    X14.1966 Y25.4736
    X14.2406 Y25.4891
    X14.2521 Y25.5048
    Y25.5253
    X14.2397 Y25.5429
    X14.1968 Y25.5576
    X14.1167 Y25.5581
    X14.1103 Y25.556
    X14.1207 Y25.5467
    X14.1338 Y25.5515
    Z-0.0537 F12
    X14.1308 Y25.5536 Z-0.0626
    X14.1276 Y25.5553 Z-0.0714
    G3 X14.1103 Y25.556 Z-0.0787 I-0.0096 J-0.0231
    X14.0604 Y25.5253
    Y25.5048
    X14.0731 Y25.4873
    X14.1167 Y25.4732
    X14.1966 Y25.4736
    X14.2406 Y25.4891
    X14.2521 Y25.5048
    Y25.5253
    X14.2397 Y25.5429
    X14.1968 Y25.5576
    X14.1167 Y25.5581
    X14.1103 Y25.556
    X14.1207 Y25.5467
    X14.1338 Y25.5515
    Z-0.0931 F12
    X14.1308 Y25.5536 Z-0.1019
    X14.1276 Y25.5553 Z-0.1108
    G3 X14.1103 Y25.556 Z-0.1181 I-0.0096 J-0.0231
    X14.0604 Y25.5253
    Y25.5048
    X14.0731 Y25.4873
    X14.1167 Y25.4732
    X14.1966 Y25.4736
    X14.2406 Y25.4891
    X14.2521 Y25.5048
    Y25.5253
    X14.2397 Y25.5429
    X14.1968 Y25.5576
    X14.1167 Y25.5581
    X14.1103 Y25.556
    X14.1207 Y25.5467
    X14.1338 Y25.5515
    Z-0.1325 F12
    X14.1308 Y25.5536 Z-0.1413
    X14.1276 Y25.5553 Z-0.1502
    G3 X14.1103 Y25.556 Z-0.1575 I-0.0096 J-0.0231
    X14.0604 Y25.5253
    Y25.5048
    X14.0731 Y25.4873
    X14.1167 Y25.4732
    X14.1966 Y25.4736
    X14.2406 Y25.4891
    X14.2521 Y25.5048
    Y25.5253
    X14.2397 Y25.5429
    X14.1968 Y25.5576
    X14.1167 Y25.5581
    X14.1103 Y25.556
    X14.1207 Y25.5467
    X14.1338 Y25.5515
    Z-0.1719 F12
    X14.1308 Y25.5536 Z-0.1807
    X14.1276 Y25.5553 Z-0.1895
    G3 X14.1103 Y25.556 Z-0.1969 I-0.0096 J-0.0231
    X14.0604 Y25.5253
    Y25.5048
    X14.0731 Y25.4873
    X14.1167 Y25.4732
    X14.1966 Y25.4736
    X14.2406 Y25.4891
    X14.2521 Y25.5048
    Y25.5253
    X14.2397 Y25.5429
    X14.1968 Y25.5576
    X14.1167 Y25.5581
    X14.1103 Y25.556
    X14.1207 Y25.5467
    X14.1338 Y25.5515
    Z-0.2112 F12
    X14.1308 Y25.5536 Z-0.2201
    X14.1276 Y25.5553 Z-0.2289
    G3 X14.1103 Y25.556 Z-0.2362 I-0.0096 J-0.0231
    X14.0604 Y25.5253
    Y25.5048
    X14.0731 Y25.4873
    X14.1167 Y25.4732
    X14.1966 Y25.4736
    X14.2406 Y25.4891
    X14.2521 Y25.5048
    Y25.5253
    X14.2397 Y25.5429
    X14.1968 Y25.5576
    X14.1167 Y25.5581
    X14.1103 Y25.556
    X14.1207 Y25.5467
    X14.1338 Y25.5515
    Z-0.2506 F12
    X14.1308 Y25.5536 Z-0.2594
    X14.1276 Y25.5553 Z-0.2683
    G3 X14.1103 Y25.556 Z-0.2756 I-0.0096 J-0.0231
    X14.0604 Y25.5253
    Y25.5048
    X14.0731 Y25.4873
    X14.1167 Y25.4732
    X14.1966 Y25.4736
    X14.2406 Y25.4891
    X14.2521 Y25.5048
    Y25.5253
    X14.2397 Y25.5429
    X14.1968 Y25.5576
    X14.1167 Y25.5581
    X14.1103 Y25.556
    X14.1207 Y25.5467
    X14.1338 Y25.5515
    Z-0.29 F12
    X14.1308 Y25.5536 Z-0.2988
    X14.1276 Y25.5553 Z-0.3076
    G3 X14.1103 Y25.556 Z-0.315 I-0.0096 J-0.0231
    X14.0604 Y25.5253
    Y25.5048
    X14.0731 Y25.4873
    X14.1167 Y25.4732
    X14.1966 Y25.4736
    X14.2406 Y25.4891
    X14.2521 Y25.5048
    Y25.5253
    X14.2397 Y25.5429
    X14.1968 Y25.5576
    X14.1167 Y25.5581
    X14.1103 Y25.556
    X14.1207 Y25.5467
    X14.1338 Y25.5515
    Z-0.3293 F12
    X14.1308 Y25.5536 Z-0.3382
    X14.1276 Y25.5553 Z-0.347
    G3 X14.1103 Y25.556 Z-0.3543 I-0.0096 J-0.0231
    X14.0604 Y25.5253
    Y25.5048
    X14.0731 Y25.4873
    X14.1167 Y25.4732
    X14.1966 Y25.4736
    X14.2406 Y25.4891
    X14.2521 Y25.5048
    Y25.5253
    X14.2397 Y25.5429
    X14.1968 Y25.5576
    X14.1167 Y25.5581
    X14.1103 Y25.556
    X14.1207 Y25.5467
    X14.1338 Y25.5515
    Z-0.3687 F12
    X14.1308 Y25.5536 Z-0.3775
    X14.1276 Y25.5553 Z-0.3864
    G3 X14.1103 Y25.556 Z-0.3937 I-0.0096 J-0.0231
    X14.0604 Y25.5253
    Y25.5048
    X14.0731 Y25.4873
    X14.1167 Y25.4732
    X14.1966 Y25.4736
    X14.2406 Y25.4891
    X14.2521 Y25.5048
    Y25.5253
    X14.2397 Y25.5429
    X14.1968 Y25.5576
    X14.1167 Y25.5581
    X14.1103 Y25.556
    X14.1207 Y25.5467
    X14.1338 Y25.5515
    Z-0.4081 F12
    X14.1308 Y25.5536 Z-0.4169
    X14.1276 Y25.5553 Z-0.4257
    G3 X14.1103 Y25.556 Z-0.4331 I-0.0096 J-0.0231
    X14.0604 Y25.5253
    Y25.5048
    X14.0731 Y25.4873
    X14.1167 Y25.4732
    X14.1966 Y25.4736
    X14.2406 Y25.4891
    X14.2521 Y25.5048
    Y25.5253
    X14.2397 Y25.5429
    X14.1968 Y25.5576
    X14.1167 Y25.5581
    X14.1103 Y25.556
    X14.1207 Y25.5467
    X14.1338 Y25.5515
    Z-0.4474 F12
    X14.1308 Y25.5536 Z-0.4563
    X14.1276 Y25.5553 Z-0.4651
    G3 X14.1103 Y25.556 Z-0.4724 I-0.0096 J-0.0231
    X14.0604 Y25.5253
    Y25.5048
    X14.0731 Y25.4873
    X14.1167 Y25.4732
    X14.1966 Y25.4736
    X14.2406 Y25.4891
    X14.2521 Y25.5048
    Y25.5253
    X14.2397 Y25.5429
    X14.1968 Y25.5576
    X14.1167 Y25.5581
    X14.1103 Y25.556
    G3 X14.111 Y25.5444 I0.0018 J-0.0057
    G1 X14.1289 Y25.541
    G3 X14.1338 Y25.5515 I0.0011 J0.0059
    G1 Z-0.4868 F12
    X14.1308 Y25.5536 Z-0.4956
    X14.1276 Y25.5553 Z-0.5045
    G3 X14.1103 Y25.556 Z-0.5118 I-0.0096 J-0.0231
    X14.0604 Y25.5253
    Y25.5048
    X14.0731 Y25.4873
    X14.1167 Y25.4732
    X14.1966 Y25.4736
    X14.2406 Y25.4891
    X14.2521 Y25.5048
    Y25.5253
    X14.2397 Y25.5429
    X14.1968 Y25.5576
    X14.1167 Y25.5581
    X14.1103 Y25.556
    X14.1207 Y25.5467
    X14.1338 Y25.5515
    Z-0.5262 F12
    X14.1308 Y25.5536 Z-0.535
    X14.1276 Y25.5553 Z-0.5439
    G3 X14.1103 Y25.556 Z-0.5512 I-0.0096 J-0.0231
    X14.0604 Y25.5253
    Y25.5048
    X14.0731 Y25.4873
    X14.1167 Y25.4732
    X14.1966 Y25.4736
    X14.2406 Y25.4891
    X14.2521 Y25.5048
    Y25.5253
    X14.2397 Y25.5429
    X14.1968 Y25.5576
    X14.1167 Y25.5581
    X14.1103 Y25.556
    X14.1207 Y25.5467
    X14.1338 Y25.5515
    Z-0.5656 F12
    X14.1308 Y25.5536 Z-0.5744
    X14.1276 Y25.5553 Z-0.5832
    G3 X14.1103 Y25.556 Z-0.5906 I-0.0096 J-0.0231
    X14.0604 Y25.5253
    Y25.5048
    X14.0731 Y25.4873
    X14.1167 Y25.4732
    X14.1966 Y25.4736
    X14.2406 Y25.4891
    X14.2521 Y25.5048
    Y25.5253
    X14.2397 Y25.5429
    X14.1968 Y25.5576
    X14.1167 Y25.5581
    X14.1103 Y25.556
    X14.1207 Y25.5467
    X14.1338 Y25.5515
    Z-0.6049 F12
    X14.1308 Y25.5536 Z-0.6138
    X14.1276 Y25.5553 Z-0.6226
    G3 X14.1103 Y25.556 Z-0.6299 I-0.0096 J-0.0231
    X14.0604 Y25.5253
    Y25.5048
    X14.0731 Y25.4873
    X14.1167 Y25.4732
    X14.1966 Y25.4736
    X14.2406 Y25.4891
    X14.2521 Y25.5048
    Y25.5253
    X14.2397 Y25.5429
    X14.1968 Y25.5576
    X14.1167 Y25.5581
    X14.1103 Y25.556
    X14.1207 Y25.5467
    X14.1338 Y25.5515
    Z-0.6443 F12
    X14.1308 Y25.5536 Z-0.6531
    X14.1276 Y25.5553 Z-0.662
    G3 X14.1103 Y25.556 Z-0.6693 I-0.0096 J-0.0231
    X14.0604 Y25.5253
    Y25.5048
    X14.0731 Y25.4873
    X14.1167 Y25.4732
    X14.1966 Y25.4736
    X14.2406 Y25.4891
    X14.2521 Y25.5048
    Y25.5253
    X14.2397 Y25.5429
    X14.1968 Y25.5576
    X14.1167 Y25.5581
    X14.1103 Y25.556
    X14.1203 Y25.5474
    X14.1324 Y25.5526
    X14.1295 Y25.5544 Z-0.6775 F12
    X14.1264 Y25.5557 Z-0.6857
    G3 X14.1103 Y25.556 Z-0.6925 I-0.0084 J-0.0235
    X14.0604 Y25.5253
    Y25.5048
    X14.0731 Y25.4873
    X14.1167 Y25.4732
    X14.1966 Y25.4736
    X14.2406 Y25.4891
    X14.2521 Y25.5048
    Y25.5253
    X14.2397 Y25.5429
    X14.1968 Y25.5576
    X14.1167 Y25.5581
    X14.1103 Y25.556
    G3 X14.0967 Y25.5453 Z-0.6852 I0.0077 J-0.0238
    G1 X14.095 Y25.542 Z-0.6763
    X14.0938 Y25.5385 Z-0.6675
    G0 Z0.2
    X14.1338 Y27.0515
    Z0.0787
    G1 Z-0.0144 F12
    X14.1308 Y27.0536 Z-0.0232
    X14.1276 Y27.0553 Z-0.032
    G3 X14.1103 Y27.056 Z-0.0394 I-0.0096 J-0.0231
    G1 X14.0731 Y27.0439 F39.37
    X14.0604 Y27.0265
    Y27.0052
    X14.0733 Y26.9873
    X14.1167 Y26.9732
    X14.1969 Y26.9736
    X14.2399 Y26.9883
    X14.2521 Y27.0052
    Y27.0265
    X14.2408 Y27.042
    X14.1965 Y27.0576
    X14.1167 Y27.0581
    X14.1103 Y27.056
    G3 X14.111 Y27.0444 I0.0018 J-0.0057
    G1 X14.1289 Y27.041
    G3 X14.1338 Y27.0515 I0.0011 J0.0059
    G1 Z-0.0537 F12
    X14.1308 Y27.0536 Z-0.0626
    X14.1276 Y27.0553 Z-0.0714
    G3 X14.1103 Y27.056 Z-0.0787 I-0.0096 J-0.0231
    X14.0604 Y27.0265
    Y27.0052
    X14.0733 Y26.9873
    X14.1167 Y26.9732
    X14.1969 Y26.9736
    X14.2399 Y26.9883
    X14.2521 Y27.0052
    Y27.0265
    X14.2408 Y27.042
    X14.1965 Y27.0576
    X14.1167 Y27.0581
    X14.1103 Y27.056
    X14.1207 Y27.0467
    X14.1338 Y27.0515
    Z-0.0931 F12
    X14.1308 Y27.0536 Z-0.1019
    X14.1276 Y27.0553 Z-0.1108
    G3 X14.1103 Y27.056 Z-0.1181 I-0.0096 J-0.0231
    X14.0604 Y27.0265
    Y27.0052
    X14.0733 Y26.9873
    X14.1167 Y26.9732
    X14.1969 Y26.9736
    X14.2399 Y26.9883
    X14.2521 Y27.0052
    Y27.0265
    X14.2408 Y27.042
    X14.1965 Y27.0576
    X14.1167 Y27.0581
    X14.1103 Y27.056
    G1 X14.1289 Y27.041
    G1 Z-0.1325 F12
    X14.1308 Y27.0536 Z-0.1413
