error loading saved workspace.
Discussion in 'OpenBuilds Bug Report' started by dawhite, Feb 26, 2023.
  1. dawhite
    dawhite New
    Hi, latest cam is unable to read a saved workspace. I get the error. I did create the gcode and save that, and then also saved the workspace. I can load other workspaces i've used in the past.
  2. dawhite
    dawhite New
    Further to the above, if I create a circle in autocad, break it, convert to pline, export to dxf, import dxf into cam.openbuilds, I am able to generate gcode and it's all cool, BUT when I save the workspace.obc file, I get the errors I mentioned above, when I try to open it the next time. Also, the loading documents frame tries to load forever, even if I create a new workspace.
    if i create the circle direct in cam, then it works as expected.
