Error on generating GCODE file from SketchUp/SketchUCam
Discussion in 'CAD' started by KEN MACDONALD, Dec 20, 2020.
  1. KEN MACDONALD
    Hi I am trying to generate a GCODE from SketchUCam on the attached file and I'm getting this error.
    GcodeUtil.generate_gcode FAILED; Error:undefined method `edges' for #<Sketchup::OptionsProvider:0x007fca42a15e00>
    I am using SketchUp Make 2017 17.3.116 and
    SketchUcam Version 1.4d
    Jan 2016
    Any ideas anyone?
    The problem is in the right hand side (some internal sketchup drawing weirdness), I am not getting an error but I am getting some odd Gcode.
    Solved by deleting the cutlines, select and 'phlatten' the slot, then delete and redraw the bottom straight line,then replace the cutlines.
    Yes, I inserted V-tabs as that is my default. Speeds up cutting a lot, but you must make them longer and deeper than normal tabs.
  3. KEN MACDONALD
    Thank you I'll try that.
  4. KEN MACDONALD
    Hi I tried selecting and phlattening the slot, but it won't then let me select it for cutting
  5. David the swarfer
    odd, I am not having a problem at all. I have attached my version.
  6. KEN MACDONALD
    Thank you, all ok now using your files. Must be a bug somewhere in the MAC version of Sketchup