    X14.1276 Y27.0553 Z-0.1502
    G3 X14.1103 Y27.056 Z-0.1575 I-0.0096 J-0.0231
    X14.0604 Y27.0265
    Y27.0052
    X14.0733 Y26.9873
    X14.1167 Y26.9732
    X14.1969 Y26.9736
    X14.2399 Y26.9883
    X14.2521 Y27.0052
    Y27.0265
    X14.2408 Y27.042
    X14.1965 Y27.0576
    X14.1167 Y27.0581
    X14.1103 Y27.056
    X14.1207 Y27.0467
    X14.1338 Y27.0515
    Z-0.1719 F12
    X14.1308 Y27.0536 Z-0.1807
    X14.1276 Y27.0553 Z-0.1895
    G3 X14.1103 Y27.056 Z-0.1969 I-0.0096 J-0.0231
    X14.0604 Y27.0265
    Y27.0052
    X14.0733 Y26.9873
    X14.1167 Y26.9732
    X14.1969 Y26.9736
    X14.2399 Y26.9883
    X14.2521 Y27.0052
    Y27.0265
    X14.2408 Y27.042
    X14.1965 Y27.0576
    X14.1167 Y27.0581
    X14.1103 Y27.056
    G1 X14.1289 Y27.041
    G1 Z-0.2112 F12
    X14.1308 Y27.0536 Z-0.2201
    X14.1276 Y27.0553 Z-0.2289
    G3 X14.1103 Y27.056 Z-0.2362 I-0.0096 J-0.0231
    X14.0604 Y27.0265
    Y27.0052
    X14.0733 Y26.9873
    X14.1167 Y26.9732
    X14.1969 Y26.9736
    X14.2399 Y26.9883
    X14.2521 Y27.0052
    Y27.0265
    X14.2408 Y27.042
    X14.1965 Y27.0576
    X14.1167 Y27.0581
    X14.1103 Y27.056
    G1 X14.1289 Y27.041
    G1 Z-0.2506 F12
    X14.1308 Y27.0536 Z-0.2594
    X14.1276 Y27.0553 Z-0.2683
    G3 X14.1103 Y27.056 Z-0.2756 I-0.0096 J-0.0231
    X14.0604 Y27.0265
    Y27.0052
    X14.0733 Y26.9873
    X14.1167 Y26.9732
    X14.1969 Y26.9736
    X14.2399 Y26.9883
    X14.2521 Y27.0052
    Y27.0265
    X14.2408 Y27.042
    X14.1965 Y27.0576
    X14.1167 Y27.0581
    X14.1103 Y27.056
    G1 X14.1289 Y27.041
    G1 Z-0.29 F12
    X14.1308 Y27.0536 Z-0.2988
    X14.1276 Y27.0553 Z-0.3076
    G3 X14.1103 Y27.056 Z-0.315 I-0.0096 J-0.0231
    X14.0604 Y27.0265
    Y27.0052
    X14.0733 Y26.9873
    X14.1167 Y26.9732
    X14.1969 Y26.9736
    X14.2399 Y26.9883
    X14.2521 Y27.0052
    Y27.0265
    X14.2408 Y27.042
    X14.1965 Y27.0576
    X14.1167 Y27.0581
    X14.1103 Y27.056
    G1 X14.1289 Y27.041
    G1 Z-0.3293 F12
    X14.1308 Y27.0536 Z-0.3382
    X14.1276 Y27.0553 Z-0.347
    G3 X14.1103 Y27.056 Z-0.3543 I-0.0096 J-0.0231
    X14.0604 Y27.0265
    Y27.0052
    X14.0733 Y26.9873
    X14.1167 Y26.9732
    X14.1969 Y26.9736
    X14.2399 Y26.9883
    X14.2521 Y27.0052
    Y27.0265
    X14.2408 Y27.042
    X14.1965 Y27.0576
    X14.1167 Y27.0581
    X14.1103 Y27.056
    G1 X14.1289 Y27.041
    G1 Z-0.3687 F12
    X14.1308 Y27.0536 Z-0.3775
    X14.1276 Y27.0553 Z-0.3864
    G3 X14.1103 Y27.056 Z-0.3937 I-0.0096 J-0.0231
    X14.0604 Y27.0265
    Y27.0052
    X14.0733 Y26.9873
    X14.1167 Y26.9732
    X14.1969 Y26.9736
    X14.2399 Y26.9883
    X14.2521 Y27.0052
    Y27.0265
    X14.2408 Y27.042
    X14.1965 Y27.0576
    X14.1167 Y27.0581
    X14.1103 Y27.056
    G1 X14.1289 Y27.041
    G1 Z-0.4081 F12
    X14.1308 Y27.0536 Z-0.4169
    X14.1276 Y27.0553 Z-0.4257
    G3 X14.1103 Y27.056 Z-0.4331 I-0.0096 J-0.0231
    X14.0604 Y27.0265
    Y27.0052
    X14.0733 Y26.9873
    X14.1167 Y26.9732
    X14.1969 Y26.9736
    X14.2399 Y26.9883
    X14.2521 Y27.0052
    Y27.0265
    X14.2408 Y27.042
    X14.1965 Y27.0576
    X14.1167 Y27.0581
    X14.1103 Y27.056
    G1 X14.1289 Y27.041
    G1 Z-0.4474 F12
    X14.1308 Y27.0536 Z-0.4563
    X14.1276 Y27.0553 Z-0.4651
    G3 X14.1103 Y27.056 Z-0.4724 I-0.0096 J-0.0231
    X14.0604 Y27.0265
    Y27.0052
    X14.0733 Y26.9873
    X14.1167 Y26.9732
    X14.1969 Y26.9736
    X14.2399 Y26.9883
    X14.2521 Y27.0052
    Y27.0265
    X14.2408 Y27.042
    X14.1965 Y27.0576
    X14.1167 Y27.0581
    X14.1103 Y27.056
    G1 X14.1289 Y27.041
    G1 Z-0.4868 F12
    X14.1308 Y27.0536 Z-0.4956
    X14.1276 Y27.0553 Z-0.5045
    G3 X14.1103 Y27.056 Z-0.5118 I-0.0096 J-0.0231
    X14.0604 Y27.0265
    Y27.0052
    X14.0733 Y26.9873
    X14.1167 Y26.9732
    X14.1969 Y26.9736
    X14.2399 Y26.9883
    X14.2521 Y27.0052
    Y27.0265
    X14.2408 Y27.042
    X14.1965 Y27.0576
    X14.1167 Y27.0581
    X14.1103 Y27.056
    G1 X14.1289 Y27.041
    G1 Z-0.5262 F12
    X14.1308 Y27.0536 Z-0.535
    X14.1276 Y27.0553 Z-0.5439
    G3 X14.1103 Y27.056 Z-0.5512 I-0.0096 J-0.0231
    X14.0604 Y27.0265
    Y27.0052
    X14.0733 Y26.9873
    X14.1167 Y26.9732
    X14.1969 Y26.9736
    X14.2399 Y26.9883
    X14.2521 Y27.0052
    Y27.0265
    X14.2408 Y27.042
    X14.1965 Y27.0576
    X14.1167 Y27.0581
    X14.1103 Y27.056
    G1 X14.1289 Y27.041
    G1 Z-0.5656 F12
    X14.1308 Y27.0536 Z-0.5744
    X14.1276 Y27.0553 Z-0.5832
    G3 X14.1103 Y27.056 Z-0.5906 I-0.0096 J-0.0231
    X14.0604 Y27.0265
    Y27.0052
    X14.0733 Y26.9873
    X14.1167 Y26.9732
    X14.1969 Y26.9736
    X14.2399 Y26.9883
    X14.2521 Y27.0052
    Y27.0265
    X14.2408 Y27.042
    X14.1965 Y27.0576
    X14.1167 Y27.0581
    X14.1103 Y27.056
    G1 X14.1289 Y27.041
    G1 Z-0.6049 F12
    X14.1308 Y27.0536 Z-0.6138
    X14.1276 Y27.0553 Z-0.6226
    G3 X14.1103 Y27.056 Z-0.6299 I-0.0096 J-0.0231
    X14.0604 Y27.0265
    Y27.0052
    X14.0733 Y26.9873
    X14.1167 Y26.9732
    X14.1969 Y26.9736
    X14.2399 Y26.9883
    X14.2521 Y27.0052
    Y27.0265
    X14.2408 Y27.042
    X14.1965 Y27.0576
    X14.1167 Y27.0581
    X14.1103 Y27.056
    G1 X14.1289 Y27.041
    G1 Z-0.6443 F12
    X14.1308 Y27.0536 Z-0.6531
    X14.1276 Y27.0553 Z-0.662
    G3 X14.1103 Y27.056 Z-0.6693 I-0.0096 J-0.0231
    X14.0604 Y27.0265
    Y27.0052
    X14.0733 Y26.9873
    X14.1167 Y26.9732
    X14.1969 Y26.9736
    X14.2399 Y26.9883
    X14.2521 Y27.0052
    Y27.0265
    X14.2408 Y27.042
    X14.1965 Y27.0576
    X14.1167 Y27.0581
    X14.1103 Y27.056
    X14.1203 Y27.0474
    X14.1324 Y27.0526
    X14.1295 Y27.0544 Z-0.6775 F12
    X14.1264 Y27.0557 Z-0.6857
    G3 X14.1103 Y27.056 Z-0.6925 I-0.0084 J-0.0235
    X14.0604 Y27.0265
    Y27.0052
    X14.0733 Y26.9873
    X14.1167 Y26.9732
    X14.1969 Y26.9736
    X14.2399 Y26.9883
    X14.2521 Y27.0052
    Y27.0265
    X14.2408 Y27.042
    X14.1965 Y27.0576
    X14.1167 Y27.0581
    X14.1103 Y27.056
    G3 X14.0967 Y27.0453 Z-0.6852 I0.0077 J-0.0238
    G1 X14.095 Y27.042 Z-0.6763
    X14.0938 Y27.0386 Z-0.6675
    G0 Z0.2
    X13.1678 Y27.9335
    Z0.0787
    G1 Z-0.0144 F12
    X13.1648 Y27.9313 Z-0.0232
    X13.1623 Y27.9287 Z-0.032
    G3 X13.1563 Y27.9125 Z-0.0394 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X13.1783 Y27.8467
    X13.1819 Y27.8381
    X13.2187 Y27.8228
    X13.2556 Y27.8381
    X13.2813 Y27.9001
    X13.2812 Y27.9752
    X13.2557 Y28.0369
    X13.2187 Y28.0522
    X13.1819 Y28.0369
    X13.1563 Y27.9752
    Y27.9125
    G3 X13.1813 Y27.9124 I0.0125
    G1 Y27.918
    G3 X13.157 Y27.9223 I-0.0125 J0.0001
    X13.1747 Y27.9105 I0.0103 J-0.0037
    G1 X13.181 Y27.9162
    G3 X13.1678 Y27.9335 I-0.0073 J0.0081
    G1 Z-0.0537 F12
    X13.1648 Y27.9313 Z-0.0626
    X13.1623 Y27.9287 Z-0.0714
    G3 X13.1563 Y27.9125 Z-0.0787 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X13.1783 Y27.8467
    X13.1819 Y27.8381
    X13.2187 Y27.8228
    X13.2556 Y27.8381
    X13.2813 Y27.9001
    X13.2812 Y27.9752
    X13.2557 Y28.0369
    X13.2187 Y28.0522
    X13.1819 Y28.0369
    X13.1563 Y27.9752
    Y27.9125
    G1 Y27.918
    G1 X13.181 Y27.9162
    G1 Z-0.0931 F12
    X13.1648 Y27.9313 Z-0.1019
    X13.1623 Y27.9287 Z-0.1108
    G3 X13.1563 Y27.9125 Z-0.1181 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X13.1783 Y27.8467
    X13.1819 Y27.8381
    X13.2187 Y27.8228
    X13.2556 Y27.8381
    X13.2813 Y27.9001
    X13.2812 Y27.9752
    X13.2557 Y28.0369
    X13.2187 Y28.0522
    X13.1819 Y28.0369
    X13.1563 Y27.9752
    Y27.9125
    G1 Y27.918
    G1 X13.181 Y27.9162
    G1 Z-0.1325 F12
    X13.1648 Y27.9313 Z-0.1413
    X13.1623 Y27.9287 Z-0.1502
    G3 X13.1563 Y27.9125 Z-0.1575 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X13.1783 Y27.8467
    X13.1819 Y27.8381
    X13.2187 Y27.8228
    X13.2556 Y27.8381
    X13.2813 Y27.9001
    X13.2812 Y27.9752
    X13.2557 Y28.0369
    X13.2187 Y28.0522
    X13.1819 Y28.0369
    X13.1563 Y27.9752
    Y27.9125
    G1 Y27.918
    G1 X13.181 Y27.9162
    G1 Z-0.1719 F12
    X13.1648 Y27.9313 Z-0.1807
    X13.1623 Y27.9287 Z-0.1895
    G3 X13.1563 Y27.9125 Z-0.1969 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X13.1783 Y27.8467
    X13.1819 Y27.8381
    X13.2187 Y27.8228
    X13.2556 Y27.8381
    X13.2813 Y27.9001
    X13.2812 Y27.9752
    X13.2557 Y28.0369
    X13.2187 Y28.0522
    X13.1819 Y28.0369
    X13.1563 Y27.9752
    Y27.9125
    G1 Y27.918
    G1 X13.181 Y27.9162
    G1 Z-0.2112 F12
    X13.1648 Y27.9313 Z-0.2201
    X13.1623 Y27.9287 Z-0.2289
    G3 X13.1563 Y27.9125 Z-0.2362 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X13.1783 Y27.8467
    X13.1819 Y27.8381
    X13.2187 Y27.8228
    X13.2556 Y27.8381
    X13.2813 Y27.9001
    X13.2812 Y27.9752
    X13.2557 Y28.0369
    X13.2187 Y28.0522
    X13.1819 Y28.0369
    X13.1563 Y27.9752
    Y27.9125
