Error from Blackbox
Discussion in 'OpenBuilds Forum Help' started by ricklach, Aug 26, 2019.
  1. ricklach
    ricklach New
    Tried to connect to my blackbox for the first time and got this error: ERROR!: No supported firmware detected - you need a controller with Grbl 1.1x on it, or there is a problem with your controller. Closing port COM1
    How do I fix this error?
  2. sharmstr
    sharmstr Master
    A few things to check
    1 - Are you sure COM1 is the correct port?
    2 - Did you install the FTDI drivers?: Virtual COM Port Drivers
    3 - If all else fails, you can try reflashing using the flashing tool located in the Wizards menu.
  3. ricklach
    ricklach New
    Thanks, wrong port, that fixed it.
  4. Bobby nath
    Wednesday
    I did all that an not able to flash I think the board is dead. the TOOL light is on constant. I think the board got a chip sucked in. an it died.
    Its flashed by default, no need to flash.
    Any other history? Did it work for a while, then die? Or why are you attempting to reflash?
  6. Bobby nath
    Wednesday
    Thank you for your interest an reply, it worked for abit then died out fully, I disassembled it an found a metal chip inside. It won't connect, no lights on the board either. (USB) I'm guessing it shorted something out.