    G1 Y27.918
    G1 X13.181 Y27.9162
    G1 Z-0.2506 F12
    X13.1648 Y27.9313 Z-0.2594
    X13.1623 Y27.9287 Z-0.2683
    G3 X13.1563 Y27.9125 Z-0.2756 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X13.1783 Y27.8467
    X13.1819 Y27.8381
    X13.2187 Y27.8228
    X13.2556 Y27.8381
    X13.2813 Y27.9001
    X13.2812 Y27.9752
    X13.2557 Y28.0369
    X13.2187 Y28.0522
    X13.1819 Y28.0369
    X13.1563 Y27.9752
    Y27.9125
    G1 Y27.918
    G1 X13.181 Y27.9162
    G1 Z-0.29 F12
    X13.1648 Y27.9313 Z-0.2988
    X13.1623 Y27.9287 Z-0.3076
    G3 X13.1563 Y27.9125 Z-0.315 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X13.1783 Y27.8467
    X13.1819 Y27.8381
    X13.2187 Y27.8228
    X13.2556 Y27.8381
    X13.2813 Y27.9001
    X13.2812 Y27.9752
    X13.2557 Y28.0369
    X13.2187 Y28.0522
    X13.1819 Y28.0369
    X13.1563 Y27.9752
    Y27.9125
    G1 Y27.918
    G1 X13.181 Y27.9162
    G1 Z-0.3293 F12
    X13.1648 Y27.9313 Z-0.3382
    X13.1623 Y27.9287 Z-0.347
    G3 X13.1563 Y27.9125 Z-0.3543 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X13.1783 Y27.8467
    X13.1819 Y27.8381
    X13.2187 Y27.8228
    X13.2556 Y27.8381
    X13.2813 Y27.9001
    X13.2812 Y27.9752
    X13.2557 Y28.0369
    X13.2187 Y28.0522
    X13.1819 Y28.0369
    X13.1563 Y27.9752
    Y27.9125
    G1 Y27.918
    G1 X13.181 Y27.9162
    G1 Z-0.3687 F12
    X13.1648 Y27.9313 Z-0.3775
    X13.1623 Y27.9287 Z-0.3864
    G3 X13.1563 Y27.9125 Z-0.3937 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X13.1783 Y27.8467
    X13.1819 Y27.8381
    X13.2187 Y27.8228
    X13.2556 Y27.8381
    X13.2813 Y27.9001
    X13.2812 Y27.9752
    X13.2557 Y28.0369
    X13.2187 Y28.0522
    X13.1819 Y28.0369
    X13.1563 Y27.9752
    Y27.9125
    G1 Y27.918
    G1 X13.181 Y27.9162
    G1 Z-0.4081 F12
    X13.1648 Y27.9313 Z-0.4169
    X13.1623 Y27.9287 Z-0.4257
    G3 X13.1563 Y27.9125 Z-0.4331 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X13.1783 Y27.8467
    X13.1819 Y27.8381
    X13.2187 Y27.8228
    X13.2556 Y27.8381
    X13.2813 Y27.9001
    X13.2812 Y27.9752
    X13.2557 Y28.0369
    X13.2187 Y28.0522
    X13.1819 Y28.0369
    X13.1563 Y27.9752
    Y27.9125
    G1 Y27.918
    G1 X13.181 Y27.9162
    G1 Z-0.4474 F12
    X13.1648 Y27.9313 Z-0.4563
    X13.1623 Y27.9287 Z-0.4651
    G3 X13.1563 Y27.9125 Z-0.4724 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X13.1783 Y27.8467
    X13.1819 Y27.8381
    X13.2187 Y27.8228
    X13.2556 Y27.8381
    X13.2813 Y27.9001
    X13.2812 Y27.9752
    X13.2557 Y28.0369
    X13.2187 Y28.0522
    X13.1819 Y28.0369
    X13.1563 Y27.9752
    Y27.9125
    G1 Y27.918
    G1 X13.181 Y27.9162
    G1 Z-0.4868 F12
    X13.1648 Y27.9313 Z-0.4956
    X13.1623 Y27.9287 Z-0.5045
    G3 X13.1563 Y27.9125 Z-0.5118 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X13.1783 Y27.8467
    X13.1819 Y27.8381
    X13.2187 Y27.8228
    X13.2556 Y27.8381
    X13.2813 Y27.9001
    X13.2812 Y27.9752
    X13.2557 Y28.0369
    X13.2187 Y28.0522
    X13.1819 Y28.0369
    X13.1563 Y27.9752
    Y27.9125
    G1 Y27.918
    G1 X13.181 Y27.9162
    G1 Z-0.5262 F12
    X13.1648 Y27.9313 Z-0.535
    X13.1623 Y27.9287 Z-0.5439
    G3 X13.1563 Y27.9125 Z-0.5512 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X13.1783 Y27.8467
    X13.1819 Y27.8381
    X13.2187 Y27.8228
    X13.2556 Y27.8381
    X13.2813 Y27.9001
    X13.2812 Y27.9752
    X13.2557 Y28.0369
    X13.2187 Y28.0522
    X13.1819 Y28.0369
    X13.1563 Y27.9752
    Y27.9125
    G1 Y27.918
    G1 X13.181 Y27.9162
    G1 Z-0.5656 F12
    X13.1648 Y27.9313 Z-0.5744
    X13.1623 Y27.9287 Z-0.5832
    G3 X13.1563 Y27.9125 Z-0.5906 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X13.1783 Y27.8467
    X13.1819 Y27.8381
    X13.2187 Y27.8228
    X13.2556 Y27.8381
    X13.2813 Y27.9001
    X13.2812 Y27.9752
    X13.2557 Y28.0369
    X13.2187 Y28.0522
    X13.1819 Y28.0369
    X13.1563 Y27.9752
    Y27.9125
    G1 Y27.918
    G1 X13.181 Y27.9162
    G1 Z-0.6049 F12
    X13.1648 Y27.9313 Z-0.6138
    X13.1623 Y27.9287 Z-0.6226
    G3 X13.1563 Y27.9125 Z-0.6299 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X13.1783 Y27.8467
    X13.1819 Y27.8381
    X13.2187 Y27.8228
    X13.2556 Y27.8381
    X13.2813 Y27.9001
    X13.2812 Y27.9752
    X13.2557 Y28.0369
    X13.2187 Y28.0522
    X13.1819 Y28.0369
    X13.1563 Y27.9752
    Y27.9125
    G1 Y27.918
    G1 X13.181 Y27.9162
    G1 Z-0.6443 F12
    X13.1648 Y27.9313 Z-0.6531
    X13.1623 Y27.9287 Z-0.662
    G3 X13.1563 Y27.9125 Z-0.6693 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X13.1783 Y27.8467
    X13.1819 Y27.8381
    X13.2187 Y27.8228
    X13.2556 Y27.8381
    X13.2813 Y27.9001
    X13.2812 Y27.9752
    X13.2557 Y28.0369
    X13.2187 Y28.0522
    X13.1819 Y28.0369
    X13.1563 Y27.9752
    Y27.9125
    G1 Y27.9176
    G3 X13.1569 Y27.9216 I-0.0125 J0.0001
    X13.1752 Y27.9104 I0.0105 J-0.0035
    G1 X13.1807 Y27.9159
    G3 X13.1663 Y27.9325 I-0.0078 J0.0078
    G1 X13.1637 Y27.9303 Z-0.6775 F12
    X13.1615 Y27.9277 Z-0.6857
    G3 X13.1563 Y27.9125 Z-0.6925 I0.0198 J-0.0153
    G1 Y27.9001 F39.37
    X13.1783 Y27.8467
    X13.1819 Y27.8381
    X13.2187 Y27.8228
    X13.2556 Y27.8381
    X13.2813 Y27.9001
    X13.2812 Y27.9752
    X13.2557 Y28.0369
    X13.2187 Y28.0522
    X13.1819 Y28.0369
    X13.1563 Y27.9752
    Y27.9125
    G3 X13.1623 Y27.8962 Z-0.6852 I0.025
    G1 X13.1648 Y27.8936 Z-0.6763
    X13.1678 Y27.8915 Z-0.6675
    G0 Z0.2
    X11.6678 Y27.9348
    Z0.0787
    G1 Z-0.0144 F12
    X11.6648 Y27.9326 Z-0.0232
    X11.6623 Y27.93 Z-0.032
    G3 X11.6563 Y27.9137 Z-0.0394 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X11.6819 Y27.8381
    X11.7187 Y27.8228
    X11.7537 Y27.8373
    X11.7813 Y27.9007
    X11.7812 Y27.9752
    X11.7557 Y28.0369
    X11.7187 Y28.0522
    X11.6819 Y28.0369
    X11.6563 Y27.9752
    Y27.9137
    G3 X11.6813 Y27.9136 I0.0125
    G1 Y27.9194
    G3 X11.6571 Y27.9239 I-0.0125 J0.0001
    X11.6752 Y27.9113 I0.0107 J-0.004
    G1 X11.6813 Y27.9165
    G3 X11.6678 Y27.9348 I-0.0074 J0.0086
    G1 Z-0.0537 F12
    X11.6648 Y27.9326 Z-0.0626
    X11.6623 Y27.93 Z-0.0714
    G3 X11.6563 Y27.9137 Z-0.0787 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X11.6819 Y27.8381
    X11.7187 Y27.8228
    X11.7537 Y27.8373
    X11.7813 Y27.9007
    X11.7812 Y27.9752
    X11.7557 Y28.0369
    X11.7187 Y28.0522
    X11.6819 Y28.0369
    X11.6563 Y27.9752
    Y27.9137
    G1 Y27.9194
    G1 Z-0.0931 F12
    X11.6648 Y27.9326 Z-0.1019
    X11.6623 Y27.93 Z-0.1108
    G3 X11.6563 Y27.9137 Z-0.1181 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X11.6819 Y27.8381
    X11.7187 Y27.8228
    X11.7537 Y27.8373
    X11.7813 Y27.9007
    X11.7812 Y27.9752
    X11.7557 Y28.0369
    X11.7187 Y28.0522
    X11.6819 Y28.0369
    X11.6563 Y27.9752
    Y27.9137
    G1 Y27.9194
    G1 Z-0.1325 F12
    X11.6648 Y27.9326 Z-0.1413
    X11.6623 Y27.93 Z-0.1502
    G3 X11.6563 Y27.9137 Z-0.1575 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X11.6819 Y27.8381
    X11.7187 Y27.8228
    X11.7537 Y27.8373
    X11.7813 Y27.9007
    X11.7812 Y27.9752
    X11.7557 Y28.0369
    X11.7187 Y28.0522
    X11.6819 Y28.0369
    X11.6563 Y27.9752
    Y27.9137
    G1 Y27.9194
    G1 Z-0.1719 F12
    X11.6648 Y27.9326 Z-0.1807
    X11.6623 Y27.93 Z-0.1895
    G3 X11.6563 Y27.9137 Z-0.1969 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X11.6819 Y27.8381
    X11.7187 Y27.8228
    X11.7537 Y27.8373
    X11.7813 Y27.9007
    X11.7812 Y27.9752
    X11.7557 Y28.0369
    X11.7187 Y28.0522
    X11.6819 Y28.0369
    X11.6563 Y27.9752
    Y27.9137
    G1 Y27.9194
    G1 Z-0.2112 F12
    X11.6648 Y27.9326 Z-0.2201
    X11.6623 Y27.93 Z-0.2289
    G3 X11.6563 Y27.9137 Z-0.2362 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X11.6819 Y27.8381
    X11.7187 Y27.8228
    X11.7537 Y27.8373
    X11.7813 Y27.9007
    X11.7812 Y27.9752
    X11.7557 Y28.0369
    X11.7187 Y28.0522
    X11.6819 Y28.0369
    X11.6563 Y27.9752
    Y27.9137
    G1 Y27.9194
    G1 Z-0.2506 F12
    X11.6648 Y27.9326 Z-0.2594
    X11.6623 Y27.93 Z-0.2683
    G3 X11.6563 Y27.9137 Z-0.2756 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X11.6819 Y27.8381
    X11.7187 Y27.8228
    X11.7537 Y27.8373
    X11.7813 Y27.9007
    X11.7812 Y27.9752
    X11.7557 Y28.0369
    X11.7187 Y28.0522
    X11.6819 Y28.0369
    X11.6563 Y27.9752
    Y27.9137
    G1 Y27.9194
    G1 Z-0.29 F12
    X11.6648 Y27.9326 Z-0.2988
    X11.6623 Y27.93 Z-0.3076
    G3 X11.6563 Y27.9137 Z-0.315 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X11.6819 Y27.8381
    X11.7187 Y27.8228
    X11.7537 Y27.8373
    X11.7813 Y27.9007
    X11.7812 Y27.9752
    X11.7557 Y28.0369
    X11.7187 Y28.0522
    X11.6819 Y28.0369
    X11.6563 Y27.9752
    Y27.9137
    G1 Y27.9194
    G1 Z-0.3293 F12
    X11.6648 Y27.9326 Z-0.3382
    X11.6623 Y27.93 Z-0.347
    G3 X11.6563 Y27.9137 Z-0.3543 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X11.6819 Y27.8381
    X11.7187 Y27.8228
    X11.7537 Y27.8373
    X11.7813 Y27.9007
    X11.7812 Y27.9752
    X11.7557 Y28.0369
    X11.7187 Y28.0522
    X11.6819 Y28.0369
    X11.6563 Y27.9752
    Y27.9137
    G1 Y27.9194
    G1 Z-0.3687 F12
    X11.6648 Y27.9326 Z-0.3775
    X11.6623 Y27.93 Z-0.3864
    G3 X11.6563 Y27.9137 Z-0.3937 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X11.6819 Y27.8381
    X11.7187 Y27.8228
    X11.7537 Y27.8373
    X11.7813 Y27.9007
    X11.7812 Y27.9752
    X11.7557 Y28.0369
    X11.7187 Y28.0522
    X11.6819 Y28.0369
    X11.6563 Y27.9752
    Y27.9137
    G1 Y27.9194
    G1 Z-0.4081 F12
    X11.6648 Y27.9326 Z-0.4169
    X11.6623 Y27.93 Z-0.4257
    G3 X11.6563 Y27.9137 Z-0.4331 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X11.6819 Y27.8381
    X11.7187 Y27.8228
    X11.7537 Y27.8373
    X11.7813 Y27.9007
    X11.7812 Y27.9752
    X11.7557 Y28.0369
    X11.7187 Y28.0522
    X11.6819 Y28.0369
    X11.6563 Y27.9752
    Y27.9137
    G1 Y27.9194
    G1 Z-0.4474 F12
    X11.6648 Y27.9326 Z-0.4563
    X11.6623 Y27.93 Z-0.4651
    G3 X11.6563 Y27.9137 Z-0.4724 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X11.6819 Y27.8381
    X11.7187 Y27.8228
    X11.7537 Y27.8373
    X11.7813 Y27.9007
    X11.7812 Y27.9752
    X11.7557 Y28.0369
    X11.7187 Y28.0522
    X11.6819 Y28.0369
    X11.6563 Y27.9752
    Y27.9137
    G1 Y27.9194
    G1 Z-0.4868 F12
    X11.6648 Y27.9326 Z-0.4956
    X11.6623 Y27.93 Z-0.5045
    G3 X11.6563 Y27.9137 Z-0.5118 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X11.6819 Y27.8381
    X11.7187 Y27.8228
    X11.7537 Y27.8373
    X11.7813 Y27.9007
    X11.7812 Y27.9752
    X11.7557 Y28.0369
    X11.7187 Y28.0522
    X11.6819 Y28.0369
    X11.6563 Y27.9752
    Y27.9137
    G1 Y27.9194
    G1 Z-0.5262 F12
    X11.6648 Y27.9326 Z-0.535
    X11.6623 Y27.93 Z-0.5439
    G3 X11.6563 Y27.9137 Z-0.5512 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X11.6819 Y27.8381
    X11.7187 Y27.8228
    X11.7537 Y27.8373
    X11.7813 Y27.9007
    X11.7812 Y27.9752
    X11.7557 Y28.0369
    X11.7187 Y28.0522
    X11.6819 Y28.0369
    X11.6563 Y27.9752
    Y27.9137
    G1 Y27.9194
    G1 Z-0.5656 F12
    X11.6648 Y27.9326 Z-0.5744
    X11.6623 Y27.93 Z-0.5832
    G3 X11.6563 Y27.9137 Z-0.5906 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X11.6819 Y27.8381
    X11.7187 Y27.8228
    X11.7537 Y27.8373
    X11.7813 Y27.9007
    X11.7812 Y27.9752
    X11.7557 Y28.0369
    X11.7187 Y28.0522
    X11.6819 Y28.0369
    X11.6563 Y27.9752
    Y27.9137
    G1 Y27.9194
    G1 Z-0.6049 F12
    X11.6648 Y27.9326 Z-0.6138
    X11.6623 Y27.93 Z-0.6226
    G3 X11.6563 Y27.9137 Z-0.6299 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X11.6819 Y27.8381
    X11.7187 Y27.8228
    X11.7537 Y27.8373
    X11.7813 Y27.9007
    X11.7812 Y27.9752
    X11.7557 Y28.0369
    X11.7187 Y28.0522
    X11.6819 Y28.0369
    X11.6563 Y27.9752
    Y27.9137
    G1 Y27.9194
    G1 Z-0.6443 F12
    X11.6648 Y27.9326 Z-0.6531
    X11.6623 Y27.93 Z-0.662
    G3 X11.6563 Y27.9137 Z-0.6693 I0.019 J-0.0162
    G1 Y27.9001 F39.37
    X11.6819 Y27.8381
    X11.7187 Y27.8228
    X11.7537 Y27.8373
    X11.7813 Y27.9007
    X11.7812 Y27.9752
    X11.7557 Y28.0369
    X11.7187 Y28.0522
    X11.6819 Y28.0369
    X11.6563 Y27.9752
    Y27.9137
    G3 X11.6813 I0.0125
    G1 Y27.919
    G3 X11.657 Y27.9232 I-0.0125 J0.0001
    X11.6758 Y27.9111 I0.0108 J-0.0038
    G1 X11.6811 Y27.9163
    G3 X11.6663 Y27.9337 I-0.008 J0.0083
    G1 X11.6637 Y27.9315 Z-0.6775 F12
    X11.6615 Y27.929 Z-0.6857
    G3 X11.6563 Y27.9137 Z-0.6925 I0.0198 J-0.0153
    G1 Y27.9001 F39.37
    X11.6819 Y27.8381
    X11.7187 Y27.8228
    X11.7537 Y27.8373
    X11.7813 Y27.9007
    X11.7812 Y27.9752
    X11.7557 Y28.0369
    X11.7187 Y28.0522
    X11.6819 Y28.0369
    X11.6563 Y27.9752
    Y27.9137
    G3 X11.6623 Y27.8975 Z-0.6852 I0.025
    G1 X11.6648 Y27.8949 Z-0.6763
    X11.6678 Y27.8927 Z-0.6675
    G0 Z0.2
    X6.2261 Y27.9122
    Z0.0787
    G1 Z-0.0144 F12
    X6.2242 Y27.9091 Z-0.0232
    X6.2228 Y27.9057 Z-0.032
    G3 X6.2235 Y27.8884 Z-0.0394 I0.0238 J-0.0077
    G1 X6.2443 Y27.8381 F39.37
    X6.2813 Y27.8228
    X6.3181 Y27.8381
    X6.3437 Y27.8999
    X6.3432 Y27.9763
    X6.3181 Y28.0369
    X6.2813 Y28.0522
    X6.2447 Y28.0371
    X6.2187 Y27.972
    Y27.8999
    X6.2235 Y27.8884
    X6.2318 Y27.8995
    X6.2261 Y27.9122
    Z-0.0537 F12
    X6.2242 Y27.9091 Z-0.0626
    X6.2228 Y27.9057 Z-0.0714
    G3 X6.2235 Y27.8884 Z-0.0787 I0.0238 J-0.0077
    X6.2813 Y27.8228
    X6.3181 Y27.8381
    X6.3437 Y27.8999
    X6.3432 Y27.9763
    X6.3181 Y28.0369
    X6.2813 Y28.0522
    X6.2447 Y28.0371
    X6.2187 Y27.972
    Y27.8999
    X6.2235 Y27.8884
    X6.2318 Y27.8995
    X6.2261 Y27.9122
    Z-0.0931 F12
    X6.2242 Y27.9091 Z-0.1019
    X6.2228 Y27.9057 Z-0.1108
    G3 X6.2235 Y27.8884 Z-0.1181 I0.0238 J-0.0077
    X6.2813 Y27.8228
    X6.3181 Y27.8381
    X6.3437 Y27.8999
    X6.3432 Y27.9763
    X6.3181 Y28.0369
    X6.2813 Y28.0522
    X6.2447 Y28.0371
    X6.2187 Y27.972
    Y27.8999
    X6.2235 Y27.8884
    X6.2318 Y27.8995
    X6.2261 Y27.9122
    Z-0.1325 F12
    X6.2242 Y27.9091 Z-0.1413
    X6.2228 Y27.9057 Z-0.1502
    G3 X6.2235 Y27.8884 Z-0.1575 I0.0238 J-0.0077
    X6.2813 Y27.8228
    X6.3181 Y27.8381
    X6.3437 Y27.8999
    X6.3432 Y27.9763
    X6.3181 Y28.0369
    X6.2813 Y28.0522
    X6.2447 Y28.0371
    X6.2187 Y27.972
    Y27.8999
    X6.2235 Y27.8884
    X6.2318 Y27.8995
    X6.2261 Y27.9122
    Z-0.1719 F12
    X6.2242 Y27.9091 Z-0.1807
    X6.2228 Y27.9057 Z-0.1895
    G3 X6.2235 Y27.8884 Z-0.1969 I0.0238 J-0.0077
    X6.2813 Y27.8228
    X6.3181 Y27.8381
    X6.3437 Y27.8999
    X6.3432 Y27.9763
    X6.3181 Y28.0369
    X6.2813 Y28.0522
    X6.2447 Y28.0371
    X6.2187 Y27.972
    Y27.8999
    X6.2235 Y27.8884
    X6.2318 Y27.8995
    X6.2261 Y27.9122
    Z-0.2112 F12
    X6.2242 Y27.9091 Z-0.2201
    X6.2228 Y27.9057 Z-0.2289
    G3 X6.2235 Y27.8884 Z-0.2362 I0.0238 J-0.0077
    X6.2813 Y27.8228
    X6.3181 Y27.8381
    X6.3437 Y27.8999
    X6.3432 Y27.9763
    X6.3181 Y28.0369
    X6.2813 Y28.0522
    X6.2447 Y28.0371
    X6.2187 Y27.972
    Y27.8999
    X6.2235 Y27.8884
    X6.2318 Y27.8995
    X6.2261 Y27.9122
    Z-0.2506 F12
    X6.2242 Y27.9091 Z-0.2594
    X6.2228 Y27.9057 Z-0.2683
    G3 X6.2235 Y27.8884 Z-0.2756 I0.0238 J-0.0077
    X6.2813 Y27.8228
    X6.3181 Y27.8381
    X6.3437 Y27.8999
    X6.3432 Y27.9763
    X6.3181 Y28.0369
    X6.2813 Y28.0522
    X6.2447 Y28.0371
    X6.2187 Y27.972
    Y27.8999
    X6.2235 Y27.8884
    X6.2318 Y27.8995
    X6.2261 Y27.9122
    Z-0.29 F12
    X6.2242 Y27.9091 Z-0.2988
    X6.2228 Y27.9057 Z-0.3076
    G3 X6.2235 Y27.8884 Z-0.315 I0.0238 J-0.0077
    X6.2813 Y27.8228
    X6.3181 Y27.8381
    X6.3437 Y27.8999
    X6.3432 Y27.9763
    X6.3181 Y28.0369
    X6.2813 Y28.0522
    X6.2447 Y28.0371
    X6.2187 Y27.972
    Y27.8999
    X6.2235 Y27.8884
    X6.2318 Y27.8995
    X6.2261 Y27.9122
    Z-0.3293 F12
    X6.2242 Y27.9091 Z-0.3382
    X6.2228 Y27.9057 Z-0.347
    G3 X6.2235 Y27.8884 Z-0.3543 I0.0238 J-0.0077
    X6.2813 Y27.8228
    X6.3181 Y27.8381
    X6.3437 Y27.8999
    X6.3432 Y27.9763
    X6.3181 Y28.0369
    X6.2813 Y28.0522
    X6.2447 Y28.0371
    X6.2187 Y27.972
    Y27.8999
    X6.2235 Y27.8884
    X6.2318 Y27.8995
    X6.2261 Y27.9122
    Z-0.3687 F12
    X6.2242 Y27.9091 Z-0.3775
    X6.2228 Y27.9057 Z-0.3864
    G3 X6.2235 Y27.8884 Z-0.3937 I0.0238 J-0.0077
    X6.2813 Y27.8228
    X6.3181 Y27.8381
    X6.3437 Y27.8999
    X6.3432 Y27.9763
    X6.3181 Y28.0369
    X6.2813 Y28.0522
    X6.2447 Y28.0371
    X6.2187 Y27.972
    Y27.8999
    X6.2235 Y27.8884
    X6.2318 Y27.8995
    X6.2261 Y27.9122
    Z-0.4081 F12
    X6.2242 Y27.9091 Z-0.4169
    X6.2228 Y27.9057 Z-0.4257
    G3 X6.2235 Y27.8884 Z-0.4331 I0.0238 J-0.0077
    X6.2813 Y27.8228
    X6.3181 Y27.8381
    X6.3437 Y27.8999
    X6.3432 Y27.9763
    X6.3181 Y28.0369
    X6.2813 Y28.0522
    X6.2447 Y28.0371
    X6.2187 Y27.972
    Y27.8999
    X6.2235 Y27.8884
    X6.2318 Y27.8995
    X6.2261 Y27.9122
    Z-0.4474 F12
    X6.2242 Y27.9091 Z-0.4563
    X6.2228 Y27.9057 Z-0.4651
    G3 X6.2235 Y27.8884 Z-0.4724 I0.0238 J-0.0077
    X6.2813 Y27.8228
    X6.3181 Y27.8381
    X6.3437 Y27.8999
    X6.3432 Y27.9763
    X6.3181 Y28.0369
    X6.2813 Y28.0522
    X6.2447 Y28.0371
    X6.2187 Y27.972
    Y27.8999
    X6.2235 Y27.8884
    X6.2318 Y27.8995
    X6.2261 Y27.9122
    Z-0.4868 F12
    X6.2242 Y27.9091 Z-0.4956
    X6.2228 Y27.9057 Z-0.5045
    G3 X6.2235 Y27.8884 Z-0.5118 I0.0238 J-0.0077
    X6.2813 Y27.8228
    X6.3181 Y27.8381
    X6.3437 Y27.8999
    X6.3432 Y27.9763
    X6.3181 Y28.0369
    X6.2813 Y28.0522
    X6.2447 Y28.0371
    X6.2187 Y27.972
    Y27.8999
    X6.2235 Y27.8884
    X6.2318 Y27.8995
    X6.2261 Y27.9122
    Z-0.5262 F12
    X6.2242 Y27.9091 Z-0.535
    X6.2228 Y27.9057 Z-0.5439
    G3 X6.2235 Y27.8884 Z-0.5512 I0.0238 J-0.0077
    X6.2813 Y27.8228
    X6.3181 Y27.8381
    X6.3437 Y27.8999
    X6.3432 Y27.9763
    X6.3181 Y28.0369
    X6.2813 Y28.0522
    X6.2447 Y28.0371
    X6.2187 Y27.972
    Y27.8999
    X6.2235 Y27.8884
    X6.2318 Y27.8995
    X6.2261 Y27.9122
    Z-0.5656 F12
    X6.2242 Y27.9091 Z-0.5744
    X6.2228 Y27.9057 Z-0.5832
    G3 X6.2235 Y27.8884 Z-0.5906 I0.0238 J-0.0077
    X6.2813 Y27.8228
    X6.3181 Y27.8381
    X6.3437 Y27.8999
    X6.3432 Y27.9763
    X6.3181 Y28.0369
    X6.2813 Y28.0522
    X6.2447 Y28.0371
    X6.2187 Y27.972
    Y27.8999
    X6.2235 Y27.8884
    X6.2318 Y27.8995
    X6.2261 Y27.9122
    Z-0.6049 F12
    X6.2242 Y27.9091 Z-0.6138
    X6.2228 Y27.9057 Z-0.6226
    G3 X6.2235 Y27.8884 Z-0.6299 I0.0238 J-0.0077
    X6.2813 Y27.8228
    X6.3181 Y27.8381
    X6.3437 Y27.8999
    X6.3432 Y27.9763
    X6.3181 Y28.0369
    X6.2813 Y28.0522
    X6.2447 Y28.0371
    X6.2187 Y27.972
    Y27.8999
    X6.2235 Y27.8884
    X6.2318 Y27.8995
    X6.2261 Y27.9122
    Z-0.6443 F12
    X6.2242 Y27.9091 Z-0.6531
    X6.2228 Y27.9057 Z-0.662
    G3 X6.2235 Y27.8884 Z-0.6693 I0.0238 J-0.0077
    X6.2813 Y27.8228
    X6.3181 Y27.8381
    X6.3437 Y27.8999
    X6.3432 Y27.9763
    X6.3181 Y28.0369
    X6.2813 Y28.0522
    X6.2447 Y28.0371
    X6.2187 Y27.972
    Y27.8999
    X6.2235 Y27.8884
    X6.2312 Y27.8991
    X6.2251 Y27.9107
    X6.2236 Y27.9077 Z-0.6775 F12
    X6.2225 Y27.9045 Z-0.6857
    G3 X6.2235 Y27.8884 Z-0.6925 I0.0241 J-0.0065
    X6.2813 Y27.8228
    X6.3181 Y27.8381
    X6.3437 Y27.8999
    X6.3432 Y27.9763
    X6.3181 Y28.0369
    X6.2813 Y28.0522
    X6.2447 Y28.0371
    X6.2187 Y27.972
    Y27.8999
    X6.2235 Y27.8884
    G3 X6.2352 Y27.8757 Z-0.6852 I0.0231 J0.0096
    G1 X6.2386 Y27.8743 Z-0.6763
    X6.2422 Y27.8734 Z-0.6675
    G0 Z0.2
    X4.8322 Y27.8915
    Z0.0787
    G1 Z-0.0144 F12
    X4.8352 Y27.8937 Z-0.0232
    X4.8377 Y27.8963 Z-0.032
    G3 X4.8437 Y27.9125 Z-0.0394 I-0.019 J0.0162
    G1 Y27.9737 F39.37
    X4.818 Y28.037
    X4.7813 Y28.0522
    X4.7443 Y28.0369
    X4.7187 Y27.9751
    Y27.9
    X4.7275 Y27.8786
    X4.7443 Y27.8381
    X4.7813 Y27.8228
    X4.8181 Y27.8381
    X4.8437 Y27.9001
    Y27.9125
    X4.8318 Y27.9054
    X4.8322 Y27.8915
    Z-0.0537 F12
    X4.8352 Y27.8937 Z-0.0626
    X4.8377 Y27.8963 Z-0.0714
    G3 X4.8437 Y27.9125 Z-0.0787 I-0.019 J0.0162
    G1 Y27.9737 F39.37
    X4.818 Y28.037
    X4.7813 Y28.0522
    X4.7443 Y28.0369
    X4.7187 Y27.9751
    Y27.9
    X4.7275 Y27.8786
    X4.7443 Y27.8381
    X4.7813 Y27.8228
    X4.8181 Y27.8381
    X4.8437 Y27.9001
    Y27.9125
    X4.8318 Y27.9054
    X4.8322 Y27.8915
    Z-0.0931 F12
    X4.8352 Y27.8937 Z-0.1019
    X4.8377 Y27.8963 Z-0.1108
    G3 X4.8437 Y27.9125 Z-0.1181 I-0.019 J0.0162
    G1 Y27.9737 F39.37
    X4.818 Y28.037
    X4.7813 Y28.0522
    X4.7443 Y28.0369
    X4.7187 Y27.9751
    Y27.9
    X4.7275 Y27.8786
    X4.7443 Y27.8381
    X4.7813 Y27.8228
    X4.8181 Y27.8381
    X4.8437 Y27.9001
    Y27.9125
    X4.8318 Y27.9054
    X4.8322 Y27.8915
    Z-0.1325 F12
    X4.8352 Y27.8937 Z-0.1413
    X4.8377 Y27.8963 Z-0.1502
    G3 X4.8437 Y27.9125 Z-0.1575 I-0.019 J0.0162
    G1 Y27.9737 F39.37
    X4.818 Y28.037
    X4.7813 Y28.0522
    X4.7443 Y28.0369
    X4.7187 Y27.9751
    Y27.9
    X4.7275 Y27.8786
    X4.7443 Y27.8381
    X4.7813 Y27.8228
    X4.8181 Y27.8381
    X4.8437 Y27.9001
    Y27.9125
    X4.8318 Y27.9054
    X4.8322 Y27.8915
    Z-0.1719 F12
    X4.8352 Y27.8937 Z-0.1807
    X4.8377 Y27.8963 Z-0.1895
    G3 X4.8437 Y27.9125 Z-0.1969 I-0.019 J0.0162
    G1 Y27.9737 F39.37
    X4.818 Y28.037
    X4.7813 Y28.0522
    X4.7443 Y28.0369
    X4.7187 Y27.9751
    Y27.9
    X4.7275 Y27.8786
    X4.7443 Y27.8381
    X4.7813 Y27.8228
    X4.8181 Y27.8381
    X4.8437 Y27.9001
    Y27.9125
    X4.8318 Y27.9054
    X4.8322 Y27.8915
    Z-0.2112 F12
    X4.8352 Y27.8937 Z-0.2201
    X4.8377 Y27.8963 Z-0.2289
    G3 X4.8437 Y27.9125 Z-0.2362 I-0.019 J0.0162
    G1 Y27.9737 F39.37
    X4.818 Y28.037
    X4.7813 Y28.0522
    X4.7443 Y28.0369
    X4.7187 Y27.9751
    Y27.9
    X4.7275 Y27.8786
    X4.7443 Y27.8381
    X4.7813 Y27.8228
    X4.8181 Y27.8381
    X4.8437 Y27.9001
    Y27.9125
    X4.8318 Y27.9054
    X4.8322 Y27.8915
    Z-0.2506 F12
    X4.8352 Y27.8937 Z-0.2594
    X4.8377 Y27.8963 Z-0.2683
    G3 X4.8437 Y27.9125 Z-0.2756 I-0.019 J0.0162
    G1 Y27.9737 F39.37
    X4.818 Y28.037
    X4.7813 Y28.0522
    X4.7443 Y28.0369
    X4.7187 Y27.9751
    Y27.9
    X4.7275 Y27.8786
    X4.7443 Y27.8381
    X4.7813 Y27.8228
    X4.8181 Y27.8381
    X4.8437 Y27.9001
    Y27.9125
    X4.8318 Y27.9054
    X4.8322 Y27.8915
    Z-0.29 F12
    X4.8352 Y27.8937 Z-0.2988
    X4.8377 Y27.8963 Z-0.3076
    G3 X4.8437 Y27.9125 Z-0.315 I-0.019 J0.0162
    G1 Y27.9737 F39.37
    X4.818 Y28.037
    X4.7813 Y28.0522
    X4.7443 Y28.0369
    X4.7187 Y27.9751
    Y27.9
    X4.7275 Y27.8786
    X4.7443 Y27.8381
    X4.7813 Y27.8228
    X4.8181 Y27.8381
    X4.8437 Y27.9001
    Y27.9125
    X4.8318 Y27.9054
    X4.8322 Y27.8915
    Z-0.3293 F12
    X4.8352 Y27.8937 Z-0.3382
    X4.8377 Y27.8963 Z-0.347
    G3 X4.8437 Y27.9125 Z-0.3543 I-0.019 J0.0162
    G1 Y27.9737 F39.37
    X4.818 Y28.037
    X4.7813 Y28.0522
    X4.7443 Y28.0369
    X4.7187 Y27.9751
    Y27.9
    X4.7275 Y27.8786
    X4.7443 Y27.8381
    X4.7813 Y27.8228
    X4.8181 Y27.8381
    X4.8437 Y27.9001
    Y27.9125
    X4.8318 Y27.9054
    X4.8322 Y27.8915
    Z-0.3687 F12
    X4.8352 Y27.8937 Z-0.3775
    X4.8377 Y27.8963 Z-0.3864
    G3 X4.8437 Y27.9125 Z-0.3937 I-0.019 J0.0162
    G1 Y27.9737 F39.37
    X4.818 Y28.037
    X4.7813 Y28.0522
    X4.7443 Y28.0369
    X4.7187 Y27.9751
    Y27.9
    X4.7275 Y27.8786
    X4.7443 Y27.8381
    X4.7813 Y27.8228
    X4.8181 Y27.8381
    X4.8437 Y27.9001
    Y27.9125
    X4.8318 Y27.9054
    X4.8322 Y27.8915
    Z-0.4081 F12
    X4.8352 Y27.8937 Z-0.4169
    X4.8377 Y27.8963 Z-0.4257
    G3 X4.8437 Y27.9125 Z-0.4331 I-0.019 J0.0162
    G1 Y27.9737 F39.37
    X4.818 Y28.037
    X4.7813 Y28.0522
    X4.7443 Y28.0369
    X4.7187 Y27.9751
    Y27.9
    X4.7275 Y27.8786
    X4.7443 Y27.8381
    X4.7813 Y27.8228
    X4.8181 Y27.8381
    X4.8437 Y27.9001
    Y27.9125
    X4.8318 Y27.9054
    X4.8322 Y27.8915
    Z-0.4474 F12
    X4.8352 Y27.8937 Z-0.4563
    X4.8377 Y27.8963 Z-0.4651
    G3 X4.8437 Y27.9125 Z-0.4724 I-0.019 J0.0162
    G1 Y27.9737 F39.37
    X4.818 Y28.037
    X4.7813 Y28.0522
    X4.7443 Y28.0369
    X4.7187 Y27.9751
    Y27.9
    X4.7275 Y27.8786
    X4.7443 Y27.8381
    X4.7813 Y27.8228
    X4.8181 Y27.8381
    X4.8437 Y27.9001
    Y27.9125
    X4.8318 Y27.9054
    X4.8322 Y27.8915
    Z-0.4868 F12
    X4.8352 Y27.8937 Z-0.4956
    X4.8377 Y27.8963 Z-0.5045
    G3 X4.8437 Y27.9125 Z-0.5118 I-0.019 J0.0162
    G1 Y27.9737 F39.37
    X4.818 Y28.037
    X4.7813 Y28.0522
    X4.7443 Y28.0369
    X4.7187 Y27.9751
    Y27.9
    X4.7275 Y27.8786
    X4.7443 Y27.8381
    X4.7813 Y27.8228
    X4.8181 Y27.8381
    X4.8437 Y27.9001
    Y27.9125
    X4.8318 Y27.9054
    X4.8322 Y27.8915
    Z-0.5262 F12
    X4.8352 Y27.8937 Z-0.535
    X4.8377 Y27.8963 Z-0.5439
    G3 X4.8437 Y27.9125 Z-0.5512 I-0.019 J0.0162
    G1 Y27.9737 F39.37
    X4.818 Y28.037
    X4.7813 Y28.0522
    X4.7443 Y28.0369
    X4.7187 Y27.9751
    Y27.9
    X4.7275 Y27.8786
    X4.7443 Y27.8381
    X4.7813 Y27.8228
    X4.8181 Y27.8381
    X4.8437 Y27.9001
    Y27.9125
    X4.8318 Y27.9054
    X4.8322 Y27.8915
    Z-0.5656 F12
    X4.8352 Y27.8937 Z-0.5744
    X4.8377 Y27.8963 Z-0.5832
    G3 X4.8437 Y27.9125 Z-0.5906 I-0.019 J0.0162
    G1 Y27.9737 F39.37
    X4.818 Y28.037
    X4.7813 Y28.0522
    X4.7443 Y28.0369
    X4.7187 Y27.9751
    Y27.9
    X4.7275 Y27.8786
    X4.7443 Y27.8381
    X4.7813 Y27.8228
    X4.8181 Y27.8381
    X4.8437 Y27.9001
    Y27.9125
    X4.8318 Y27.9054
    X4.8322 Y27.8915
    Z-0.6049 F12
    X4.8352 Y27.8937 Z-0.6138
    X4.8377 Y27.8963 Z-0.6226
    G3 X4.8437 Y27.9125 Z-0.6299 I-0.019 J0.0162
    G1 Y27.9737 F39.37
    X4.818 Y28.037
    X4.7813 Y28.0522
    X4.7443 Y28.0369
    X4.7187 Y27.9751
    Y27.9
    X4.7275 Y27.8786
    X4.7443 Y27.8381
    X4.7813 Y27.8228
    X4.8181 Y27.8381
    X4.8437 Y27.9001
    Y27.9125
    X4.8318 Y27.9054
    X4.8322 Y27.8915
    Z-0.6443 F12
    X4.8352 Y27.8937 Z-0.6531
    X4.8377 Y27.8963 Z-0.662
    G3 X4.8437 Y27.9125 Z-0.6693 I-0.019 J0.0162
    G1 Y27.9737 F39.37
    X4.818 Y28.037
    X4.7813 Y28.0522
    X4.7443 Y28.0369
    X4.7187 Y27.9751
    Y27.9
    X4.7275 Y27.8786
    X4.7443 Y27.8381
    X4.7813 Y27.8228
    X4.8181 Y27.8381
    X4.8437 Y27.9001
    Y27.9125
    X4.8325 Y27.9056
    X4.8337 Y27.8925
    X4.8363 Y27.8947 Z-0.6775 F12
    X4.8385 Y27.8972 Z-0.6857
    G3 X4.8437 Y27.9125 Z-0.6925 I-0.0198 J0.0153
    G1 Y27.9737 F39.37
    X4.818 Y28.037
    X4.7813 Y28.0522
    X4.7443 Y28.0369
    X4.7187 Y27.9751
    Y27.9
    X4.7275 Y27.8786
    X4.7443 Y27.8381
    X4.7813 Y27.8228
    X4.8181 Y27.8381
    X4.8437 Y27.9001
    Y27.9125
    G3 X4.8377 Y27.9287 Z-0.6852 I-0.025
    G1 X4.8352 Y27.9313 Z-0.6763
    X4.8322 Y27.9335 Z-0.6675
    G0 Z0.2
    X3.8351 Y27.0467
    Z0.0787
    G1 Z-0.0144 F12
    X3.8328 Y27.0496 Z-0.0232
    X3.8302 Y27.0521 Z-0.032
    G3 X3.814 Y27.058 Z-0.0394 I-0.0161 J-0.0191
    G1 X3.7411 Y27.0576 F39.37
    X3.6967 Y27.042
    X3.6854 Y27.0265
    Y27.0052
    X3.6976 Y26.9883
    X3.7406 Y26.9736
    X3.8208 Y26.9732
    X3.8642 Y26.9873
    X3.8771 Y27.0052
    Y27.0265
    X3.8644 Y27.0439
    X3.8208 Y27.0581
    X3.814 Y27.058
    X3.8211 Y27.0461
    X3.8351 Y27.0467
    Z-0.0537 F12
    X3.8328 Y27.0496 Z-0.0626
    X3.8302 Y27.0521 Z-0.0714
    G3 X3.814 Y27.058 Z-0.0787 I-0.0161 J-0.0191
    X3.6967 Y27.042
    X3.6854 Y27.0265
    Y27.0052
    X3.6976 Y26.9883
    X3.7406 Y26.9736
    X3.8208 Y26.9732
    X3.8642 Y26.9873
    X3.8771 Y27.0052
    Y27.0265
    X3.8644 Y27.0439
    X3.8208 Y27.0581
    X3.814 Y27.058
    X3.8211 Y27.0461
    X3.8351 Y27.0467
    Z-0.0931 F12
    X3.8328 Y27.0496 Z-0.1019
    X3.8302 Y27.0521 Z-0.1108
    G3 X3.814 Y27.058 Z-0.1181 I-0.0161 J-0.0191
    X3.6967 Y27.042
    X3.6854 Y27.0265
    Y27.0052
    X3.6976 Y26.9883
    X3.7406 Y26.9736
    X3.8208 Y26.9732
    X3.8642 Y26.9873
    X3.8771 Y27.0052
    Y27.0265
    X3.8644 Y27.0439
    X3.8208 Y27.0581
    X3.814 Y27.058
    X3.8211 Y27.0461
    X3.8351 Y27.0467
    Z-0.1325 F12
    X3.8328 Y27.0496 Z-0.1413
    X3.8302 Y27.0521 Z-0.1502
    G3 X3.814 Y27.058 Z-0.1575 I-0.0161 J-0.0191
    X3.6967 Y27.042
    X3.6854 Y27.0265
    Y27.0052
    X3.6976 Y26.9883
    X3.7406 Y26.9736
    X3.8208 Y26.9732
    X3.8642 Y26.9873
    X3.8771 Y27.0052
    Y27.0265
    X3.8644 Y27.0439
    X3.8208 Y27.0581
    X3.814 Y27.058
    X3.8211 Y27.0461
    X3.8351 Y27.0467
    Z-0.1719 F12
    X3.8328 Y27.0496 Z-0.1807
    X3.8302 Y27.0521 Z-0.1895
    G3 X3.814 Y27.058 Z-0.1969 I-0.0161 J-0.0191
    X3.6967 Y27.042
    X3.6854 Y27.0265
    Y27.0052
    X3.6976 Y26.9883
    X3.7406 Y26.9736
    X3.8208 Y26.9732
    X3.8642 Y26.9873
    X3.8771 Y27.0052
    Y27.0265
    X3.8644 Y27.0439
    X3.8208 Y27.0581
    X3.814 Y27.058
    X3.8211 Y27.0461
    X3.8351 Y27.0467
    Z-0.2112 F12
    X3.8328 Y27.0496 Z-0.2201
    X3.8302 Y27.0521 Z-0.2289
    G3 X3.814 Y27.058 Z-0.2362 I-0.0161 J-0.0191
    X3.6967 Y27.042
    X3.6854 Y27.0265
    Y27.0052
    X3.6976 Y26.9883
    X3.7406 Y26.9736
    X3.8208 Y26.9732
    X3.8642 Y26.9873
    X3.8771 Y27.0052
    Y27.0265
    X3.8644 Y27.0439
    X3.8208 Y27.0581
    X3.814 Y27.058
    X3.8211 Y27.0461
    X3.8351 Y27.0467
    Z-0.2506 F12
    X3.8328 Y27.0496 Z-0.2594
    X3.8302 Y27.0521 Z-0.2683
    G3 X3.814 Y27.058 Z-0.2756 I-0.0161 J-0.0191
    X3.6967 Y27.042
    X3.6854 Y27.0265
    Y27.0052
    X3.6976 Y26.9883
    X3.7406 Y26.9736
    X3.8208 Y26.9732
    X3.8642 Y26.9873
    X3.8771 Y27.0052
    Y27.0265
    X3.8644 Y27.0439
    X3.8208 Y27.0581
    X3.814 Y27.058
    X3.8211 Y27.0461
    X3.8351 Y27.0467
    Z-0.29 F12
    X3.8328 Y27.0496 Z-0.2988
    X3.8302 Y27.0521 Z-0.3076
    G3 X3.814 Y27.058 Z-0.315 I-0.0161 J-0.0191
    X3.6967 Y27.042
    X3.6854 Y27.0265
    Y27.0052
    X3.6976 Y26.9883
    X3.7406 Y26.9736
    X3.8208 Y26.9732
    X3.8642 Y26.9873
    X3.8771 Y27.0052
    Y27.0265
    X3.8644 Y27.0439
    X3.8208 Y27.0581
    X3.814 Y27.058
    X3.8211 Y27.0461
    X3.8351 Y27.0467
    Z-0.3293 F12
    X3.8328 Y27.0496 Z-0.3382
    X3.8302 Y27.0521 Z-0.347
    G3 X3.814 Y27.058 Z-0.3543 I-0.0161 J-0.0191
    X3.6967 Y27.042
    X3.6854 Y27.0265
    Y27.0052
    X3.6976 Y26.9883
    X3.7406 Y26.9736
    X3.8208 Y26.9732
    X3.8642 Y26.9873
    X3.8771 Y27.0052
    Y27.0265
    X3.8644 Y27.0439
    X3.8208 Y27.0581
    X3.814 Y27.058
    X3.8211 Y27.0461
    X3.8351 Y27.0467
    Z-0.3687 F12
    X3.8328 Y27.0496 Z-0.3775
    X3.8302 Y27.0521 Z-0.3864
    G3 X3.814 Y27.058 Z-0.3937 I-0.0161 J-0.0191
    X3.6967 Y27.042
    X3.6854 Y27.0265
    Y27.0052
    X3.6976 Y26.9883
    X3.7406 Y26.9736
    X3.8208 Y26.9732
    X3.8642 Y26.9873
    X3.8771 Y27.0052
    Y27.0265
    X3.8644 Y27.0439
    X3.8208 Y27.0581
    X3.814 Y27.058
    X3.8211 Y27.0461
    X3.8351 Y27.0467
    Z-0.4081 F12
    X3.8328 Y27.0496 Z-0.4169
    X3.8302 Y27.0521 Z-0.4257
    G3 X3.814 Y27.058 Z-0.4331 I-0.0161 J-0.0191
    X3.6967 Y27.042
    X3.6854 Y27.0265
    Y27.0052
    X3.6976 Y26.9883
    X3.7406 Y26.9736
    X3.8208 Y26.9732
    X3.8642 Y26.9873
    X3.8771 Y27.0052
    Y27.0265
    X3.8644 Y27.0439
    X3.8208 Y27.0581
    X3.814 Y27.058
    X3.8211 Y27.0461
    X3.8351 Y27.0467
    Z-0.4474 F12
    X3.8328 Y27.0496 Z-0.4563
    X3.8302 Y27.0521 Z-0.4651
    G3 X3.814 Y27.058 Z-0.4724 I-0.0161 J-0.0191
    X3.6967 Y27.042
    X3.6854 Y27.0265
    Y27.0052
    X3.6976 Y26.9883
    X3.7406 Y26.9736
    X3.8208 Y26.9732
    X3.8642 Y26.9873
    X3.8771 Y27.0052
    Y27.0265
    X3.8644 Y27.0439
    X3.8208 Y27.0581
    X3.814 Y27.058
    X3.8211 Y27.0461
    X3.8351 Y27.0467
    Z-0.4868 F12
    X3.8328 Y27.0496 Z-0.4956
    X3.8302 Y27.0521 Z-0.5045
    G3 X3.814 Y27.058 Z-0.5118 I-0.0161 J-0.0191
    X3.6967 Y27.042
    X3.6854 Y27.0265
    Y27.0052
    X3.6976 Y26.9883
    X3.7406 Y26.9736
    X3.8208 Y26.9732
    X3.8642 Y26.9873
    X3.8771 Y27.0052
    Y27.0265
    X3.8644 Y27.0439
    X3.8208 Y27.0581
    X3.814 Y27.058
    X3.8211 Y27.0461
    X3.8351 Y27.0467
    Z-0.5262 F12
    X3.8328 Y27.0496 Z-0.535
    X3.8302 Y27.0521 Z-0.5439
    G3 X3.814 Y27.058 Z-0.5512 I-0.0161 J-0.0191
    X3.6967 Y27.042
    X3.6854 Y27.0265
    Y27.0052
    X3.6976 Y26.9883
    X3.7406 Y26.9736
    X3.8208 Y26.9732
    X3.8642 Y26.9873
    X3.8771 Y27.0052
    Y27.0265
    X3.8644 Y27.0439
    X3.8208 Y27.0581
    X3.814 Y27.058
    X3.8211 Y27.0461
    X3.8351 Y27.0467
    Z-0.5656 F12
    X3.8328 Y27.0496 Z-0.5744
    X3.8302 Y27.0521 Z-0.5832
    G3 X3.814 Y27.058 Z-0.5906 I-0.0161 J-0.0191
    X3.6967 Y27.042
    X3.6854 Y27.0265
    Y27.0052
    X3.6976 Y26.9883
    X3.7406 Y26.9736
    X3.8208 Y26.9732
    X3.8642 Y26.9873
    X3.8771 Y27.0052
    Y27.0265
    X3.8644 Y27.0439
    X3.8208 Y27.0581
    X3.814 Y27.058
    X3.8211 Y27.0461
    X3.8351 Y27.0467
    Z-0.6049 F12
    X3.8328 Y27.0496 Z-0.6138
    X3.8302 Y27.0521 Z-0.6226
    G3 X3.814 Y27.058 Z-0.6299 I-0.0161 J-0.0191
    X3.6967 Y27.042
    X3.6854 Y27.0265
    Y27.0052
    X3.6976 Y26.9883
    X3.7406 Y26.9736
    X3.8208 Y26.9732
    X3.8642 Y26.9873
    X3.8771 Y27.0052
    Y27.0265
    X3.8644 Y27.0439
    X3.8208 Y27.0581
    X3.814 Y27.058
    G3 X3.8111 Y27.0468 J-0.006
    G1 X3.8272 Y27.0381
    G3 X3.8351 Y27.0467 I0.0028 J0.0053
    G1 Z-0.6443 F12
    X3.8328 Y27.0496 Z-0.6531
    X3.8302 Y27.0521 Z-0.662
    G3 X3.814 Y27.058 Z-0.6693 I-0.0161 J-0.0191
    X3.6967 Y27.042
    X3.6854 Y27.0265
    Y27.0052
    X3.6976 Y26.9883
    X3.7406 Y26.9736
    X3.8208 Y26.9732
    X3.8642 Y26.9873
    X3.8771 Y27.0052
    Y27.0265
    X3.8644 Y27.0439
    X3.8208 Y27.0581
    X3.814 Y27.058
    G3 X3.8115 Y27.0474 J-0.0056
    G1 X3.8271 Y27.0397
    G3 X3.834 Y27.0481 I0.0025 J0.005
    G1 X3.8318 Y27.0507 Z-0.6775 F12
    X3.8292 Y27.0529 Z-0.6857
    G3 X3.814 Y27.058 Z-0.6925 I-0.0151 J-0.0199
    X3.6967 Y27.042
    X3.6854 Y27.0265
    Y27.0052
    X3.6976 Y26.9883
    X3.7406 Y26.9736
    X3.8208 Y26.9732
    X3.8642 Y26.9873
    X3.8771 Y27.0052
    Y27.0265
    X3.8644 Y27.0439
    X3.8208 Y27.0581
    X3.814 Y27.058
    G3 X3.7977 Y27.0519 Z-0.6852 I0.0001 J-0.025
    G1 X3.7952 Y27.0494 Z-0.6763
    X3.793 Y27.0464 Z-0.6675
    G0 Z0.2
    X3.8437 Y25.5385
    Z0.0787
    G1 Z-0.0144 F12
    X3.8425 Y25.542 Z-0.0232
    X3.8409 Y25.5453 Z-0.032
    G3 X3.8272 Y25.556 Z-0.0394 I-0.0213 J-0.0131
    G1 X3.8208 Y25.5581 F39.37
    X3.7407 Y25.5576
    X3.6978 Y25.5429
    X3.6854 Y25.5253
    Y25.5048
    X3.6969 Y25.4891
    X3.741 Y25.4736
    X3.8208 Y25.4732
    X3.8644 Y25.4873
    X3.8771 Y25.5048
    Y25.5253
    X3.864 Y25.5441
    X3.8272 Y25.556
    G3 X3.821 Y25.5461 I-0.0018 J-0.0057
    G1 X3.8336 Y25.5329
    G3 X3.8437 Y25.5385 I0.0044 J0.0041
    G1 Z-0.0537 F12
    X3.8425 Y25.542 Z-0.0626
    X3.8409 Y25.5453 Z-0.0714
    G3 X3.8272 Y25.556 Z-0.0787 I-0.0213 J-0.0131
    X3.7407 Y25.5576
    X3.6978 Y25.5429
    X3.6854 Y25.5253
    Y25.5048
    X3.6969 Y25.4891
    X3.741 Y25.4736
    X3.8208 Y25.4732
    X3.8644 Y25.4873
    X3.8771 Y25.5048
    Y25.5253
    X3.864 Y25.5441
    X3.8272 Y25.556
    G1 X3.8336 Y25.5329
    G1 Z-0.0931 F12
    X3.8425 Y25.542 Z-0.1019
    X3.8409 Y25.5453 Z-0.1108
    G3 X3.8272 Y25.556 Z-0.1181 I-0.0213 J-0.0131
    X3.7407 Y25.5576
    X3.6978 Y25.5429
    X3.6854 Y25.5253
    Y25.5048
    X3.6969 Y25.4891
    X3.741 Y25.4736
    X3.8208 Y25.4732
    X3.8644 Y25.4873
    X3.8771 Y25.5048
    Y25.5253
    X3.864 Y25.5441
    X3.8272 Y25.556
    G1 X3.8336 Y25.5329
    G1 Z-0.1325 F12
    X3.8425 Y25.542 Z-0.1413
    X3.8409 Y25.5453 Z-0.1502
    G3 X3.8272 Y25.556 Z-0.1575 I-0.0213 J-0.0131
    X3.7407 Y25.5576
    X3.6978 Y25.5429
    X3.6854 Y25.5253
    Y25.5048
    X3.6969 Y25.4891
    X3.741 Y25.4736
    X3.8208 Y25.4732
    X3.8644 Y25.4873
    X3.8771 Y25.5048
    Y25.5253
    X3.864 Y25.5441
    X3.8272 Y25.556
    G1 X3.8336 Y25.5329
    G1 Z-0.1719 F12
    X3.8425 Y25.542 Z-0.1807
    X3.8409 Y25.5453 Z-0.1895
    G3 X3.8272 Y25.556 Z-0.1969 I-0.0213 J-0.0131
    X3.7407 Y25.5576
    X3.6978 Y25.5429
    X3.6854 Y25.5253
    Y25.5048
    X3.6969 Y25.4891
    X3.741 Y25.4736
    X3.8208 Y25.4732
    X3.8644 Y25.4873
    X3.8771 Y25.5048
    Y25.5253
    X3.864 Y25.5441
    X3.8272 Y25.556
    G1 X3.8336 Y25.5329
    G1 Z-0.2112 F12
    X3.8425 Y25.542 Z-0.2201
    X3.8409 Y25.5453 Z-0.2289
    G3 X3.8272 Y25.556 Z-0.2362 I-0.0213 J-0.0131
    X3.7407 Y25.5576
    X3.6978 Y25.5429
    X3.6854 Y25.5253
    Y25.5048
    X3.6969 Y25.4891
    X3.741 Y25.4736
    X3.8208 Y25.4732
    X3.8644 Y25.4873
    X3.8771 Y25.5048
    Y25.5253
    X3.864 Y25.5441
    X3.8272 Y25.556
    G1 X3.8336 Y25.5329
    G1 Z-0.2506 F12
    X3.8425 Y25.542 Z-0.2594
    X3.8409 Y25.5453 Z-0.2683
    G3 X3.8272 Y25.556 Z-0.2756 I-0.0213 J-0.0131
    X3.7407 Y25.5576
    X3.6978 Y25.5429
    X3.6854 Y25.5253
    Y25.5048
    X3.6969 Y25.4891
    X3.741 Y25.4736
    X3.8208 Y25.4732
    X3.8644 Y25.4873
    X3.8771 Y25.5048
    Y25.5253
    X3.864 Y25.5441
    X3.8272 Y25.556
    G1 X3.8336 Y25.5329
    G1 Z-0.29 F12
    X3.8425 Y25.542 Z-0.2988
    X3.8409 Y25.5453 Z-0.3076
    G3 X3.8272 Y25.556 Z-0.315 I-0.0213 J-0.0131
    X3.7407 Y25.5576
    X3.6978 Y25.5429
    X3.6854 Y25.5253
    Y25.5048
    X3.6969 Y25.4891
    X3.741 Y25.4736
    X3.8208 Y25.4732
    X3.8644 Y25.4873
    X3.8771 Y25.5048
    Y25.5253
    X3.864 Y25.5441
    X3.8272 Y25.556
    G1 X3.8336 Y25.5329
    G1 Z-0.3293 F12
    X3.8425 Y25.542 Z-0.3382
    X3.8409 Y25.5453 Z-0.347
    G3 X3.8272 Y25.556 Z-0.3543 I-0.0213 J-0.0131
    X3.7407 Y25.5576
    X3.6978 Y25.5429
    X3.6854 Y25.5253
    Y25.5048
    X3.6969 Y25.4891
    X3.741 Y25.4736
    X3.8208 Y25.4732
    X3.8644 Y25.4873
    X3.8771 Y25.5048
    Y25.5253
    X3.864 Y25.5441
    X3.8272 Y25.556
    G1 X3.8336 Y25.5329
    G1 Z-0.3687 F12
    X3.8425 Y25.542 Z-0.3775
    X3.8409 Y25.5453 Z-0.3864
    G3 X3.8272 Y25.556 Z-0.3937 I-0.0213 J-0.0131
    X3.7407 Y25.5576
    X3.6978 Y25.5429
    X3.6854 Y25.5253
    Y25.5048
    X3.6969 Y25.4891
    X3.741 Y25.4736
    X3.8208 Y25.4732
    X3.8644 Y25.4873
    X3.8771 Y25.5048
    Y25.5253
    X3.864 Y25.5441
    X3.8272 Y25.556
    G1 X3.8336 Y25.5329
    G1 Z-0.4081 F12
    X3.8425 Y25.542 Z-0.4169
    X3.8409 Y25.5453 Z-0.4257
    G3 X3.8272 Y25.556 Z-0.4331 I-0.0213 J-0.0131
    X3.7407 Y25.5576
    X3.6978 Y25.5429
    X3.6854 Y25.5253
    Y25.5048
    X3.6969 Y25.4891
    X3.741 Y25.4736
    X3.8208 Y25.4732
    X3.8644 Y25.4873
    X3.8771 Y25.5048
    Y25.5253
    X3.864 Y25.5441
    X3.8272 Y25.556
    G1 X3.8336 Y25.5329
    G1 Z-0.4474 F12
    X3.8425 Y25.542 Z-0.4563
    X3.8409 Y25.5453 Z-0.4651
    G3 X3.8272 Y25.556 Z-0.4724 I-0.0213 J-0.0131
    X3.7407 Y25.5576
    X3.6978 Y25.5429
    X3.6854 Y25.5253
    Y25.5048
    X3.6969 Y25.4891
    X3.741 Y25.4736
    X3.8208 Y25.4732
    X3.8644 Y25.4873
    X3.8771 Y25.5048
    Y25.5253
    X3.864 Y25.5441
    X3.8272 Y25.556
    G1 X3.8336 Y25.5329
    G1 Z-0.4868 F12
    X3.8425 Y25.542 Z-0.4956
    X3.8409 Y25.5453 Z-0.5045
    G3 X3.8272 Y25.556 Z-0.5118 I-0.0213 J-0.0131
    X3.7407 Y25.5576
    X3.6978 Y25.5429
    X3.6854 Y25.5253
    Y25.5048
    X3.6969 Y25.4891
    X3.741 Y25.4736
    X3.8208 Y25.4732
    X3.8644 Y25.4873
    X3.8771 Y25.5048
    Y25.5253
    X3.864 Y25.5441
    X3.8272 Y25.556
    G1 X3.8336 Y25.5329
    G1 Z-0.5262 F12
    X3.8425 Y25.542 Z-0.535
    X3.8409 Y25.5453 Z-0.5439
    G3 X3.8272 Y25.556 Z-0.5512 I-0.0213 J-0.0131
    X3.7407 Y25.5576
    X3.6978 Y25.5429
    X3.6854 Y25.5253
    Y25.5048
    X3.6969 Y25.4891
    X3.741 Y25.4736
    X3.8208 Y25.4732
    X3.8644 Y25.4873
    X3.8771 Y25.5048
    Y25.5253
    X3.864 Y25.5441
    X3.8272 Y25.556
    G1 X3.8336 Y25.5329
    G1 Z-0.5656 F12
    X3.8425 Y25.542 Z-0.5744
    X3.8409 Y25.5453 Z-0.5832
    G3 X3.8272 Y25.556 Z-0.5906 I-0.0213 J-0.0131
    X3.7407 Y25.5576
    X3.6978 Y25.5429
    X3.6854 Y25.5253
    Y25.5048
    X3.6969 Y25.4891
    X3.741 Y25.4736
    X3.8208 Y25.4732
    X3.8644 Y25.4873
    X3.8771 Y25.5048
    Y25.5253
    X3.864 Y25.5441
    X3.8272 Y25.556
    G1 X3.8336 Y25.5329
    G1 Z-0.6049 F12
    X3.8425 Y25.542 Z-0.6138
    X3.8409 Y25.5453 Z-0.6226
    G3 X3.8272 Y25.556 Z-0.6299 I-0.0213 J-0.0131
    X3.7407 Y25.5576
    X3.6978 Y25.5429
    X3.6854 Y25.5253
    Y25.5048
    X3.6969 Y25.4891
    X3.741 Y25.4736
    X3.8208 Y25.4732
    X3.8644 Y25.4873
    X3.8771 Y25.5048
    Y25.5253
    X3.864 Y25.5441
    X3.8272 Y25.556
    G1 X3.8336 Y25.5329
    G1 Z-0.6443 F12
    X3.8425 Y25.542 Z-0.6531
    X3.8409 Y25.5453 Z-0.662
    G3 X3.8272 Y25.556 Z-0.6693 I-0.0213 J-0.0131
    X3.7407 Y25.5576
    X3.6978 Y25.5429
    X3.6854 Y25.5253
    Y25.5048
    X3.6969 Y25.4891
    X3.741 Y25.4736
    X3.8208 Y25.4732
    X3.8644 Y25.4873
    X3.8771 Y25.5048
    Y25.5253
    X3.864 Y25.5441
    X3.8272 Y25.556
    G3 X3.8216 Y25.5466 I-0.0017 J-0.0053
    G1 X3.834 Y25.5345
    G3 X3.8432 Y25.5403 I0.0039 J0.004
    G1 X3.8419 Y25.5434 Z-0.6775 F12
    X3.8402 Y25.5463 Z-0.6857
    G3 X3.8272 Y25.556 Z-0.6925 I-0.0206 J-0.0141
    X3.7407 Y25.5576
    X3.6978 Y25.5429
    X3.6854 Y25.5253
    Y25.5048
    X3.6969 Y25.4891
    X3.741 Y25.4736
    X3.8208 Y25.4732
    X3.8644 Y25.4873
    X3.8771 Y25.5048
    Y25.5253
    X3.864 Y25.5441
    X3.8272 Y25.556
    G3 X3.81 Y25.5553 Z-0.6852 I-0.0077 J-0.0238
    G1 X3.8067 Y25.5536 Z-0.6763
    X3.8037 Y25.5515 Z-0.6675
    G0 Z0.2
    X3.7202 Y20.7426
    Z0.0787
    G1 Z-0.0144 F12
    X3.7214 Y20.7392 Z-0.0232
    X3.7231 Y20.7359 Z-0.032
    G3 X3.7368 Y20.7254 Z-0.0394 I0.0212 J0.0133
    G1 X3.7434 Y20.7233 F39.37
    X3.8266 Y20.725
    X3.8624 Y20.7366
    X3.877 Y20.7557
    X3.8769 Y20.7767
    X3.8644 Y20.7939
    X3.8208 Y20.8081
    X3.7401 Y20.8076
    X3.6988 Y20.7942
    X3.686 Y20.7769
    X3.6863 Y20.7537
    X3.698 Y20.7375
    X3.7368 Y20.7254
    G3 X3.7527 Y20.7403 I0.0037 J0.0119
    G1 X3.738 Y20.7995
    G2 X3.7478 Y20.805 I0.0054 J0.0018
    G1 X3.7611 Y20.7895
    G3 X3.7702 Y20.7963 I0.0043 J0.0037
    G1 Z-0.0537 F12
    X3.768 Y20.7992 Z-0.0626
    X3.7654 Y20.8018 Z-0.0714
    G3 X3.7491 Y20.8077 Z-0.0787 I-0.0161 J-0.0191
    G1 X3.7401 Y20.8076 F39.37
    X3.6988 Y20.7942
    X3.686 Y20.7769
    X3.6863 Y20.7537
    X3.698 Y20.7375
    X3.7434 Y20.7233
    X3.8266 Y20.725
    X3.8624 Y20.7366
    X3.877 Y20.7557
    X3.8769 Y20.7767
    X3.8644 Y20.7939
    X3.8208 Y20.8081
    X3.7491 Y20.8077
    G3 X3.7463 Y20.7964 J-0.006
    G1 X3.7623 Y20.7877
    G3 X3.7702 Y20.7963 I0.0028 J0.0053
    G1 Z-0.0931 F12
    X3.768 Y20.7992 Z-0.1019
    X3.7654 Y20.8018 Z-0.1108
    G3 X3.7491 Y20.8077 Z-0.1181 I-0.0161 J-0.0191
    X3.6988 Y20.7942
    X3.686 Y20.7769
    X3.6863 Y20.7537
    X3.698 Y20.7375
    X3.7434 Y20.7233
    X3.8266 Y20.725
    X3.8624 Y20.7366
    X3.877 Y20.7557
    X3.8769 Y20.7767
    X3.8644 Y20.7939
    X3.8208 Y20.8081
    X3.7491 Y20.8077
    G3 X3.7484 Y20.7827 I0.0001 J-0.0125
    G1 X3.7539 Y20.7824
    G3 X3.7591 Y20.8065 I0.0007 J0.0125
    X3.7483 Y20.7899 I-0.0036 J-0.0095
    G1 X3.7545 Y20.7836
    G3 X3.7702 Y20.7963 I0.0072 J0.0072
    G1 Z-0.1325 F12
    X3.768 Y20.7992 Z-0.1413
    X3.7654 Y20.8018 Z-0.1502
    G3 X3.7491 Y20.8077 Z-0.1575 I-0.0161 J-0.0191
    X3.6988 Y20.7942
    X3.686 Y20.7769
    X3.6863 Y20.7537
    X3.698 Y20.7375
    X3.7434 Y20.7233
    X3.8266 Y20.725
    X3.8624 Y20.7366
    X3.877 Y20.7557
    X3.8769 Y20.7767
    X3.8644 Y20.7939
    X3.8208 Y20.8081
    X3.7491 Y20.8077
    G1 X3.7623 Y20.7877
    G1 Z-0.1719 F12
    X3.768 Y20.7992 Z-0.1807
    X3.7654 Y20.8018 Z-0.1895
    G3 X3.7491 Y20.8077 Z-0.1969 I-0.0161 J-0.0191
    X3.6988 Y20.7942
    X3.686 Y20.7769
    X3.6863 Y20.7537
    X3.698 Y20.7375
    X3.7434 Y20.7233
    X3.8266 Y20.725
    X3.8624 Y20.7366
    X3.877 Y20.7557
    X3.8769 Y20.7767
    X3.8644 Y20.7939
    X3.8208 Y20.8081
    X3.7491 Y20.8077
    G1 X3.7539 Y20.7824
    G1 X3.7545 Y20.7836
    G1 Z-0.2112 F12
    X3.768 Y20.7992 Z-0.2201
    X3.7654 Y20.8018 Z-0.2289
    G3 X3.7491 Y20.8077 Z-0.2362 I-0.0161 J-0.0191
    X3.6988 Y20.7942
    X3.686 Y20.7769
    X3.6863 Y20.7537
    X3.698 Y20.7375
    X3.7434 Y20.7233
    X3.8266 Y20.725
    X3.8624 Y20.7366
    X3.877 Y20.7557
    X3.8769 Y20.7767
    X3.8644 Y20.7939
    X3.8208 Y20.8081
    X3.7491 Y20.8077
    G1 X3.7623 Y20.7877
    G1 Z-0.2506 F12
    X3.768 Y20.7992 Z-0.2594
    X3.7654 Y20.8018 Z-0.2683
    G3 X3.7491 Y20.8077 Z-0.2756 I-0.0161 J-0.0191
    X3.6988 Y20.7942
    X3.686 Y20.7769
    X3.6863 Y20.7537
    X3.698 Y20.7375
    X3.7434 Y20.7233
    X3.8266 Y20.725
    X3.8624 Y20.7366
    X3.877 Y20.7557
    X3.8769 Y20.7767
    X3.8644 Y20.7939
    X3.8208 Y20.8081
    X3.7491 Y20.8077
    G1 X3.7539 Y20.7824
    G1 X3.7545 Y20.7836
    G1 Z-0.29 F12
    X3.768 Y20.7992 Z-0.2988
    X3.7654 Y20.8018 Z-0.3076
    G3 X3.7491 Y20.8077 Z-0.315 I-0.0161 J-0.0191
    X3.6988 Y20.7942
    X3.686 Y20.7769
    X3.6863 Y20.7537
    X3.698 Y20.7375
    X3.7434 Y20.7233
    X3.8266 Y20.725
    X3.8624 Y20.7366
    X3.877 Y20.7557
    X3.8769 Y20.7767
    X3.8644 Y20.7939
    X3.8208 Y20.8081
    X3.7491 Y20.8077
    G1 X3.7539 Y20.7824
    G1 X3.7545 Y20.7836
    G1 Z-0.3293 F12
    X3.768 Y20.7992 Z-0.3382
    X3.7654 Y20.8018 Z-0.347
    G3 X3.7491 Y20.8077 Z-0.3543 I-0.0161 J-0.0191
    X3.6988 Y20.7942
    X3.686 Y20.7769
    X3.6863 Y20.7537
    X3.698 Y20.7375
    X3.7434 Y20.7233
    X3.8266 Y20.725
    X3.8624 Y20.7366
    X3.877 Y20.7557
    X3.8769 Y20.7767
    X3.8644 Y20.7939
    X3.8208 Y20.8081
    X3.7491 Y20.8077
    G1 X3.7539 Y20.7824
    G1 X3.7545 Y20.7836
    G1 Z-0.3687 F12
    X3.768 Y20.7992 Z-0.3775
    X3.7654 Y20.8018 Z-0.3864
    G3 X3.7491 Y20.8077 Z-0.3937 I-0.0161 J-0.0191
    X3.6988 Y20.7942
    X3.686 Y20.7769
    X3.6863 Y20.7537
    X3.698 Y20.7375
    X3.7434 Y20.7233
    X3.8266 Y20.725
    X3.8624 Y20.7366
    X3.877 Y20.7557
    X3.8769 Y20.7767
    X3.8644 Y20.7939
    X3.8208 Y20.8081
    X3.7491 Y20.8077
    G1 X3.7539 Y20.7824
    G1 X3.7545 Y20.7836
    G1 Z-0.4081 F12
    X3.768 Y20.7992 Z-0.4169
    X3.7654 Y20.8018 Z-0.4257
    G3 X3.7491 Y20.8077 Z-0.4331 I-0.0161 J-0.0191
    X3.6988 Y20.7942
    X3.686 Y20.7769
    X3.6863 Y20.7537
    X3.698 Y20.7375
    X3.7434 Y20.7233
    X3.8266 Y20.725
    X3.8624 Y20.7366
    X3.877 Y20.7557
    X3.8769 Y20.7767
    X3.8644 Y20.7939
    X3.8208 Y20.8081
    X3.7491 Y20.8077
    G1 X3.7539 Y20.7824
    G1 X3.7545 Y20.7836
    G1 Z-0.4474 F12
    X3.768 Y20.7992 Z-0.4563
    X3.7654 Y20.8018 Z-0.4651
    G3 X3.7491 Y20.8077 Z-0.4724 I-0.0161 J-0.0191
    X3.6988 Y20.7942
    X3.686 Y20.7769
    X3.6863 Y20.7537
    X3.698 Y20.7375
    X3.7434 Y20.7233
    X3.8266 Y20.725
    X3.8624 Y20.7366
    X3.877 Y20.7557
    X3.8769 Y20.7767
    X3.8644 Y20.7939
    X3.8208 Y20.8081
    X3.7491 Y20.8077
    G1 X3.7539 Y20.7824
    G1 X3.7545 Y20.7836
    G1 Z-0.4868 F12
    X3.768 Y20.7992 Z-0.4956
    X3.7654 Y20.8018 Z-0.5045
    G3 X3.7491 Y20.8077 Z-0.5118 I-0.0161 J-0.0191
    X3.6988 Y20.7942
    X3.686 Y20.7769
    X3.6863 Y20.7537
    X3.698 Y20.7375
    X3.7434 Y20.7233
    X3.8266 Y20.725
    X3.8624 Y20.7366
    X3.877 Y20.7557
    X3.8769 Y20.7767
    X3.8644 Y20.7939
    X3.8208 Y20.8081
    X3.7491 Y20.8077
    G1 X3.7539 Y20.7824
    G1 X3.7545 Y20.7836
    G1 Z-0.5262 F12
    X3.768 Y20.7992 Z-0.535
    X3.7654 Y20.8018 Z-0.5439
    G3 X3.7491 Y20.8077 Z-0.5512 I-0.0161 J-0.0191
    X3.6988 Y20.7942
    X3.686 Y20.7769
    X3.6863 Y20.7537
    X3.698 Y20.7375
    X3.7434 Y20.7233
    X3.8266 Y20.725
    X3.8624 Y20.7366
    X3.877 Y20.7557
    X3.8769 Y20.7767
    X3.8644 Y20.7939
    X3.8208 Y20.8081
    X3.7491 Y20.8077
    G1 X3.7539 Y20.7824
    G1 X3.7545 Y20.7836
    G1 Z-0.5656 F12
    X3.768 Y20.7992 Z-0.5744
    X3.7654 Y20.8018 Z-0.5832
    G3 X3.7491 Y20.8077 Z-0.5906 I-0.0161 J-0.0191
    X3.6988 Y20.7942
    X3.686 Y20.7769
    X3.6863 Y20.7537
    X3.698 Y20.7375
    X3.7434 Y20.7233
    X3.8266 Y20.725
    X3.8624 Y20.7366
    X3.877 Y20.7557
    X3.8769 Y20.7767
    X3.8644 Y20.7939
    X3.8208 Y20.8081
    X3.7491 Y20.8077
    G1 X3.7539 Y20.7824
    G1 X3.7545 Y20.7836
    G1 Z-0.6049 F12
    X3.768 Y20.7992 Z-0.6138
    X3.7654 Y20.8018 Z-0.6226
    G3 X3.7491 Y20.8077 Z-0.6299 I-0.0161 J-0.0191
    X3.6988 Y20.7942
    X3.686 Y20.7769
    X3.6863 Y20.7537
    X3.698 Y20.7375
    X3.7434 Y20.7233
    X3.8266 Y20.725
    X3.8624 Y20.7366
    X3.877 Y20.7557
    X3.8769 Y20.7767
    X3.8644 Y20.7939
    X3.8208 Y20.8081
    X3.7491 Y20.8077
    G1 X3.7539 Y20.7824
    G1 X3.7545 Y20.7836
    G1 Z-0.6443 F12
    X3.768 Y20.7992 Z-0.6531
    X3.7654 Y20.8018 Z-0.662
    G3 X3.7491 Y20.8077 Z-0.6693 I-0.0161 J-0.0191
    X3.6988 Y20.7942
    X3.686 Y20.7769
    X3.6863 Y20.7537
    X3.698 Y20.7375
    X3.7434 Y20.7233
    X3.8266 Y20.725
    X3.8624 Y20.7366
    X3.877 Y20.7557
    X3.8769 Y20.7767
    X3.8644 Y20.7939
    X3.8208 Y20.8081
    X3.7491 Y20.8077
    G3 X3.7485 Y20.7827 I0.0001 J-0.0125
    G1 X3.7536 Y20.7824
    G3 X3.7585 Y20.8067 I0.0007 J0.0125
    X3.7482 Y20.7895 I-0.0034 J-0.0096
    G1 X3.7541 Y20.784
    G3 X3.7692 Y20.7978 I0.0069 J0.0076
    G1 X3.7669 Y20.8003 Z-0.6775 F12
    X3.7644 Y20.8025 Z-0.6857
    G3 X3.7491 Y20.8077 Z-0.6925 I-0.0151 J-0.0199
    X3.6988 Y20.7942
    X3.686 Y20.7769
    X3.6863 Y20.7537
    X3.698 Y20.7375
    X3.7434 Y20.7233
    X3.8266 Y20.725
    X3.8624 Y20.7366
    X3.877 Y20.7557
    X3.8769 Y20.7767
    X3.8644 Y20.7939
    X3.8208 Y20.8081
    X3.7491 Y20.8077
    G3 X3.7329 Y20.8016 Z-0.6852 I0.0001 J-0.025
    G1 X3.7303 Y20.799 Z-0.6763
    X3.7281 Y20.7961 Z-0.6675
    G0 Z0.45
    (Drill1)
    X2.125 Y6
    Z0.45
    Z0.2
    G1 Z-0.7125 F6
    G0 Z0.2
    Y4.5
    G1 Z-0.7125 F6
    G0 Z0.2
    X15.875
    G1 Z-0.7125 F6
    G0 Z0.2
    Y6
    G1 Z-0.7125 F6
    G0 Z0.2
    Y28
    G1 Z-0.7125 F6
    G0 Z0.2
    Y26.3125
    G1 Z-0.7125 F6
    G0 Z0.2
    X2.125
    G1 Z-0.7125 F6
    G0 Z0.2
    Y28
    G1 Z-0.7125 F6
    G0 Z0.2
    Z0.45
    G28 G91 Z0
    G90
    G28 G91 X0 Y0
    G90
    M30
  9. sharmstr
    Okay. You mentioned using the strooom processor, so I thought that was what you are using which does output G53 (from what I recall). The gcode you posted is outputting G28 which you probably havent set. There's also tool changes in there which wont work.
    Forget all that and use this processor and let me know how it goes: swarfer/GRBL-Post-Processor
    Pay attention to the post properties and where the spindle will move to after job completion ("use msc", "machinehomex", etc...)
    Alex Chambers likes this.
  10. Eric Arnold
    You're awesome. Thanks for your help Shawn.
  11. sharmstr
    Sorry it took so long to get to that point. :) Happy cutting!
  12. David the swarfer
    for safety.
    Gcode runs machines using hundreds of horsepower down to Workbees and smaller. Over the years methods of safe operation have been developed because 10's of horsepower machines do not take hostages, they kill! We are operating small machines but a 1hp router can still remove a finger in an instant.
    This safety dictates that Z home is as high as possible, then we know that a move to Z home or close to it is high up away from the work and 'safe' to move in X and Y. Nearly ALL industrial machines adhere rigidly to this sort of safety guideline and conventions for axis directions and home positions.
    Yes you can do crazy setups where high Z is no more safe than low Z, but that is rare. I have done a job where I had 6mm between Z0 and the top of the work so I had to be very careful about Z clearance and so on.
    So, what is a safe move?
    When your code is just starting it has to move to the initial cut starting point and to do so safely we need the Z to be as high as possible so that the tool misses all the clamps/vices/ bolts/excess material etc that might be in the way. So most Gcode processors do a safety move of
    G53 G0 Z0 (or -10 to clear the limit switch) (the Stroom processor does this, the autodesk one uses G28 which can amount to the same thing but sometimes does not).
    This tells the machine to move to Z's home position, as high as possible, before doing something like
    G0 X0 Y0
    which moves to the part zero, but that initial move may be to somewhere on the part where it will start cutting which is more efficient.
    So long as Z is high enough to clear everything this is a safe move.
    I often do a cut and then jog the cutter away so I can measure or check something, then do another cut. When I start that second job I definitely want Z to go high so it clears clamps etc before it moves in for the cut. The half second it takes to go up and come back down again is just not important. My machine rapids at 3500mm/min.
  13. Eric Arnold
    Thanks David for the extra info today. Much appreciated.
